Author Topic: Le Koo Cee Dubloo  (Read 539 times)
Offline TDAF
Le Koo Cee Dubloo
« on: March 29, 2018, 03:15:11 PM »
So, I've started working on my QCW DRSSTC
Here's what i came up with,
do the numbers check out??
if not, what can i improve??
Offline TDAF
Re: Le Koo Cee Dubloo
« Reply #1 on: April 02, 2018, 02:30:42 PM »
So, I've slightly tweaked some parameters to get a higher Fres
Attached is a shot from JAVATC
« Reply #2 on: April 15, 2018, 10:00:19 PM »
I can only comment on this from a DRSSTC point of view, where I think that your topload has a too small minor diameter and too large major diameter. You will loose some of the tight field control around the secondary / primary coil when the edge of the topload is so far away. Not sure if its needed in QCW-land :)
Offline TDAF
« Reply #3 on: April 16, 2018, 02:56:30 AM »
Thank you for the reply!!
So, the top load was made that large as I've read that qcw coils with large toploads work well
So, what might a solution be to the field shaping problem?
I can't change the minor diameter due to certain monetary issues
Would adding another intermediate toroidal with a smaller major diameter between the main top load and the secondary help?
« Reply #4 on: April 16, 2018, 09:55:14 AM »
I'd agree that this may not be a big issue for a QCW coil - topload voltages are much lower and the spark growth seems to be driven by the field at tip of the arc. If the topload is already finished then I'd test it on the finished coil before worrying about whether it needs to be changed.
Offline TDAF
« Reply #5 on: April 16, 2018, 10:19:15 AM »
The thing is I haven't even started :P
I wanna make sure everything is just right  before proceeding with the construction
Offline TDAF
« Reply #6 on: April 16, 2018, 01:59:29 PM »
Now, I know that turns ratio isnt of much importance in a tesla coil but a 1:10 ratio as is the case here Would it produce any problems??
also, will the low secondary impedance have any negative effect??
Offline TDAF
« Reply #7 on: April 19, 2018, 05:25:54 PM »
So, for the MMC
Will CBB capacitors work?
I'm thinking of something like 100 caps 10 in series 10 in parallel to give about 10nf of capacitance
https://www.ebay.com/itm/10Pcs-CBB-Capacitor-100V-101-683-0-1nF-68nF-101J-683J-Pitch-5mm/192143864676?hash=item2cbcaab364:m:miP5zeN54Fp-RSicta7nMyQ
Something like these capacitors...
« Reply #8 on: April 19, 2018, 10:27:32 PM »
I think this has already been covered on the forum - complete mystery caps are a bad idea, especially when you don't even know what dielectric they have. If you can find a datasheet that shows them to be polypropylene with reasonable RMS and peak current specs then maybe, but without that or someone having tested them then it's not recommended.
Offline TDAF
« Reply #9 on: April 20, 2018, 02:16:16 AM »
OK
But I've seen people use similar caps in large drsstcs of the yore
« Reply #10 on: April 20, 2018, 09:27:06 AM »
I think you can assume that they are similar to the old Panasonic capacitors, I got some datasheet and derived data on them here: http://kaizerpowerelectronics.dk/theory/good-mmc-capacitors/
They are old by design and compared to modern MKP power film capacitors, so I would advise on getting something better.
« Reply #11 on: April 20, 2018, 09:44:57 AM »
I agree that they look similar to the old Panasonic caps, but unless you know at least if they are polypropylene I wouldn't assume anything about the actual equivalence.
It also looks like you've already made a thread about these exact capacitors here: https://highvoltageforum.net/index.php?topic=252 - please try and not ask the same things in different places!
Offline TDAF
« Reply #12 on: April 20, 2018, 10:16:32 AM »
I'm sorry
I thought I asked that on 4hv :P
Really sorry
So, what in your opinion might be a good mmc capacitor for this use?
Offline Steve Ward
« Reply #13 on: April 23, 2018, 01:59:22 AM »
If you can't find a good surplus source, I suggest these caps (which aren't very expensive anyway and work very well if you operate at Vpk <= VAC rating):
https://www.mouser.com/ProductDetail/EPCOS-TDK/B32672L1333J?qs=sGAEpiMZZMv1cc3ydrPrF17RCV4vUJ9zc%2fmHTzNoF2E%3d
I find that the smaller capacitors offer far better IRMS/Capacitance ratings which is desirable for QCWs as the required C is usually small, but the RMS current can be large.
Your toroid capacity looks to be "more than adequate". I might suggest smaller toroid and more turns on the secondary.  The design trade off here is that a lower impedance secondary necessitates higher secondary current to charge that capacitance to the useful range of 50-80kV that typical QCW coil will operate at.  This higher secondary current will mean higher losses in the copper wire.  On the other hand, the large top capacitance gives frequency stability when the plasma grows, which has the advantage of more efficient energy transfer from primary to secondary as the tuning does not drift as far.  It's difficult to identify an optimum selection of coil parameters, even if you understand the theory and math.  I did notice particularly nice results when using a 16"x3" toroid instead of an 8"x2" toroid (different secondary wire awg, however, to keep Fres similar).  But, it's not as if the 16x3 toroid was twice as good at twice the diameter... maybe just 20% better than the small toroid, and so it never seemed practical to me.
This line of thinking led me to experiment with extra capacitors inside of my secondaries to have both a small toroid and big capacitance. With modest additional capacitance in the 20pF range this did seem to have a nice effect when using a "small" 8" x 2" toroid.  Using too much capacitance resulted in disappointment as the charging current can become unacceptable, and basically you won't see the best spark length to primary current ratio.
Offline TDAF
« Reply #14 on: April 23, 2018, 12:15:47 PM »
Your toroid capacity looks to be "more than adequate". I might suggest smaller toroid and more turns on the secondary.  The design trade-off here is that a lower impedance secondary necessitates higher secondary current to charge that capacitance to the useful range of 50-80kV that typical QCW coil will operate at.
how much secondary impedance should I be shooting for??
So, I tweaked the secondary geometry,
Now, with a larger impedance and a smaller topload!! :P
« Last Edit: April 23, 2018, 02:32:54 PM by Mads Barnkob »
« Reply #15 on: April 23, 2018, 02:43:30 PM »
I was a bit surprised to hear, that Steves best results were obtained with a larger topload or equivalently, a secondary MMC. Usually the secondary Q (under arc load) should not be too large. My guess for an optimal Q would be around 1/k. An estimate for your last design suggestion would put it above 10. That depends much on the input power you can provide, so this is very uncertain.
You can get away with a high secondary Q, if you run in upper pole mode. I believe Steve used that and for your choice of a secondary that mode of operation seems necessary.
Offline TDAF
« Reply #16 on: April 23, 2018, 02:46:11 PM »
So, will the higher Q be a problem??
If yes, How do I reduce it??
« Reply #17 on: April 23, 2018, 06:52:30 PM »
Secondary Q is the ratio of arc resistance to secondary impedance. Arc resistance drops with higher power, but you might have constraints on that  ;)
You can also increase secondary impedance by more inductance. But that implies a smaller toroid. And that again means larger frequency changes due to arc capacitance.
AFAIK most QCW designs run on the upper pole as e.g. mentioned in Loneoceans web pages. Upper pole operation works with much larger secondary Q than lower pole operation. I'm not sure how Loneoceans did this. My opinion was, that you need a PLL driver for that.
Offline Teravolt
« Reply #18 on: April 23, 2018, 09:34:51 PM »
Hi Uspring correct me if I am wrong, high Q gives more output from the tesla by sharpening the point of resonance. it will also make the frequency splitting grater. It will also make the tesla harder to tune so arc capacitance will de tune easier. if arc capacitance is taken in to consideration shouldn't that give optimal performance. I remember somewhere that the upper pole has more voltage amplitude than the lower pole? this topic has been discussed on 4hv a couple of times before.
TDAF I found this
https://www.allaboutcircuits.com/https://www.allaboutcircuits.com/textbook/alternating-current/chpt-6/q-and-bandwidth-resonant-circuit
https://ieeexplore.ieee.org/stamp/stamp.jsp?arnumber=6971783
https://electronics.stackexchange.com/questions/115933/why-does-frequency-splitting-happen-when-two-resonant-circuits-are-magnetically
http://4hv.org/e107_plugins/forum/forum_viewtopic.php?7499
« Reply #19 on: April 24, 2018, 12:05:42 AM »
In the QCW coil I am building the upper pole is significantly stronger than the lower and it oscillates there with either PLL or zero-crossing driver. Both primary and secondary are tuned a little over 300kHz in the graph below which shows both poles with the upper being the stronger of the two (lower impedance, though a little hard to see without log Y axis sorry):
post Re: Trying to build my first tesla coil!
Today at 02:39:07 AM
April 26, 2018, 10:30:35 PM
LordAlvin
April 26, 2018, 10:23:41 PM
April 26, 2018, 06:29:33 PM
April 26, 2018, 03:22:38 PM
April 26, 2018, 03:14:58 PM
April 26, 2018, 03:03:33 PM
April 26, 2018, 10:22:19 AM
April 26, 2018, 10:20:39 AM
post Trying to build my first tesla coil!
LordAlvin
April 26, 2018, 02:03:35 AM
April 26, 2018, 12:30:04 AM
April 26, 2018, 12:27:02 AM
April 25, 2018, 11:04:04 PM
April 25, 2018, 11:01:12 PM
April 25, 2018, 10:58:42 PM
April 25, 2018, 08:41:51 PM
[Light, lasers and optics]
April 25, 2018, 08:28:19 PM
April 25, 2018, 08:24:52 PM
April 25, 2018, 08:20:00 PM
TDAF
April 25, 2018, 07:01:06 PM
TDAF
April 25, 2018, 06:55:20 PM
April 25, 2018, 06:37:56 PM
TDAF
April 25, 2018, 06:15:05 PM
April 25, 2018, 05:54:03 PM
TDAF
April 25, 2018, 05:39:59 PM
April 25, 2018, 05:39:49 PM
April 25, 2018, 05:24:15 PM
post Re: Le Koo Cee Dubloo
TDAF
April 25, 2018, 04:30:01 PM
post How go get single mode optic fiber to work
TDAF
April 25, 2018, 04:27:52 PM
April 25, 2018, 03:40:02 PM
April 25, 2018, 03:34:16 PM
April 25, 2018, 03:07:11 PM
post Re: Micro drsstc
April 25, 2018, 02:58:51 PM
April 25, 2018, 12:57:37 PM
April 25, 2018, 12:26:05 PM
April 24, 2018, 11:41:03 PM
April 24, 2018, 07:09:04 PM
TDAF
April 24, 2018, 06:35:50 PM
TDAF
April 24, 2018, 06:34:09 PM
April 24, 2018, 06:32:18 PM
April 24, 2018, 06:29:41 PM
post On frequency splitting
TDAF
April 24, 2018, 06:23:49 PM
TDAF
April 24, 2018, 05:42:20 PM
TDAF
April 24, 2018, 05:37:23 PM
April 24, 2018, 04:57:54 PM
April 24, 2018, 04:36:38 PM
April 24, 2018, 02:42:09 PM
April 24, 2018, 02:06:32 PM
April 24, 2018, 02:00:08 PM
April 24, 2018, 01:41:39 PM
