Author Topic: Syntherrupter - Help and Issues  (Read 2516 times)
Offline tronic
« on: October 13, 2021, 10:54:37 AM »
Unfortunately, I am having great problems rebuilding the great project
and would be happy if someone finds the error
Bought new : EK-TM4C1294XL
Bought new : NEXTION NX8048T050-011
Connected
 red +
black -
yellow PA5
blue PA4
Step 1 :
Download "Syntherrupter_Firmwares_v4.2.0-beta.7.zip".
unzip
LM Flash Programmer installed under Windows 10
Quickset TM4C1294XL Launchpad
Program Syntherrupter_Tiva_1_Coil.bin
-> programming & verifying complete-passed
Step 2
File "Syntherrupter_Nextion_NX8048T050_011.tft on Mico-SD".
Insert SD card into display and switch on
Display performs update, message successful
power off
Nothing, display remains dark
« Last Edit: October 13, 2021, 11:26:16 AM by tronic »
Offline Max
    • My Youtube Channel
Re: Syntherrupter - Help and Issues
« Reply #1 on: October 13, 2021, 02:04:02 PM »
Hello tronic and welcome to the forum!
Sorry to hear that your Syntherrupter doesn't work and thank you for the detailed report. Unfortunately I cannot reproduce the issue here. If I flash the files the device powers up fine. Assuming it's not a hardware issue there's only one difference between your setup and mine; your device is all new; meaning its EEPROM does not contain any settings. I'll have a look at that - though I don't think that's the origin of your issues.
Other than that it might be a power supply issue but it seems somewhat unlikely, too...
Couple questions for further debugging:
Do you have a scope?
Any way to decode serial data (to check the coms between the screen and the microcontroller)?
Do you feel comfortable using a tool like Syfoh?
I hope we get this fixed soon!
Offline tronic
« Reply #2 on: October 13, 2021, 02:17:41 PM »
Thank you very much for your support.
Yes, oscillator with serial coding is available, but no signal comes out of the TX PIN.
Offline Max
« Reply #3 on: October 13, 2021, 02:22:54 PM »
If you want, we can continue this dialog via PM or any chat platform instead of "spamming" this topic. I'll afterwards report here what the solution was. If you agree, let me know the contact details via PM.
That aside, "TX PIN" is unfortunately unclear... Do you mean tiva's TX pin or Nextion's?
Offline Max
« Reply #4 on: October 19, 2021, 11:36:44 PM »
The issue was a bug in the v4.2.0-beta.3 - v4.2.0-beta.7 firmware versions. It has been fixed with the v4.2.0 (stable) release. Unfortunately this is likely not the fix for Mathieu's issue...
Offline Cameron Prince
    • Tesla Universe
« Reply #5 on: July 31, 2024, 09:54:47 PM »
Hi @Max,
I'm continuing to make progress with my Syntherrupter and have even purchased a second set up to work with on the bench.
I'm trying to get the Lightsaber function working, but having some troubles. There are some inconsistencies with the documentation related to the ESP-01's and I'd like to confirm which are correct. In learning about these boards, I see that others are concerned about possibly needing a level shifter when connecting with the RX/TX of the Tiva due to the 3.3V <-> 5.0V differences.
I have been able to successfully program the ESP's using a USB serial adapter made for them. I have not been able to program through the USB -> ESP bridge in the Syntherrupter, but the Nextion flashes with no problem. The Syntherrupter displays a message on the USB -> ESP bridge screen indicating GPIO0 must be set to ground to flash the ESP, but if you look at the main schematic, it shows GPIO2 being set to ground via the switch: https://github.com/MMMZZZZ/Syntherrupter/blob/dev/Documentation/Wiring%20and%20Schematics/Syntherrupter%20Complete/Syntherrupter%20Complete%20Schematic.png
I've tried grounding both pins (separately) and I see the blue COMM LED flash in unison with me clicking the program button, but the software never shows the QR code or device ID like it does using the USB serial adapter to flash with.
I have flashed multiple ESPs using the USB serial adapter and have made several receivers and senders. They don't seem to ever connect. I don't see the blue COMM LED ever flash on the senders like yours does in the YouTube video. I do see the flashes on the receiver.
It's also unclear to me how the Syntherrupter Lightsaber UI is to operate. I hold down on the buttons to assign an address, but the buttons just darken for a moment and nothing happens.
There are some docs I've read about issuing AT commands to the ESP's via the serial port, I've tried this with the USB serial adapter using PuTTY, but don't get a response.
Please let me know if you have any ideas that might help.
Thanks,
Cameron
« Last Edit: July 31, 2024, 09:56:55 PM by Cameron Prince »
    • Tesla Universe
« Reply #6 on: August 01, 2024, 03:23:10 AM »
@Max, I just saw your reply in the other post regarding the Lightsabers. Thanks for the info about using the 3.3V on the Tiva. I had concerns about the ESP's needing more current than that circuit could supply, so I've been using buck converters. Once I get it working, I'll try running from the Tiva instead.
Here's a few more photos of my setup:
I'm using a bench power supply to power everything. The Tiva, Nextion and buck converter all have dedicated power connections.
Red and yellow here are 5V and go to VCC and the enable pin on the ESP. Pink and blue are TX and RX, respectively.
This is a test sender. Note the buck converter stacked on the back of the MPU. Not sure if this is a good idea or not.
Here's a sender packed into a toy lightsaber. The buck converter is to the right of the battery and the MPU on the left, both wrapped in heat shrink. The ESP at the bottom, my thought being to have it hopefully below the grip for better signal.
Please let me know what you think.
Thanks,
Cameron
Today at 09:00:36 AM
Today at 06:21:32 AM
Today at 04:41:21 AM
Today at 01:19:36 AM
Today at 12:59:54 AM
fillertext
radbloke
曹靖
曹靖
曹靖
August 31, 2024, 08:36:20 PM
August 31, 2024, 08:28:14 PM
post Re: Neon sign + an -?
August 31, 2024, 05:16:06 PM
post Neon sign + an -?
kenw232
August 31, 2024, 02:31:02 PM
August 30, 2024, 12:56:57 PM
SunboX
August 30, 2024, 07:47:55 AM
August 30, 2024, 05:20:42 AM
Unrealeous
August 30, 2024, 03:38:24 AM
Sando3450
August 30, 2024, 02:33:31 AM
August 30, 2024, 01:41:49 AM
August 30, 2024, 01:34:01 AM
Unrealeous
August 30, 2024, 12:23:43 AM
August 29, 2024, 10:21:08 PM
August 29, 2024, 08:54:20 PM
Sando3450
August 29, 2024, 05:26:43 PM
PhotonLab
August 29, 2024, 09:52:48 AM
sky-guided
August 29, 2024, 05:38:42 AM
post Re: designing VTTC
August 29, 2024, 12:17:30 AM
August 28, 2024, 11:59:34 PM
post Re: FPS4000
buxdahu
August 28, 2024, 05:39:06 PM
August 28, 2024, 12:36:22 PM
MikeD99
August 28, 2024, 06:53:54 AM
sky-guided
August 28, 2024, 04:39:27 AM
August 28, 2024, 04:23:23 AM
post Re: Plasma Toroid
sky-guided
August 28, 2024, 03:18:13 AM
sky-guided
August 28, 2024, 03:16:44 AM
Domo
August 28, 2024, 12:44:17 AM
Mathieu thm
August 27, 2024, 10:31:05 PM
Luca c.
August 27, 2024, 07:16:09 PM
August 27, 2024, 02:58:53 PM
drobotk
August 27, 2024, 12:06:52 PM
August 27, 2024, 12:51:27 AM
Domo
August 26, 2024, 11:01:55 PM
drobotk
August 26, 2024, 07:05:33 PM
August 26, 2024, 06:53:06 PM
August 26, 2024, 06:50:51 PM
August 26, 2024, 06:43:24 PM
August 26, 2024, 02:38:49 PM
PhotonLab
August 26, 2024, 01:31:13 PM
PhotonLab
August 26, 2024, 01:10:18 PM
PhotonLab
August 26, 2024, 11:45:00 AM
August 26, 2024, 09:00:16 AM
sky-guided
August 26, 2024, 06:47:35 AM
Domo
August 26, 2024, 05:14:48 AM
TheMadHatter
August 26, 2024, 04:29:12 AM
August 26, 2024, 04:14:35 AM
verliebt_in_neukölln17
August 26, 2024, 03:01:07 AM
August 26, 2024, 02:31:29 AM
August 25, 2024, 07:53:51 PM
August 25, 2024, 06:49:37 PM
August 25, 2024, 06:29:53 PM
August 25, 2024, 04:33:05 PM
August 25, 2024, 04:30:42 PM
August 25, 2024, 01:07:43 PM
August 25, 2024, 01:06:11 PM
August 24, 2024, 11:48:04 PM
August 24, 2024, 10:55:02 PM
August 24, 2024, 09:00:23 PM
August 24, 2024, 05:38:13 PM
Damaged1
August 24, 2024, 03:52:15 PM
August 24, 2024, 11:19:59 AM
August 24, 2024, 11:11:09 AM
August 23, 2024, 06:40:03 AM
August 23, 2024, 05:23:58 AM
August 23, 2024, 04:21:47 AM
kenw232
August 23, 2024, 02:39:08 AM
August 22, 2024, 10:33:43 PM
Matyáš Suchý
August 22, 2024, 09:30:42 PM
August 22, 2024, 07:09:31 PM
kenw232
August 22, 2024, 06:58:03 PM
August 22, 2024, 06:15:03 PM
kenw232
August 22, 2024, 03:41:44 PM
August 22, 2024, 03:23:48 PM
post How to wire my flyback?
kenw232
August 22, 2024, 01:35:41 AM
August 21, 2024, 10:20:32 PM
August 21, 2024, 07:59:53 PM
August 21, 2024, 01:20:40 AM
August 20, 2024, 10:41:56 PM
