Author Topic: Air cored inductors proximity to conductive objects  (Read 1143 times)
Offline John123
  • All the gear, no idea. UK
« on: November 23, 2022, 01:10:17 AM »
Can air cored inductors be influenced by proximity to other conductive things such as heatsinks even if nothing actually enters the inside of the windings? I'm talking about simple ones such as this:
Re: Air cored inductors proximity to conductive objects
« Reply #1 on: November 23, 2022, 04:44:20 AM »
Yes, but much less so than similar ferrite-core inductors.  With air-core, most of the magnetic reluctance is where field is concentrated through core center.  With lots of area for field to return outside of the coil, blocking some of that return path has only a tiny effect.  Unless you block much of it, such as if you milled a slot in a heatsink and placed it over the coil blocking most field return paths.
« Reply #2 on: November 23, 2022, 09:29:01 AM »
It would be very dependent on the aspect ratio of the coil - long skinny vs wide flat.  This is how basic metal detectors work, after all, by using a wide flat coil.
Offline John123
« Reply #3 on: November 23, 2022, 11:27:18 PM »
Thanks Dave, here's some photos of it. Excuse the messy amateur DIY construction.
It's a single layer coil measuring 32.5mm x 15mm and about 26 turns of litz wire (was aiming for a couple uH). It's 12mm at its closest point from the grounded heatsink. Flying blue wire is circuit ground.
« Last Edit: November 23, 2022, 11:30:29 PM by John123 »
« Reply #4 on: November 24, 2022, 03:02:11 AM »
Looks fine.  Heat sink should have negligible effect on inductance of coil with that geometry.
Today at 02:31:59 PM
Today at 02:30:10 PM
PhotonLab
post Re: Ramped DRSSTC
post Re: Lathe Restauration
Keybored
PhotonLab
PhotonLab
Luca c.
Keybored
PhotonLab
Keybored
post Re: TNY265 flyback issue
Lucasww
cnichols
post TNY265 flyback issue
michaelrcolton
post Re: How much power?
Terry
post Anyone used iCCFL.com?
Lucasww
post Re: SSTC bus inductance
post SSTC bus inductance
January 31, 2024, 11:43:32 PM
Ranni81
January 31, 2024, 08:03:40 PM
Hysteresis
January 31, 2024, 03:34:48 PM
January 31, 2024, 05:08:10 AM
January 30, 2024, 10:17:45 PM
post How much power?
Terry
January 30, 2024, 08:07:39 PM
post Ultrasonic Plastic Welding experiments with TA-40CS transducer
January 28, 2024, 11:37:30 PM
January 28, 2024, 03:07:12 AM
post Re: First time DRSSTC Build
January 27, 2024, 02:27:29 PM
January 27, 2024, 01:26:34 PM
post Re: Determine output voltage of DRSSTC
January 27, 2024, 01:15:51 PM
January 27, 2024, 01:13:29 PM
post Determine output voltage of DRSSTC
Pavol
January 27, 2024, 11:35:35 AM
post is there a standard pinout of optical audio output connectors?
January 27, 2024, 01:47:13 AM
January 26, 2024, 11:26:11 PM
January 26, 2024, 08:24:30 PM
January 26, 2024, 05:19:18 PM
post Re: Anyone had success using analogue/digital HV panel meters?
January 26, 2024, 04:28:38 PM
Luca c.
January 26, 2024, 03:34:10 PM
January 26, 2024, 11:49:48 AM
TizianoBll
January 26, 2024, 11:04:37 AM
January 26, 2024, 06:26:58 AM
