Author Topic: FFEDBACK INDUCTION HEATER  (Read 294 times)
Offline radbloke
« on: August 04, 2024, 01:27:54 AM »
Before posting any real material I just wanted to find out if this is the appropriate section to start a post on an induction heater project I have going on??⚡️⚡️ The project which has gone through several iterations utilizes a current control circuit for the primary tank.
« Last Edit: August 04, 2024, 01:48:31 AM by radbloke »
Re: FFEDBACK INDUCTION HEATER
« Reply #1 on: August 04, 2024, 07:32:15 AM »
Most IH discussions have been under Electronic Circuits.
Offline radbloke
« Reply #2 on: September 03, 2024, 06:08:20 AM »
OK folks, this is a very basic question but something that maybe somebody can answer because I’m not exactly sure what is the best approach – basically the issue is I built an approximately 10 kW induction heater. This is a series LC induction heater using a ferrite coupling transformer to transfer energy to the tank circuit. The coupling transformer is connected to the inverter. One of the outputs of the inverter is connected to the coupling transformer via a DC blocking capacitor, which has a higher value than the value of the tank circuit capacitor. The other output of the inverter is connected directly to the other end of the coupling transformer. Is the DC blocking capacitor really necessary and if so why?
Offline Anders Mikkelsen
« Reply #3 on: September 03, 2024, 04:43:37 PM »
The bridge output doesn't have any DC component, in the ideal case, but in real life there can be some DC due to mismatched rise and fall times, uneven duty cycle, and other factors. With 400 V bus voltage for example, even just a quarter percent of imbalance will give a volt of DC on the output. And the primary of the transformer has a pretty low impedance at DC, leading to large current flow. If for example the DC resistance is 0.1 ohm, 1 V of DC imbalance causes 10 A of current to flow. In addition to causing losses, this current can saturate your transformer and cause it to draw a large and asymmetrical magnetizing current. So the DC blocking cap is practically always required, or at least strongly recommended.
Today at 09:00:36 AM
Today at 06:21:32 AM
Today at 04:41:21 AM
Today at 01:19:36 AM
Today at 12:59:54 AM
fillertext
radbloke
曹靖
曹靖
曹靖
August 31, 2024, 08:36:20 PM
August 31, 2024, 08:28:14 PM
post Re: Neon sign + an -?
August 31, 2024, 05:16:06 PM
post Neon sign + an -?
kenw232
August 31, 2024, 02:31:02 PM
August 30, 2024, 12:56:57 PM
SunboX
August 30, 2024, 07:47:55 AM
August 30, 2024, 05:20:42 AM
August 30, 2024, 03:38:24 AM
Sando3450
August 30, 2024, 02:33:31 AM
August 30, 2024, 01:41:49 AM
August 30, 2024, 01:34:01 AM
August 30, 2024, 12:23:43 AM
August 29, 2024, 10:21:08 PM
August 29, 2024, 08:54:20 PM
Sando3450
August 29, 2024, 05:26:43 PM
PhotonLab
August 29, 2024, 09:52:48 AM
August 29, 2024, 05:38:42 AM
post Re: designing VTTC
August 29, 2024, 12:17:30 AM
August 28, 2024, 11:59:34 PM
post Re: FPS4000
buxdahu
August 28, 2024, 05:39:06 PM
August 28, 2024, 12:36:22 PM
MikeD99
August 28, 2024, 06:53:54 AM
August 28, 2024, 04:39:27 AM
August 28, 2024, 04:23:23 AM
post Re: Plasma Toroid
August 28, 2024, 03:18:13 AM
August 28, 2024, 03:16:44 AM
Domo
August 28, 2024, 12:44:17 AM
Mathieu thm
August 27, 2024, 10:31:05 PM
Luca c.
August 27, 2024, 07:16:09 PM
August 27, 2024, 02:58:53 PM
drobotk
August 27, 2024, 12:06:52 PM
August 27, 2024, 12:51:27 AM
Domo
August 26, 2024, 11:01:55 PM
drobotk
August 26, 2024, 07:05:33 PM
August 26, 2024, 06:53:06 PM
ItsChloeUwU
August 26, 2024, 06:50:51 PM
August 26, 2024, 06:43:24 PM
August 26, 2024, 02:38:49 PM
PhotonLab
August 26, 2024, 01:31:13 PM
PhotonLab
August 26, 2024, 01:10:18 PM
PhotonLab
August 26, 2024, 11:45:00 AM
ItsChloeUwU
August 26, 2024, 09:00:16 AM
August 26, 2024, 06:47:35 AM
Domo
August 26, 2024, 05:14:48 AM
TheMadHatter
August 26, 2024, 04:29:12 AM
August 26, 2024, 04:14:35 AM
verliebt_in_neukölln17
August 26, 2024, 03:01:07 AM
August 26, 2024, 02:31:29 AM
August 25, 2024, 07:53:51 PM
August 25, 2024, 06:49:37 PM
August 25, 2024, 06:29:53 PM
August 25, 2024, 04:33:05 PM
August 25, 2024, 04:30:42 PM
August 25, 2024, 01:07:43 PM
August 25, 2024, 01:06:11 PM
August 24, 2024, 11:48:04 PM
August 24, 2024, 10:55:02 PM
August 24, 2024, 09:00:23 PM
August 24, 2024, 05:38:13 PM
Damaged1
August 24, 2024, 03:52:15 PM
August 24, 2024, 11:19:59 AM
August 24, 2024, 11:11:09 AM
August 23, 2024, 06:40:03 AM
August 23, 2024, 05:23:58 AM
August 23, 2024, 04:21:47 AM
kenw232
August 23, 2024, 02:39:08 AM
ItsChloeUwU
August 22, 2024, 10:33:43 PM
Matyáš Suchý
August 22, 2024, 09:30:42 PM
August 22, 2024, 07:09:31 PM
kenw232
August 22, 2024, 06:58:03 PM
August 22, 2024, 06:15:03 PM
kenw232
August 22, 2024, 03:41:44 PM
August 22, 2024, 03:23:48 PM
post How to wire my flyback?
kenw232
August 22, 2024, 01:35:41 AM
August 21, 2024, 10:20:32 PM
August 21, 2024, 07:59:53 PM
August 21, 2024, 01:20:40 AM
August 20, 2024, 10:41:56 PM
