Author Topic: Benjamin's DRSSTC1  (Read 774 times)
Offline Benjamin Lockhart
Benjamin's DRSSTC1
« on: April 29, 2023, 11:00:25 PM »
Hey guys I thought I'd share my new coil!
Specs are
fga60n65smd half bridge, older Onetesla driver board, 210khz ish, 2.875"x7.75" 36AWG, 1.9"x8" aluminum toroid, I'm using an older Onetesla interrupter.
100nF tank cap, 100us max on time, roughly 280A peak primary current, breakout point is 18.5" off the ground. The whole coil stands about 15.5" tall.
Primary coil is 1/8" copper tubing spaced 1/8" apart, 7 turns. Inner diameter 3.9", outer diameter is about 7". Primary inner turn to secondary clearance is 1/2".
The primary is about level with the bottom turn of the secondary. 1/2" copper tube strike rail.
0.19 coupling coefficient
Primary is only detuned slightly here maybe 5-8% Tapped at turn 5.75
Max spark so far is 18.5", 470mm!
Longer than about 70us on time creates a 2nd beat (big notch and then current rise again) in the primary current envelope, and spark length does not increase further. I suspect that it could use more detuning and a slightly larger toroid for better sparks, but I'm happy with this!
This new short secondary and flat primary has solved all the tuning and flashover problems that I had with the original Onetesla kit and it performs better too!
« Last Edit: April 30, 2023, 03:56:26 AM by Benjamin Lockhart »
Re: Benjamin's DRSSTC1
« Reply #1 on: April 30, 2023, 12:27:15 AM »
That sounds accurate.  As you say, looks like a great coil, so not much incentive to tweak.  Also, although more detuning will likely increase arc length a bit, music may sound better with tuning as is.
« Reply #2 on: May 03, 2023, 08:17:51 PM »
Correct, some notes wont play well, when you have detuned and need a large current buildup for breakout to appear, the note might be played half way through, before breakout occurs and only result in a "glimpses" like sound.
« Reply #3 on: September 21, 2023, 05:59:38 AM »
My small coil is 100% done now!
I have had some troubles with adding an OCD circuit to the Onetesla board using Alex Yuan's board design, but it's working now, I just had to replace a few ICs.
I upgraded the MMC from a single 100nF cap to four in series-parallel because it was getting hot.
The OCD is set at 290A and only triggers on ground strikes. It has hit 19.5 inch sparks to a ground plate now, not too bad for a small half bridge.
The bus caps and 1/8 inch tube primary actually get hotter than anything else on high duty cycle songs.
Here are some tunes!
Pretty good bass using the midistick!
4 note polyphony
« Last Edit: September 21, 2023, 06:08:17 AM by Benjamin Lockhart »
« Reply #4 on: September 22, 2023, 05:28:53 AM »
Here's the javatc file if anyone is interested.
ae7b
Today at 06:53:52 AM
Keybored
Today at 12:25:37 AM
Lucasww
bobfrancis1980
Lucasww
bobfrancis1980
post GDT magnetizing current
Keybored
Lucasww
bobfrancis1980
bobfrancis1980
Keybored
bobfrancis1980
post Re: 2 Layer primary coil
post 2 Layer primary coil
tazea
Hysteresis
nzoomed
post Segmented Primary Coil
tbbrune
post Chain reactions
post P5104 40kV 20MHz probes
Benjamin_collier
tazea
post Small Coil Build
post Re: GU-81 vs. GU-81M
thehay95
nzoomed
post Re: Benjamin's DRSSTC3
post Benjamin's DRSSTC3
bobfrancis1980
coilerer
coilerer
bobfrancis1980
