Author Topic: Setting OCD without blowing up transistors  (Read 369 times)
« on: April 16, 2018, 12:36:29 AM »
My tesla coil has a full bridge of FGH60N60SMD IGBTs.  I am trying to get a handle on how to set the overcurrent without blowing up the transistors.
From what I have been told, these can handle about 300 A peak current.  My current sense transformer is 625:1 consisting of two 25:1 cascaded ferrite transformers.  The burden resistor I am using is 4.7 ohms.
For 300 A, assuming a 625:1 ratio, the current through the transformer on the secondary is 0.48 A.  This means I should set the voltage on the comparator to 2.25 V, correct?  Is there any correction for the forward drop of the Schottky diodes?   I am using a 625:1 transformer because I hope to add a second set of IGBTs to make the peak current 600 A.
Re: Setting OCD without blowing up transistors
« Reply #1 on: April 16, 2018, 02:00:36 AM »
I think Steve ward wrote in the drsstc log book about the voltage drop.
What I've been doing to set the ocd is set a voltage (let's say I want 300a ocd) at the comparator for a 200a limit. I then use a seperate ct connected to an oscilloscope and run the coil, slowly adjusting the voltage between runs until a 300a limit is achieved.
I've only done this method twice, and I'm also confident there's a better way of doing it. But it works for me.
« Reply #2 on: April 16, 2018, 10:18:16 AM »
You can ignore the forward drop of the diodes, they do not affect the current passed through the burden resistor (and thus voltage across it). The critical things are the CT ratio and the burden resistor value, and it sounds like you have the right idea about setting the voltage based on this.
I have also in the past set OCD with a measure & adjust strategy using a second CT, but either method should work. If you're aiming for a particular current then be a little conservative with the OCD setting, as the current can still rise for up to another half cycle after a trip. However the 300A goal you're after isn't likely critical, so it's reasonable to just set the correct voltage for a 300A trip and leave it be (unless the coil has a particularly low impedance primary tank, which I assume is not the case here).
post Re: My First DRSSTC
Today at 11:07:22 AM
sjsimmo
Today at 08:08:58 AM
sjsimmo
Today at 01:24:15 AM
January 18, 2019, 07:32:38 PM
January 18, 2019, 04:25:14 PM
CristianM
January 18, 2019, 03:48:06 PM
the_anomaly
January 17, 2019, 02:01:36 AM
January 16, 2019, 04:26:38 AM
January 15, 2019, 09:48:48 PM
post Re: My X-Ray Machine
neukyhm
January 15, 2019, 10:51:46 AM
January 14, 2019, 05:08:38 PM
the_anomaly
January 14, 2019, 01:15:53 PM
January 14, 2019, 12:22:07 PM
January 11, 2019, 05:10:39 AM
January 10, 2019, 10:59:25 PM
post Re: 迎词、来
January 10, 2019, 06:56:59 PM
January 10, 2019, 05:33:48 PM
black.yang
January 10, 2019, 02:11:58 AM
January 09, 2019, 09:14:59 PM
Physikfan
January 08, 2019, 08:44:16 PM
Felix Bieri
January 08, 2019, 05:33:55 PM
[Radio frequency]
January 08, 2019, 08:25:08 AM
January 08, 2019, 08:25:02 AM
January 08, 2019, 02:01:50 AM
post Re: (DR)SSTC II
January 07, 2019, 10:23:38 PM
January 07, 2019, 08:53:32 PM
January 07, 2019, 08:17:44 PM
January 07, 2019, 07:37:53 PM
January 07, 2019, 01:30:36 PM
January 07, 2019, 12:43:26 PM
January 07, 2019, 08:09:49 AM
NEYi
January 07, 2019, 07:43:50 AM
January 07, 2019, 06:48:06 AM
January 07, 2019, 06:39:56 AM
January 06, 2019, 09:23:19 PM
January 06, 2019, 07:11:25 PM
January 06, 2019, 07:02:14 PM
January 06, 2019, 12:43:46 PM
January 06, 2019, 11:55:09 AM
TDAF
January 06, 2019, 09:48:06 AM
TDAF
January 06, 2019, 09:45:17 AM
black.yang
January 06, 2019, 08:34:46 AM
post 迎词、来
black.yang
January 06, 2019, 08:20:21 AM
January 06, 2019, 12:34:15 AM
January 05, 2019, 05:27:23 PM
January 05, 2019, 03:46:29 PM
January 05, 2019, 09:51:10 AM
January 04, 2019, 11:02:25 PM
January 03, 2019, 08:38:15 PM
January 03, 2019, 08:15:48 PM
