Author Topic: Air Gap: why and how much?  (Read 2185 times)
Offline HighVoltageRulezz
« on: August 13, 2020, 06:23:24 PM »
Hi-
I laready researched this topic but it did not help much..
Could somebody explain in Laymans Terms how to specify the airgap?
My setup is planned the following way:
CCPS Topology according to https://www.stevehv.4hv.org/ccps1.htm
Big Ferrite Core. My driver has can be controlled in frequency and duty cyle I plan for a frequency of perhaps 30-40 kHz. Output is planned to be around 15kV and currents of perhaps 200mA.
So how big must my air gap be? What if I make it bigger / smaller?
Thanks
Roman
Re: Air Gap: why and how much?
« Reply #1 on: August 13, 2020, 08:26:56 PM »
If the big ferrite parts are for a transformer, not a flyback converter,
then I don't see any benefit from a deliberate air gap in the core.
Other readers may know better.  Perhaps to lower the inductance in a resonant design?
We can talk about air gaps in flyback cores, after you explain the difference between transformer operation and flyback converter operation.
« Reply #2 on: August 13, 2020, 09:45:58 PM »
As far as i know you use the air-gap to get the required inductance that I worked out for the drive frequency.
The air gap also helps to stop saturation effects taking out the drive silicon. With no air gap when you saturate, the core disappears and your transformer is equivalent to having the same inductance as if you have removed the core altogether.
Normally you look up the magnetic path length and core area and design around these and the ferrite properties. You then calculate the required turns and I usually go 10 to 25 % over so I can shim the core gap to get the required inductance. Suitable shim material = kapton tape which is approx 60 - 68 microns per layer.
For final production transformers in the E core type I have the central core of one half ground back to the required gap. Doing this allows the windings to shield the magnetic fringing around the gap that may affect other magnetic devices nearby or induce currents in circuit traces
« Reply #3 on: August 13, 2020, 10:59:27 PM »
The air gap increases the reluctance of the magnetic circuit that contains the primary and secondary windings.
https://en.wikipedia.org/wiki/Magnetic_reluctance
Some increase in reluctance can be beneficial as the amount of flux in the circuit will be reduced given a certain of ampere-turns of your winding.  The gap which is useful for switching power supplies like flyback transformers that transfer the energy stored in the gap.  It also increases the amount of current tolerated before the transformer saturates.
For other kinds of switching supplies that use direct coupling of the primary and secondary windings, an excessive large gap can create too much leakage inductance that reduces the current and can create large voltage spikes on the switches (MOSFETs or IGBTs).
You can use a piece of tape to introduce a small gap in a U/I core transformer.  I have example formulas on calculating the gap size in this document:
https://drive.google.com/file/d/0BwFicJLV0O4jYlQ0ejJ6NE9XVE0/view
post Re: Big Coil Build Log
Today at 05:47:34 AM
Today at 04:45:07 AM
Today at 04:18:27 AM
post Push Pull VTTC
janno288
Today at 01:10:08 AM
March 27, 2024, 10:54:52 PM
March 27, 2024, 11:53:42 AM
post Re: OCD Triggering Early + Low Output
March 27, 2024, 05:14:36 AM
March 27, 2024, 04:47:48 AM
post Re: DRSSTC Questions
March 27, 2024, 04:41:59 AM
March 27, 2024, 12:04:34 AM
post Re: Super flat QCW simulation (does this look reasonable?)
toooldforthis
March 26, 2024, 11:08:14 PM
March 26, 2024, 11:07:20 PM
March 26, 2024, 10:46:29 PM
post OCD Triggering Early + Low Output
March 26, 2024, 09:03:43 PM
March 26, 2024, 08:46:59 PM
March 26, 2024, 05:02:18 PM
March 26, 2024, 03:16:03 PM
March 26, 2024, 01:41:49 PM
March 26, 2024, 04:48:22 AM
post Re: Re-chargeable 1.5 volt lithium ion AAA batteries
March 26, 2024, 04:16:37 AM
March 26, 2024, 04:16:24 AM
post Re: Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 26, 2024, 04:13:02 AM
March 26, 2024, 04:00:43 AM
March 26, 2024, 03:19:18 AM
March 26, 2024, 01:50:42 AM
March 25, 2024, 08:05:02 PM
March 25, 2024, 07:41:29 PM
March 25, 2024, 06:45:46 PM
March 25, 2024, 05:44:25 PM
March 25, 2024, 04:47:17 PM
March 25, 2024, 04:27:22 PM
post Re-chargeable 1.5 volt lithium ion AAA batteries
March 25, 2024, 03:57:34 PM
March 25, 2024, 02:06:41 PM
post Re: Odd MOSFET Driver Behavior
KrisPringle
March 25, 2024, 04:43:25 AM
March 25, 2024, 02:39:40 AM
KrisPringle
March 25, 2024, 12:47:09 AM
March 24, 2024, 07:36:32 PM
March 24, 2024, 07:27:24 PM
March 24, 2024, 04:25:23 AM
March 23, 2024, 10:47:35 PM
March 23, 2024, 09:30:21 PM
March 23, 2024, 04:34:31 PM
March 23, 2024, 03:04:25 PM
March 23, 2024, 01:38:34 PM
March 23, 2024, 04:20:03 AM
March 23, 2024, 12:54:30 AM
March 23, 2024, 12:05:57 AM
post capacitor and diodes. Voltage values for a CW
March 22, 2024, 11:45:03 PM
March 22, 2024, 11:30:09 PM
post Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 22, 2024, 10:20:35 PM
post Re: Where's all this voltage coming from?
March 22, 2024, 09:21:13 PM
March 22, 2024, 03:37:11 PM
post What actually kills MOSFETs?
March 22, 2024, 05:09:20 AM
March 22, 2024, 03:57:54 AM
March 22, 2024, 02:59:25 AM
March 21, 2024, 06:31:42 PM
post Re: 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 21, 2024, 03:08:01 PM
post Re: [WTS] IGBT, Ferrite, Capacitors, Tools, PSU, Industrial components and parts
March 21, 2024, 01:37:32 PM
March 21, 2024, 11:42:07 AM
post Re: Phase Lead Questions
March 21, 2024, 04:09:14 AM
March 21, 2024, 02:15:31 AM
post My Homemade Structural Analysis X-Ray Machine
Luca c.
March 21, 2024, 01:35:40 AM
March 20, 2024, 10:40:00 PM
March 20, 2024, 08:03:41 PM
March 20, 2024, 07:51:57 PM
March 20, 2024, 10:39:47 AM
March 20, 2024, 04:09:59 AM
March 20, 2024, 01:13:23 AM
Keybored
March 20, 2024, 12:45:16 AM
March 20, 2024, 12:30:30 AM
March 19, 2024, 11:12:24 PM
Late
March 19, 2024, 09:47:49 PM
Late
March 19, 2024, 09:44:19 PM
post Phase Lead Questions
March 19, 2024, 06:52:09 PM
March 19, 2024, 05:02:44 PM
March 19, 2024, 05:01:41 PM
March 19, 2024, 04:31:02 PM
March 19, 2024, 03:59:54 PM
March 19, 2024, 06:41:39 AM
March 19, 2024, 04:05:49 AM
March 18, 2024, 09:08:35 PM
post Re: Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 09:07:35 PM
March 18, 2024, 08:57:06 PM
March 18, 2024, 03:51:33 PM
Late
March 18, 2024, 02:59:46 PM
Late
March 18, 2024, 02:33:25 PM
post Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 11:02:12 AM
March 18, 2024, 02:36:11 AM
post Re: Best forum for vacuum tube amplifiers?
March 17, 2024, 07:42:55 PM
March 17, 2024, 04:15:14 PM
March 17, 2024, 05:05:04 AM
March 17, 2024, 04:50:51 AM
March 17, 2024, 04:45:17 AM
post 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 17, 2024, 04:17:51 AM
post Where's all this voltage coming from?
Terry
March 17, 2024, 01:29:32 AM
March 17, 2024, 12:33:06 AM
Keybored
March 16, 2024, 08:46:20 PM
post Re: Bleeder resistor for MMC
March 16, 2024, 08:39:24 PM
March 16, 2024, 08:21:44 PM
post Best forum for vacuum tube amplifiers?
March 16, 2024, 08:20:13 PM
