Author Topic: Looking for a high speed comparator for use in UD2.X drivers  (Read 1420 times)
Offline Late
« on: October 16, 2023, 11:25:44 PM »
Hello there,
Recently I've been working on making my own DRSSTC driver by modifying the already existing UD2.7 design by adding some new features and replacing all the ancient parts. Also have been doing some cost optimization. Though i have ran into the issue that I'm unable to find any relatively cheap and modern replacement for the tl3116 high speed comparator that's used for the feedback on UD2.7C.
Does anyone know of any relatively cheap and relatively modern ICs that would work for this task?
Second question is does anyone maybe know of some modern, cheap and available gate driver ICs that would work here too?
Thanks in advance for help,
Late
Hi, my name is Patriks and I'm from Latvia. I'm interesting electronics, especially power electronics and high voltage. I also make content on YouTube showing my journey in the awesome world of High Voltage.
YouTube: LateNightProjects
Re: Looking for a high speed comparator for use in UD2.X drivers
« Reply #1 on: October 17, 2023, 06:22:23 AM »
I've been using TLV3501 and quite happy with it.  Input range and output swing are both rail to rail.  However, it has a single output, not differential.  Not hard to deal with if AND gates following comparitor are replaced with a mux chip such as 74AHC157 as in this version:
https://highvoltageforum.net/index.php?topic=2054.msg15611#msg15611
Rail-to-rail capability makes adding self-oscillation easier too.  In above schematic and in this snippet:
https://highvoltageforum.net/index.php?topic=1336.msg9894#msg9894
Haven't searched much for UD2.7 driver options.  With only 9V needed, there are likely lots of options.  In case interested in driving small H-bridges (ie. single TO247 IGBTs) without GDT FET buffer stage, here's a post of driver chip options good to 20V or higher:
https://highvoltageforum.net/index.php?topic=2400.msg17650#msg17650
Another option to consider:  Use logic-level FETs for buffer stage, FETs with specified on resistance etc. at Vgs of 4.5V or less.  Logic level FETs can be driven directly from 5V logic.  Eliminates need for 9V supply.  If FET gate charge is low enough, something like 74AHC157 could drive gates directly.  For larger FETs, a CMOS buffer/inverter could be added.  For a hex inverter, parallel 3 to drive each P/N FET pair.
« Last Edit: October 18, 2023, 04:55:39 AM by davekni »
Offline Anders Mikkelsen
« Reply #2 on: October 17, 2023, 04:45:31 PM »
MCP6561/MCP6562 are also nice options. Not as fast as the TLV3501 or TL3116, but very good value if your application can live with some 50 ns propagation delay.
Offline Late
« Reply #3 on: October 19, 2023, 10:04:15 AM »
Thanks for suggestion.
Could i possibly use the TLV3502 which has 2 comparators in it and just connect the inverted input of one to noninverting input of the other and noninverted of one to inverting of the other to get one of the outputs to be inverted? or would that not work?
« Last Edit: October 19, 2023, 10:06:27 AM by Late »
« Reply #4 on: October 19, 2023, 10:05:42 PM »
Probably would work.  However, if a dual comparitor is really the best option, I'd use the second comparitor as an inverter after output of first comparitor.  Or just add a normal inverter.  Dual inverters are available in small packages such as 6-lead SOT23, ie. SN74LVC2G04.
Offline Late
« Reply #5 on: October 20, 2023, 09:39:47 AM »
Okay thanks!
Also i was looking on LCSC and found this comparitor GS8743-TR. It seems to be pretty fast and its also cheap. Would it work in this application on the UD2.X type boards?
« Reply #6 on: October 20, 2023, 10:19:04 PM »
Yes, looks like a great and inexpensive comparitor.  The SOT23-5 package is small, but still large enough to hand solder.
As with TLV3501, it is single output, not differential.  Not that difficult to handle, such as with SOT23-6 LVC2G04 or using a mux chip for enable and phase reversal logic instead of AND gates.
Offline Late
« Reply #7 on: October 20, 2023, 10:39:57 PM »
I have experience soldering small parts with hand such as 0402 parts but for this board im planning to use a stencil and reflow solder the whole board so small parts arent an issue.
Yeah ik. Planning to use a small inverter ic to invert the output
Thanks for the help
post Re: Problem with SSTC
Today at 01:33:37 AM
Nunu00
Today at 12:17:32 AM
post Re: Restoring a Rogowski coil calibrator
July 11, 2024, 07:38:26 PM
July 11, 2024, 06:30:00 PM
post LOD Non Resonant SSTC?
ColinHeath
July 11, 2024, 06:08:30 PM
post Re: FIRST DRSSTC SKM400GB128D OCD SETTING
July 11, 2024, 12:24:56 PM
post Re: Strange QCW Streamer Behavior
July 11, 2024, 06:42:23 AM
post Re: Syntherrupter Lightsaber Sender Programming
Cameron Prince
July 11, 2024, 05:46:07 AM
post Syntherrupter Lightsaber Sender Programming
Cameron Prince
July 11, 2024, 05:26:51 AM
July 11, 2024, 02:50:54 AM
post Strange QCW Streamer Behavior
Coupling
July 11, 2024, 12:59:55 AM
July 10, 2024, 07:10:34 PM
post Re: Understanding and tracking upper and lower poles of QCW DRSSTC
July 10, 2024, 06:52:42 PM
July 10, 2024, 06:28:19 PM
Alex_1996
July 10, 2024, 01:34:09 PM
post Re: Silicon(e) plasma
July 10, 2024, 12:09:06 AM
Nunu00
July 09, 2024, 11:52:00 PM
post Understanding and tracking upper and lower poles of QCW DRSSTC
Simranjit
July 09, 2024, 07:37:22 PM
MechatEng2023
July 09, 2024, 07:30:05 PM
post Re: UD2.7C outputs very odd single square wave pulses
July 09, 2024, 03:30:49 AM
verliebt_in_neukölln17
July 09, 2024, 12:51:02 AM
July 08, 2024, 11:30:44 PM
post Re: Why so cheap?
July 08, 2024, 10:57:10 PM
post UD2.7C outputs very odd single square wave pulses
July 08, 2024, 10:21:01 PM
post Why so cheap?
July 08, 2024, 09:55:24 PM
Cameron Prince
July 08, 2024, 09:18:21 PM
July 08, 2024, 05:17:49 PM
Cameron Prince
July 08, 2024, 04:49:20 PM
post Re: Tesla coil in FEMM
Simranjit
July 08, 2024, 04:28:43 AM
July 08, 2024, 04:06:53 AM
post Tesla coil in FEMM
Simranjit
July 08, 2024, 03:46:49 AM
post Re: Best core material for QCW Buck modulator ?
Simranjit
July 08, 2024, 02:42:00 AM
post Re: QCWDRSSTC - Project Build
July 08, 2024, 01:37:55 AM
post Re: First DRSSTC Build- Issues with Fibernet project
Sebigamer
July 08, 2024, 12:53:08 AM
July 08, 2024, 12:49:48 AM
July 07, 2024, 11:15:35 PM
post Silicon(e) plasma
MechatEng2023
July 07, 2024, 11:04:43 PM
July 07, 2024, 09:39:07 PM
July 07, 2024, 05:32:56 PM
July 07, 2024, 02:52:19 PM
post Re: No change in Phase Lead
July 07, 2024, 02:50:04 PM
July 07, 2024, 02:20:11 PM
post Teardown of a APC SmartUPS VT 40 kVA
July 07, 2024, 10:02:22 AM
post First DRSSTC Build- Issues with Fibernet project
Sebigamer
July 07, 2024, 09:23:58 AM
July 07, 2024, 12:44:53 AM
post Re: FEMM tesla coil simulation
Simranjit
July 07, 2024, 12:08:50 AM
July 06, 2024, 10:35:49 PM
post FEMM tesla coil simulation
Simranjit
July 06, 2024, 09:42:43 PM
July 06, 2024, 06:06:23 PM
July 06, 2024, 10:21:16 AM
July 06, 2024, 10:15:42 AM
Simranjit
July 06, 2024, 04:53:56 AM
July 06, 2024, 04:42:16 AM
July 06, 2024, 04:09:50 AM
July 06, 2024, 03:07:11 AM
July 06, 2024, 03:05:18 AM
July 06, 2024, 02:37:16 AM
Simranjit
July 06, 2024, 02:20:14 AM
post QCWDRSSTC - Project Build
July 06, 2024, 01:55:14 AM
July 05, 2024, 11:50:37 PM
post Best core material for QCW Buck modulator ?
Simranjit
July 05, 2024, 10:07:04 PM
post 230v Tesla coil and krypton gas
gravitysrainbow
July 05, 2024, 07:13:25 PM
July 05, 2024, 06:17:13 PM
post Re: Phase lead inductors
July 04, 2024, 11:40:45 PM
post Re: Sling Psychrometer
July 04, 2024, 11:02:32 PM
post Phase lead inductors
July 04, 2024, 06:28:08 PM
July 04, 2024, 12:31:40 AM
Alex_1996
July 04, 2024, 12:07:21 AM
Alex_1996
July 04, 2024, 12:06:17 AM
July 03, 2024, 10:51:23 PM
July 03, 2024, 09:44:14 PM
post Re: Coax cable for DRSSTC interrupter?
July 03, 2024, 08:48:13 PM
Simranjit
July 03, 2024, 08:24:50 PM
Alex_1996
July 03, 2024, 08:12:55 PM
July 03, 2024, 07:29:53 PM
July 03, 2024, 07:21:38 PM
July 03, 2024, 05:05:39 PM
Alex_1996
July 03, 2024, 04:29:53 PM
July 03, 2024, 04:09:11 PM
post FIRST DRSSTC SKM400GB128D OCD SETTING
Alex_1996
July 03, 2024, 02:47:18 PM
post Re: Eliminating discharges from a SSTC
Alex_1996
July 03, 2024, 01:35:24 PM
July 03, 2024, 02:19:03 AM
July 03, 2024, 01:19:50 AM
post Coax cable for DRSSTC interrupter?
Simranjit
July 02, 2024, 11:29:18 PM
post Re: Is this a good pulse experiment capacitor?
July 02, 2024, 09:59:07 PM
July 02, 2024, 09:55:53 PM
post Re: Capacitor wiring for single phase 240 to split phase (180 degree) 240v
July 02, 2024, 09:44:55 PM
July 02, 2024, 07:51:37 PM
July 02, 2024, 06:14:07 PM
post Is this a good pulse experiment capacitor?
July 02, 2024, 06:02:38 PM
July 02, 2024, 11:37:46 AM
post Re: Building my first DRSSTC
July 02, 2024, 05:22:10 AM
post Re: Coulometric hourmeters
July 02, 2024, 05:16:30 AM
drobotk
July 01, 2024, 11:50:12 PM
July 01, 2024, 08:48:53 PM
post Uses for Weston's Little Bee probe
July 01, 2024, 08:40:59 AM
July 01, 2024, 08:09:42 AM
June 30, 2024, 06:49:45 AM
June 30, 2024, 03:57:13 AM
June 30, 2024, 03:19:40 AM
