Author Topic: Grounding issues...  (Read 631 times)
Offline Manz
Grounding issues...
« on: August 19, 2023, 05:21:08 PM »
Hello everyone.
Here you can find a brief overview of my coil before talking about the problem that popped up the other day...
Inverter: skm100 fullbridge with a 4700uF 450V electrolytic capacitor
MMC: 97.5nF 8kV (4S10P 39nF 2kVdc mkp capacitors)
Secondary coil: 10*38cm 0.2mm wire. 100*38cm topload around 125khz resonant frequency
Driver: ud2.9 in pulseskip mode
Primary: 10turns, 4mm copper tube
The coil has a 24V psu that powers the driver and a relay for the bus capacitor precharge and a 12V one to power a fan.
I connected the 12V-24V psu grounds and the negative output to the coil's RF ground together with strike rail,inverter heatsink and driver's enclosure.
I run the coil for several minutes when all of a sudden I saw a small spark on the 24V psu screw terminals shorting ground to line tripping the breaker.
It seems like everything is working fine and just the 24V power supply died so it will be an easy fix.
I guess for some reason (probably bad grounding) the RF ground potential was high enough to jump to the nearby line, how can I avoid that? Should I just leave everything floating so it doesn't happen again?
I will for sure find a way to improve the RF ground like using a metal mesh but now I'm scared of it happening again....
Re: Grounding issues...
« Reply #1 on: August 19, 2023, 08:34:51 PM »
Many builds include "Y" cap(s) from H-bridge power to ground.  That provides a path for any arcs that do manage to hit primary coil.  Not certain if that is your issue or not.
Yes, some form of counterpoise along ground/floor is good practice.  Aluminum foil works fine, though not as durable as other solutions.
Offline Manz
« Reply #2 on: August 19, 2023, 10:42:49 PM »
I'm thinking about buying some chicken wire to make a decently sized counterpoise (probably around 5 square meters) and I will also add the 100nF "Y" caps.
I still don't know if it's better to leave the power supplies floating or to connect the to RF ground like I did
« Reply #3 on: August 19, 2023, 11:19:11 PM »
My preference is to ground everything possible.  Any floating metal has the possibility of picking up electric field and then sparking to something.
BTW, last month after reworking a bit of my QCW coil, I forgot to connect ground to buck converter (which also grounds following H-bridge for coil primary).  After a bit of running, fried the 19.5V laptop supply that feeds buck converter and H-bridge gate drive circuitry.  Replaced that supply and connected ground and it runs fine.
« Last Edit: August 19, 2023, 11:30:51 PM by davekni »
Offline Manz
« Reply #4 on: August 20, 2023, 10:06:07 AM »
good to hear the power supply was the only damaged part.
Do you also connect the negative output of the power supply to RF-ground or just the shielding?
« Reply #5 on: August 20, 2023, 06:15:06 PM »
All grounds connect together for my coils.  Includes counterpoise, boxes for electronics, control supply (19.5V for most of mine) negative side.  Vbus- (H-bridge negative) is tied either through "Y" cap or directly to ground too.  I built an isolated PFC supply for Vbus for my normal DRSSTC and my QCW, so Vbus- can be grounded.
Offline Manz
« Reply #6 on: August 20, 2023, 06:49:41 PM »
Thank you for your insight I really appreciate it.
I'd like to hear if someone else had the same grounding problem I had with my coil and how they solved it
Online AstRii
« Reply #7 on: September 11, 2023, 08:36:52 PM »
Isn't the earth eventually connected with neutral in the fuse box? If you connect Vbus- directly to earth, aren't you shorting out a diode in the bridge rectifier?
Also, are you sure this is a good practice? Wouldn't it be better if driver is insulated from earth so that any ground strikes won't interfere with the circuit as much?
Bc. Marek Novotny
www.uhvlab.org
« Reply #8 on: September 12, 2023, 05:56:42 AM »
My coils are not typical.  I've built isolated "PFC" units to generate Vbus for my coils.  That way I can adjust Vbus without a Variac, and ground Vbus- for easy scoping.  (My largest Variac is 15A at 120V, not enough for larger coils.)  My isolated "PFC" units limit power to what line can handle (10kW for my 240Vac unit and 1.8kW for my 120Vac unit) including during initial bulk cap charging.
For normal coils, a Y cap is recommended between Vbus- and ground to handle any stray secondary current (arc to primary or just capacitive coupling).
Insulated from earth ground is fine as long as insignificant current manages to get from secondary to primary.  I prefer to protect from that, with a Y cap if using a conventional line bridge or voltage doubler.
Good questions.  Please feel free to challenge my reasoning here.
Online AstRii
« Reply #9 on: September 12, 2023, 06:11:44 PM »
Alright, that makes sense now.
You mean as during a primary strike? I agree at this point that the primary strike current must return back not to interfere or destroy transistors but wouldn't it be better to use Y cap to earth from one of the inverter outputs? Wouldn't that prevent stray currents to flow through IGBTs and limit the overvoltage caused by a primary strike?
I'm not sure if I'm competent yet for such task but in my experience having the driver not insulated from earth, causes EMI issues. For example, in one of my coils the UD+ driver's on board FPGA would "restart" everytime when the ground strike rail was hit.
« Last Edit: September 12, 2023, 06:13:25 PM by AstRii »
Bc. Marek Novotny
www.uhvlab.org
« Reply #10 on: September 14, 2023, 05:53:59 AM »
Y caps from inverter outputs might be better for primary strikes, but would inject high frequency noise into line ground and add capacitive load to H-bridge.  I think secondary current is generally low enough for IGBTs to handle.  The issue without Y caps to Vbus is that H-bridge voltage rises enough to break down GDT insulation.
First, yes, isolated electronics can work fine when shielded.
When grounded, as there any path through driver ECB ground?  In other words, was ground current likely to pass through driver?  For example, if driver power supply has a path back to line ground, perhaps a second ground connection is causing current through board.  Ideally board ground plane would handle that without causing any disruption, but ground planes are not perfect.
FPGAs are quite sensitive.  I use FPGAs regularly for interrupters and other optically-isolated purposes.  For these, FPGA board is grounded, but has no copper connection to power circuitry.  My only project with FPGA driver is my latest QCW coil.  FPGA board is grounded and adjacent H-bridge, isolated only by GDT insulation.
Thank you for sharing your experience.
Today at 07:21:13 PM
Manz
Today at 05:36:26 PM
Today at 05:32:57 PM
post Re: Is it beneficial to use a semi toroidal DRSSTC primary coil?
Today at 05:27:38 PM
Today at 05:11:00 PM
Today at 05:04:19 PM
post Re: What to drive this UY30 transformer?
Today at 02:18:49 PM
post Ramped SSTC build, some questions
Manz
Today at 02:10:57 PM
Today at 01:36:22 PM
post Brass vs Copper for spark gap?
Today at 01:03:25 PM
Today at 06:54:33 AM
post Is it beneficial to use a semi toroidal DRSSTC primary coil?
Today at 06:43:58 AM
post Re: 3kJ coin shrinking
Today at 04:45:06 AM
Lucasww
Today at 04:41:19 AM
Today at 03:23:29 AM
Lucasww
Today at 12:36:10 AM
post Rotary Spark Gap Arcing Not Sustained
tbbrune
September 24, 2023, 03:02:34 PM
post X-ray Image Scanner Teardown. Philips / Fujifilm PCR Eleva S (3 part series)
September 24, 2023, 01:14:03 PM
Lucasww
September 24, 2023, 09:57:24 AM
post Re: QCW problem with ZVS and phase lead (solved)
Didik8774
September 24, 2023, 06:23:39 AM
tatemac
September 24, 2023, 04:12:50 AM
September 24, 2023, 03:12:58 AM
post Re: Small UD3 Coil build log
September 23, 2023, 06:52:35 PM
Jhornel
September 23, 2023, 02:14:35 PM
Download
September 23, 2023, 04:52:28 AM
Lucasww
September 23, 2023, 02:11:05 AM
September 22, 2023, 10:22:28 PM
September 22, 2023, 09:51:07 PM
September 22, 2023, 09:20:18 PM
September 22, 2023, 07:53:07 PM
September 22, 2023, 07:43:55 PM
Download
September 22, 2023, 03:49:44 PM
post Re: Capacitors filter problem
September 22, 2023, 02:07:29 PM
Luca c.
September 22, 2023, 11:24:33 AM
Lucasww
September 22, 2023, 07:24:58 AM
post Re: Interrupter pulling ct signal
September 22, 2023, 06:26:32 AM
September 22, 2023, 06:05:35 AM
September 22, 2023, 05:51:59 AM
September 22, 2023, 05:40:29 AM
post Re: Benjamin's DRSSTC1
September 22, 2023, 05:28:53 AM
September 22, 2023, 05:22:04 AM
September 22, 2023, 05:14:26 AM
post Capacitors filter problem
September 22, 2023, 04:40:04 AM
post Re: What Cable Thickness for Capacitor Discharges?
September 22, 2023, 01:01:25 AM
September 21, 2023, 11:56:16 PM
post Re: Measuring electric voltage in a Tesla coil
September 21, 2023, 11:22:30 PM
September 21, 2023, 10:44:08 PM
post Phone sensor fusion demo
[Smart Phones]
September 21, 2023, 09:22:14 PM
omrid13
September 21, 2023, 08:54:31 PM
September 21, 2023, 08:41:31 PM
September 21, 2023, 08:10:53 PM
post Re: Magnifier tesla coil
Hysteresis
September 21, 2023, 08:06:32 PM
September 21, 2023, 07:48:53 PM
post Re: Rotary SG, Gap Distance Vs Performance ?
Hysteresis
September 21, 2023, 07:48:22 PM
September 21, 2023, 07:23:34 PM
post Re: LLC resonant converters (Why the second inductor?)
September 21, 2023, 05:20:33 PM
IonWind
September 21, 2023, 04:49:15 PM
September 21, 2023, 04:02:06 PM
post Nice little flybacks for the price
IonWind
September 21, 2023, 11:12:29 AM
September 21, 2023, 09:34:12 AM
post LLC resonant converters (Why the second inductor?)
September 21, 2023, 09:29:56 AM
Lucasww
September 21, 2023, 09:23:30 AM
September 21, 2023, 05:59:38 AM
September 21, 2023, 04:55:53 AM
post Re: Varying the Coulomb Potential of Metal Tube. MOT secondary flashover.
Luca c.
September 20, 2023, 11:03:21 PM
September 20, 2023, 09:01:50 PM
RoamingD
September 20, 2023, 04:39:36 PM
September 20, 2023, 07:34:07 AM
September 20, 2023, 06:05:54 AM
RoamingD
September 20, 2023, 05:51:18 AM
September 20, 2023, 05:49:15 AM
September 20, 2023, 05:24:44 AM
September 20, 2023, 05:07:10 AM
RoamingD
September 19, 2023, 10:02:13 PM
post Re: First drsstc issues
Hari33
September 19, 2023, 09:18:47 PM
September 19, 2023, 09:10:06 PM
RoamingD
September 19, 2023, 08:53:11 PM
September 19, 2023, 08:46:36 PM
post Re: Inverter question
September 19, 2023, 08:44:54 PM
September 19, 2023, 08:18:38 PM
post First drsstc issues
Hari33
September 19, 2023, 07:39:42 PM
post UD2.7Cs for sale
All Science
September 19, 2023, 07:06:39 PM
RoamingD
September 19, 2023, 03:57:15 PM
September 19, 2023, 03:48:23 PM
September 19, 2023, 03:33:06 PM
post What to drive this UY30 transformer?
September 19, 2023, 09:06:16 AM
RoamingD
September 19, 2023, 07:53:34 AM
omrid13
September 19, 2023, 07:14:57 AM
September 19, 2023, 06:29:00 AM
September 19, 2023, 06:15:40 AM
September 19, 2023, 05:56:13 AM
September 19, 2023, 05:05:57 AM
post Re: Migatronic FocusStick 161E Stick Welder Teardown
orac
September 19, 2023, 04:52:30 AM
post Re: Part identification for a Esab Es300i renegade Machine
orac
September 19, 2023, 04:48:02 AM
orac
September 19, 2023, 04:29:14 AM
post Measuring electric voltage in a Tesla coil
omrid13
September 19, 2023, 01:14:00 AM
post Re: First sstc is not working
September 19, 2023, 12:59:52 AM
September 19, 2023, 12:45:37 AM
September 18, 2023, 11:16:41 PM
September 18, 2023, 09:55:08 PM
