Author Topic: Drsstc feedback startup  (Read 674 times)
Offline RoamingD
  • Self taught 19yo enthusiast
« on: September 18, 2023, 02:59:10 PM »
Hello, it may sound like a stupid question, but do I need to have my secondary coil in place for my ud2.7c to be able to pick up the feedback signal from the primary coil?
Currently my driver works fine only when it is fed a 120khz square wave, and the feedback transformer when loaded with a 51ohm burden resistor appears on the oscilloscope
Offline flyingperson23
  • noob
Re: Drsstc feedback startup
« Reply #1 on: September 18, 2023, 04:29:15 PM »
No, the UD operates on primary current feedback; all it needs is for current to be flowing through the primary. If you operate without a secondary, the UD will oscillate normally as current will still flow through the primary.
Offline RoamingD
« Reply #2 on: September 18, 2023, 05:01:22 PM »
Some quick scope shots, this is the halfbridge output working when the driver is fed a signal
I fed it 170 vac on the bus at some point and nothing blew up so the halfbridge is switching right
This is the feedback transformer loaded on a 51ohm burden resistor and it looks good  ???
but the really strange output is this "starting pulse" that I measured on the gdt when it has no feedback connected, to me it looks inverted, how is this possible?
« Last Edit: September 18, 2023, 05:05:26 PM by RoamingD »
  • noob
« Reply #3 on: September 18, 2023, 06:20:30 PM »
Those waveforms look normal enough to me. What do you mean by 'inverted'?
Offline RoamingD
« Reply #4 on: September 18, 2023, 07:46:46 PM »
I mean the output is almost high and has just a short off time, kinda like a high duty cycle, and on the internet I saw quite the opposite, a short positive pulse, not a short gnd pulse like mine, I really don't know, but the circuit isn't able to start it's oscillation from the current transformer
  • noob
« Reply #5 on: September 19, 2023, 12:45:37 AM »
Did you try changing the phasing on the driver? If your feedback phase is wrong it won't oscillate under its own feedback.
« Reply #6 on: September 19, 2023, 06:15:40 AM »
Do you have a bleed resistor pulling half-bridge output low?  Something is causing output to end up at 0V after enable pulse ends.
Looks like Vbus is 60V for this scope capture.  Is that accurate?  Is Vbus 60V for the current transformer output capture too?
Where on GDT are you probing?  Is this low-side Vge (or Vgs if using FETs)?  If so, it looks appropriate, other than possible CT inversion issue as flyingperson23 mentioned.  What does half-bridge output look like?  What does voltage across UD2.7 51-ohm resistor look like?
If this is low-side Vge, then high side Vge should be a matching positive pulse.  That should make a low-to-high transition on half-bridge output.  That output transition should cause current that should trigger another transition.
Offline RoamingD
« Reply #7 on: September 19, 2023, 07:53:34 AM »
This horrible thing I drew is the schematic of the bridge, I dont use any bleed resistor except on the bus capacitor
and this is how I connected the probe
This is how I connected and measured the feedback transformer with a 120khz signal from a 555 timer fed in the feedback connector, the variac was set to 50v ac
With no feedback transformer/signal generator, this is the startup pulse that I can measure on the gates of the igbt, is this normal?
And I dont think the gdt is the problem because with external feedback, the circuit didnt blow at 170vac input and also no real heating, at some point I was even tripping the ocd
I really dont know what to do, but for a last resort can I run the coil based on the signal generator and ditch primary feedback, keeping in mind the ocd does still work?
  • noob
« Reply #8 on: September 19, 2023, 03:48:23 PM »
Typically the non-igbt end of a half bridge tank circuit is connected to a capacitive voltage divider, not Vbus-
Offline RoamingD
« Reply #9 on: September 19, 2023, 03:57:15 PM »
I asked previously about this in this thread https://highvoltageforum.net/index.php?topic=2348.0
« Reply #10 on: September 19, 2023, 08:46:36 PM »
I replied to your thread "Re: Inverter question" and I think your problem here is primary coil saturation, from leaving out the DC blocking capacitors. Often they are mistaken for only being used for voltage doubling in 120VAC countries, but that is just a double use of them.
Offline RoamingD
« Reply #11 on: September 19, 2023, 08:53:11 PM »
Oh, I see, but I have one more question, when adding the DC blocking caps does their capacity add up to the MMC?
« Reply #12 on: September 19, 2023, 09:10:06 PM »
Not if you calculate it correctly as I linked to in the other thread.
Offline RoamingD
« Reply #13 on: September 19, 2023, 10:02:13 PM »
I am very sorry if my physics or mathematics skills are lacking :))) the resonant freq is 122khz with a 3.808 uH primary coil inductance
I have run the calculations and a 1uF capacitor will have 1.305 Ohms of reactance but the frequency comes at around 0.08164 kHz, will this work?
Also, another beginner question, what should the voltage rating of those caps be? Can I get away with 630v?
« Last Edit: September 19, 2023, 10:46:46 PM by RoamingD »
« Reply #14 on: September 20, 2023, 05:24:44 AM »
Then I'm puzzled as to why half-bridge output returns quickly to 0V (to Vbus-) shortly after a burst.  (This is from first scope capture of reply #2 above.)  Only explanations I'm thinking of at the moment are either there is some glitch in low-side IGBT Vge or the low-side IGBT is partially damaged (leakage current).
I'll guess the probe is really 10x, so 20V/div.  Even then it does not look normal.   Initial -24V pulse looks somewhat reasonable, but too short.  Subsequent ring appears clipped, more square than sine wave, and too high frequency for your 122kHz coil.  Are you sure GDT is on ferrite core and not powdered iron?  It may work barely well enough for operation at 122kHz, but not for the initial start transition.
Agree.  But I don't think this is a significant cause of issues showing up here.
Offline RoamingD
« Reply #15 on: September 20, 2023, 05:51:18 AM »
Sadly I am sure the gdt is proper ferrite, I have used this type of core in my 200khz sstc and it was fine, here is a link of it
https://www.tme.eu/ro/details/b64290l0618x830/miezuri-de-ferita/epcos/
Also, I think the output returning to 0 was some kind of weird glitch with that cheap oscilloscope, my trusty analog scope doesn't show it falling, but staying in the middle
« Reply #16 on: September 20, 2023, 06:05:54 AM »
Material is fine.  How many turns are on your GDT?  Core is rather small for 120kHz.  I'm guessing core is saturating after 5us.  That should be just enough for 120kHz (4us half-cycle).  Not much margin, but probably not the main issue.
Puzzling, but I'll ignore that one capture showing quick return to Vbus-.  You still might need bleed resistors to keep half-bridge output at half way point.  Without scope load, if upper IGBT happens to have slightly higher leakage current, output may drift high.  Initial start pulse tries to pull it high.  If output is already high, no initial change, so no feedback.
I still suggest scoping UD2.7 51ohm CT burden resistor during that startup pulse, then half-bridge output.
Offline RoamingD
« Reply #17 on: September 20, 2023, 04:39:36 PM »
Hello, I made a huge discovery, the whole thing works fine when I touch the 2nd or 3rd pin of the AD8561ANZ  ultra fast comparator that I used instead of the lt1001 with the tip of a oscilloscope probe
Now I am confused as to why does this solve the problem and what should I change on the board to make it work by itself
With red is where I probed and it stared working (the ground lead was not connected to anything)
« Last Edit: September 20, 2023, 06:02:04 PM by RoamingD »
« Reply #18 on: September 21, 2023, 04:55:53 AM »
Scope probe and lead cable are acting as an antenna.  You are picking up enough either random noise or more likely voltage from secondary.  That pickup makes extra driver output transitions to start oscillation.
Three options come to mind for fixing this without a scope probe:
1) Add an antenna.  NOT recommended.  Hard to control what phase lead will be or how much signal may be picked up and over-drive comparitor input.
2) Fix the issue(s) preventing normal startup.  I've already twice suggested next scope measurements to take, so won't repeat here.
3) Modify your driver to be self-oscillating.  I described this for UD2.7 in third paragraph of this post:
    https://highvoltageforum.net/index.php?topic=1373.msg10197#msg10197
Manz
Today at 05:36:26 PM
Today at 05:32:57 PM
post Re: Is it beneficial to use a semi toroidal DRSSTC primary coil?
Today at 05:27:38 PM
Today at 05:11:00 PM
Today at 05:04:19 PM
post Re: What to drive this UY30 transformer?
Today at 02:18:49 PM
post Ramped SSTC build, some questions
Manz
Today at 02:10:57 PM
Today at 01:36:22 PM
post Brass vs Copper for spark gap?
Today at 01:03:25 PM
Today at 06:54:33 AM
post Is it beneficial to use a semi toroidal DRSSTC primary coil?
Today at 06:43:58 AM
post Re: 3kJ coin shrinking
Today at 04:45:06 AM
Lucasww
Today at 04:41:19 AM
Today at 03:23:29 AM
Lucasww
Today at 12:36:10 AM
post Rotary Spark Gap Arcing Not Sustained
tbbrune
September 24, 2023, 03:02:34 PM
post X-ray Image Scanner Teardown. Philips / Fujifilm PCR Eleva S (3 part series)
September 24, 2023, 01:14:03 PM
Lucasww
September 24, 2023, 09:57:24 AM
post Re: QCW problem with ZVS and phase lead (solved)
Didik8774
September 24, 2023, 06:23:39 AM
tatemac
September 24, 2023, 04:12:50 AM
September 24, 2023, 03:12:58 AM
post Re: Small UD3 Coil build log
September 23, 2023, 06:52:35 PM
Jhornel
September 23, 2023, 02:14:35 PM
Download
September 23, 2023, 04:52:28 AM
Lucasww
September 23, 2023, 02:11:05 AM
September 22, 2023, 10:22:28 PM
September 22, 2023, 09:51:07 PM
September 22, 2023, 09:20:18 PM
September 22, 2023, 07:53:07 PM
September 22, 2023, 07:43:55 PM
Download
September 22, 2023, 03:49:44 PM
post Re: Capacitors filter problem
September 22, 2023, 02:07:29 PM
Luca c.
September 22, 2023, 11:24:33 AM
Lucasww
September 22, 2023, 07:24:58 AM
post Re: Interrupter pulling ct signal
September 22, 2023, 06:26:32 AM
September 22, 2023, 06:05:35 AM
September 22, 2023, 05:51:59 AM
September 22, 2023, 05:40:29 AM
post Re: Benjamin's DRSSTC1
September 22, 2023, 05:28:53 AM
September 22, 2023, 05:22:04 AM
September 22, 2023, 05:14:26 AM
post Capacitors filter problem
September 22, 2023, 04:40:04 AM
post Re: What Cable Thickness for Capacitor Discharges?
September 22, 2023, 01:01:25 AM
September 21, 2023, 11:56:16 PM
post Re: Measuring electric voltage in a Tesla coil
September 21, 2023, 11:22:30 PM
September 21, 2023, 10:44:08 PM
post Phone sensor fusion demo
[Smart Phones]
September 21, 2023, 09:22:14 PM
omrid13
September 21, 2023, 08:54:31 PM
September 21, 2023, 08:41:31 PM
September 21, 2023, 08:10:53 PM
post Re: Magnifier tesla coil
Hysteresis
September 21, 2023, 08:06:32 PM
September 21, 2023, 07:48:53 PM
post Re: Rotary SG, Gap Distance Vs Performance ?
Hysteresis
September 21, 2023, 07:48:22 PM
September 21, 2023, 07:23:34 PM
post Re: LLC resonant converters (Why the second inductor?)
September 21, 2023, 05:20:33 PM
IonWind
September 21, 2023, 04:49:15 PM
September 21, 2023, 04:02:06 PM
post Nice little flybacks for the price
IonWind
September 21, 2023, 11:12:29 AM
September 21, 2023, 09:34:12 AM
post LLC resonant converters (Why the second inductor?)
September 21, 2023, 09:29:56 AM
Lucasww
September 21, 2023, 09:23:30 AM
September 21, 2023, 05:59:38 AM
post Re: Varying the Coulomb Potential of Metal Tube. MOT secondary flashover.
Luca c.
September 20, 2023, 11:03:21 PM
September 20, 2023, 09:01:50 PM
RoamingD
September 20, 2023, 07:34:07 AM
RoamingD
September 20, 2023, 05:49:15 AM
September 20, 2023, 05:07:10 AM
RoamingD
post Re: First drsstc issues
Hari33
September 19, 2023, 09:18:47 PM
RoamingD
post Re: Inverter question
September 19, 2023, 08:44:54 PM
September 19, 2023, 08:18:38 PM
post First drsstc issues
Hari33
September 19, 2023, 07:39:42 PM
post UD2.7Cs for sale
All Science
September 19, 2023, 07:06:39 PM
RoamingD
September 19, 2023, 03:33:06 PM
post What to drive this UY30 transformer?
September 19, 2023, 09:06:16 AM
RoamingD
omrid13
September 19, 2023, 07:14:57 AM
September 19, 2023, 06:29:00 AM
September 19, 2023, 05:56:13 AM
September 19, 2023, 05:05:57 AM
post Re: Migatronic FocusStick 161E Stick Welder Teardown
orac
September 19, 2023, 04:52:30 AM
post Re: Part identification for a Esab Es300i renegade Machine
orac
September 19, 2023, 04:48:02 AM
orac
September 19, 2023, 04:29:14 AM
post Measuring electric voltage in a Tesla coil
omrid13
September 19, 2023, 01:14:00 AM
post Re: First sstc is not working
September 19, 2023, 12:59:52 AM
September 18, 2023, 11:16:41 PM
September 18, 2023, 09:55:08 PM
Lucasww
September 18, 2023, 08:15:37 PM
