Author Topic: Mains Staccato / T-200 VTTC  (Read 187 times)
Offline 304er
  • "Always the hard way..."
« on: October 24, 2021, 11:18:22 AM »
Hi all,
First off I want to reference this just posted thread:
Mains Staccato / SGTC
So after the success of this...
I again got to wondering on one of my VTTC's. Specifically my "new" old T-200 one. This coil also has origins in the 1980's also. This coil is normally run on just normal AC with a fairly heavy plate transformer(38 lbs). I have run this coil with my now modified German Staccato controller and a SSR switching the cathode like normal. Works great and everything nice and smooth running. Single shots and burst modes all work great. Now this coil does not get very good swords. The frequency is about 100kHz too high. This coil never originally back then had this in mind at all. But it does have interesting bushy sparks though.
So I have decided to try hooking up the SSR to the 120vac mains input on the plate transformer. Going to switch the primary of the transformer direct again. And pretty much as expected, this works great. SSR zero crossover working very well. Any controller changes are very smooth and very responsive. This coil puts out about a maximum 20" sparks at times.
I have a link to a few pictures of this setup and a video I took of this running this way:
https://photos.app.goo.gl/fMz5gAGDmjMpvq5P9
I want to say this my even seem to run even smoother than before.
Also the plate transformer runs now even cooler than before, since again not constantly energized. I have also run this coil many times now no problem this way. Some runs over 2 hours even.
I currently do not remember the idle current of this transformer, but it not much when I last checked. Now this transformer when the tube cathode was switched, it would get a little warm. Now running this way barely warm at all. Actually maybe a little surprised some here.
And a final note here, this way will not work for a level shifted supply.
I thought about this because of the charge capacitor will not charge up properly. Decided to do a slightly risky test just to be sure. I took the removed bigger old MOT with a level shifter that is now removed and not going to be used anymore on the 304 coil and test on this T-200.
As I thought this does not work well at all! Got some strange occasional small poor sparks. Did not run long for fear of hurting something.
Next I hooked this up for regular cathode switching and the coil would  now get 27" sparks maximum. But this is pushing this old coil very hard. Primary wire especially. It is not very big wire at all!!! Gets quite hot now.
Tube does fairly ok. And well since no fan on the MOT it heats up quite quickly like they normally do. Just wanted to do a quick test this way also, just to verify.
I put the plate transformer back on switching the primary again and let it run for over an hour. Still all working great.
Chris Reeland
Ladd Illinois USA
Chris Reeland
Ladd Illinois USA
Former Printer
Offline Duane B
    • Roaring 20s Superhets
Re: Mains Staccato / T-200 VTTC
« Reply #1 on: October 24, 2021, 08:04:02 PM »
Hi Chris, nice looking coil! I am impressed with the output and the staccato controller seems to work great. I see some light flashes coming from the corner of the plate transformer. Are these flashes electrical, or just reflections from the sparks coming from the top of the secondary? Again, good work!
Duane Bylund
Offline 304er
« Reply #2 on: October 25, 2021, 01:58:47 AM »
Hi Duane,
Thanks again.
Yeah this old fella does pretty good. It actually has a very inefficient primary, but does pretty good as is seen. That said, tuning...tuining....said twice on purpose is key despite other problem areas of this coil design. Getting the grid leak set up was very challenging on this fella while also getting the tank capacitance right at the same time. Dozens and dozens of trys changing things.
That said, why one would not design new better primary and this includes feedback...well for nostalgia sakes for me here :^) And actually...I enjoy a good challenge...
I like the some old with new here.
Oh...the flashing on the transformer is on some threads sticking out from the core clamp bolts. I have wrapped one wire lead to this which the whole core is grounded and bent the other wire lead straight up the side of the little neon bulb as a little antenna for my fun little RF detector.
I do something similar on my 304 VTTC also, which is a "green" neon bulb.
Mentioning my 304, this coil now has always been about getting better, good efficient design.
That said tuning is still very challenging to getting right.
Not sure if you have seen the other videos of it yet, but it "uses" at times most of the yard stick hanging behind it. Pretty good for just a single MOT and a single tube and no over voltage input. Using 120v in to MOT.
Oh... the very temporary 27" was achievable because of the vacuum variable capacitor this has in parallel with the 2 mica tank caps.
I had extra wiggle adjustment left to put on more proper capacitance needed using this VVC.
Chris Reeland
Ladd Illinois USA
Chris Reeland
Ladd Illinois USA
Former Printer
post Re: Как создать новую тему в highvoltageforum.net ??
Evaykv
Today at 01:49:46 PM
Today at 07:59:37 AM
Today at 07:54:38 AM
Today at 07:52:59 AM
Today at 07:51:01 AM
Today at 07:47:23 AM
Today at 07:37:57 AM
post Re: Someone built Big TC
Today at 07:21:43 AM
patracy
Today at 06:06:59 AM
304er
Today at 05:27:27 AM
304er
Today at 03:19:55 AM
304er
Today at 02:31:46 AM
304er
Today at 02:22:20 AM
post Driverless SSTC
bismallah
post Re: "Exploding" water
Intra
paulj
ItsChloeUwU
304er
Kamui
304er
ItsChloeUwU
304er
post "Exploding" water
November 25, 2021, 03:29:00 PM
post Как создать новую тему в highvoltageforum.net ??
Igorjel
November 25, 2021, 01:49:29 PM
paulj
304er
Intra
paulj
post Re: Hi! 811 A tesa coil
jpvvv123
304er
ItsChloeUwU
jpvvv123
jpvvv123
post Re: First DRSSTC
balazs
post Re: Safety concern
November 23, 2021, 02:16:01 PM
November 23, 2021, 09:04:25 AM
November 23, 2021, 01:33:38 AM
turtle
November 22, 2021, 09:13:05 PM
balazs
November 22, 2021, 09:12:25 PM
Kizmo
November 22, 2021, 07:56:40 PM
November 22, 2021, 07:16:43 PM
November 22, 2021, 07:13:14 PM
Kizmo
November 22, 2021, 06:55:08 PM
post First DRSSTC
balazs
November 22, 2021, 05:30:02 PM
post Re: sstc bad gdt signal
balazs
November 22, 2021, 05:21:33 PM
304er
November 22, 2021, 12:40:12 PM
November 22, 2021, 04:46:29 AM
huntergroundmind
November 22, 2021, 03:33:06 AM
November 22, 2021, 02:40:48 AM
post Re: GDT minimum frequency
November 22, 2021, 12:24:39 AM
ItsChloeUwU
November 21, 2021, 07:30:59 PM
post GDT minimum frequency
November 21, 2021, 06:27:03 PM
November 21, 2021, 06:16:06 PM
November 21, 2021, 05:23:57 AM
November 21, 2021, 05:00:10 AM
November 21, 2021, 01:49:14 AM
PowerTech
November 20, 2021, 11:34:49 PM
post Re: Is this IGBT enough?
November 20, 2021, 10:26:31 PM
post Re: discrete RF prototyping
November 20, 2021, 08:28:17 PM
PEDRO HENRIQUE
November 20, 2021, 03:33:34 PM
post Re: Building a battery powered coil
November 20, 2021, 05:03:43 AM
euthon
November 20, 2021, 04:03:01 AM
post [WTB/T] Fast high current bridge rectifiers
November 20, 2021, 03:18:05 AM
November 20, 2021, 01:06:50 AM
November 20, 2021, 12:43:50 AM
post sstc bad gdt signal
balazs
November 19, 2021, 07:01:57 PM
November 19, 2021, 05:37:42 PM
turtle
November 19, 2021, 04:03:47 PM
PowerTech
November 19, 2021, 01:02:50 PM
euthon
November 19, 2021, 02:35:49 AM
November 19, 2021, 12:25:48 AM
November 18, 2021, 11:38:16 PM
euthon
November 18, 2021, 11:00:58 PM
turtle
November 18, 2021, 10:47:03 PM
