Author Topic: Half-Bridge SSTC Failed  (Read 2726 times)
Re: Half-Bridge SSTC Failed
« Reply #20 on: May 24, 2023, 03:46:37 AM »
Or I just use Fast recovery rectifier diode to replace those schottkys ?
That should work well.  Or TVS diodes across schottkys.  Whatever is easiest for you.
Offline NyaaX_X
« Reply #21 on: May 25, 2023, 05:17:49 AM »
OK Thank you Dave ~ Then I go in this way keep simulating
« Last Edit: May 25, 2023, 05:19:59 AM by NyaaX_X »
Offline NyaaX_X
« Reply #22 on: May 25, 2023, 01:49:04 PM »
Here I want to build a simple bridge rectifier. But I see that if I place a extra electrolytic capacitor parallel to two bridge polarized electrolytic capacitors, there will be some reverse current flow into them (bridge capacitors). But the voltage is still positive cross them. Is that harmful to the electrolytic capacitors?
« Last Edit: May 25, 2023, 02:22:53 PM by NyaaX_X »
« Reply #23 on: May 25, 2023, 07:34:15 PM »
I don't think this forum is an appropriate place for basic electronics questions.  However, I'll provide a hint to this one:  Consider any capacitor, electrolytic or not.  What would happen if current was always one polarity?  Try that in simulation.
Offline NyaaX_X
« Reply #24 on: May 26, 2023, 07:36:10 AM »
My fault . Stupid question stuck my brain... Yes charging and discharging current in capacitors are in two direction. I was thinking why my two capacitor getting hot after mosfets died. Those two capacitor is always push and pull a high value of current before I cutdown the power supply? I guess.
Here my question is turning into "if 200V polarized capacitors misconnected to 125V AC for few seconds. There's some chance won't break those capacitors?"
« Last Edit: May 26, 2023, 08:26:58 AM by NyaaX_X »
« Reply #25 on: May 26, 2023, 06:58:41 PM »
Simulate that circuit, just the AC input diodes and caps, with a shorted load.  Check capacitor voltages and currents.
125Vac for long will cause the capacitors to physically explode due to internal steam generation.  For shorter durations, capacitor will likely degrade, especially with higher ESR than before, and perhaps higher leakage current.
Offline NyaaX_X
« Reply #26 on: May 27, 2023, 04:09:09 AM »
Thank you Dave for keep replying my low level questions. Wish you always have a nice day.
I have simulated that so I wondering why they didn't blow up, or even nothing blow up. I expected mosfets or this two capacitor will crack or smoking but the only thing was a hissing sound then I cut the power. The value of capacitors do not change. Maybe the ESR will increase after the accident? I don't have implement to measure this. According to there're something heating I think I was lucky that cutting the power before anything blow up?
« Reply #27 on: May 30, 2023, 02:04:44 AM »
Hissing sound was probably from electrolytic capacitors venting steam.  Electrolytic capacitors are usually designed to have an intentional weak spot in the case top or bottom seal, something that will break open and vent steam to avoid explosion.  If you had left power applied, steam might have been generated too fast for the vent and made an explosion.  If my guess is correct about venting, ESR will be higher.  ESR will likely continue to rise over time unless vent self-seals again after venting.  Many don't reseal.
Offline NyaaX_X
« Reply #28 on: May 30, 2023, 04:14:20 AM »
The only things broken are mosfets, and I can't confirm which component is heating. Sorry for wasting your time. I will take care of that next time. But I think I will make half-bridge and power supply separately.
By the way here I post some images of my layout of the half bridge. Maybe give me some advices if have time~ Thank you very much.
« Last Edit: May 30, 2023, 04:26:17 AM by NyaaX_X »
« Reply #29 on: May 30, 2023, 04:28:11 AM »
Do you have a second ECB layer for ground plane?  Two-layer ECBs can have much lower parasitic inductance compared to single-layer ECBs, presuming reasonable layout.  May be sufficient exactly as is.  Adding a ground plane (plane connected to - supply (or + supply) would be a big improvement.
Offline NyaaX_X
« Reply #30 on: May 30, 2023, 04:54:19 AM »
Wow OK here I only draw one layer. I was thinking to make two same shape layput in two layout. So now I may create the other layout cover with power + -. Maybe the upper half with negtive and lower with postive? According to my image.
« Last Edit: May 30, 2023, 05:09:51 AM by NyaaX_X »
« Reply #31 on: June 01, 2023, 04:21:42 AM »
Rather, I was suggesting that the other layer be only one supply voltage or the other, not both.  And cover the entire other layer (obviously with clearance for through-holes).
Offline NyaaX_X
« Reply #32 on: June 01, 2023, 07:41:02 AM »
OK I connect it with power supply (-) but I don't know which is better for my gate signal and protection.
« Reply #33 on: June 01, 2023, 07:39:52 PM »
Your second image is best.  To be a perfectionist like me, you could remove a tiny bit of the Vbus- plane under high-side IGBT gate trace.  That is the only place where parasitic capacitance to Vbus- could be an issue.  Low-side gate is referenced to Vbus- (low side emitter), so Vbus- plane under there is good.
Offline NyaaX_X
« Reply #34 on: June 02, 2023, 04:19:51 AM »
Well... My bad. I love a symmetry one. So I make two new case of it.
« Reply #35 on: June 02, 2023, 05:20:44 AM »
Either will be fine.  Circuit itself is not symmetric.  IGBTs are not complimentary (not like one PFET and one NFET).  That is why ideal layout is not symmetric.
Offline NyaaX_X
« Reply #36 on: June 02, 2023, 05:52:52 AM »
I will use MOSFET.. what do that mean "complimentary" I have no idea.
« Reply #37 on: June 02, 2023, 06:34:00 PM »
I am not recommending changing to FETs.  Even if you did change, N-channel MOSFETs (NFETs) have better specifications than their compliments, PFETs.  So most H-bridges that do use FETs use all NFETs, so are just as asymmetric as IGBT H-bridges.
BTW, look at typical DRSSTC drivers such as UD2.7.  The final stage driving GDT is complimentary, pairs of one NFET and one PFET for each GDT primary lead.
Offline NyaaX_X
« Reply #38 on: June 03, 2023, 04:40:21 AM »
Sorry maybe I didn't express clearly. I am makeing a simple N-mosfet half bridge single resonant SSTC. And the frequency will be too high for IGBTs.. The "symmetric" is about the ECB shape.. Not for circuit like pmos nmos inverter or something. If I exposure two pair of GDT to mosfet wiring from Vbus ECB covering. Will the leakage inductance like that make a trouble?
« Reply #39 on: June 03, 2023, 06:24:39 AM »
Probably fine.  I'm just a perfectionist, so try to optimize everything.
October 03, 2023, 10:32:16 PM
post How do you measure HV current?
nsled
October 03, 2023, 10:09:13 PM
October 03, 2023, 07:36:37 PM
post NTC question
October 03, 2023, 07:24:34 PM
October 03, 2023, 06:40:29 PM
post Re: First SSTC
October 03, 2023, 11:15:40 AM
post Re: Pole pigs in Australia (Europe?) vs North America
October 03, 2023, 10:45:59 AM
October 03, 2023, 09:40:15 AM
post Re: Driverless DRSSTC Interruption
October 03, 2023, 08:28:01 AM
October 03, 2023, 08:21:23 AM
post Re: First SSTC
October 03, 2023, 06:23:45 AM
post Re: First SSTC
October 03, 2023, 06:16:23 AM
post Re: cw sstc build advise (parameters)
October 03, 2023, 05:17:47 AM
October 03, 2023, 05:14:06 AM
October 03, 2023, 05:13:00 AM
October 03, 2023, 04:30:32 AM
post Re: Rotary Spark Gap Arcing Not Sustained
October 03, 2023, 03:07:31 AM
October 03, 2023, 02:53:26 AM
post First SSTC
blahaj
October 03, 2023, 02:24:27 AM
October 02, 2023, 09:56:41 PM
October 02, 2023, 06:00:47 PM
October 02, 2023, 03:59:17 PM
October 02, 2023, 06:09:09 AM
post Pole pigs in Australia (Europe?) vs North America
October 02, 2023, 05:32:52 AM
October 02, 2023, 05:30:43 AM
tbbrune
October 02, 2023, 05:16:37 AM
October 02, 2023, 05:11:57 AM
October 02, 2023, 04:53:08 AM
tbbrune
October 02, 2023, 04:39:17 AM
October 02, 2023, 03:01:58 AM
tbbrune
October 02, 2023, 01:15:24 AM
post RDRSSTC - Project Build
October 01, 2023, 11:01:03 PM
post Re: 3kJ coin shrinking
October 01, 2023, 07:32:22 PM
October 01, 2023, 07:23:35 PM
October 01, 2023, 07:14:40 PM
October 01, 2023, 04:54:44 PM
MechatEng2023
October 01, 2023, 04:52:09 PM
October 01, 2023, 04:35:41 PM
post Re: can't get enough power out of high voltage generator
October 01, 2023, 01:54:43 PM
October 01, 2023, 06:51:33 AM
October 01, 2023, 06:44:40 AM
October 01, 2023, 05:33:53 AM
post Driverless DRSSTC Interruption
ARCreator
October 01, 2023, 04:58:52 AM
post 40kW X-ray Machine (Huge XRT Arcs, Tube Autopsy, Mods, etc.) Part 2 video
breezetix
October 01, 2023, 01:55:15 AM
tbbrune
October 01, 2023, 12:12:39 AM
September 30, 2023, 11:18:29 PM
September 30, 2023, 10:01:31 PM
September 30, 2023, 09:48:42 PM
September 30, 2023, 09:31:43 PM
September 30, 2023, 09:23:25 PM
September 30, 2023, 09:13:37 PM
post Re: Question about center tap autotransformer
September 30, 2023, 07:20:35 PM
September 30, 2023, 06:59:36 PM
tbbrune
September 30, 2023, 04:45:23 PM
post Re: A DIY Flame gun
September 30, 2023, 03:24:23 PM
post Re: Interesting IGBT failure
September 30, 2023, 11:58:45 AM
September 30, 2023, 08:26:40 AM
September 30, 2023, 07:32:22 AM
September 30, 2023, 06:23:14 AM
post Question about center tap autotransformer
christianrodher
September 30, 2023, 05:11:00 AM
post cw sstc build advise (parameters)
September 30, 2023, 04:46:02 AM
September 30, 2023, 04:20:20 AM
September 30, 2023, 03:12:12 AM
post Re: GDT (Gate Drive Transformer) tutorial
September 30, 2023, 02:42:02 AM
September 30, 2023, 01:43:06 AM
post Re: Heatsink grounding
September 30, 2023, 01:20:27 AM
September 30, 2023, 12:32:30 AM
September 30, 2023, 12:06:24 AM
September 29, 2023, 09:35:21 PM
September 29, 2023, 09:00:54 PM
September 29, 2023, 07:15:19 PM
post Heatsink grounding
September 29, 2023, 04:33:32 PM
September 29, 2023, 04:20:52 PM
post Aliexpress Mystery Driver
September 29, 2023, 04:15:30 PM
September 29, 2023, 01:43:46 PM
post Interesting IGBT failure
September 29, 2023, 10:56:54 AM
September 29, 2023, 09:55:11 AM
September 29, 2023, 05:49:38 AM
September 29, 2023, 12:30:30 AM
September 28, 2023, 11:01:20 PM
September 28, 2023, 10:33:46 PM
September 28, 2023, 09:40:55 PM
post A DIY Flame gun
September 28, 2023, 08:57:30 PM
post Re: Ramped SSTC build, some questions
September 28, 2023, 06:21:53 PM
September 28, 2023, 04:29:08 PM
September 28, 2023, 05:16:32 AM
September 28, 2023, 04:51:48 AM
September 28, 2023, 04:44:12 AM
September 27, 2023, 10:22:40 PM
September 27, 2023, 07:37:00 PM
September 27, 2023, 07:21:16 PM
September 27, 2023, 06:57:27 PM
September 27, 2023, 05:05:09 PM
September 27, 2023, 04:58:12 PM
post can't get enough power out of high voltage generator
September 27, 2023, 04:42:28 PM
Manz
September 27, 2023, 03:54:47 PM
September 27, 2023, 12:18:44 PM
post Re: Brass vs Copper for spark gap?
September 27, 2023, 10:30:04 AM
September 27, 2023, 05:56:15 AM
tatemac
September 27, 2023, 02:39:07 AM
