Author Topic: GDT design  (Read 269 times)
Online flyingperson23
  • noob
GDT design
« on: September 13, 2023, 05:26:00 PM »
I'm designing a big coil, and a point was brought up - during operation, full bus voltage is across a pair of gdt windings at all times. I'm hoping to use a boost converter for a bus around 1200v and cat5 wires have 300v insulation, so I don't want to risk a gdt flashover destroying my igbt gates. Are there any other cable standards like cat5 but rated for a sufficiently high voltage, or will I have to use individual wires?
Re: GDT design
« Reply #1 on: September 13, 2023, 07:30:37 PM »
Perhaps some multi core control cable like LIYY 8x0.25 could be used, its 6.2mm outer diameter and would properly require a larger core, than if you used cat5 cable.
It has a voltage rating of 500V.
https://www.tme.eu/dk/en/details/liyy-8x0.25/multicore-cables-unshielded/lapp/0028308/
There do also exist 300V, 600V and 1000V Ethernet cable, but I think its only the outer insulation that goes for that rating, as to which other cables you are allowed to mix it with in a cable tray.
Maybe you could wind two ethernet cables on the same core, one cable for the primary (all wires connected together for 1 winding) and the other cable for 4 pairs of two wires in parallel. But the leakage inductance might get too high from low coupling.
« Last Edit: September 13, 2023, 07:35:42 PM by Mads Barnkob »
Re: GDT design
« Reply #2 on: September 14, 2023, 06:01:04 AM »
Wow, what voltage rating are your IGBTs?
People regularly use 300V cable for 560Vbus with whatever spike voltage occurs above that.  Insulation rating is for long term exposure and high reliability.  However, 1200V may be too high for 300V wire, especially if you want low risk and your coil will be used frequently.
Probably easiest to find suitable individual wire.  I'd still recommend twisting that wire into 4 pairs, paralleling one wire of each pair to form primary.  Will minimize leakage inductance.
  • noob
Re: GDT design
« Reply #3 on: September 14, 2023, 04:20:04 PM »
I'm using 1700v igbts (ff1000). I am using a ud3.1 so I'll need 2 GDTs so wire diameter will be less of an issue, I just need to find suitable wire.
Re: GDT design
« Reply #4 on: September 14, 2023, 04:33:09 PM »
You could wind the GDTs with something like RG-174 or similar small diameter coax - voltage rating should be >1kV (look it up for whatever cable you find) and you can run the primary winding on the shield and the secondary on the core for very high coupling (low leakage).
Re: GDT design
post Re: Ramped SSTC build, some questions
Manz
Today at 05:36:26 PM
post Re: Brass vs Copper for spark gap?
Today at 05:32:57 PM
post Re: Is it beneficial to use a semi toroidal DRSSTC primary coil?
Today at 05:27:38 PM
Today at 05:11:00 PM
Today at 05:04:19 PM
Today at 02:18:49 PM
post Ramped SSTC build, some questions
Manz
Today at 02:10:57 PM
Today at 01:36:22 PM
post Brass vs Copper for spark gap?
Today at 01:03:25 PM
Today at 06:54:33 AM
post Is it beneficial to use a semi toroidal DRSSTC primary coil?
Today at 06:43:58 AM
post Re: 3kJ coin shrinking
Today at 04:45:06 AM
Lucasww
Today at 04:41:19 AM
Today at 03:23:29 AM
Lucasww
Today at 12:36:10 AM
post Rotary Spark Gap Arcing Not Sustained
tbbrune
September 24, 2023, 03:02:34 PM
post X-ray Image Scanner Teardown. Philips / Fujifilm PCR Eleva S (3 part series)
September 24, 2023, 01:14:03 PM
Lucasww
September 24, 2023, 09:57:24 AM
post Re: QCW problem with ZVS and phase lead (solved)
Didik8774
September 24, 2023, 06:23:39 AM
tatemac
September 24, 2023, 04:12:50 AM
September 24, 2023, 03:12:58 AM
September 23, 2023, 06:52:35 PM
Jhornel
September 23, 2023, 02:14:35 PM
Download
September 23, 2023, 04:52:28 AM
Lucasww
September 23, 2023, 02:11:05 AM
Egg
Download
Luca c.
Lucasww
September 22, 2023, 07:24:58 AM
post Re: Benjamin's DRSSTC1
September 22, 2023, 05:14:26 AM
post Phone sensor fusion demo
omrid13
post Re: Magnifier tesla coil
Hysteresis
Hysteresis
Egg
IonWind
Egg
IonWind
Lucasww
September 21, 2023, 09:23:30 AM
Luca c.
RoamingD
Egg
RoamingD
RoamingD
post Re: First drsstc issues
Hari33
RoamingD
post Re: Inverter question
post First drsstc issues
Hari33
post UD2.7Cs for sale
All Science
RoamingD
RoamingD
omrid13
September 19, 2023, 06:29:00 AM
September 19, 2023, 05:56:13 AM
orac
orac
orac
September 19, 2023, 04:29:14 AM
omrid13
Egg
Lucasww
September 18, 2023, 08:15:37 PM
