Author Topic: FIRST DRSSTC SKM400GB128D OCD SETTING  (Read 1650 times)
Offline Alex_1996
Re: FIRST DRSSTC SKM400GB128D OCD SETTING
« Reply #20 on: August 01, 2024, 06:15:32 PM »
Offline radbloke
« Reply #21 on: August 02, 2024, 07:00:06 AM »
Hello everyone. After having built two successful DRSSTC's with a full bridge of TO247 FGA60N65SMD IGBT's, I have built a new model with a full bridge of SKM400GB128D. Here I share some data:
Secondary 36cm high and 10cm wide with 0.2mm diameter enameled copper wire. The whole secondary coated with epoxy resin.
Toroid 35,5cm x 10,5cm made with aluminum rings. The discharge wire is 47cm long. I think it may be too long.
Resonant frequency of the secondary with the toroid is about 155kHz.
7-turn primary and 66nF/12kV MMC bank for a primary frequency of 142kHz at the tuning point, which is a detuning of about 8.38%.
2 DC bus capacitors connected in voltage doubler with a total of 900V/1650uF (each 450V/3300uF).
2 snubber capacitors of 1kV DC and 2.2uF each.
1.5ke400CA bi-directional protection TVS diodes (two in series).
Feedback CT ratio is 1/625 (25 turns x 25 turns)
Driver 2.7.The phase advance adjustment was performed correctly and successfully.
Here comes my doubt. The discharges, in my opinion, are a bit small. Understand me. I achieve some 80cm discharges when they hit a target on the ground with a voltage input on the full bridge of 362VDC (150VAC from my variac) and the OCD is set to 350A. The tip of the discharge needle is 90cm high (maybe a little high). My question is:
Can I raise the OCD value to 400A or higher? I don't know if this model of IGBT's can support 400A or higher running at a primary frequency of 142kHz. They are placed on a good heat sink. The power consumption with the normal interrupter operating mode (70-100uS / 560 bps) and in MIDI mode is between 600W and 800W, respectively. My goal is that the discharges can reach the ground without having to place an object that shortens the distance to help the lightning to reach the ground more easily.
I had thought about raising the OCD limit to 400A and maybe 400V DC bus power supply in order to achieve higher discharges that can reach the ground without any problem.
I attach photos and if any data is missing do not hesitate to tell me about it. I also attach a video of the operation.
Video: https://youtube.com/shorts/fBSI0B8LMx4?feature=share
Best regards and thanks for your help
Here is the one that I built a few years back. It’s got exactly the same switches as yours i.e. the SKM 400 switches in a full bridge configuration. The OCD is set at 1000Apk.  I have dawncaps 375 nF bank - these get a little warm after long runs but work great. Using freewheeling with UD+
Fres is 52kHz with 31 inch x 6.5 inch secondary.
Here is a link to the coil running with 3/8”  copper tube breakout and 31 inch diam topload at 1000A OCD for the freewheel. The video files were too large to upload directly to this forum.
So you have plenty of room to increase your OCD to well above 350 A!!!
« Last Edit: August 02, 2024, 07:03:25 AM by radbloke »
Offline Alex_1996
« Reply #22 on: August 05, 2024, 05:32:10 PM »
This DRSSTC presents an incredible result. The electrical discharges are impressive.
After what has been exposed in this forum thread, I am sure I can set the OCD above 350A. The only drawback I see is the resonant frequency of the primary, which is set at 142kHz. I don't know if that's too high a frequency for the SKM400's.
Also, maybe my small secondary won't handle the excess voltage from the increased current and could break.
However, for future models, I will build coils of a larger size to lower the resonance frequency and I will use higher quality MMC bank capacitors and copper tubing for the primary winding.
Offline Jj
« Reply #23 on: August 06, 2024, 01:14:47 PM »
Very nice build!
you have already been given the good advice here,  but you could measure the switching time occurrence to check the performance. If you are staying close to zero current all is good. Switching losses are much less of an issue for low duty cycle operation.
Not sure how much more you can get from that secondary coil. Problems usually start when spark length is at 3x the secondary length for my DRSSTCs. Improvements can often be made, though it takes more effort and the returns get smaller.
Today at 09:00:36 AM
Today at 06:21:32 AM
Today at 04:41:21 AM
Today at 01:19:36 AM
Today at 12:59:54 AM
fillertext
radbloke
曹靖
曹靖
曹靖
August 31, 2024, 08:36:20 PM
August 31, 2024, 08:28:14 PM
post Re: Neon sign + an -?
August 31, 2024, 05:16:06 PM
post Neon sign + an -?
kenw232
August 31, 2024, 02:31:02 PM
August 30, 2024, 12:56:57 PM
SunboX
August 30, 2024, 07:47:55 AM
August 30, 2024, 05:20:42 AM
Unrealeous
August 30, 2024, 03:38:24 AM
Sando3450
August 30, 2024, 02:33:31 AM
August 30, 2024, 01:41:49 AM
August 30, 2024, 01:34:01 AM
Unrealeous
August 30, 2024, 12:23:43 AM
August 29, 2024, 10:21:08 PM
August 29, 2024, 08:54:20 PM
Sando3450
August 29, 2024, 05:26:43 PM
PhotonLab
August 29, 2024, 09:52:48 AM
sky-guided
August 29, 2024, 05:38:42 AM
post Re: designing VTTC
August 29, 2024, 12:17:30 AM
August 28, 2024, 11:59:34 PM
post Re: FPS4000
buxdahu
August 28, 2024, 05:39:06 PM
August 28, 2024, 12:36:22 PM
MikeD99
August 28, 2024, 06:53:54 AM
sky-guided
August 28, 2024, 04:39:27 AM
August 28, 2024, 04:23:23 AM
post Re: Plasma Toroid
sky-guided
August 28, 2024, 03:18:13 AM
sky-guided
August 28, 2024, 03:16:44 AM
Domo
August 28, 2024, 12:44:17 AM
Mathieu thm
August 27, 2024, 10:31:05 PM
Luca c.
August 27, 2024, 07:16:09 PM
August 27, 2024, 02:58:53 PM
drobotk
August 27, 2024, 12:06:52 PM
August 27, 2024, 12:51:27 AM
Domo
August 26, 2024, 11:01:55 PM
drobotk
August 26, 2024, 07:05:33 PM
August 26, 2024, 06:53:06 PM
August 26, 2024, 06:50:51 PM
August 26, 2024, 06:43:24 PM
August 26, 2024, 02:38:49 PM
PhotonLab
August 26, 2024, 01:31:13 PM
PhotonLab
August 26, 2024, 01:10:18 PM
PhotonLab
August 26, 2024, 11:45:00 AM
August 26, 2024, 09:00:16 AM
sky-guided
August 26, 2024, 06:47:35 AM
Domo
August 26, 2024, 05:14:48 AM
TheMadHatter
August 26, 2024, 04:29:12 AM
August 26, 2024, 04:14:35 AM
verliebt_in_neukölln17
August 26, 2024, 03:01:07 AM
August 26, 2024, 02:31:29 AM
August 25, 2024, 07:53:51 PM
August 25, 2024, 06:49:37 PM
August 25, 2024, 06:29:53 PM
August 25, 2024, 04:33:05 PM
August 25, 2024, 04:30:42 PM
August 25, 2024, 01:07:43 PM
August 25, 2024, 01:06:11 PM
August 24, 2024, 11:48:04 PM
August 24, 2024, 10:55:02 PM
August 24, 2024, 09:00:23 PM
August 24, 2024, 05:38:13 PM
Damaged1
August 24, 2024, 03:52:15 PM
August 24, 2024, 11:19:59 AM
August 24, 2024, 11:11:09 AM
August 23, 2024, 06:40:03 AM
August 23, 2024, 05:23:58 AM
August 23, 2024, 04:21:47 AM
kenw232
August 23, 2024, 02:39:08 AM
August 22, 2024, 10:33:43 PM
Matyáš Suchý
August 22, 2024, 09:30:42 PM
August 22, 2024, 07:09:31 PM
kenw232
August 22, 2024, 06:58:03 PM
August 22, 2024, 06:15:03 PM
kenw232
August 22, 2024, 03:41:44 PM
August 22, 2024, 03:23:48 PM
post How to wire my flyback?
kenw232
August 22, 2024, 01:35:41 AM
August 21, 2024, 10:20:32 PM
August 21, 2024, 07:59:53 PM
August 21, 2024, 01:20:40 AM
August 20, 2024, 10:41:56 PM
