Author Topic: LabCoatz Staccato QCW No straight sparks  (Read 1767 times)
Offline Admiral Aaron Ravensdale
« on: February 21, 2024, 02:31:59 PM »
Hi new build, new issues :-(
I build the Staccato QCW out of this Video.
With the following stats.
and shematic
Now I run into the issue that I don't get straight sparks!
First I try it with a 28cm Toroid and 337kHz@15nf
and now with a 20cm Toroid and 378kHz @40nf
With an Probe in the air it looks like the ramp is very short but i can change the time like described from 1ms to 8 ms
also confirmed the 378kHz when I zoom in on the upper picture
also the Signal at the Pin "Int" of the shematic looks good
But you can see only wild sparking more like an DRSSTC than QCW
any ideas whats wrong?
Video with 200VAC and all pulse width
https://photos.app.goo.gl/t16hUAzQX47Hd1Gm6
« Last Edit: February 21, 2024, 03:07:32 PM by Admiral Aaron Ravensdale »
Offline ZakW
  • YouTube @QZW_Labs
Re: LabCoatz Staccato QCW No straight sparks
« Reply #1 on: February 21, 2024, 06:58:39 PM »
You first probe waveform looks to be the issue. You have a sharp spike in the beginning instead of a ramp. That spike is going to cause arcs to branch a lot. Are you powering the coil with unfiltered rectified AC (no bulk capacitors to smooth input voltage)?
The zero cross detector might not be triggering at the zero crossing, here is an example of that: When the coil turns on too late into the AC half cycle (ramp) it causes more of a burst of power into the primary rather than a more gradual ramp. What AC source are you using for the ZCD? In the picture, the purple trace is the probe hanging in air. Yellow is from an AC transformer.
This is the wave form you are looking for: Blue is the probe hanging in the air by the coil. Coil turns on at or as close to zero crossing and ramps up as AC voltage increases.
The 1-8ms adjustment determines when the coil shuts off. It should always trigger as close to the start of the AC half cycle (zero crossing) and then can be adjusted to shut off before the cycle has ended.
Good luck!
« Reply #2 on: February 21, 2024, 07:28:29 PM »
Thanks for the reply.
The side of the Power Input for the IGBT looks like that 2 Caps 250V 1000uf in series and a 1600V 100A Brick rectifier
 [ Invalid Attachment ]
I use this transformer 12.6V AC
OK this looks quiet different.
How can I figure out if the which side cause the issue?
THANKS!
Offline ZakW
  • YouTube @QZW_Labs
« Reply #3 on: February 21, 2024, 07:48:47 PM »
That is the issue. Just remove those capacitors and you should be good to go.
Since this is a ramped coil, you are trying to utilize the AC input (sine wave) ramp shape. With the filtering capacitors you are effective getting rid of that and smoothing it all out. So the coil is getting a high voltage pulse at startup.
The only other thing that you might need to verify is that the zero cross AC transformer is in phase with the AC bridge input. If you dont get any arcs after removing the filtering caps, try reversing the zero crossing transformer input.
nice build btw, those are some hefty resonant capacitors!
« Reply #4 on: February 21, 2024, 08:53:07 PM »
THHHHAAAAANNNKS worked now  ;D
which build? it's just the test crappy test look.
Later it looks like this QCW where I currently wait for the "Simple Driver" from Ukrain but you know the war and the struggle there is real, I mailed already with he is still alive but he spend nearly every day in a bunker somewhere in Kiev and don't get parts :-(
Offline ZakW
  • YouTube @QZW_Labs
« Reply #5 on: February 21, 2024, 09:04:11 PM »
You're welcome! Happy to hear that it is working now.
-Zak
« Reply #6 on: February 21, 2024, 09:13:05 PM »
Nice!
This is how QCW Sparks should look like \o/
https://photos.app.goo.gl/DHpoqBSRY8W7kuWW8
@ZakW Got all my HV Caps from aliexpress Dawncap is a really good brand.
https://de.aliexpress.com/item/4000314891877.html
https://de.aliexpress.com/item/1005004990716404.html
But take care that you order DTR caps
Offline ZakW
  • YouTube @QZW_Labs
« Reply #7 on: February 21, 2024, 11:37:47 PM »
Nice output, thanks for sharing!
« Reply #8 on: February 22, 2024, 12:53:22 AM »
It looks like that antenna is getting a workout. I see corona coming off the tip during every pulse.
The "simple driver" works great. Used it two coils, a DRSSTC and a QCW.  Glad to hear Eugene is still OK. He is a good guy...
« Last Edit: February 22, 2024, 12:56:42 AM by alan sailer »
post Re: First DRSSTC SKM100
Today at 05:58:27 AM
post Tesla coil UV eye protection?
Today at 05:17:22 AM
post Re: Tenebrescent Potassium Iodide
Today at 12:39:59 AM
April 23, 2024, 11:07:41 PM
April 23, 2024, 10:57:39 PM
OmGigaTron
April 23, 2024, 09:33:49 PM
April 23, 2024, 06:00:42 PM
April 23, 2024, 03:50:49 AM
April 23, 2024, 03:13:31 AM
April 23, 2024, 12:50:40 AM
April 22, 2024, 11:21:06 PM
April 22, 2024, 08:11:00 PM
April 22, 2024, 06:15:30 PM
April 22, 2024, 05:52:50 PM
post Tenebrescent Potassium Iodide
April 22, 2024, 05:52:13 PM
April 22, 2024, 04:31:52 PM
April 22, 2024, 04:05:34 PM
April 22, 2024, 01:02:30 PM
April 22, 2024, 06:32:35 AM
April 22, 2024, 06:24:10 AM
post M2000NM1 toroid for gdt tesla coil
April 22, 2024, 05:13:15 AM
April 22, 2024, 02:25:29 AM
April 22, 2024, 02:09:18 AM
April 22, 2024, 12:14:21 AM
April 21, 2024, 09:47:15 PM
April 21, 2024, 08:34:02 PM
April 21, 2024, 06:09:57 PM
April 21, 2024, 06:21:54 AM
post Re: Insulate the secondary of the Tesla coil with a PET plastic bottle
April 21, 2024, 06:18:30 AM
April 21, 2024, 06:12:31 AM
April 21, 2024, 05:19:55 AM
April 21, 2024, 02:29:17 AM
April 21, 2024, 01:28:59 AM
post Insulate the secondary of the Tesla coil with a PET plastic bottle
April 21, 2024, 01:19:44 AM
April 21, 2024, 12:55:25 AM
April 20, 2024, 11:25:32 PM
April 20, 2024, 10:28:26 PM
April 20, 2024, 10:23:28 PM
April 20, 2024, 10:06:44 PM
April 20, 2024, 09:21:55 PM
April 20, 2024, 09:16:14 PM
April 20, 2024, 08:58:40 PM
April 20, 2024, 06:18:26 PM
April 20, 2024, 06:15:26 PM
April 20, 2024, 03:45:43 PM
April 20, 2024, 06:33:37 AM
April 20, 2024, 05:45:04 AM
April 20, 2024, 05:34:16 AM
April 20, 2024, 04:50:57 AM
April 20, 2024, 04:03:55 AM
April 20, 2024, 02:35:56 AM
Bobakman
April 19, 2024, 09:37:52 PM
April 19, 2024, 09:20:10 PM
April 19, 2024, 07:22:26 PM
April 19, 2024, 04:46:36 PM
April 19, 2024, 03:49:28 PM
Bobakman
April 19, 2024, 01:53:57 PM
April 19, 2024, 05:24:19 AM
Tesla Junior
April 19, 2024, 04:24:09 AM
April 19, 2024, 04:20:35 AM
Bobakman
April 19, 2024, 04:05:28 AM
April 19, 2024, 04:03:54 AM
April 19, 2024, 03:19:19 AM
April 19, 2024, 03:09:29 AM
April 19, 2024, 01:47:37 AM
Bobakman
April 19, 2024, 12:19:21 AM
April 18, 2024, 11:33:01 PM
Bobakman
April 18, 2024, 11:15:15 PM
April 18, 2024, 10:59:36 PM
April 18, 2024, 10:03:48 PM
April 18, 2024, 09:53:25 PM
April 18, 2024, 09:50:09 PM
April 18, 2024, 09:15:55 PM
April 18, 2024, 08:50:49 PM
April 18, 2024, 08:11:27 PM
April 18, 2024, 07:28:05 PM
Bobakman
April 18, 2024, 06:30:30 PM
April 18, 2024, 06:03:57 PM
April 18, 2024, 05:26:13 PM
April 18, 2024, 04:03:38 PM
April 18, 2024, 02:56:40 PM
post Re: DIY induction guns? (warning:long)
April 18, 2024, 06:17:15 AM
April 18, 2024, 05:46:07 AM
April 18, 2024, 05:18:31 AM
April 18, 2024, 04:34:52 AM
April 18, 2024, 04:11:53 AM
April 18, 2024, 04:02:44 AM
April 18, 2024, 03:35:52 AM
April 17, 2024, 11:54:05 PM
April 17, 2024, 11:37:16 PM
April 17, 2024, 02:29:30 AM
April 16, 2024, 11:56:12 PM
April 16, 2024, 11:46:57 PM
Bobakman
April 16, 2024, 10:40:11 PM
April 16, 2024, 09:21:39 PM
April 16, 2024, 08:04:16 PM
April 16, 2024, 06:48:05 PM
April 16, 2024, 06:18:40 PM
April 16, 2024, 06:14:53 PM
April 16, 2024, 05:44:44 PM
