Author Topic: Adding capacitor to primary in SSTC  (Read 598 times)
Offline Simranjit
« on: June 06, 2024, 11:20:23 PM »
Hi, Could someone please explain what is happening here.
I completed my SSTC yesterday. I just wanted to experiment a little more with it. So, I measured inductance of primary of my tesla coil which comes out to be 11.38uH with 6 turns and after calculating required capacitance at 94kHz (resonant frequency of secondary) the the result was 250nF. I had a 270nF MKPH capacitor laying around so I added that in series with primary. The circuit was not resonating correctly with antenna and it would jump around a lot like 110kHz or 250kHz. So I just used a NE555 timer at 94kHz with 50% duty cycle and the oscillations were stable. I'm attaching some files also.
Before adding series capacitor (6 turns primary):
4.1A @ 30V
Arcs would jump from 5cms
Arcs were bushy / straight / more sparky....
Near zero transients at drain of mosfets
After adding series capacitor (6 turns primary):
0.350A @ 30V (not drawing arc)
3.5A @ 30V (when drawing arc)
Arcs only jump from small distance (maybe between 0.5cm - 1.0cm) then I can draw them further
Arcs are more fire like (so I'm guessing there is more current)
Peak-peak voltage at drain of mosfets > 55v
I'm sure this is not a DRSSTC but then what is it ? and should I proceed to make it more like this or something else:
https://www.instructables.com/Building-the-Worlds-Easiest-QCW-Tesla-Coil-Staccat/
Edit: Some other interesting observations (with series capacitor). Using antenna (resonant frequency seems to be 111kHz now) and interrupting the output with 350Hz signal at 20% duty cycle results in bushy sparks again 2.3A @ 30V jumping over 3cm. I'm attaching some images for interrupted signal.
Edit 2: Using interrupter at 60Hz with 20% duty cycle and another 555 timer at 111 kHz. The max current it draws is 0.600A @ 30V. Arcs around 2cm. With Almost no transients at drain. Mosfets are also stone cold.
« Last Edit: June 07, 2024, 02:42:47 AM by Simranjit »
Re: Adding capacitor to primary in SSTC
« Reply #1 on: June 07, 2024, 06:42:26 AM »
Yes, you changed your SSTC into a DRSSTC.  That's what "dual resonant" means.  Both primary and secondary are resonant.  Search the forum and/or elsewhere to learn about upper pole and lower pole (upper and lower resonant frequencies) of dual resonant systems.
Offline Michelle_
« Reply #2 on: June 07, 2024, 03:59:57 PM »
Watch out because if you actually manage to get the primary and secondary to resonate together it will pull way more amps. Personally I would focus on getting just a regular SSTC to work reliably at full power before exploring more complicated and powerful designs.
post Re: Problem with SSTC
Nunu00
July 12, 2024, 10:17:36 PM
post Making a HV prove
July 12, 2024, 09:01:08 PM
July 12, 2024, 01:33:37 AM
Nunu00
July 12, 2024, 12:17:32 AM
July 11, 2024, 07:38:26 PM
July 11, 2024, 06:30:00 PM
ColinHeath
July 11, 2024, 06:08:30 PM
July 11, 2024, 12:24:56 PM
July 11, 2024, 06:42:23 AM
Cameron Prince
July 11, 2024, 05:46:07 AM
Cameron Prince
July 11, 2024, 05:26:51 AM
July 11, 2024, 02:50:54 AM
Coupling
July 11, 2024, 12:59:55 AM
July 10, 2024, 07:10:34 PM
July 10, 2024, 06:52:42 PM
July 10, 2024, 06:28:19 PM
Alex_1996
July 10, 2024, 01:34:09 PM
post Re: Silicon(e) plasma
July 10, 2024, 12:09:06 AM
Nunu00
July 09, 2024, 11:52:00 PM
July 09, 2024, 07:37:22 PM
July 09, 2024, 07:30:05 PM
July 09, 2024, 03:30:49 AM
verliebt_in_neukölln17
July 09, 2024, 12:51:02 AM
July 08, 2024, 11:30:44 PM
post Re: Why so cheap?
July 08, 2024, 10:57:10 PM
July 08, 2024, 10:21:01 PM
post Why so cheap?
July 08, 2024, 09:55:24 PM
Cameron Prince
July 08, 2024, 09:18:21 PM
July 08, 2024, 05:17:49 PM
Cameron Prince
July 08, 2024, 04:49:20 PM
post Re: Tesla coil in FEMM
July 08, 2024, 04:28:43 AM
July 08, 2024, 04:06:53 AM
post Tesla coil in FEMM
July 08, 2024, 03:46:49 AM
July 08, 2024, 02:42:00 AM
July 08, 2024, 01:37:55 AM
Sebigamer
July 08, 2024, 12:53:08 AM
July 08, 2024, 12:49:48 AM
July 07, 2024, 11:15:35 PM
post Silicon(e) plasma
July 07, 2024, 11:04:43 PM
July 07, 2024, 09:39:07 PM
July 07, 2024, 05:32:56 PM
July 07, 2024, 02:52:19 PM
July 07, 2024, 02:50:04 PM
July 07, 2024, 02:20:11 PM
July 07, 2024, 10:02:22 AM
Sebigamer
July 07, 2024, 09:23:58 AM
July 07, 2024, 12:44:53 AM
July 07, 2024, 12:08:50 AM
July 06, 2024, 10:35:49 PM
July 06, 2024, 09:42:43 PM
July 06, 2024, 06:06:23 PM
July 06, 2024, 10:21:16 AM
July 06, 2024, 10:15:42 AM
July 06, 2024, 04:53:56 AM
July 06, 2024, 04:42:16 AM
July 06, 2024, 04:09:50 AM
July 06, 2024, 03:07:11 AM
July 06, 2024, 03:05:18 AM
July 06, 2024, 02:37:16 AM
July 06, 2024, 02:20:14 AM
July 06, 2024, 01:55:14 AM
July 05, 2024, 11:50:37 PM
July 05, 2024, 10:07:04 PM
gravitysrainbow
July 05, 2024, 07:13:25 PM
July 05, 2024, 06:17:13 PM
post Re: Phase lead inductors
July 04, 2024, 11:40:45 PM
post Re: Sling Psychrometer
July 04, 2024, 11:02:32 PM
post Phase lead inductors
July 04, 2024, 06:28:08 PM
July 04, 2024, 12:31:40 AM
Alex_1996
July 04, 2024, 12:07:21 AM
Alex_1996
July 04, 2024, 12:06:17 AM
July 03, 2024, 10:51:23 PM
July 03, 2024, 09:44:14 PM
July 03, 2024, 08:48:13 PM
July 03, 2024, 08:24:50 PM
Alex_1996
July 03, 2024, 08:12:55 PM
July 03, 2024, 07:29:53 PM
July 03, 2024, 07:21:38 PM
July 03, 2024, 05:05:39 PM
Alex_1996
July 03, 2024, 04:29:53 PM
July 03, 2024, 04:09:11 PM
Alex_1996
July 03, 2024, 02:47:18 PM
Alex_1996
July 03, 2024, 01:35:24 PM
July 03, 2024, 02:19:03 AM
July 03, 2024, 01:19:50 AM
July 02, 2024, 11:29:18 PM
July 02, 2024, 09:59:07 PM
July 02, 2024, 09:55:53 PM
July 02, 2024, 09:44:55 PM
July 02, 2024, 07:51:37 PM
July 02, 2024, 06:14:07 PM
July 02, 2024, 06:02:38 PM
July 02, 2024, 11:37:46 AM
July 02, 2024, 05:22:10 AM
July 02, 2024, 05:16:30 AM
drobotk
July 01, 2024, 11:50:12 PM
July 01, 2024, 08:48:53 PM
July 01, 2024, 08:40:59 AM
July 01, 2024, 08:09:42 AM
June 30, 2024, 06:49:45 AM
