Author Topic: Ferrite material for GDT SSTC/DRSSTC  (Read 244 times)
Offline thedark
« on: May 05, 2024, 02:21:54 AM »
I'm looking at what kind of core material for the GDT but I haven't found much relevant information or they are hidden somewhere in there. How do I determine the size of the core, and how do I select its material. Can MnZn or NiZn be used or must it have a permeability that adjusts to the operating frequency of the TC?
I plan to run it between 300 to 400 kHz.
Also, the igbt that I plan to use is the IXGR50N60BD1, which has a gate voltage of +-20V. Can it be operated at 20v or should I be a little lower, like 18v?
Re: Ferrite material for GDT SSTC/DRSSTC
« Reply #1 on: May 05, 2024, 03:05:44 AM »
NiZn is rarely used below 1MHz due to higher loss.  Advantage for some cases is it's an electrical insulator at room temperature.  (But not when hot.)
+-24V is fine if you want to push current.  20V limit is for high reliability under continuous use for years.  TCs typically operate for a few hours total ever.
Looks like an obsolete IGBT part.  Is it fast enough for 300-400kHz even with ZCS operation?  (And parts from EBay etc. are often counterfeit, so may be slower or not be robust at rated current.)
Offline thedark
« Reply #2 on: May 05, 2024, 04:28:40 AM »
Thank for the response, I found 9 of this in ebay say NOS but I dont know it fake or not   but that it waiting for payment, the seller have a lot of old type ic diode other https://www.ebay.com/itm/155355207170.
I see some TC esign with diferent IGBT but the time it similar
Offline thedark
« Reply #3 on: May 05, 2024, 04:49:39 AM »
What difference would there be, if I use the E core that comes in the SMPS or a C core from the old television flybacks? Is there a way to determine its permeability to know what material it is like you would with a ferrite toroid? And about the gate resistance, how do I determine its value?
Offline alan sailer
« Reply #4 on: May 05, 2024, 04:28:35 PM »
My two cents is neither would be a good idea. I have bought a fair number of old flybacks off ebay and the operating frequencies are all below 100kHz. The same goes for a typical switcher. I have seen a number of threads on this forum where builders have tried to use cores from switchers to run a tesla coil with bad results.
If you have a signal generator and a scope it's fairly easy to wind a sample transformers and judge for yourself...
Cheers.
May 18, 2024, 11:30:11 PM
May 18, 2024, 10:10:56 PM
Domo
May 18, 2024, 09:46:17 PM
May 18, 2024, 08:05:36 PM
post Re: Help an EE student
May 18, 2024, 05:59:21 AM
May 18, 2024, 05:44:41 AM
May 18, 2024, 01:55:42 AM
May 17, 2024, 11:49:33 PM
May 17, 2024, 10:18:46 PM
May 17, 2024, 07:24:22 PM
May 17, 2024, 07:14:35 PM
May 17, 2024, 08:35:38 AM
May 17, 2024, 05:34:10 AM
post Re: colored 50 Ohm coax
May 16, 2024, 10:53:53 PM
May 16, 2024, 10:37:50 PM
May 16, 2024, 10:29:30 PM
May 16, 2024, 08:26:41 PM
May 16, 2024, 06:54:05 PM
May 16, 2024, 05:04:41 PM
AntoineRcbs
May 16, 2024, 12:13:47 PM
Domo
May 16, 2024, 06:58:12 AM
May 16, 2024, 06:47:09 AM
May 16, 2024, 06:00:49 AM
May 16, 2024, 05:45:08 AM
May 16, 2024, 05:03:41 AM
May 16, 2024, 04:58:40 AM
May 16, 2024, 04:36:40 AM
May 16, 2024, 12:28:27 AM
post Re: Watercooling
May 15, 2024, 11:13:48 PM
May 15, 2024, 10:58:05 PM
post colored 50 Ohm coax
May 15, 2024, 08:31:48 PM
May 15, 2024, 07:56:38 PM
May 15, 2024, 06:29:59 PM
Felix B.
May 15, 2024, 04:04:14 PM
May 15, 2024, 03:32:57 PM
post DRSSTC grounding issues
Felix B.
May 15, 2024, 03:07:39 PM
samsonwilliams
May 15, 2024, 05:50:59 AM
Domo
May 15, 2024, 05:38:14 AM
May 15, 2024, 04:58:02 AM
post Re: Big Coil Build Log
May 15, 2024, 04:34:49 AM
May 15, 2024, 04:30:18 AM
May 15, 2024, 04:00:55 AM
May 15, 2024, 03:21:51 AM
May 14, 2024, 11:12:22 PM
May 14, 2024, 11:00:00 PM
May 14, 2024, 09:45:38 PM
May 14, 2024, 09:02:28 PM
May 14, 2024, 05:55:24 AM
May 14, 2024, 05:44:12 AM
May 14, 2024, 05:11:54 AM
May 13, 2024, 11:44:56 PM
Domo
May 13, 2024, 10:28:34 PM
May 13, 2024, 10:20:19 PM
Domo
May 13, 2024, 09:27:58 PM
May 13, 2024, 09:06:59 PM
Domo
May 13, 2024, 08:43:49 PM
May 13, 2024, 07:25:29 PM
May 13, 2024, 06:50:59 PM
May 13, 2024, 03:47:08 PM
May 13, 2024, 03:42:58 PM
May 13, 2024, 07:09:16 AM
May 13, 2024, 05:02:46 AM
May 13, 2024, 02:25:25 AM
May 13, 2024, 01:39:11 AM
post Re: Plasma Toroid
May 13, 2024, 01:33:21 AM
May 12, 2024, 10:56:53 PM
May 12, 2024, 05:10:40 PM
May 12, 2024, 04:24:44 PM
May 12, 2024, 04:10:54 PM
May 12, 2024, 04:04:11 PM
hal7rr
May 12, 2024, 03:56:57 PM
May 12, 2024, 03:46:45 PM
hal7rr
May 12, 2024, 02:59:16 PM
May 12, 2024, 02:51:27 PM
May 12, 2024, 02:49:42 PM
May 12, 2024, 08:34:39 AM
May 12, 2024, 08:30:29 AM
May 12, 2024, 02:35:17 AM
May 12, 2024, 02:07:32 AM
May 11, 2024, 09:55:59 PM
May 11, 2024, 06:16:22 PM
hal7rr
May 11, 2024, 05:24:34 PM
May 11, 2024, 10:39:24 AM
May 11, 2024, 07:02:20 AM
May 11, 2024, 06:40:50 AM
paulp1776
May 11, 2024, 06:23:59 AM
May 11, 2024, 05:27:22 AM
May 11, 2024, 01:37:37 AM
May 11, 2024, 12:10:44 AM
Luca c.
May 10, 2024, 09:38:05 PM
May 10, 2024, 09:24:21 PM
May 10, 2024, 08:43:11 PM
May 10, 2024, 08:33:47 PM
post Weird AC/DC mini SSTC build review
May 10, 2024, 05:34:15 AM
post Re: Question about using mains power and variacs to power this circuit
May 10, 2024, 05:08:38 AM
May 10, 2024, 03:02:13 AM
May 10, 2024, 01:39:53 AM
May 10, 2024, 12:06:50 AM
May 09, 2024, 07:10:19 PM
May 09, 2024, 06:59:22 PM
