Author Topic: Organize my previous QCWDRSSTC  (Read 384 times)
Offline 曹靖
« on: July 30, 2024, 03:49:31 PM »
I've been working on some PCB boards lately https://highvoltageforum.net/index.php?topic=2434.msg18070#msg18070 The machines in this post are all hand carved and made of some perforated boards. I have taken some time these days to draw a part using Pcb software. I hope to have the opportunity to resurrect it in the future                Here is a small portion of completed boards. I'm not sure if there are any areas that are not properly done. If there are any, please criticize and correct them
曹靖
Offline Unrealeous
Re: Organize my previous QCWDRSSTC
« Reply #1 on: July 31, 2024, 06:41:30 AM »
They look very nice.
[Edit: This is not correct - see below]
My only suggestion is where you have used many tiny via's (aka via-stitching) to allow high current, another option is to increase the size of the via's.  My understanding is that fewer bigger ones work better than many smaller ones.
Another option is you get the boards fabricated, you can then use the 'untented via' covering option, and you can then fill your via holes with solder - which also greatly helps with current between the layers.
Another fabrication option if you have the cash, using 2oz copper outer copper weight over default 1oz likely to help...
« Last Edit: August 01, 2024, 03:23:53 AM by Unrealeous »
With enough voltage, everything becomes a conductor.  With enough current, everything becomes a fuse.
Offline Anders Mikkelsen
« Reply #2 on: July 31, 2024, 10:05:19 PM »
Do you have a source for this? A via cuts a hole in the copper plane, while adding copper plated on the inside of the hole. The lost copper on the surface goes with the square of the diameter of the hole, while the added copper plated on the inside of the hole goes linearly with the diameter since it covers the circumference of the hole. From this it should follow that smaller holes are better.
2 oz copper is definitely a nice upgrade, if needed. Figuring out how much current your planes can handle is not trivial, and I would recommend testing it if you want to know. Having everything connected by short and wide polygons makes a huge difference. My process for making high current boards starts with component placement in order to facilitate short connections. Then adding enough layers to make all the required interconnections, then upsizing the copper thickness if required. In some cases, adding more layers can be cheaper than using thicker copper. 2 oz is supported by most board houses, at least on outer layers, but copper thicknesses beyond this tend to be more exotic and expensive.
Offline Unrealeous
« Reply #3 on: August 01, 2024, 03:20:23 AM »
Ah, you are correct.  And now I realise I've had made my via stiching assumption based on a single via and so what I said above is not correct.   I have been doing boards with via-stiching using untented vias filled with solder.
I believe the following to be true:
-An individual small tented via will conduct less than a individual large tented via
-An individual small solder-filled untented via will conduct less than a individual large solder-filled untented via
So bigger is better right?  Not so fast....
-A fixed area with a tight grid of small tented vias will conduct more than using large vias (for the reasons you describe above).
-A fixed area with a tight grid of large untented vias filled with solder will conduct the same as small untented vias filled with solder
16 circles of diameter 1 = 4pi units^2
4 circles of diameter  2 = 4pi units^2
Offline 曹靖
« Reply #4 on: August 03, 2024, 07:26:50 PM »
Today caused a phase compensation drive board
曹靖
Today at 09:00:36 AM
Today at 06:21:32 AM
Today at 04:41:21 AM
Today at 01:19:36 AM
Today at 12:59:54 AM
fillertext
radbloke
曹靖
曹靖
曹靖
August 31, 2024, 08:36:20 PM
August 31, 2024, 08:28:14 PM
post Re: Neon sign + an -?
August 31, 2024, 05:16:06 PM
post Neon sign + an -?
kenw232
August 31, 2024, 02:31:02 PM
August 30, 2024, 12:56:57 PM
SunboX
August 30, 2024, 07:47:55 AM
August 30, 2024, 05:20:42 AM
Unrealeous
August 30, 2024, 03:38:24 AM
Sando3450
August 30, 2024, 02:33:31 AM
August 30, 2024, 01:41:49 AM
August 30, 2024, 01:34:01 AM
Unrealeous
August 30, 2024, 12:23:43 AM
August 29, 2024, 10:21:08 PM
August 29, 2024, 08:54:20 PM
Sando3450
August 29, 2024, 05:26:43 PM
PhotonLab
August 29, 2024, 09:52:48 AM
sky-guided
August 29, 2024, 05:38:42 AM
post Re: designing VTTC
August 29, 2024, 12:17:30 AM
August 28, 2024, 11:59:34 PM
post Re: FPS4000
buxdahu
August 28, 2024, 05:39:06 PM
August 28, 2024, 12:36:22 PM
MikeD99
August 28, 2024, 06:53:54 AM
sky-guided
August 28, 2024, 04:39:27 AM
August 28, 2024, 04:23:23 AM
post Re: Plasma Toroid
sky-guided
August 28, 2024, 03:18:13 AM
sky-guided
August 28, 2024, 03:16:44 AM
Domo
August 28, 2024, 12:44:17 AM
Mathieu thm
August 27, 2024, 10:31:05 PM
Luca c.
August 27, 2024, 07:16:09 PM
August 27, 2024, 02:58:53 PM
drobotk
August 27, 2024, 12:06:52 PM
August 27, 2024, 12:51:27 AM
Domo
August 26, 2024, 11:01:55 PM
drobotk
August 26, 2024, 07:05:33 PM
August 26, 2024, 06:53:06 PM
August 26, 2024, 06:50:51 PM
August 26, 2024, 06:43:24 PM
August 26, 2024, 02:38:49 PM
PhotonLab
August 26, 2024, 01:31:13 PM
PhotonLab
August 26, 2024, 01:10:18 PM
PhotonLab
August 26, 2024, 11:45:00 AM
August 26, 2024, 09:00:16 AM
sky-guided
August 26, 2024, 06:47:35 AM
Domo
August 26, 2024, 05:14:48 AM
TheMadHatter
August 26, 2024, 04:29:12 AM
August 26, 2024, 04:14:35 AM
verliebt_in_neukölln17
August 26, 2024, 03:01:07 AM
August 26, 2024, 02:31:29 AM
August 25, 2024, 07:53:51 PM
August 25, 2024, 06:49:37 PM
August 25, 2024, 06:29:53 PM
August 25, 2024, 04:33:05 PM
August 25, 2024, 04:30:42 PM
August 25, 2024, 01:07:43 PM
August 25, 2024, 01:06:11 PM
August 24, 2024, 11:48:04 PM
August 24, 2024, 10:55:02 PM
August 24, 2024, 09:00:23 PM
August 24, 2024, 05:38:13 PM
Damaged1
August 24, 2024, 03:52:15 PM
August 24, 2024, 11:19:59 AM
August 24, 2024, 11:11:09 AM
August 23, 2024, 06:40:03 AM
August 23, 2024, 05:23:58 AM
August 23, 2024, 04:21:47 AM
kenw232
August 23, 2024, 02:39:08 AM
August 22, 2024, 10:33:43 PM
Matyáš Suchý
August 22, 2024, 09:30:42 PM
August 22, 2024, 07:09:31 PM
kenw232
August 22, 2024, 06:58:03 PM
August 22, 2024, 06:15:03 PM
kenw232
August 22, 2024, 03:41:44 PM
August 22, 2024, 03:23:48 PM
post How to wire my flyback?
kenw232
August 22, 2024, 01:35:41 AM
August 21, 2024, 10:20:32 PM
August 21, 2024, 07:59:53 PM
August 21, 2024, 01:20:40 AM
August 20, 2024, 10:41:56 PM
