Author Topic: First sstc is not working  (Read 1676 times)
Re: First sstc is not working
« Reply #20 on: September 11, 2023, 01:30:24 AM »
he circuit I made is not working properly. I have been dealing with this for about 3 months.
It only works when I touch the interrupter with one hand and bring my other hand closer to the coil.i think i will copy another design
Sounds disappointing!  Sometimes starting over is the easiest.  However, I don't think there is any inherent issue with the circuit you are using.  Now that you have a scope, debugging should be possible.  It will take some time to step through the circuit scoping signals at each point.  If you want to continue, I'd suggest testing entirely in interrupted mode with duty cycle set low.  That minimizes risk of part damage as average power remains low.
« Reply #21 on: September 11, 2023, 12:20:34 PM »
Sounds like you need to find the fault in the feedback circuit. The gain is not high enough, there must be some faulty or wrong component. You are basically acting as a large antenna and amplifier, when you can make it work by touching it.
I have also started over completely on some projects, it happens to all of us, do not loose hope :)
The schematic seems to be a run of the mill version of Steve Wards Mini SSTC, which is really one of the simplest to get running, I would recommend to still go with that schematic. I built 3 of them myself: https://kaizerpowerelectronics.dk/tesla-coils/kaizer-sstc-i/ and https://kaizerpowerelectronics.dk/tesla-coils/kaizer-sstc-ii/ and https://kaizerpowerelectronics.dk/tesla-coils/kaizer-sstc-iii/
Offline NyaaX_X
« Reply #22 on: September 11, 2023, 03:53:38 PM »
My half-bridge SSTC is still been tested too. My experiences may not be helpful.  ::)
The wiring might be as short as possible. But the primary coil leads be stranded and make the tesla coil tower far away from your driver at least about 15cm (for me) might be better. And away from interrupter like 30cm up and make the interrupter connect to power V- or ground. I saw many people put all the circuit under the tower but their circuit might be finished. And that position seems also have low EMI.
The unuse "input" pins of 74HC14 are better to be connected to ground or 5V.
And you can make a 200k ~ 500k Hz oscillator with ~50% dutycycle 5V squarewave output directly go into UCC "in" pin and catch the GDT waveforms with oscilloscope. I think here do not have to  power the half-bridge power stage while testing.  To test if your half-bridge driver working fine. (Also maybe disable the interrupter so driver run in CW mode. Watch out the UCC temperature)
Online Recep talip
« Reply #23 on: September 11, 2023, 06:50:50 PM »
Thank you all. I'll fix the feedback section soon and fix other issues. thank you all  for inspiring me
I will follow all your advice,
Online Recep talip
« Reply #24 on: September 16, 2023, 09:28:50 PM »
 :) hello again i'm back with more problems. I rebuilt the driver circuit, and I changed the UCCs and 74hc14 and to test gdt I  bought a signal genenator  8)
N30 material 10 turn CAT5 wire
driver output
interrupter output
my first problem is: a ringing comes from the bridge and comes a tittle from gdt. Trying to reduce the number of turns of the primer didn't help.I changed the direction of the primer but nothing changed.
all unused pins of 74hc14 connected to gnd. bus voltage is 80v dc   I still can't get this project working.
« Last Edit: September 16, 2023, 09:32:28 PM by Recep talip »
« Reply #25 on: September 17, 2023, 05:29:59 AM »
Only unused inputs should be connected to ground.  Leave unused outputs unconnected.  With inputs grounded, outputs will be high.  Grounding them will short outputs and make 74HC14 chip get hot.
interrupter output
I'd suggest testing at much lower duty cycle than shown 50%.  Reduces risk of something burning out.
Then scope GDT inputs (driver outputs) while trying to run in feedback mode.    Scope antenna too.  These scope traces should give some idea of what the issue may be.
Online Recep talip
« Reply #26 on: September 17, 2023, 11:24:49 AM »
yes that's how i did it
Ringing coming from primary and gdt in interrupter mode
No output in CW mode,touching the antenna did not work. This is the signal on the input pins of the uccs
« Last Edit: September 17, 2023, 11:26:38 AM by Recep talip »
Offline NyaaX_X
« Reply #27 on: September 17, 2023, 06:05:59 PM »
If there are mistakes in my saying please check and correct them for safety, thank you very much
Here I have a few questions. Where do you connect your secondary coil ground to? A big piece metal or something else? And how much is the k-factor in your coil. The javaTC might help you to calculate the parameters of tesla coil. Sorry for I don't know how to use it.. Here is the url https://www.classictesla.com/java/javatc/javatc.html . And in your post the "driver output" 80V waveform seems to be measured from the half bridge? without secondary? If that's right I think the GDT is working. Maybe you can catch a VGS waveform and post it in the future. Here I don't recommend you probe your live wire connected circuit with a non-isolated oscilloscope. And the ringing may caused by the parasitic inductors and oscillation. You have to optimize your power stage wiring and also can add a capacitor between Vbus +- near your half-bridge transistors as near as possible to  absorb some switching ringing.
And you can also read about Steve ward's articles like https://www.stevehv.4hv.org/SSTC5.htm or the transformer feedback type from the left-up side of
https://www.stevehv.4hv.org/DRSSTC.5.htm, you can ignore the JK flip-flop part, focus on the 74HC14 and current transformer part. I'm shocked you buy a function generator.. But not bad if you like to play with electronics and you have enough resource  :)
Pay attention while playing with AC live wire...
« Last Edit: September 17, 2023, 06:20:18 PM by NyaaX_X »
« Reply #28 on: September 18, 2023, 06:07:25 AM »
That looks like a great 671kHz square wave.  As NyaaX_X said, JavaTC can tell you if that is expected frequency for your secondary and top load.  If so, then coil is running, just without enough power.  If JavaTC indicates a lower frequency, then the antenna is picking up the wrong signal and/or phase is inverted.
Online Recep talip
« Reply #29 on: September 18, 2023, 07:47:21 PM »
 :) Hello again, I'm back with some good results
I connect the secondary to the building ground line. there is a bus cap 1500uf 450v
when it started to work at first, the length of the arcs was short, I set the primary as 4 turns and it looks like this at 80v dc. but the coil sometimes doesn't work when playing with the interrupter.
the coil  not working in CW mode. I think what Davekni said is not true for my 671khz coil
 I will review and share when I have time
I am grateful for your help, thank you all
I don't know much about how to use javatc. need to do some research
« Last Edit: September 18, 2023, 08:03:58 PM by Recep talip »
Offline NyaaX_X
« Reply #30 on: September 19, 2023, 12:59:52 AM »
So how do you get that 631kHz? Feedback form coil or function generator?
If you want to boost up the Vbus voltage then you might have to decrease the ringing on your power stage half bridge.  8)
Today at 07:21:13 PM
Manz
Today at 05:36:26 PM
Today at 05:32:57 PM
post Re: Is it beneficial to use a semi toroidal DRSSTC primary coil?
Today at 05:27:38 PM
Today at 05:11:00 PM
Today at 05:04:19 PM
post Re: What to drive this UY30 transformer?
Today at 02:18:49 PM
post Ramped SSTC build, some questions
Manz
Today at 02:10:57 PM
Today at 01:36:22 PM
post Brass vs Copper for spark gap?
Today at 01:03:25 PM
Today at 06:54:33 AM
post Is it beneficial to use a semi toroidal DRSSTC primary coil?
Today at 06:43:58 AM
post Re: 3kJ coin shrinking
Today at 04:45:06 AM
Lucasww
Today at 04:41:19 AM
Today at 03:23:29 AM
Lucasww
Today at 12:36:10 AM
post Rotary Spark Gap Arcing Not Sustained
tbbrune
September 24, 2023, 03:02:34 PM
post X-ray Image Scanner Teardown. Philips / Fujifilm PCR Eleva S (3 part series)
September 24, 2023, 01:14:03 PM
Lucasww
September 24, 2023, 09:57:24 AM
post Re: QCW problem with ZVS and phase lead (solved)
Didik8774
September 24, 2023, 06:23:39 AM
tatemac
September 24, 2023, 04:12:50 AM
September 24, 2023, 03:12:58 AM
post Re: Small UD3 Coil build log
September 23, 2023, 06:52:35 PM
Jhornel
September 23, 2023, 02:14:35 PM
Download
September 23, 2023, 04:52:28 AM
Lucasww
September 23, 2023, 02:11:05 AM
September 22, 2023, 10:22:28 PM
September 22, 2023, 09:51:07 PM
September 22, 2023, 09:20:18 PM
September 22, 2023, 07:53:07 PM
September 22, 2023, 07:43:55 PM
Download
September 22, 2023, 03:49:44 PM
post Re: Capacitors filter problem
September 22, 2023, 02:07:29 PM
Luca c.
September 22, 2023, 11:24:33 AM
Lucasww
September 22, 2023, 07:24:58 AM
post Re: Interrupter pulling ct signal
September 22, 2023, 06:26:32 AM
September 22, 2023, 06:05:35 AM
September 22, 2023, 05:51:59 AM
September 22, 2023, 05:40:29 AM
post Re: Benjamin's DRSSTC1
September 22, 2023, 05:28:53 AM
September 22, 2023, 05:22:04 AM
September 22, 2023, 05:14:26 AM
post Capacitors filter problem
September 22, 2023, 04:40:04 AM
post Re: What Cable Thickness for Capacitor Discharges?
September 22, 2023, 01:01:25 AM
September 21, 2023, 11:56:16 PM
post Re: Measuring electric voltage in a Tesla coil
September 21, 2023, 11:22:30 PM
September 21, 2023, 10:44:08 PM
post Phone sensor fusion demo
[Smart Phones]
September 21, 2023, 09:22:14 PM
omrid13
September 21, 2023, 08:54:31 PM
September 21, 2023, 08:41:31 PM
September 21, 2023, 08:10:53 PM
post Re: Magnifier tesla coil
Hysteresis
September 21, 2023, 08:06:32 PM
September 21, 2023, 07:48:53 PM
post Re: Rotary SG, Gap Distance Vs Performance ?
Hysteresis
September 21, 2023, 07:48:22 PM
September 21, 2023, 07:23:34 PM
post Re: LLC resonant converters (Why the second inductor?)
September 21, 2023, 05:20:33 PM
IonWind
September 21, 2023, 04:49:15 PM
September 21, 2023, 04:02:06 PM
post Nice little flybacks for the price
IonWind
September 21, 2023, 11:12:29 AM
September 21, 2023, 09:34:12 AM
post LLC resonant converters (Why the second inductor?)
September 21, 2023, 09:29:56 AM
Lucasww
September 21, 2023, 09:23:30 AM
September 21, 2023, 05:59:38 AM
September 21, 2023, 04:55:53 AM
post Re: Varying the Coulomb Potential of Metal Tube. MOT secondary flashover.
Luca c.
September 20, 2023, 11:03:21 PM
September 20, 2023, 09:01:50 PM
RoamingD
September 20, 2023, 04:39:36 PM
September 20, 2023, 07:34:07 AM
September 20, 2023, 06:05:54 AM
RoamingD
September 20, 2023, 05:51:18 AM
September 20, 2023, 05:49:15 AM
September 20, 2023, 05:24:44 AM
September 20, 2023, 05:07:10 AM
RoamingD
September 19, 2023, 10:02:13 PM
post Re: First drsstc issues
Hari33
September 19, 2023, 09:18:47 PM
September 19, 2023, 09:10:06 PM
RoamingD
September 19, 2023, 08:53:11 PM
September 19, 2023, 08:46:36 PM
post Re: Inverter question
September 19, 2023, 08:44:54 PM
September 19, 2023, 08:18:38 PM
post First drsstc issues
Hari33
September 19, 2023, 07:39:42 PM
post UD2.7Cs for sale
All Science
September 19, 2023, 07:06:39 PM
RoamingD
September 19, 2023, 03:57:15 PM
September 19, 2023, 03:48:23 PM
September 19, 2023, 03:33:06 PM
post What to drive this UY30 transformer?
September 19, 2023, 09:06:16 AM
RoamingD
September 19, 2023, 07:53:34 AM
omrid13
September 19, 2023, 07:14:57 AM
September 19, 2023, 06:29:00 AM
September 19, 2023, 06:15:40 AM
September 19, 2023, 05:56:13 AM
September 19, 2023, 05:05:57 AM
post Re: Migatronic FocusStick 161E Stick Welder Teardown
orac
September 19, 2023, 04:52:30 AM
post Re: Part identification for a Esab Es300i renegade Machine
orac
September 19, 2023, 04:48:02 AM
orac
September 19, 2023, 04:29:14 AM
post Measuring electric voltage in a Tesla coil
omrid13
September 19, 2023, 01:14:00 AM
post Re: First sstc is not working
September 19, 2023, 12:45:37 AM
September 18, 2023, 11:16:41 PM
September 18, 2023, 09:55:08 PM
