Author Topic: Using PVC insulated wire instead of enamel  (Read 1567 times)
Offline PowerTech
« on: December 10, 2021, 02:54:33 PM »
How about using PVC insulated wire in diy ferrite core transformer ? (Cu 0.5mm^2, with insulation d = 2.1mm)
Using zero insulation between layers,  when done put in transformer oil + vacuum (aspirator vacuum pump) to remove air.
Re: Using PVC insulated wire instead of enamel
« Reply #1 on: December 10, 2021, 03:51:28 PM »
Insulation thickness leaves much less room for turn in the transformer core window available.
PVC insulation is rated for a lower temperature than enameled wire, so melting insulation in the middle of the winding is a real problem
I have done low voltage transformer re-windings of MOTs with PVC wire, the voltage was limited by how many turns I could fit in, but I have not yet melted it, as I do not overload it :)
Offline rikkitikkitavi
« Reply #2 on: December 15, 2021, 11:17:44 PM »
It it is for an off line transformer, you need extra insulation or triple insulated wire or what requirements a suitable standard sets.
PVC is fine for "home standard", but I would use something with a bit more resistance. Rewinding a MOT where you have a split bobin you could basically use anything with large enough. I have added secondary turns on ordinary toroids, just because that was what I had at hand, was poor and did care that it looked like s-t. Worked fine.
However , single layer insulated wire is probably not suitable for off.line and/or high voltages.
PVC and mineral oil is not a good combo.
PVC has lower temperature resistance, and the insulation will lead to higher temperature in the inner layers.
Also, you might want to have a better coupling and adding thick insulation means a more spacious winding reducing coupling, and increasing leakage inducatnce. Which might or might not be a good thing depending on topology.
I have toyed with the idea about using large cores, and triple insulated wiring in off line power supplies , but two layer enamlled wiring with 500Vrms would probably be sufficient as the voltage per turn is below wiring stand off voltage.
Which basically makes PVC wire unnecessary.
post Re: Problem with SSTC
Today at 01:33:37 AM
Nunu00
Today at 12:17:32 AM
post Re: Restoring a Rogowski coil calibrator
July 11, 2024, 07:38:26 PM
July 11, 2024, 06:30:00 PM
post LOD Non Resonant SSTC?
ColinHeath
July 11, 2024, 06:08:30 PM
post Re: FIRST DRSSTC SKM400GB128D OCD SETTING
July 11, 2024, 12:24:56 PM
post Re: Strange QCW Streamer Behavior
July 11, 2024, 06:42:23 AM
post Re: Syntherrupter Lightsaber Sender Programming
Cameron Prince
July 11, 2024, 05:46:07 AM
post Syntherrupter Lightsaber Sender Programming
Cameron Prince
July 11, 2024, 05:26:51 AM
July 11, 2024, 02:50:54 AM
post Strange QCW Streamer Behavior
Coupling
July 11, 2024, 12:59:55 AM
July 10, 2024, 07:10:34 PM
post Re: Understanding and tracking upper and lower poles of QCW DRSSTC
July 10, 2024, 06:52:42 PM
July 10, 2024, 06:28:19 PM
Alex_1996
July 10, 2024, 01:34:09 PM
post Re: Silicon(e) plasma
July 10, 2024, 12:09:06 AM
Nunu00
July 09, 2024, 11:52:00 PM
post Understanding and tracking upper and lower poles of QCW DRSSTC
Simranjit
July 09, 2024, 07:37:22 PM
MechatEng2023
July 09, 2024, 07:30:05 PM
post Re: UD2.7C outputs very odd single square wave pulses
July 09, 2024, 03:30:49 AM
verliebt_in_neukölln17
July 09, 2024, 12:51:02 AM
July 08, 2024, 11:30:44 PM
post Re: Why so cheap?
July 08, 2024, 10:57:10 PM
post UD2.7C outputs very odd single square wave pulses
July 08, 2024, 10:21:01 PM
post Why so cheap?
July 08, 2024, 09:55:24 PM
Cameron Prince
July 08, 2024, 09:18:21 PM
July 08, 2024, 05:17:49 PM
Cameron Prince
July 08, 2024, 04:49:20 PM
post Re: Tesla coil in FEMM
Simranjit
July 08, 2024, 04:28:43 AM
July 08, 2024, 04:06:53 AM
post Tesla coil in FEMM
Simranjit
July 08, 2024, 03:46:49 AM
post Re: Best core material for QCW Buck modulator ?
Simranjit
July 08, 2024, 02:42:00 AM
post Re: QCWDRSSTC - Project Build
July 08, 2024, 01:37:55 AM
post Re: First DRSSTC Build- Issues with Fibernet project
Sebigamer
July 08, 2024, 12:53:08 AM
July 08, 2024, 12:49:48 AM
July 07, 2024, 11:15:35 PM
post Silicon(e) plasma
MechatEng2023
July 07, 2024, 11:04:43 PM
July 07, 2024, 09:39:07 PM
July 07, 2024, 05:32:56 PM
July 07, 2024, 02:52:19 PM
post Re: No change in Phase Lead
July 07, 2024, 02:50:04 PM
July 07, 2024, 02:20:11 PM
post Teardown of a APC SmartUPS VT 40 kVA
July 07, 2024, 10:02:22 AM
post First DRSSTC Build- Issues with Fibernet project
Sebigamer
July 07, 2024, 09:23:58 AM
July 07, 2024, 12:44:53 AM
post Re: FEMM tesla coil simulation
Simranjit
July 07, 2024, 12:08:50 AM
July 06, 2024, 10:35:49 PM
post FEMM tesla coil simulation
Simranjit
July 06, 2024, 09:42:43 PM
July 06, 2024, 06:06:23 PM
July 06, 2024, 10:21:16 AM
July 06, 2024, 10:15:42 AM
Simranjit
July 06, 2024, 04:53:56 AM
July 06, 2024, 04:42:16 AM
July 06, 2024, 04:09:50 AM
July 06, 2024, 03:07:11 AM
July 06, 2024, 03:05:18 AM
July 06, 2024, 02:37:16 AM
Simranjit
July 06, 2024, 02:20:14 AM
post QCWDRSSTC - Project Build
July 06, 2024, 01:55:14 AM
July 05, 2024, 11:50:37 PM
post Best core material for QCW Buck modulator ?
Simranjit
July 05, 2024, 10:07:04 PM
post 230v Tesla coil and krypton gas
gravitysrainbow
July 05, 2024, 07:13:25 PM
July 05, 2024, 06:17:13 PM
post Re: Phase lead inductors
July 04, 2024, 11:40:45 PM
post Re: Sling Psychrometer
July 04, 2024, 11:02:32 PM
post Phase lead inductors
July 04, 2024, 06:28:08 PM
July 04, 2024, 12:31:40 AM
Alex_1996
July 04, 2024, 12:07:21 AM
Alex_1996
July 04, 2024, 12:06:17 AM
July 03, 2024, 10:51:23 PM
July 03, 2024, 09:44:14 PM
post Re: Coax cable for DRSSTC interrupter?
July 03, 2024, 08:48:13 PM
Simranjit
July 03, 2024, 08:24:50 PM
Alex_1996
July 03, 2024, 08:12:55 PM
July 03, 2024, 07:29:53 PM
July 03, 2024, 07:21:38 PM
July 03, 2024, 05:05:39 PM
Alex_1996
July 03, 2024, 04:29:53 PM
July 03, 2024, 04:09:11 PM
post FIRST DRSSTC SKM400GB128D OCD SETTING
Alex_1996
July 03, 2024, 02:47:18 PM
post Re: Eliminating discharges from a SSTC
Alex_1996
July 03, 2024, 01:35:24 PM
July 03, 2024, 02:19:03 AM
July 03, 2024, 01:19:50 AM
post Coax cable for DRSSTC interrupter?
Simranjit
July 02, 2024, 11:29:18 PM
post Re: Is this a good pulse experiment capacitor?
July 02, 2024, 09:59:07 PM
July 02, 2024, 09:55:53 PM
post Re: Capacitor wiring for single phase 240 to split phase (180 degree) 240v
July 02, 2024, 09:44:55 PM
July 02, 2024, 07:51:37 PM
July 02, 2024, 06:14:07 PM
post Is this a good pulse experiment capacitor?
July 02, 2024, 06:02:38 PM
July 02, 2024, 11:37:46 AM
post Re: Building my first DRSSTC
July 02, 2024, 05:22:10 AM
post Re: Coulometric hourmeters
July 02, 2024, 05:16:30 AM
drobotk
July 01, 2024, 11:50:12 PM
July 01, 2024, 08:48:53 PM
post Uses for Weston's Little Bee probe
July 01, 2024, 08:40:59 AM
July 01, 2024, 08:09:42 AM
June 30, 2024, 06:49:45 AM
June 30, 2024, 03:57:13 AM
June 30, 2024, 03:19:40 AM
