Author Topic: 160mm DRSSTC project  (Read 3750 times)
Offline Mathieu thm
Re: 160mm DRSSTC project
« Reply #20 on: March 01, 2023, 03:05:30 PM »
Aha, glad to see someone is using some of the stuff I put on Github :) Really need to do some updates and add some new stuff there!
I was looking for a pcb for the gates of  CM300dy-24h, and this pcb is exactly what I was looking for, Thanks for designing them !
Mike is correct - this was designed for maximum flexibility, I've dug up a photo (attached) and I used 2*2R2 in parallel for turn off, and 2*10R in parallel for turn on. Those values were somewhat guesswork though, but they seem to work OK with the CM300s I was driving.
BTW I'd avoid using any of the other boards on my Github other than the "Big_DRSSTC..." ones (of which this is one of them), and I'd check the compatibility with the terminals on your brick before using either of them. The others have known issues or could be improved, but I have a coil running using the "Big_DRSSTC..." ones (with the bridge ones using a stack of thin boards as noted in the README.md on github.
The resistance values ​​are much better than what I started to put, I will surely change for these values :)
« Reply #21 on: March 01, 2023, 03:36:08 PM »
The 5R (equivalent of the 2*10R in parallel) I used might be a bit higher than is ideal for fast turn-on; the 1R1 (from 2*2R2) used for turn-off is close to the datasheet nominal value they used for the switching times, which is why I chose it.
If you already have 5R6 resistors then I'd use one to begin with, and look at the turn-on speed, if you think it could be a bit faster (and you're not seeing nasty spikes on turn-on) then maybe try and add another in parallel to speed things up. This is where the separate resistors for turn-on/turn-off are nice, as they allow the values to be tweaked independently. BTW I suspect that the actual values aren't too critical as long as they are in the right ballpark (and turn-off is faster than turn-on to avoid shoot-through).
Offline Mathieu thm
« Reply #22 on: March 01, 2023, 03:51:07 PM »
Thanks for the advice, i will do it when i finish the coil, i still have a lot works on it !
BTW, do you know the exact model of your TVS? because I could see that my TVS that I used (the same as in the diagram) are 24v TVS but have a blocking voltage of 38.9 V, isn't that a bit high?
« Reply #23 on: March 01, 2023, 07:22:51 PM »
Haha, you've just discovered the dirty secret of TVS diodes.
Sadly you have to specify them based on the peak expected working voltage of your circuit (as you have done here), but they will clamp well above that number with any appreciable current. This means that it's hard to protect anything that has a narrow range between operating and maximum voltage by using a TVS.
Happily the IGBT won't pop even with a 40V spike on the gate (unless you're extremely unlucky and have a dud).
I don't know the exact model I used, but I can pretty much guarantee that it won't be any better than yours!
Offline Mathieu thm
« Reply #24 on: March 12, 2023, 09:23:23 PM »
I had several 24v through hole TVS that triggered around 27-28v so I thought it was the same for these TVS !
Some update since last post,
I made the primary coil out of 1/4 inch copper tubing (starts at around 200mm in diameter, spaced approx 15mm center-center) I still have to make the strike rail :
I also put two power supplies (12v and 24v) for the two 120mm high speed fans and the ud 2.7 :
« Last Edit: March 12, 2023, 09:27:40 PM by Mathieu thm »
Offline Mathieu thm
« Reply #25 on: April 10, 2023, 07:09:06 PM »
Some news here !
I started making a laminated BUS on solidworks :
(I forgot some dimensions on the pdf, ask me if necessary)
Some specs :
  • 1.5mm aluminum plate
  • insulation with 1.2mm plexiglass
  • 150A 1600V rectifier
  • SKM300GB128D (I also have SKM400GB128D,I think the SKM300 are more than enough)
I found two large 6000µF 400v capacitors on Ebay and a 150a rectifier on Amazon :
Here are some pictures of the bridge (I still have to find snubber capacitors, probably 1000v 2µF or something similar EDIT : probably this cap : https://www.mouser.fr/ProductDetail/80-C4BSNBX4200ZALJ) :
I also found a sort of trick to either make a simple rectifier or make a voltage doubler, for a 325v BUS voltage I just have to wire the rectifier normally, or if I want a voltage doubler, I connect the two rectifier inputs together on one mains wire, and the other mains wire, I plug it in between the two big capacitors.
I could test more simply either with 325v or 650v by changing a wire.
The next step will be to find a heatsink and fit everything in the case.
EDIT : to take some pictures I quickly assembled the bridge and I just noticed that the capacitors are mounted upside down !
« Last Edit: April 16, 2023, 03:03:43 PM by Mathieu thm »
Offline Mathieu thm
« Reply #26 on: April 19, 2023, 03:01:21 PM »
I found a perfect heatsink for my build, I drilled holes for the two IGBT and the rectifier (and three at the bottom to mount the heatsink to the frame) :
To mount the two large capacitors I 3d printed two supports :
I definitely glued the laminated BUS plates for more robustness, and this is the final result :
The two snubber capacitors will probably be two KEMET 1000V 2uF
For the precharge resistor I think to use a resistor of 180ohms 25w.
For the balancing resistors that go on both capacitors, I calculated that 15Kohm 7w resistors will be fine.
And I would put a resistor of 10K 20w on the output of the bridge.
« Last Edit: April 19, 2023, 03:05:13 PM by Mathieu thm »
Offline Mathieu thm
« Reply #27 on: June 15, 2023, 11:28:10 PM »
Hi everyone
It's been a long time since I've done an update.
I received the last components to finish the drsstc (MMC, CTs, GDT, snubber....), I started placing components in the enclosure :
I've finished the CTs (N30 900 to 1 ratio ):
I have a question about the GDT (N30 10 turns), I did it this way with cat5 cable by removing the main sheath to make jointed spir :
Do you think it's a good idea or is it better to stay with a classic GDT with a classic cat 5 cable ?
I'm afraid of insulation defaults with what I've done but there can't be a problem at these voltages?
« Last Edit: June 15, 2023, 11:40:13 PM by Mathieu thm »
« Reply #28 on: June 16, 2023, 12:21:01 AM »
I'm afraid of insulation defaults but there can't be a problem at these voltages?
The high voltage (H-bridge voltage) is between one wire and the other within each pair.  The outer jacket provides no improvement.  GDT use voltage is far above specification for such wire.  Generally not a problem for the short term use DRSSTCs experience (compared to specifications that cover 24 hours per day for years).  I haven't heard of any GDT insulation failures reported even for designs using 560Vbus (peak of 400Vac).
I recommend one unrelated change:  Leakage inductance will be lower if leads of each primary winding are twisted with themselves, separated only at the very end for connection to driver.  In other words, four white twisted pairs, joined at the end.  The four twisted pairs can be twisted together as a group or not.  That makes little difference.  Individual pair twisting is better than twisting the two bundles of four primary leads as shown now.
« Last Edit: June 16, 2023, 12:22:39 AM by davekni »
Offline Mathieu thm
« Reply #29 on: June 21, 2023, 11:24:56 PM »
Hi !
Sorry for the late reply, you mean like this ? :
I have finished (almost, the strike rail and the gnd of the secondary coil remain) the primary circuit, here are some pictures :
So I was able to do a first "test", I made a ct  for the current sensor and connected my oscilloscope.
I did the test with a Vbus of 60-70 v (with three 6s Lipo in series), and this is what it looks like without lead phase adjustment (7m3 223) :
I can't find in a thread that talked about what resistance value to put on the currant CT to measure on the oscilloscope, i had some problem of bad phase reading on the oscilloscope because of this ressitance, i put a 10ohm and it seems to be right. but what resistance value should we put on the measurement CT ?
The next step will be more oscilloscope capture (gate etc), connect the gnd of the secondary coil and the strike rail and try to adjust the phase lead to then do the first test with the secondary coil.
« Last Edit: June 21, 2023, 11:30:34 PM by Mathieu thm »
« Reply #30 on: June 22, 2023, 05:09:16 AM »
Yes.  Looks great.
Looks like plenty of MMC caps, so hopefully they don't generate much heat.  Many designs include some gap between cap rows for cooling air flow.
10ohms is a common value for CT burden resistance.  Presume CT cores are appropriate ferrite, not powdered iron.  Ratio somewhere around 1000:1?
Too-high resistance has two possible issues.  One is excess power dissipation.  Other is short L/R time constant for CT output inductance L.  In other words, resistance becomes a significant fraction of CT output impedance at operating frequency.  For accuracy, R should be <1% of CT output impedance.
Main issue with too-low resistance is small signal amplitude.  Usually scope is also measuring bridge output at comparatively high voltage.  Can introduce measurement errors to current with any channel-to-channel coupling.  Other possible issue is resistor inductance.  Low value resistors are often wire-wound.  If impedance of resistor series inductance becomes more than ~1% of resistance, adds measurement error.
BTW, even with battery power, scoping is often more accurate measuring one bridge output at a time with scope probe ground to Vbus-.  Avoids rapid voltage swing between scope ground and H-bridge components (heat sink etc.).  Reduces inductive drop along scope probe ground leads etc.  May be fine as is, but can obscure subtle details of measurements.
Offline Mathieu thm
« Reply #31 on: June 29, 2023, 11:02:54 PM »
Yes.  Looks great.
perfect :D
I did some tests at 500a OCD and they are cold after a few minutes. From what I've calculated, they'll heat up very little.
BTW the drsstc draws about 20a max at about 130-140Vac from the variac and with the OCD set to 500a (which doesn't trip very often), the arcs are about 1m20.
the ratio is 900:1 for all three CTs.
Thanks for the explanation, it's always important to understand problems.
I've finally decided to insulate the upper part of the frame, i've printed 3d parts and it seems to do the trick, but i know it's not ideal :
There are four spacers for the screws, which also go through the aluminum, kapton under the aluminum square and two black insulating pieces between the 20x20 profiles, all 3d printed.
I made several oscilloscope captures (Vbus at 90-100v with battery) :
  • bridge output
  • bridge output with gnd at Vbus-
  • Vge
  • primary current
OVERVIEW (bridge output = yellow and primary current = purple) :
Start of pulses :
End of pulses :
At the end of the pulses with the transition when the freewheel diodes of IGBTs take over :
Both sides of the bridge with the oscilloscope's gnd to Vbus- :
Vge of one IGBT :
And primary current :
There's something bothering me, i've set the phase lead to have the least amount of ringing and spiking on the bridge output, but I get the impression that there's a lot of phase lead.
What do you think? should we set less phase lead? is setting for less ringing not a good solution?
Sorry for the dumb question, but I'd like to know more about how to get a perfect phase lead (or at least the best possible setting).
I'd like to be sure of my phase lead before testing at full power.
« Last Edit: June 30, 2023, 07:07:53 AM by Mathieu thm »
« Reply #32 on: June 30, 2023, 06:34:41 PM »
You should adjust your phase lead for somewhere between zero-current-switching and least-possible-spikes. If you only adjust for not spikes, you risk having high dissipation losses from turn-on or turn-off losses being higher than it could be.
Regarding your MMC, I am afraid that you have to do something about it. You need active cooling on it, with a fan, forced air cooling. You need to make room between acrylic side and MMC for air to flow on both sides.
Capacitor dissipate 2/3 of their losses through the terminals and 1/3 through the body. This makes your heat dissipation very uneven in the very tight configuration. This will lead to hot spots and that is bad for current sharing. I predict that your most inner/middle capacitors will eventually fail.
"Microsoft Paint Simulation" of heat dissipation in your MMC.
« Reply #33 on: June 30, 2023, 09:53:20 PM »
The "ideal" situation is to have IGBTs turn off with just enough remaining current to cause bridge output voltage to transition due to just that remaining current.  Ideally, opposite IGBTs turn just as output voltage transition completes, which would be just as current crosses zero.
Of course, no real build can be "ideal", especially since IGBT delays increase with temperature.
You may have more dead-time than necessary (time between IGBT turn-off and opposite IGBT turn-on).  That may be why phase lead needs to be high.  (Doesn't look bad to me as-is.)  What does Vce (output) look like with slightly less phase lead?  I'm guessing what I refer to here as triple-transition.  Vce rises, then starts to fall after current crosses zero, then Vce rises again as opposite IGBT turns on.  As Mads pointed out, a little bit of that is fine.  To much triple-transition (or past that with even less phase lead) and you may add as much power dissipation there as you save by lower turn-off current.
How do those conditions compare to your intended operating conditions?  Cap heating will be proportional to duty cycle and to current squared.  If you end up needing just a bit more cooling, say 1.5x, thick copper foil (0.1-0.2mm) strips could be soldered across cap middle wires to provide crude heat-sink fins.  That and some fan air flow will help noticeably.
« Last Edit: June 30, 2023, 09:55:27 PM by davekni »
Offline Mathieu thm
« Reply #34 on: July 01, 2023, 04:42:24 PM »
I set the phase lead like this to have less dissipation losses, I think this setting is better, what do you think ? :
pulse start :
end of pulses :
on both sides of the output with gnd to Vbus- :
The "interference" on the primary current signal when current crosses 0 is due to what?
parasitic inductance of the oscilloscope probe or something like that?
I'm well aware that the MMC is not designed in the best way but good idea I'll leave some space between the acrylic and the MMC for cooling.
I think I'll set the OCD in the 700-750a range.
« Reply #35 on: July 02, 2023, 02:32:13 AM »
Looks great!  Definitely not excess dead time as I'd speculated previously.  Third scope capture, final falling edge before enable ends, shows a very brief pause center-transition.  Looks like turn-off is early enough to cause half of the output voltage swing, then opposite IGBT turn-on pulls the output the remainder of the way down.  If there was excess dead time, that brief pause would rise briefly before falling (triple transition).
The one possible concern:  When coil is driven hard and IGBTs get hot, IGBT delay increases.  I personally prefer to start with a bit too much phase lead, enough to compensate for increased delay due to temperature.  Before making any change, best to scope at higher bus voltage and higher current.  IGBT capacitance is lower at high voltage, and higher current will cause faster bridge output transition at turn-off.  So you may have some margin (some "excess" phase lead) at operating conditions.
However, I have relatively little experience with IGBT bricks, mostly smaller TO247 devices.  So if Mads or others with more experience with bricks says otherwise, follow their advice.
Such interference is difficult to avoid.  CT signals are relatively low voltage compared to bridge output swings.  Capacitance between CT winding and bridge output wire through center will inject some signal.  Can be mitigated, but usually not worth the work.  Grounded shield around bridge output wire inside CT core can help, though inductance in that ground lead can limit effectiveness.  Common-mode choke in CT output helps.  CT can be wound as a center-tapped coil, with center grounded and one half used for scoping, other half "unused".  If coil is symmetric, capacitance to both winding halves cancels.
« Last Edit: July 02, 2023, 03:03:16 AM by davekni »
Offline Mathieu thm
« Reply #36 on: July 07, 2023, 07:25:42 PM »
Ok I see thanks.
Yes, of course I have to try with higher bus voltages and higher primary current, but I don't have a differential probe.
I've tried this technique, but I can't get a clear oscilloscope capture : https://highvoltageforum.net/index.php?topic=1373.msg10212#msg10212
Okay, I understand, so this interference isn't a problem.
« Reply #37 on: July 08, 2023, 01:01:28 AM »
Ok I see thanks.
Some digital scopes capture multiple waveforms and display the composite on screen (simulates behavior of an analog scope).  That may be making a confusing display result.  Either turn that mode off if possible, or go into single-capture mode.  Single-capture mode requires pushing run/stop button for every new capture, but should give you a stable view of each capture.
For scope measurements, just ignore the interference.  Drivers such as UD2.7 have a small capacitor across CT to filter out such high-frequency noise.  Could be a problem if using a driver that doesn't filter out high frequency noise.
Today at 06:52:35 PM
Jhornel
Today at 02:14:35 PM
Today at 04:52:28 AM
Today at 02:11:05 AM
post Re: Benjamin's DRSSTC1
post Phone sensor fusion demo
omrid13
post Re: Magnifier tesla coil
post Re: Inverter question
post First drsstc issues
post UD2.7Cs for sale
All Science
omrid13
orac
orac
orac
omrid13
Recep talip
All Science
post Drsstc feedback startup
ako
ako
Recep talip
Recep talip
