Author Topic: Sling Psychrometer  (Read 479 times)
Sling Psychrometer
« on: June 10, 2024, 04:43:59 PM »
Since flea market yesterday, my instrument shelf includes a sling psychrometer. The gold standard for relative humidity since 19th century, I'd never owned or used or even seen one.  What mercury-free substitute do meteorologists and humidity-detector calibrators use nowadays?
Picture incidentally shows a digital multiplier unit, confirmed to be perfectly accurate, and an analog Vacuum Fluorescent Display with a 6U5 tube, as yet untested by me.
I gave the psychrometer a good whirl after wetting its wick.  Indicated bulb temperatures were 70 °F and 59.5 °F;   a traditional psychrometric chart says that matches RH of 55 percent. https://www.engineeringtoolbox.com/docs/documents/816/psychrometric_chart_29inHg.pdf
Each glass thermometer tube has a molded hook at the head end, so it would not go flying if an attachment clip were to slip.
Re: Sling Psychrometer
« Reply #1 on: June 11, 2024, 12:29:31 AM »
The environmental chambers we have at work still use a wet bulb / dry bulb technique to measure rel. humidity, only they use thermocouples instead of mercury.  Its a bit easier for a PID controller to read a thermocouple.
« Reply #2 on: July 04, 2024, 12:31:40 AM »
That's good to know, Twospoons.   Is the wet "bulb" cooling wick always wet?   Any special water treatment or maintenance requirement?
There is a heat wave this week in my part of California.
At 3 pm today, dry bulb temperature was 105 °F  (40.6 °C).
Wet bulb temperature was 72 °F  (22.2 °C), implying relative humidity between 18% and 19%.
That's how much one could cool down outdoors by getting all wet.
High temperature with low humidity invites catastrophic wildfires.
For more cooling, I put some denatured alcohol on the psychrometer wick.
Got the wet bulb down to 62 °F (16.7 °C) without much effort to remove water first.
This might be helpful in emergency hyperthermia situations, if one avoids sources of ignition. :)
« Last Edit: July 04, 2024, 12:34:28 AM by klugesmith »
« Reply #3 on: July 04, 2024, 11:02:32 PM »
Yes the wet bulb is kept wet with deionised water. Using distilled or deionised water is essential for two reasons: it prevents a build up of crud on the wick, and its more accurate since any dissolved salts will affect the vapor pressure of the water and hence its temperature.
post Re: Problem with SSTC
Nunu00
July 12, 2024, 10:17:36 PM
post Making a HV prove
July 12, 2024, 09:01:08 PM
July 12, 2024, 01:33:37 AM
Nunu00
July 12, 2024, 12:17:32 AM
July 11, 2024, 07:38:26 PM
July 11, 2024, 06:30:00 PM
ColinHeath
July 11, 2024, 06:08:30 PM
July 11, 2024, 12:24:56 PM
July 11, 2024, 06:42:23 AM
Cameron Prince
July 11, 2024, 05:46:07 AM
Cameron Prince
July 11, 2024, 05:26:51 AM
July 11, 2024, 02:50:54 AM
Coupling
July 11, 2024, 12:59:55 AM
July 10, 2024, 07:10:34 PM
July 10, 2024, 06:52:42 PM
July 10, 2024, 06:28:19 PM
Alex_1996
July 10, 2024, 01:34:09 PM
post Re: Silicon(e) plasma
July 10, 2024, 12:09:06 AM
Nunu00
July 09, 2024, 11:52:00 PM
July 09, 2024, 07:37:22 PM
July 09, 2024, 07:30:05 PM
July 09, 2024, 03:30:49 AM
verliebt_in_neukölln17
July 09, 2024, 12:51:02 AM
July 08, 2024, 11:30:44 PM
post Re: Why so cheap?
July 08, 2024, 10:57:10 PM
July 08, 2024, 10:21:01 PM
post Why so cheap?
July 08, 2024, 09:55:24 PM
Cameron Prince
July 08, 2024, 09:18:21 PM
July 08, 2024, 05:17:49 PM
Cameron Prince
July 08, 2024, 04:49:20 PM
post Re: Tesla coil in FEMM
July 08, 2024, 04:28:43 AM
July 08, 2024, 04:06:53 AM
post Tesla coil in FEMM
July 08, 2024, 03:46:49 AM
July 08, 2024, 02:42:00 AM
July 08, 2024, 01:37:55 AM
Sebigamer
July 08, 2024, 12:53:08 AM
July 08, 2024, 12:49:48 AM
July 07, 2024, 11:15:35 PM
post Silicon(e) plasma
July 07, 2024, 11:04:43 PM
July 07, 2024, 09:39:07 PM
July 07, 2024, 05:32:56 PM
July 07, 2024, 02:52:19 PM
July 07, 2024, 02:50:04 PM
July 07, 2024, 02:20:11 PM
July 07, 2024, 10:02:22 AM
Sebigamer
July 07, 2024, 09:23:58 AM
July 07, 2024, 12:44:53 AM
July 07, 2024, 12:08:50 AM
July 06, 2024, 10:35:49 PM
July 06, 2024, 09:42:43 PM
July 06, 2024, 06:06:23 PM
July 06, 2024, 10:21:16 AM
July 06, 2024, 10:15:42 AM
July 06, 2024, 04:53:56 AM
July 06, 2024, 04:42:16 AM
July 06, 2024, 04:09:50 AM
July 06, 2024, 03:07:11 AM
July 06, 2024, 03:05:18 AM
July 06, 2024, 02:37:16 AM
July 06, 2024, 02:20:14 AM
July 06, 2024, 01:55:14 AM
July 05, 2024, 11:50:37 PM
July 05, 2024, 10:07:04 PM
gravitysrainbow
July 05, 2024, 07:13:25 PM
July 05, 2024, 06:17:13 PM
post Re: Phase lead inductors
July 04, 2024, 11:40:45 PM
post Re: Sling Psychrometer
post Phase lead inductors
July 04, 2024, 06:28:08 PM
Alex_1996
July 04, 2024, 12:07:21 AM
Alex_1996
July 04, 2024, 12:06:17 AM
July 03, 2024, 10:51:23 PM
July 03, 2024, 09:44:14 PM
July 03, 2024, 08:48:13 PM
July 03, 2024, 08:24:50 PM
Alex_1996
July 03, 2024, 08:12:55 PM
July 03, 2024, 07:29:53 PM
July 03, 2024, 07:21:38 PM
July 03, 2024, 05:05:39 PM
Alex_1996
July 03, 2024, 04:29:53 PM
July 03, 2024, 04:09:11 PM
Alex_1996
July 03, 2024, 02:47:18 PM
Alex_1996
July 03, 2024, 01:35:24 PM
July 03, 2024, 02:19:03 AM
July 03, 2024, 01:19:50 AM
July 02, 2024, 11:29:18 PM
July 02, 2024, 09:59:07 PM
July 02, 2024, 09:55:53 PM
July 02, 2024, 09:44:55 PM
July 02, 2024, 07:51:37 PM
July 02, 2024, 06:14:07 PM
July 02, 2024, 06:02:38 PM
July 02, 2024, 11:37:46 AM
July 02, 2024, 05:22:10 AM
July 02, 2024, 05:16:30 AM
drobotk
July 01, 2024, 11:50:12 PM
July 01, 2024, 08:48:53 PM
July 01, 2024, 08:40:59 AM
July 01, 2024, 08:09:42 AM
June 30, 2024, 06:49:45 AM
