Author Topic: HFSSTC not working well  (Read 3199 times)
Offline toooldforthis
« on: March 08, 2021, 07:18:50 PM »
Hi all,
I am not sure what I am doing wrong here. I built the standard HFSSTC circuit with the capacitor voltage divider gate drive circuit that every one uses. I am seeing some very poor gate waveforms and I am not able to achieve breakout on my secondary. Perhaps I have made a stupid mistake that someone can spot? Too many paracitics somewhere?
I'm obviously not achieving class-e switching here. I must need more loading, however I am not able to achieve breakout. I have tried changing the coupling between primary and secondary which did not help.
Do I have to tune the resonance of the secondary to match the primary side tank? I would like to do it the way Steve Ward did it which is why I made the secondary resonance about twice that of the primary side.
I made the tank cap out of polystyrene. It is 115pF and should survive up to 10kV I would guess.
Offline Kevindk9
Re: HFSSTC not working well
« Reply #1 on: March 13, 2021, 10:39:41 PM »
First off, your secondary coil (60 turns) should not be grounded.  It should be connected right on the corner of your schematic between the primary coil (2.15uh) and the 115ph capacitor.
5nf may be too much gate-source capacitance, i use 2.5nf but it varies from transistor to transistor (don't ask..  ???) . Im using SiC mosfets, but the IRFP460's liked ~8nf capacitance.
I think you should make your primary coil tunable, try 5 turns of 12 gauge wire, 3 inches wide and 3 inches tall.  use a wire with an alligator clip to move it up and down the last winding.
I also have my primary coils frequency about half of the secondarys frequency.  I might be wrong here, but the theory is that the plasma flame will reduce the resonant frequency of the secondary coil, the bigger it gets, the lower the frequency drops.  My coil will not start by itself, but if I bring a piece of metal near the secondary coil (reducing its resonant frequency), a flame will break out. As I turn the pot up, I bring the metal (screwdriver) away until it can self sustain the flame.
So if you still arent getting a break out, you must be way out of tune.
Offline radbloke
« Reply #2 on: August 03, 2024, 08:14:12 PM »
Polystyrene is a poor material for RF impulse rated caps and would be lossy or not work at all  Better to use mica or polypropylene film caps such as the CDE series.
Offline Anders Mikkelsen
« Reply #3 on: August 07, 2024, 11:37:18 PM »
Did anybody successfully make a HFSSTC with a superjunction FET? Your named part number is a superjunction MOSFET, and these behave very differently from conventional MOSFET transistors. At least this is something to look into if the circuit doesn't behave as expected.
Today at 09:00:36 AM
Today at 06:21:32 AM
Today at 04:41:21 AM
Today at 01:19:36 AM
Today at 12:59:54 AM
fillertext
radbloke
曹靖
曹靖
曹靖
August 31, 2024, 08:36:20 PM
August 31, 2024, 08:28:14 PM
post Re: Neon sign + an -?
August 31, 2024, 05:16:06 PM
post Neon sign + an -?
kenw232
August 31, 2024, 02:31:02 PM
August 30, 2024, 12:56:57 PM
SunboX
August 30, 2024, 07:47:55 AM
August 30, 2024, 05:20:42 AM
Unrealeous
August 30, 2024, 03:38:24 AM
Sando3450
August 30, 2024, 02:33:31 AM
August 30, 2024, 01:41:49 AM
August 30, 2024, 01:34:01 AM
Unrealeous
August 30, 2024, 12:23:43 AM
August 29, 2024, 10:21:08 PM
August 29, 2024, 08:54:20 PM
Sando3450
August 29, 2024, 05:26:43 PM
PhotonLab
August 29, 2024, 09:52:48 AM
sky-guided
August 29, 2024, 05:38:42 AM
post Re: designing VTTC
August 29, 2024, 12:17:30 AM
August 28, 2024, 11:59:34 PM
post Re: FPS4000
buxdahu
August 28, 2024, 05:39:06 PM
August 28, 2024, 12:36:22 PM
MikeD99
August 28, 2024, 06:53:54 AM
sky-guided
August 28, 2024, 04:39:27 AM
August 28, 2024, 04:23:23 AM
post Re: Plasma Toroid
sky-guided
August 28, 2024, 03:18:13 AM
sky-guided
August 28, 2024, 03:16:44 AM
Domo
August 28, 2024, 12:44:17 AM
Mathieu thm
August 27, 2024, 10:31:05 PM
Luca c.
August 27, 2024, 07:16:09 PM
August 27, 2024, 02:58:53 PM
drobotk
August 27, 2024, 12:06:52 PM
August 27, 2024, 12:51:27 AM
Domo
August 26, 2024, 11:01:55 PM
drobotk
August 26, 2024, 07:05:33 PM
August 26, 2024, 06:53:06 PM
August 26, 2024, 06:50:51 PM
August 26, 2024, 06:43:24 PM
August 26, 2024, 02:38:49 PM
PhotonLab
August 26, 2024, 01:31:13 PM
PhotonLab
August 26, 2024, 01:10:18 PM
PhotonLab
August 26, 2024, 11:45:00 AM
August 26, 2024, 09:00:16 AM
sky-guided
August 26, 2024, 06:47:35 AM
Domo
August 26, 2024, 05:14:48 AM
TheMadHatter
August 26, 2024, 04:29:12 AM
August 26, 2024, 04:14:35 AM
verliebt_in_neukölln17
August 26, 2024, 03:01:07 AM
August 26, 2024, 02:31:29 AM
August 25, 2024, 07:53:51 PM
August 25, 2024, 06:49:37 PM
August 25, 2024, 06:29:53 PM
August 25, 2024, 04:33:05 PM
August 25, 2024, 04:30:42 PM
August 25, 2024, 01:07:43 PM
August 25, 2024, 01:06:11 PM
August 24, 2024, 11:48:04 PM
August 24, 2024, 10:55:02 PM
August 24, 2024, 09:00:23 PM
August 24, 2024, 05:38:13 PM
Damaged1
August 24, 2024, 03:52:15 PM
August 24, 2024, 11:19:59 AM
August 24, 2024, 11:11:09 AM
August 23, 2024, 06:40:03 AM
August 23, 2024, 05:23:58 AM
August 23, 2024, 04:21:47 AM
kenw232
August 23, 2024, 02:39:08 AM
August 22, 2024, 10:33:43 PM
Matyáš Suchý
August 22, 2024, 09:30:42 PM
August 22, 2024, 07:09:31 PM
kenw232
August 22, 2024, 06:58:03 PM
August 22, 2024, 06:15:03 PM
kenw232
August 22, 2024, 03:41:44 PM
August 22, 2024, 03:23:48 PM
post How to wire my flyback?
kenw232
August 22, 2024, 01:35:41 AM
August 21, 2024, 10:20:32 PM
August 21, 2024, 07:59:53 PM
August 21, 2024, 01:20:40 AM
August 20, 2024, 10:41:56 PM
