Author Topic: Magnifier tesla coil  (Read 1444 times)
Offline Acid Byte
« on: August 20, 2023, 09:25:02 AM »
Hey enthousiast!
So ive been working on a magnifier setup the last couple of weeks.
Wich was actually fun most of the time.
The coil is powered by 2x NST 8kv@25mA and is protected by a lowpass filter.
Setup was created from multiple coils.
Main resonator is resonant at 375khz.
The secundairy is a ¼ wave length coil to the main resonator, this coil consists of 3 flat pancake coils.
And the primary is tuned to arround 358khz.
Primary former and secundairy coils
Secundairy coils made of 0.75mm² wire and have 36 turns for each flat coil.
Main resonator
Fres = 375khz
960 turns 0.2mm wire of a 75mm form for 19.2cm
150mm x 37.5mm topload
Making the primary coil
Primary is made from 5mm brake line tubing and has a total of 10 turns on the form
All coils together
The coil setup
Mmc bank 10.5kvac @ 20nF
15x 100nF@700vac in series with 3 strings total for 20nF capacitance
Magneticly quenced sparkgap with neodimium magnets
And last but not least a video of the coil running.
« Last Edit: August 20, 2023, 09:41:40 AM by Acid Byte »
Offline NyaaX_X
Re: Magnifier tesla coil
« Reply #1 on: August 20, 2023, 04:22:38 PM »
That is a pretty and clear SGTC. Nice work~ ;)
Offline Acid Byte
« Reply #2 on: August 20, 2023, 07:30:49 PM »
Thank you very much 😃
Offline Hysteresis
« Reply #3 on: September 03, 2023, 04:22:59 AM »
You do nice work. Very cool coil. If you have the time you should try a rotary spark gap. For my coils it really helped the performance.
Offline Acid Byte
« Reply #4 on: September 09, 2023, 10:38:03 AM »
Thank you very much :)
Yeah i wanna go that route. Not sure yet how it will perform without a synchronous motor though.
Any thoughts?
Would it be easier to make a dc coil maybe?
Offline Acid Byte
« Reply #5 on: September 09, 2023, 03:49:40 PM »
Changed the topload for a step bigger on the resonator.
And added terminal capacitance to the secundairy coil.
Spark seem more fluid and bigger now :)
Secundairy terminal capacitance
/>The result.
« Last Edit: September 09, 2023, 03:51:27 PM by Acid Byte »
Offline Hysteresis
« Reply #6 on: September 21, 2023, 08:06:32 PM »
Hi Acid Byte. I would start out with a asynchronous system. Just get a small DC motor and vary the voltage to the motor when the coil is running. Find the sweet spot! Then if you have the time you can build a sync system.
Offline Acid Byte
« Reply #7 on: October 13, 2023, 06:08:04 PM »
Yeah so thats what i build and will be testing for this weekend 😃
And yes i hope the async will do some nice stuff.
Can vary it anywhere from 10bps to 1000 bps :)
Any chance in knowing what it will do with primary tuning?
Will be posting a video soon :)
« Last Edit: October 13, 2023, 07:00:20 PM by Acid Byte »
Offline Hysteresis
« Reply #8 on: October 14, 2023, 09:16:10 PM »
Looks good Acid Byte. Primary tuning with new RSG ?? Any time I make any change to the primary I see the tuning change. So check it.
ae7b
Today at 06:53:52 AM
Keybored
Today at 12:25:37 AM
Lucasww
bobfrancis1980
Lucasww
bobfrancis1980
post GDT magnetizing current
Keybored
Lucasww
bobfrancis1980
bobfrancis1980
Keybored
bobfrancis1980
post Re: 2 Layer primary coil
post 2 Layer primary coil
tazea
Hysteresis
nzoomed
post Segmented Primary Coil
tbbrune
post Chain reactions
post P5104 40kV 20MHz probes
Benjamin_collier
tazea
post Small Coil Build
post Re: GU-81 vs. GU-81M
thehay95
nzoomed
post Re: Benjamin's DRSSTC3
post Benjamin's DRSSTC3
bobfrancis1980
coilerer
coilerer
bobfrancis1980
