Author Topic: First sstc is not working  (Read 1596 times)
Offline Recep talip
« on: June 18, 2023, 03:42:54 PM »
hello my name is Recep, first sorry for my english  ,https://www.vn-experimenty.eu/teslov-transformator/sstc/sstc-3.html I am trying to copy this coil
 I have been dealing with this project for a while, but it is not working. UCCs are always on fire. I bought them from china.
I ordered some parts from the mouser, but I haven't received it yet.
I couldn't test the GDT because I don't have an oscilloscope material N30 cat5wire
where could the error be?
« Last Edit: June 18, 2023, 03:45:00 PM by Recep talip »
Offline ZakW
Re: First sstc is not working
« Reply #1 on: June 18, 2023, 08:22:45 PM »
Hello Recep, welcome!
Your English is fine :D
Thank you for the included schematic and pictures. Troubleshooting without an oscilloscope can be difficult.
Some Ideas:
  • First thing that comes to mind is counterfeit UCC gate drive chips. I know several other users have had issues with them. From what I have read the ENABLE pin does not work on them. This might lead to the driver running uninterrupted which could stress them a lot leading to excess heating.
  • 15v gate drive might be a bit high for MOSFETs, you could overvolt/damage them
  • It is hard to tell from the pictures, are the MOSFETs on separate pads to insulated them from the heatsink? If not, they can be shorted.
  • How have you been testing the coil? Are you only powering up the driver and it gets hot?
  • You said it is not working, have you seen any output from the coil at all?
  • Do you hear any clicking or chirping from the GDT when the interrupter is running? That could be an indication the ENABLE pin is working.
Your GDT looks nicely done. From what I have seen the schematic looks pretty standard, I hope you have better results with your parts from Mouser.
Offline Recep talip
« Reply #2 on: June 18, 2023, 08:39:30 PM »
Thank you for your answer.  bus voltage 24v
yes my UCC they get warm after a little bit of work
There is thermal paste between the heatsink and the mosfet. pad is safer, i will replace it
there is no output from the coil I am testing with a fluorescent lamb
There was a ringing at first but after the uccs burned out, I replaced them with new ones. It doesn't respond at all anymore.
« Last Edit: June 18, 2023, 08:44:20 PM by Recep talip »
Offline ZakW
« Reply #3 on: June 18, 2023, 10:36:11 PM »
If they are not getting really hot in a short amount of time that could be a good sign. Still not ideal, but as long as they are not rapidly heating and smoking. If they are outputting constantly at a high frequency that can lead to them warming up. That is why I mentioned the enable pin might not be functioning properly causing them to output all the time.
Is the bridge drawing any power? Do your MOSFETs heat up?
I don't think thermal paste is sufficient insultation, at least not that I have heard of. This could be a separate issue. Best practice is to use pads or separate heatsinks.
A ringing sound could be a sign of high frequency gate drive (causing heating), at lower frequencies (BPS) there should be a clicking sound from the GDT that matches the output of the interrupter.
Throughout your testing, as long as nothing is burning up try flipping the primary output around to check if the phase is backwards.
Do you have an LED on the interrupter to see if it is outputting a pulse like it should be?
Offline NyaaX_X
« Reply #4 on: June 19, 2023, 11:08:17 AM »
I'm not a expert. So please check and listen to others answers. Sorry for my english too.
For a antenna feedback halfbridge tesla coil. I don't know if 24V bus voltage on halfbridge power stage is high enough to create suitable field to transfer into the circuit.
I see there is a 74hc14 schmitt oscillator for starting up. But it's may output a signal way higher then your coil resonant frequency. If the antenna didn't catch enough power to feedback the oscillation the UCCs will work in too high frequency. And if the "enable" not working in the same time. The UCCs would burn hot. Check if the "enable" is working and tune the "10k" potentiometer let the frequency close to your coil (well you don't have a oscilloscope...). By the way according to others experience it's better to connect the not using input pin of 74HC14 to gnd or VCC.
And I see there're something like voltage regulators? I don't ever use them to power the UCCs cause the output current are usually 1A max. Although there're few 1000uF capacitors. So I don't know if thet're good enough in this using.
« Last Edit: June 19, 2023, 02:42:47 PM by NyaaX_X »
Offline ZakW
« Reply #5 on: June 19, 2023, 07:25:10 PM »
My understanding is that gate drive chips like the UCC's don't require large amounts of constant current. Instead they output short high current pulses that are sustained by adequate bypass capacitance. The UCC37XX chips can output 9A peak but don't draw 9 amps from the supply. My driver powering an IGBT half bridge (UCC27425 4A ouput) only draws about 30-40mA during operation.
Source: https://highvoltageforum.net/index.php?topic=1903.msg14206#msg14206
UCC output stage is a bipolar/MOS combination.  Output impedance is much higher close to supply rails than would be implied by 9A peak current.
Additional bypass capacitance at the UCC chips is always a good idea, especially with breadboard construction (no ground or power planes).  I'd suggest at least 0.47uF at each driver chip.  (1uF electrolytic capacitors likely have too high ESR, so likely need to be larger if electrolytic.)
I suspect the two 100uf caps in the schematic do little to supply current for the UCC chips.
Offline Recep talip
« Reply #6 on: July 08, 2023, 05:21:05 PM »
Hello again
i tried with new ucc's There is a ringing sound from gdt but no arc, bus voltage is 100V ,I reversed the primary, nothing changed
Offline ZakW
« Reply #7 on: July 08, 2023, 10:53:15 PM »
Sorry to hear that it is still not working. Remember when testing the coil, always turn the driver on first and then the bridge.
  • Does the bridge draw any current at 100v?
  • Can you test the MOSFETs with a multimeter to make sure they are not damaged?
  • If the MOSFETs are okay, can you double check GDT phasing is correct?
  • Have you tried adjusting how close the antenna is to the coil?
Offline Recep talip
« Reply #8 on: July 12, 2023, 07:48:43 PM »
Hello again. new uccs arrived. I noticed a few errors in the bridge and fixed it now it works.
but for some reason, a fluorescent bulb barely burns at 100v dc. there are no arcs. How can I fix
Offline ZakW
« Reply #9 on: July 12, 2023, 11:00:13 PM »
Hello, glad to hear you got it working!
Try flipping the primary phase again, you might have it backwards. Also, I counted 10 or so primary turns. You can try removing a turn or two to see if that helps once the phase is correct.
You might want to bend a small loop or curve the tip of your antenna to help reduce corona build up and limit the likelihood of arcs hitting it.
Nice work!
Offline Recep talip
« Reply #10 on: July 14, 2023, 08:06:12 PM »
coil is not working CW mode. what could be the problem?
Offline ZakW
« Reply #11 on: July 14, 2023, 08:16:37 PM »
Is the coil working with the interrupter at least? I am not sure if you got that portion working at this point or not.
When you switch off the interrupter and you have it in CW mode does the output stop? What is happening when "it is not working". Are the UCC's getting hot in CW mode?
Some additional information will hopefully help figure out what is going on.
Offline Recep talip
« Reply #12 on: July 14, 2023, 08:22:41 PM »
coil is working with interrupter, At 100v dc, only fluorescent bulb lights up, no arcs
nothing happens when i switch to cw mode while working with interrupter
ucc's not warming up
Offline ZakW
« Reply #13 on: July 14, 2023, 08:26:35 PM »
Two things:
1. Just to be clear, you are getting an output with the interrupter at 100v? Sparks are forming at the breakout point, right?
2. When you switch from the interrupter to CW mode that is when there is no output but only the fluorescent bulb lights up?
Offline Recep talip
« Reply #14 on: July 14, 2023, 08:28:46 PM »
1: No arc, just fluorescent bulb lights up
2: nothing happens
Offline ZakW
« Reply #15 on: July 14, 2023, 08:36:39 PM »
Got it, thanks for that. I misunderstood and thought you were getting sparks with the output.
I think your best bet is to get the coil working first with the interrupter. CW mode stresses a lot of components and can easily kill your coil.
Have you tried to disconnect the startup portion or your driver and just use the antenna? I wonder if your coil is not switching over to the antenna feedback once the coil starts running.
Offline NyaaX_X
« Reply #16 on: July 15, 2023, 04:38:20 PM »
As always. We recommend to cover the driver part with grounded faraday cage (or aluminium foil) to avoid the EMF bothering them . And if you have a oscilloscope . Maybe you can check the driver waveform without powering up the power bridge stage first . And if running this circuit in CW mode under higher frequency . The gate driver IC and gate resistors may be heating up . Notice that .
Offline Recep talip
« Reply #17 on: August 31, 2023, 08:15:05 PM »
Hello :)  again ı have a some result,but ı have a lot of problem again
anymore ı have an oscilloscope
+My first problem is that when I put one hand on the output of the interrupter and bring my other hand close to the coil, it works.normally there is just a sizzle
mosfet gate signal
driver output
« Reply #18 on: September 01, 2023, 10:41:10 PM »
Hello :)  again ı have a some result,but ı have a lot of problem again anymore ı have an oscilloscope
Great that you have a scope now!  That will be very helpful.  Likely worth reading more about scope use and probing techniques.
For almost all uses, avoid 1x probes.  Don't use 1x setting on switchable probes.  Bandwidth is low and signal loading high.
Adjust probe compensation using scope's square wave test signal output (provided for that purpose).  Read your scope and probe manuals to learn how.  Search internet if manuals aren't clear.
Connect scope probe ground clip close to signal being measured.  Of course, if probing half-bridge, use a bench supply or isolation transformer to power coil.  Never ground to non-isolated line voltage.
Set vertical channels for DC-coupled, not AC coupled.  (This is separate from trigger coupling mode.)  Looks like you are doing this already.
If there are still issues, pictures of scope probe connection will help.
« Last Edit: September 01, 2023, 10:43:53 PM by davekni »
Offline Recep talip
« Reply #19 on: September 10, 2023, 08:02:42 PM »
I'm sorry for the late reply
The circuit I made is not working properly. I have been dealing with this for about 3 months.
It only works when I touch the interrupter with one hand and bring my other hand closer to the coil.i think i will copy another design
Today at 06:52:35 PM
Jhornel
Today at 02:14:35 PM
Today at 04:52:28 AM
Today at 02:11:05 AM
post Re: Benjamin's DRSSTC1
post Phone sensor fusion demo
omrid13
post Re: Magnifier tesla coil
post Re: Inverter question
post First drsstc issues
post UD2.7Cs for sale
All Science
omrid13
orac
orac
orac
omrid13
Recep talip
All Science
post Drsstc feedback startup
ako
ako
Recep talip
Recep talip
