Author Topic: Anyone know of a good variable driver?  (Read 3131 times)
Offline FPS
« on: February 04, 2024, 12:56:52 AM »
Maybe it just is too hard to do but does a good flyback driver that has variable frequency and duty exist? from what I've seen they all break down at higher frequencies going from a nice square wave to an awful slope l\l\l\l\l\l\ at the trailing edge.
I've tested dimmers, and the expensive variable frequency "0.01-1.5MHz" PWM from RMCybernetics but it craps itself and cannot maintain anything that looks like a square wave beyond 1kHz.  Its writeup is good https://www.rmcybernetics.com/shop/cyber-circuits/pulse-generators/pulse-modulator-ocxi but really doesn't deliver, its decent for ignition coils though.
This is the only other one I've found with both variable freq. and duty. https://www.elecbee.com/en-31968-YF-22-PWM-Dimming-Speed-Controller-Module-Frequency-Duty-Ratio-Pulse-Adjustable-Square-Wave-Rectangu?search=frequency I've ordered but isn't here yet.
I've tried this one, ZK-PP2K PWM https://www.ebay.com.au/itm/403032556643 it's an extremely weak driver.
I've also tried switching a mosfet with a signal generator, it works but is weak.
Any schematics or modules with variable freq.?
Re: Anyone know of a good variable driver?
« Reply #1 on: February 04, 2024, 08:04:36 PM »
"Good" depends on your use-case. I designed and a flyback driver with a 38 kHz to 150 kHz range, based on TL494: https://kaizerpowerelectronics.dk/high-voltage/tl494-flyback-driver/
Offline FPS
« Reply #2 on: February 04, 2024, 08:56:14 PM »
Thankyou Mads, it seems to perform well. So its a 12v driver that switches rectified mains like the RMcybernetics one above but looks to actually give a square wave.
What limited its lowest frequency to 38kHz? Is it a huge leap to get that down to 10kHz or so?
« Reply #3 on: February 04, 2024, 09:16:25 PM »
I seem to recall that it was a trade-off between bandwidth and duty-cycle, but I honestly don't remember.
I did also make a TL494 calculator that would fit perfect for your design questions :) https://kaizerpowerelectronics.dk/calculators/tl494-calculator/
Offline FPS
« Reply #4 on: February 07, 2024, 08:17:37 AM »
For arguments sake, if you could have a "universal driver" would you prefer a variable square wave +10/0, an alternating square +10/-10, or a sinusoidal wave? or other?
I've noticed some square waves perform very well like dimmers, and some not at all or extremely weakly like motor speed controllers. I've tried numerous types and I'm not sure why.
« Last Edit: February 07, 2024, 08:23:53 AM by FPS »
Offline NyaaX_X
« Reply #5 on: February 07, 2024, 04:48:02 PM »
It may not good enough -- A comparator schmitt oscillator with triangle wave - voltage level dutycycle controller like this --
That is from Electroboom's article https://www.electroboom.com/?p=575.
And you can try other faster comparator, and simulate them on the SPICE software first to check the waveform.
« Last Edit: February 07, 2024, 04:50:36 PM by NyaaX_X »
Offline FPS
« Reply #6 on: February 28, 2024, 03:24:45 PM »
The above didn't work, set to 16kHz 50% it was a weak driver that quickly went up in a puff of smoke.
Offline FPS
« Reply #7 on: March 12, 2024, 06:54:50 PM »
This is a mosfet driven from a signal generator which seems to work quite well, at least for ignition coils.
I have an older version schematic as attached, but am wondering what the improvements in the video one are? I see a capacitor has been added but where and for what purpose?.
Cameron Prince
Today at 06:44:35 AM
post I encountered a problem using GaN for ClassE
曹靖
Today at 04:12:30 AM
post Re: p-p rms or peek
July 23, 2024, 11:12:21 PM
drobotk
July 23, 2024, 03:29:44 PM
post Re: Making a HV prove
July 23, 2024, 09:04:26 AM
July 23, 2024, 01:52:21 AM
post p-p rms or peek
July 22, 2024, 11:13:57 PM
July 22, 2024, 01:41:33 PM
post Re: Measuring 2000+ Amps DC to the Hundredths Place in the 50's and 60's.
July 22, 2024, 06:22:17 AM
post Re: DRSSTC arc extinguishing controller
曹靖
July 22, 2024, 02:52:59 AM
July 21, 2024, 11:24:34 PM
July 21, 2024, 11:12:18 PM
July 21, 2024, 08:21:43 PM
TizianoBll
July 21, 2024, 07:56:12 PM
July 21, 2024, 07:29:29 PM
Alex_1996
July 21, 2024, 06:23:19 PM
July 20, 2024, 08:37:03 PM
July 20, 2024, 08:03:19 PM
July 20, 2024, 06:43:12 PM
post DRSSTC arc extinguishing controller
曹靖
July 20, 2024, 04:46:05 AM
July 20, 2024, 04:30:21 AM
July 20, 2024, 01:22:05 AM
July 19, 2024, 08:26:43 PM
post Whirlpools, Black Holes, Event Horizon and Not At All The Same?
July 19, 2024, 02:17:33 PM
post Measuring 2000+ Amps DC to the Hundredths Place in the 50's and 60's.
July 19, 2024, 09:18:12 AM
July 18, 2024, 07:47:24 PM
July 18, 2024, 06:05:22 PM
July 18, 2024, 06:35:05 AM
July 18, 2024, 05:43:53 AM
July 17, 2024, 11:38:27 PM
July 17, 2024, 01:49:59 PM
July 17, 2024, 05:24:19 AM
July 17, 2024, 05:04:38 AM
July 17, 2024, 04:28:40 AM
post 8kW CW DRSSTC driven by ZVS (Mazzilli) oscillator
July 17, 2024, 04:23:46 AM
July 17, 2024, 01:31:56 AM
post Re: QCW power draw
July 16, 2024, 11:13:42 PM
July 16, 2024, 09:00:06 PM
July 16, 2024, 08:44:20 PM
post QCW power draw
July 16, 2024, 04:37:48 PM
post Lord Kelvin's Water Dropper Fountain
[Static Electricity]
Coupling
July 16, 2024, 03:31:38 PM
post Re: Running a Large DRSSTC at 100kHz
Coupling
July 16, 2024, 03:22:09 PM
July 16, 2024, 05:40:41 AM
July 16, 2024, 03:07:36 AM
Coupling
July 16, 2024, 02:18:25 AM
July 16, 2024, 02:02:35 AM
Coupling
July 16, 2024, 01:37:14 AM
July 16, 2024, 12:29:08 AM
July 15, 2024, 11:59:51 PM
July 15, 2024, 11:53:05 PM
July 15, 2024, 11:32:14 PM
July 15, 2024, 09:36:08 PM
July 15, 2024, 09:28:58 PM
July 15, 2024, 09:26:42 PM
July 15, 2024, 09:20:18 PM
July 15, 2024, 08:51:04 PM
July 15, 2024, 08:39:07 PM
post Running a Large DRSSTC at 100kHz
Coupling
July 15, 2024, 04:45:46 PM
July 15, 2024, 03:06:30 PM
July 15, 2024, 03:03:26 PM
July 15, 2024, 12:18:14 AM
July 14, 2024, 10:49:31 PM
TizianoBll
July 14, 2024, 10:47:50 PM
July 14, 2024, 10:21:40 PM
July 14, 2024, 10:00:51 PM
July 14, 2024, 09:09:17 PM
July 14, 2024, 06:03:07 AM
post Re: Problem with SSTC
July 14, 2024, 05:36:30 AM
Nunu00
July 14, 2024, 01:32:03 AM
July 13, 2024, 10:44:55 PM
Nunu00
July 13, 2024, 10:09:06 PM
July 13, 2024, 09:58:54 PM
Nunu00
July 13, 2024, 08:30:11 PM
July 13, 2024, 07:07:03 PM
Nunu00
July 12, 2024, 10:17:36 PM
post Making a HV prove
July 12, 2024, 09:01:08 PM
July 12, 2024, 01:33:37 AM
Nunu00
July 12, 2024, 12:17:32 AM
July 11, 2024, 07:38:26 PM
July 11, 2024, 06:30:00 PM
ColinHeath
July 11, 2024, 06:08:30 PM
July 11, 2024, 12:24:56 PM
July 11, 2024, 06:42:23 AM
Cameron Prince
July 11, 2024, 05:46:07 AM
Cameron Prince
July 11, 2024, 05:26:51 AM
July 11, 2024, 02:50:54 AM
Coupling
July 11, 2024, 12:59:55 AM
July 10, 2024, 07:10:34 PM
July 10, 2024, 06:52:42 PM
July 10, 2024, 06:28:19 PM
Alex_1996
July 10, 2024, 01:34:09 PM
post Re: Silicon(e) plasma
July 10, 2024, 12:09:06 AM
Nunu00
July 09, 2024, 11:52:00 PM
July 09, 2024, 07:37:22 PM
July 09, 2024, 07:30:05 PM
July 09, 2024, 03:30:49 AM
verliebt_in_neukölln17
July 09, 2024, 12:51:02 AM
July 08, 2024, 11:30:44 PM
post Re: Why so cheap?
July 08, 2024, 10:57:10 PM
July 08, 2024, 10:21:01 PM
