Author Topic: Anyone know of a good variable driver?  (Read 1645 times)
Offline FPS
« on: February 04, 2024, 12:56:52 AM »
Maybe it just is too hard to do but does a good flyback driver that has variable frequency and duty exist? from what I've seen they all break down at higher frequencies going from a nice square wave to an awful slope l\l\l\l\l\l\ at the trailing edge.
I've tested dimmers, and the expensive variable frequency "0.01-1.5MHz" PWM from RMCybernetics but it craps itself and cannot maintain anything that looks like a square wave beyond 1kHz.  Its writeup is good https://www.rmcybernetics.com/shop/cyber-circuits/pulse-generators/pulse-modulator-ocxi but really doesn't deliver, its decent for ignition coils though.
This is the only other one I've found with both variable freq. and duty. https://www.elecbee.com/en-31968-YF-22-PWM-Dimming-Speed-Controller-Module-Frequency-Duty-Ratio-Pulse-Adjustable-Square-Wave-Rectangu?search=frequency I've ordered but isn't here yet.
I've tried this one, ZK-PP2K PWM https://www.ebay.com.au/itm/403032556643 it's an extremely weak driver.
I've also tried switching a mosfet with a signal generator, it works but is weak.
Any schematics or modules with variable freq.?
Re: Anyone know of a good variable driver?
« Reply #1 on: February 04, 2024, 08:04:36 PM »
"Good" depends on your use-case. I designed and a flyback driver with a 38 kHz to 150 kHz range, based on TL494: https://kaizerpowerelectronics.dk/high-voltage/tl494-flyback-driver/
Offline FPS
« Reply #2 on: February 04, 2024, 08:56:14 PM »
Thankyou Mads, it seems to perform well. So its a 12v driver that switches rectified mains like the RMcybernetics one above but looks to actually give a square wave.
What limited its lowest frequency to 38kHz? Is it a huge leap to get that down to 10kHz or so?
« Reply #3 on: February 04, 2024, 09:16:25 PM »
I seem to recall that it was a trade-off between bandwidth and duty-cycle, but I honestly don't remember.
I did also make a TL494 calculator that would fit perfect for your design questions :) https://kaizerpowerelectronics.dk/calculators/tl494-calculator/
Offline FPS
« Reply #4 on: February 07, 2024, 08:17:37 AM »
For arguments sake, if you could have a "universal driver" would you prefer a variable square wave +10/0, an alternating square +10/-10, or a sinusoidal wave? or other?
I've noticed some square waves perform very well like dimmers, and some not at all or extremely weakly like motor speed controllers. I've tried numerous types and I'm not sure why.
« Last Edit: February 07, 2024, 08:23:53 AM by FPS »
Offline NyaaX_X
« Reply #5 on: February 07, 2024, 04:48:02 PM »
It may not good enough -- A comparator schmitt oscillator with triangle wave - voltage level dutycycle controller like this --
That is from Electroboom's article https://www.electroboom.com/?p=575.
And you can try other faster comparator, and simulate them on the SPICE software first to check the waveform.
« Last Edit: February 07, 2024, 04:50:36 PM by NyaaX_X »
Today at 07:25:48 PM
malte0811
Today at 01:38:21 PM
Today at 05:33:49 AM
Today at 02:52:07 AM
Today at 02:43:08 AM
Kevindk9
Today at 02:25:30 AM
post Kaizer VTTC 1
PhotonLab
post Re: Ramped DRSSTC
post Re: Lathe Restauration
Keybored
PhotonLab
PhotonLab
Luca c.
Keybored
PhotonLab
Keybored
post Re: TNY265 flyback issue
Lucasww
cnichols
post TNY265 flyback issue
michaelrcolton
post Re: How much power?
Terry
post Anyone used iCCFL.com?
Lucasww
post Re: SSTC bus inductance
post SSTC bus inductance
January 31, 2024, 11:43:32 PM
Ranni81
January 31, 2024, 08:03:40 PM
