Author Topic: OneTesla SD Interrupter extending On-Time?  (Read 155 times)
Offline Phoenix
« on: April 14, 2018, 07:43:41 AM »
Hello everyone,
i have just bought and built the OneTesla Midi Interrupter for my homemade 160mm DRSSTC and it works very good but i have a question: The Interrupter only goes up to about 80uS of Ontime in the Midi mode. Currently, i am running my coil only on 350V DC. The issue now is that i will not reach the full primary current of 1000A with such a low Ontime and therefore my sparks are not as long as with my homemade Interrupter and 300uS On-Time.
Is there a way to change that on the SD Interrupter? Do i have to change the code for that and what do i need to change? I already have a large MMC (375nF) but the primary current does not ramp up fast enough in 80uS. Should I convert my coil in the future to run on 3 Phases rectified (565V)? But i do not own a 3 Phase Variac and i am a little bit umcomfortable if I can not ramp up the voltage slowly with a Variac.
Greetings,
« Last Edit: April 14, 2018, 07:45:51 AM by Phoenix »
Re: OneTesla SD Interrupter extending On-Time?
« Reply #1 on: April 15, 2018, 12:24:02 PM »
It's very simple, download their SD interrupter firmware http://onetesla.com/media/SDinterrupter.zip, edit LOOKUP_TABLE_SCALE constant in constants.h file and upload the code using arduino IDE
Code: [Select]
//on-times in microseconds, don't forget to multiply by LOOKUP_TABLE_SCALE!
#define ON_TIME_ARRAY_LENGTH 26
static byte on_times[] =
{33, 33, 33, 33, 27, 23, 20, 20, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 8, 8, 8, 8, 8, 8, 8};
LOOKUP_TABLE_SCALE will multiply on-times for different notes/bps, for example if LOOKUP_TABLE_SCALE is set to 3, max. on-time will be 99 us
Offline Phoenix
« Reply #2 on: April 15, 2018, 05:15:21 PM »
Thank you very much for your response it helps a lot  :)
I have never done anything with an Arduino so i have a question: The Interrupter has a connector called AVR-ISP. Can i hook up the Interrupter to the Arduino as shown in this image? https://www.arduino.cc/en/uploads/Tutorial/Arduino_ISP_wires.jpg
Greetings,
« Last Edit: April 15, 2018, 06:12:22 PM by Phoenix »
« Reply #3 on: April 23, 2018, 06:37:53 PM »
Yes, that should do the job
Sorry for late answer
post Re: Trying to build my first tesla coil!
Today at 02:39:07 AM
April 26, 2018, 10:30:35 PM
LordAlvin
April 26, 2018, 10:23:41 PM
April 26, 2018, 06:29:33 PM
April 26, 2018, 03:22:38 PM
April 26, 2018, 03:14:58 PM
April 26, 2018, 03:03:33 PM
April 26, 2018, 10:22:19 AM
April 26, 2018, 10:20:39 AM
post Trying to build my first tesla coil!
LordAlvin
April 26, 2018, 02:03:35 AM
April 26, 2018, 12:30:04 AM
April 26, 2018, 12:27:02 AM
April 25, 2018, 11:04:04 PM
April 25, 2018, 11:01:12 PM
April 25, 2018, 10:58:42 PM
April 25, 2018, 08:41:51 PM
[Light, lasers and optics]
April 25, 2018, 08:28:19 PM
April 25, 2018, 08:24:52 PM
April 25, 2018, 08:20:00 PM
TDAF
April 25, 2018, 07:01:06 PM
TDAF
April 25, 2018, 06:55:20 PM
April 25, 2018, 06:37:56 PM
TDAF
April 25, 2018, 06:15:05 PM
April 25, 2018, 05:54:03 PM
TDAF
April 25, 2018, 05:39:59 PM
April 25, 2018, 05:39:49 PM
April 25, 2018, 05:24:15 PM
post Re: Le Koo Cee Dubloo
TDAF
April 25, 2018, 04:30:01 PM
post How go get single mode optic fiber to work
TDAF
April 25, 2018, 04:27:52 PM
April 25, 2018, 03:40:02 PM
April 25, 2018, 03:34:16 PM
April 25, 2018, 03:07:11 PM
post Re: Micro drsstc
April 25, 2018, 02:58:51 PM
April 25, 2018, 12:57:37 PM
April 25, 2018, 12:26:05 PM
April 24, 2018, 11:41:03 PM
April 24, 2018, 07:09:04 PM
TDAF
April 24, 2018, 06:35:50 PM
TDAF
April 24, 2018, 06:34:09 PM
April 24, 2018, 06:32:18 PM
April 24, 2018, 06:29:41 PM
post On frequency splitting
TDAF
April 24, 2018, 06:23:49 PM
TDAF
April 24, 2018, 05:42:20 PM
TDAF
April 24, 2018, 05:37:23 PM
April 24, 2018, 04:57:54 PM
April 24, 2018, 04:36:38 PM
April 24, 2018, 02:42:09 PM
April 24, 2018, 02:06:32 PM
April 24, 2018, 02:00:08 PM
April 24, 2018, 01:41:39 PM
