Author Topic: CT phase lead problems ?  (Read 1055 times)
Offline Mathieu thm
« on: November 02, 2023, 06:21:24 PM »
Hello everyone,
I was about to do a test of my 160mm DRSSTC outside, I wanted to check the phase lead but I discovered that it was doing something weird, see the video :
The CT is a 900:1 with 10ohms burden resistor. (N30)
I may be missing something obvious, but does anyone know why and how to avoid phase lead in the CT?
« Last Edit: November 02, 2023, 07:13:32 PM by Mathieu thm »
Re: CT phase lead problems ?
« Reply #1 on: November 02, 2023, 08:55:33 PM »
Video is too close up to see overall setup.  However, I see a scope probe and ground clip near top of base.  Is that probing CT output?  How close is that probe to primary coil?  I'd guess you are getting induced voltage in probe tip/ground loop from primary coil.
Best to have CT outputs connected as twisted pair (or coax) until away from coil.  Burden resistor and scope probe are then away from coil and not picking up significant magnetic field.
Presuming CT cores are ferrite and not powdered iron.
Offline Mathieu thm
« Reply #2 on: November 02, 2023, 09:20:13 PM »
Yes, the oscilloscope probe is connected to the CT with the ground clip, now that you mention it, it's certain that the probe picks up a voltage induced by the primary coil. I understand better now, thanks!
It's not a problem to have too long a cable between the CT and the burden resistor ?
Is there any way of knowing that the current signal no longer has a voltage induced by the primary coil?
« Reply #3 on: November 02, 2023, 10:57:34 PM »
Generally not a problem, as long as wires are twisted.  I've ran ~10 meters of coax on CT output without issues.  In that case I used a burden resistor to match coax impedance.  Doubt that was critical.
Flip scope probe/ground loop over.  If no change in signal, you are far enough away.  If you wrap or tie probe ground lead adjacent probe, that will reduce loop area, so be less sensitive.  Less loop area allows closer placement.  Direct coax to scope input avoids even more loop area.
Offline Mathieu thm
« Reply #4 on: November 02, 2023, 11:22:43 PM »
Thanks for the advice ! I hope to be able to try it out tomorrow.
post Re: Many Multiple Mini Capacitor
Today at 08:06:55 PM
post Re: My DRSSTC1 rebuild / Strange GDT ringing
Today at 08:04:51 PM
LoFoTroFo
Today at 06:17:25 PM
December 01, 2024, 10:45:49 PM
December 01, 2024, 09:53:13 PM
LoFoTroFo
December 01, 2024, 03:42:44 PM
post Re: Last cap in CW always blowing up
JoeBusic
December 01, 2024, 03:30:50 PM
post Scientific Atlanta (Cisco) 1 GHz Combiner and PSU Teardown
December 01, 2024, 11:43:09 AM
post GU-81M Hartley Driven VTTC
janno288
December 01, 2024, 10:46:59 AM
post Single board for SSTC and DRSSTC operation
Simranjit
November 30, 2024, 09:10:38 PM
November 30, 2024, 07:29:22 PM
post My DRSSTC1 rebuild / Strange GDT ringing
LoFoTroFo
November 30, 2024, 01:47:58 PM
November 29, 2024, 02:10:44 PM
November 28, 2024, 09:34:29 PM
post Many Multiple Mini Capacitor
November 28, 2024, 07:52:42 PM
post Re: Oscilloscope recommendation for SSTC?
Simranjit
November 26, 2024, 11:34:05 PM
post Re: The evolution of a solid state Tesla coil
November 25, 2024, 01:03:46 AM
post GU-81M VTTC 2.7MHz Help
janno288
November 24, 2024, 01:53:22 PM
post Re: My SSTC's IGBT's blow up when toroid is added
November 21, 2024, 07:17:16 PM
November 20, 2024, 12:11:18 AM
betalab99
November 19, 2024, 05:41:27 PM
November 19, 2024, 01:33:48 PM
DashApple
November 19, 2024, 08:02:30 AM
November 19, 2024, 05:31:47 AM
November 19, 2024, 02:33:42 AM
dejuli2
November 18, 2024, 11:19:28 PM
November 18, 2024, 08:43:20 PM
DashApple
November 18, 2024, 06:07:11 PM
post Re: Is intentional overlap in the secondary theoretically possible?
MinuteMylar
November 18, 2024, 05:04:09 PM
Beggernator.
November 18, 2024, 12:17:41 PM
dejuli2
November 18, 2024, 09:25:38 AM
November 18, 2024, 01:09:10 AM
post Re: 160mm DRSSTC project
paulsimik
November 17, 2024, 11:36:52 PM
