Author Topic: Problem with SSTC  (Read 13321 times)
Re: Problem with SSTC
« Reply #60 on: July 13, 2024, 09:58:54 PM »
In any case, since I get the 90 VDC from a transformer, I shouldn't have any problems, right?
If you are probing both IGBT gates simultaneously, that is a serious problem.  The two emitters are shorted through scope probe ground connections.
If probing individually, not a huge problem, but high side Vge (gate to emitter voltage) may be distorted.  Scope "ground" is switching 90V suddenly.  Scope has significant capacitance to power lines even with "ground" disconnected.
Offline Nunu00
« Reply #61 on: July 13, 2024, 10:09:06 PM »
Yes, I was probing both igbt gates simultaneously 😅. So how should I probe the IGBTs correctly?
« Reply #62 on: July 13, 2024, 10:44:55 PM »
With no power to half-bridge, it is fine to probe both Vge's simultaneously, as you did before applying 90V.  Since those two Vge waveforms look good and symmetric, there isn't any real need to probe high-side Vge after Vbus is applied.  Most useful to simultaneously probe low side IGBT Vge and low side IGBT Vce (half-bridge output).
Of course, the expensive option is to purchase a differential probe for your scope.
Offline Nunu00
« Reply #63 on: July 14, 2024, 01:32:03 AM »
I redid some tests following the instructions.
With the 90 VDC applied the waveform in the gate looks like this:
These instead, are the waveforms between collector and emitter:
These are the Vge vs the Vce:
And finally this is a photo of the discharges:
« Reply #64 on: July 14, 2024, 05:36:30 AM »
Generally looks good.  A few details to consider:
Dead time may be too small.  6R8 gate resistors (R1 and R3) are low value for FGA60N65 IGBTs.  I'd guess 30 ohms would be more appropriate.
Vce spikes might be OK, but need checking as Vbus is increased towards 350V.  Need to be well below 600V peak.
Schematic doesn't show any capacitors across Vbus (across 350V supply).  Theoretically not necessary, but added capacitors reduces stray half-bridge inductance so will reduce Vce spikes.  Good half-bridge layout helps too, such as:
Offline Nunu00
« Reply #65 on: July 28, 2024, 02:26:53 AM »
The capacitors were already present on another board. Anyway I followed the advice and redid the layout of the half bridge as you can see from the photos:
 [ You are not allowed to view attachments ]
The changes seem to have worked, in fact now the Vce does not show any obvious spikes.
I didn't have 30 ohm resistors so I used 15 ohm ones. From what I see the dead time seems to have increased but the Vgs shape seems to have worsened. Is it really like that?
« Reply #66 on: July 29, 2024, 01:54:47 AM »
One detail I'd suggest following more accurately:  Emitter side of GDT secondary leads should connect as close as possible to IGBT emitter leads.  At least to copper foil where emitter is soldered if not directly to emitter lead adjacent IGBT body.  Definitely not to bulk cap terminal as is now for low side emitter.
Great.  That's exactly what low inductance half-bridge layout is intended to fix.
Presume you are referring to Vge since using IGBTs.  Looks reasonable, though may improve a bit once GDT emitter wires are attached closer to IGBT emitter leads near IGBT body.  Rising edge spikes are due to Miller capacitance (Cgc).  Can be avoided only if achieving phase-lead where Vce transitions due to remaining collector current prior to opposite IGBT turning on.  Phase lead isn't always possible with SSTC designs.
Dead time might be sufficient.  Difficult to measure without phase lead.
Offline Nunu00
« Reply #67 on: July 29, 2024, 08:11:08 PM »
I made this last change and the Vge improved slightly.
Then I finally connected it to the rectified  230 mains and everything worked fine. I also made an interrupter with an arduino that reads midi files from a micro sd and it works really well.
https://youtube.com/shorts/lrdIRCy-Lns
The only problem is that I probably have to add an emi filter on the power supply because the house differential switch (GFCI) trips. Any tips on how to make one?
« Last Edit: July 29, 2024, 08:12:52 PM by Nunu00 »
« Reply #68 on: July 31, 2024, 05:21:05 AM »
Good.  Will make more difference when running at high power.
Great!  Thank you for sharing good news.
Likely most important part is good common-mode choke(s) in series with line input.  One good choke is likely sufficient.  Sometimes two in series can help further, one large for low frequencies and a smaller one (with less inter-winding capacitance) for higher frequencies.
Today at 09:00:36 AM
Today at 06:21:32 AM
Today at 04:41:21 AM
Today at 01:19:36 AM
Today at 12:59:54 AM
fillertext
radbloke
曹靖
曹靖
曹靖
August 31, 2024, 08:36:20 PM
August 31, 2024, 08:28:14 PM
post Re: Neon sign + an -?
August 31, 2024, 05:16:06 PM
post Neon sign + an -?
kenw232
August 31, 2024, 02:31:02 PM
August 30, 2024, 12:56:57 PM
SunboX
August 30, 2024, 07:47:55 AM
August 30, 2024, 05:20:42 AM
Unrealeous
August 30, 2024, 03:38:24 AM
Sando3450
August 30, 2024, 02:33:31 AM
August 30, 2024, 01:41:49 AM
August 30, 2024, 01:34:01 AM
Unrealeous
August 30, 2024, 12:23:43 AM
August 29, 2024, 10:21:08 PM
August 29, 2024, 08:54:20 PM
Sando3450
August 29, 2024, 05:26:43 PM
PhotonLab
August 29, 2024, 09:52:48 AM
sky-guided
August 29, 2024, 05:38:42 AM
post Re: designing VTTC
August 29, 2024, 12:17:30 AM
August 28, 2024, 11:59:34 PM
post Re: FPS4000
buxdahu
August 28, 2024, 05:39:06 PM
August 28, 2024, 12:36:22 PM
MikeD99
August 28, 2024, 06:53:54 AM
sky-guided
August 28, 2024, 04:39:27 AM
August 28, 2024, 04:23:23 AM
post Re: Plasma Toroid
sky-guided
August 28, 2024, 03:18:13 AM
sky-guided
August 28, 2024, 03:16:44 AM
Domo
August 28, 2024, 12:44:17 AM
Mathieu thm
August 27, 2024, 10:31:05 PM
Luca c.
August 27, 2024, 07:16:09 PM
August 27, 2024, 02:58:53 PM
drobotk
August 27, 2024, 12:06:52 PM
August 27, 2024, 12:51:27 AM
Domo
August 26, 2024, 11:01:55 PM
drobotk
August 26, 2024, 07:05:33 PM
August 26, 2024, 06:53:06 PM
August 26, 2024, 06:50:51 PM
August 26, 2024, 06:43:24 PM
August 26, 2024, 02:38:49 PM
PhotonLab
August 26, 2024, 01:31:13 PM
PhotonLab
August 26, 2024, 01:10:18 PM
PhotonLab
August 26, 2024, 11:45:00 AM
August 26, 2024, 09:00:16 AM
sky-guided
August 26, 2024, 06:47:35 AM
Domo
August 26, 2024, 05:14:48 AM
TheMadHatter
August 26, 2024, 04:29:12 AM
August 26, 2024, 04:14:35 AM
verliebt_in_neukölln17
August 26, 2024, 03:01:07 AM
August 26, 2024, 02:31:29 AM
August 25, 2024, 07:53:51 PM
August 25, 2024, 06:49:37 PM
August 25, 2024, 06:29:53 PM
August 25, 2024, 04:33:05 PM
August 25, 2024, 04:30:42 PM
August 25, 2024, 01:07:43 PM
August 25, 2024, 01:06:11 PM
August 24, 2024, 11:48:04 PM
August 24, 2024, 10:55:02 PM
August 24, 2024, 09:00:23 PM
August 24, 2024, 05:38:13 PM
Damaged1
August 24, 2024, 03:52:15 PM
August 24, 2024, 11:19:59 AM
August 24, 2024, 11:11:09 AM
August 23, 2024, 06:40:03 AM
August 23, 2024, 05:23:58 AM
August 23, 2024, 04:21:47 AM
kenw232
August 23, 2024, 02:39:08 AM
August 22, 2024, 10:33:43 PM
Matyáš Suchý
August 22, 2024, 09:30:42 PM
August 22, 2024, 07:09:31 PM
kenw232
August 22, 2024, 06:58:03 PM
August 22, 2024, 06:15:03 PM
kenw232
August 22, 2024, 03:41:44 PM
August 22, 2024, 03:23:48 PM
post How to wire my flyback?
kenw232
August 22, 2024, 01:35:41 AM
August 21, 2024, 10:20:32 PM
August 21, 2024, 07:59:53 PM
August 21, 2024, 01:20:40 AM
August 20, 2024, 10:41:56 PM
