Author Topic: tiny QCW build  (Read 375 times)
Offline MarcusFunt
tiny QCW build
« on: October 11, 2022, 02:16:33 PM »
Hi. I'm building a tiny staccato ramped QCWDRSSTC. I calculated everything in javaTC and exported it as text:
J A V A T C version 13.6 - CONSOLIDATED OUTPUT
11.10.2022 14.09.07
Units = Centimeters
Ambient Temp = 20ºC
Secondary Coil Inputs:
Current Profile = G.PROFILE_LINEAR
3.75 = Radius 1
3.75 = Radius 2
0 = Height 1
8 = Height 2
760 = Turns
0.01 (cm)= Wire Diameter
Primary Coil Inputs:
Round Primary Conductor
5 = Radius 1
5 = Radius 2
0 = Height 1
1.39 = Height 2
4.635 = Turns
0.1(16A Rated. Intalation cable) = Wire Diameter
0 = Ribbon Width
0 = Ribbon Thickness
0.05 = Primary Cap (uF)
0 = Total Lead Length
0 = Lead Diameter
Secondary Coil Outputs:
363.13 [kHz] = Secondary Resonant Frequency
90 [deg °] = Angle of Secondary
8 [cm] = Length of Winding
95 [cm] = Turns Per Unit
0.00526 [mm] = Space Between Turns (edge to edge)
179.07 [m] = Length of Wire
1.07 [:1] = H/D Aspect Ratio
389.88 [Ohms] = DC Resistance
65908 [Ohms] = Reactance at Resonance
0.013 [ kg] = Weight of Wire
28.886 [mH] = Les-Effective Series Inductance
29.057 [mH] = Lee-Equivalent Energy Inductance
28.127 [mH] = Ldc-Low Frequency Inductance
6.65 [pF] = Ces-Effective Shunt Capacitance
6.611 [pF] = Cee-Equivalent Energy Capacitance
12.131 [pF] = Cdc-Low Frequency Capacitance
0.1195 [mm] = Skin Depth
4.61 [pF] = Topload Effective Capacitance
756.6971 [Ohms] = Effective AC Resistance
87 [Q] = Quality Factor
Primary Coil Outputs:
363.14 [kHz] = Primary Resonant Frequency
0 [%] = Percent Detuned
90 [deg °] = Angle of Primary
145.61 [cm] = Length of Wire
31.96 [mOhms] = DC Resistance
0.2 [cm] = Average spacing between turns (edge to edge)
1.195 [ cm] = Proximity between coils
0 [cm] = Recommended minimum proximity between coils
3.858 [µH] = Ldc-Low Frequency Inductance
0.05001 [µF] = Cap size needed with Primary L (reference)
0 [µH] = Lead Length Inductance
124.27 [µH] = Lm-Mutual Inductance
0.377 [k] = Coupling Coefficient
0.126 [k] = Recommended Coupling Coefficient
2.65 [half cycles] = Number of half cycles for energy transfer at K
3.32 [µs] = Time for total energy transfer
Top Load Inputs:
Toroid #1: minor=2, major=14.3, height=11, topload
Am i missing something obvious?
Offline Weston
Re: tiny QCW build
« Reply #1 on: October 11, 2022, 10:46:59 PM »
Not really sure what you are asking for feedback on, but my main comment is that 0.1mm diameter wire is really small and going to be difficult to wind. Thats 38AWG wire?. 36AWG wire is about the finest wire I would want to deal with for hand winding, and even that seems pretty iffy.
Your secondary is almost has a 1:1 aspect ratio, and everything is pretty close together. I guess you cant model it directly in JavaTC, but have you considered going something like LoneOceans curved primary https://www.loneoceans.com/labs/qcw2/ it would give better field grading and a lower chance of flash over.
Offline dru
Re: tiny QCW build
« Reply #2 on: October 14, 2022, 12:35:48 PM »
I would suggest detuning the primary to around 300khz, qcw discharges lower the resonant frequency a lot. I’d also go for a higher coupling if you can, between .45-.6. Everything else looks good.
Re: tiny QCW build
post Re: improving zvs driver
Today at 03:42:13 AM
Today at 01:01:56 AM
x-rayLamp
Today at 12:04:20 AM
post Re: ud 2.7c poped caps
January 29, 2023, 07:15:43 PM
January 29, 2023, 06:13:45 PM
Mike
January 29, 2023, 05:53:11 PM
post Please, help me (financially) build a DRSSTC
[Crowdfunding]
Pavol
January 29, 2023, 03:02:55 PM
post ud 2.7c poped caps
January 29, 2023, 02:04:59 PM
post Showa SP-103 Standalone Xray Head Teardown
January 29, 2023, 01:04:56 PM
January 29, 2023, 04:24:43 AM
January 29, 2023, 12:54:13 AM
post Re: Welding a MOT
Alberto
January 28, 2023, 11:47:22 PM
January 28, 2023, 11:34:58 PM
January 28, 2023, 10:14:54 PM
Alberto
January 28, 2023, 04:53:39 PM
January 28, 2023, 04:59:05 AM
post Re: First test of the SSTC
January 28, 2023, 04:44:51 AM
January 28, 2023, 04:35:22 AM
LoOdaK
January 28, 2023, 03:29:09 AM
January 27, 2023, 11:15:03 PM
January 27, 2023, 08:43:51 PM
Alberto
January 27, 2023, 08:17:06 PM
January 27, 2023, 08:07:12 PM
Alberto
January 27, 2023, 01:30:02 PM
x-rayLamp
January 27, 2023, 01:01:01 PM
post Re: Phase lead problems on ud2.7c
vince1
January 27, 2023, 12:49:46 PM
January 27, 2023, 06:07:49 AM
January 27, 2023, 05:22:46 AM
January 27, 2023, 05:10:14 AM
January 27, 2023, 05:05:40 AM
January 27, 2023, 04:44:24 AM
post Phase lead problems on ud2.7c
vince1
January 27, 2023, 01:26:20 AM
x-rayLamp
January 26, 2023, 08:13:24 PM
LoOdaK
January 26, 2023, 12:02:14 PM
Alberto
January 26, 2023, 12:01:48 PM
post Re: Ramped SSTC - Power Supply Issues
January 26, 2023, 05:35:32 AM
January 26, 2023, 04:55:24 AM
January 26, 2023, 04:14:49 AM
January 26, 2023, 03:57:19 AM
January 26, 2023, 03:42:01 AM
January 25, 2023, 10:21:43 PM
post Welding a MOT
Alberto
January 25, 2023, 09:37:27 PM
January 25, 2023, 09:36:22 PM
January 25, 2023, 08:35:49 PM
post improving zvs driver
x-rayLamp
January 25, 2023, 04:32:37 PM
nzoomed
January 25, 2023, 08:27:01 AM
January 25, 2023, 04:08:42 AM
January 24, 2023, 06:37:39 PM
January 24, 2023, 05:21:49 AM
post Re: 8 kW Induction Cooktop Teardown and Reverse engineering
January 24, 2023, 04:41:01 AM
post Ramped SSTC - Power Supply Question + General Improvements
January 23, 2023, 10:48:17 PM
January 23, 2023, 10:23:54 PM
post Re: 160mm DRSSTC project
Mathieu thm
January 23, 2023, 07:21:10 PM
January 23, 2023, 06:21:07 PM
January 23, 2023, 01:23:41 PM
January 22, 2023, 07:17:25 PM
LoOdaK
January 22, 2023, 12:53:01 PM
January 22, 2023, 06:21:40 AM
post Re: Creating arcs off my variac lol, popped my igbts
January 22, 2023, 04:45:46 AM
LoOdaK
January 21, 2023, 11:47:55 PM
post [WTS] (free except shipping) 115V 3600RPM sync. motor
January 21, 2023, 08:50:05 PM
January 21, 2023, 08:19:31 PM
LoOdaK
January 21, 2023, 03:01:21 PM
January 21, 2023, 05:44:15 AM
Avenger
January 21, 2023, 04:44:09 AM
LoOdaK
January 20, 2023, 10:52:40 PM
post Re: QCW questions
January 20, 2023, 06:20:32 AM
January 20, 2023, 06:03:20 AM
January 20, 2023, 04:49:50 AM
January 20, 2023, 04:19:23 AM
January 20, 2023, 03:12:39 AM
January 19, 2023, 11:39:37 PM
LoOdaK
January 19, 2023, 10:54:51 PM
Mathieu thm
January 19, 2023, 09:19:19 PM
January 19, 2023, 08:33:18 PM
January 19, 2023, 03:48:02 PM
LoOdaK
January 19, 2023, 11:09:39 AM
January 19, 2023, 04:30:49 AM
January 19, 2023, 03:10:56 AM
January 18, 2023, 08:23:57 PM
January 18, 2023, 08:13:28 PM
January 18, 2023, 05:56:11 PM
post Creating arcs off my variac lol, popped my igbts
breezetix
January 18, 2023, 08:24:15 AM
January 18, 2023, 06:40:30 AM
January 18, 2023, 06:29:45 AM
January 18, 2023, 04:56:33 AM
January 18, 2023, 04:39:55 AM
January 18, 2023, 04:27:49 AM
Mathieu thm
January 17, 2023, 11:16:00 PM
January 17, 2023, 09:37:16 PM
January 17, 2023, 05:38:24 PM
post Re: I need a review of my circuit. Polarities specifically
January 17, 2023, 03:35:47 PM
January 17, 2023, 12:43:26 PM
January 17, 2023, 07:51:05 AM
January 17, 2023, 07:02:37 AM
January 17, 2023, 05:41:59 AM
January 17, 2023, 05:41:38 AM
January 17, 2023, 05:06:24 AM
January 17, 2023, 05:04:21 AM
January 17, 2023, 04:41:26 AM
