Author Topic: DRSSTC tuning  (Read 747 times)
Offline kubajed
DRSSTC tuning
« on: October 16, 2021, 05:07:21 PM »
my tesla coil has the following properties:
1. Secondary:
Resonant frequency: without torus: 80.8 kHz, with torus: 61.8 kHz
Wire: 0,6 mm
Resistance: 145 R
Height: 1170 mm
Diameter: 250 mm
2. Primary
Inductance: 25,3 uH
Cone: fi bottom: 310 mm, fi top: 520 mm, height: 150 mm
Pipe fi 15 mm
Turns: 8
3. Torus
R = 225 mm
r = 85 mm
4. MMC
564 nF, Vdc: 16.5 kV, irms: 156 A PMB2253470KSP (6 in parallel, 5 in series)
5. Full bridge
2x ff600r12kl4c
6800u filtering
5u snubbers
8x 100 V TVS
6. Driver
Modified Predicter, additional 80 VDC minibridge. GDTs, 1:200 CTs 0.5R shunt resistor
Current and voltage without secondary (360 VDC, 1200 Apk):
The problem occurs when I add the secondary:
There is a spike on the current waveform, and this weird voltage tail. Do you know what caused it ad if this is dangerous? I'm measuring the current using additional, separated CT, the oscilloscope has grounding disconnected. With 100 VDC on the bus I am able to get about 25 cm sparks (tuned the coil more or less). I'm grounding the secondary, heat sinks, GNDs of driver and minibridge to the same point. The socket's earthing is also connected to this point.
The phase leading works correctly, I'm able to set the ZCS.
Gate waveform:
« Last Edit: October 16, 2021, 05:51:45 PM by kubajed »
Re: DRSSTC tuning
« Reply #1 on: October 16, 2021, 09:57:06 PM »
The spike on the current waveform is probably just noise, try scoping the primary current with common mode filter. The voltage tail is due to recuperation of energy back to DC capacitors through IGBT diodes, it's perfectly normal. I would say your waveforms are actually quite perfect.
Very nice clean build, but get rid of those TVS diodes on the bridge before they cause troubles :)
Marek Novotny
www.uhvlab.org
Offline kubajed
Re: DRSSTC tuning
« Reply #2 on: October 16, 2021, 10:07:03 PM »
Thank you for your reply.
Why can those diodes cause problems? I used them to suppress any voltage spikes.
I'm glad that these waveforms are ok. But I'm a bit concerned about the spark length. At 100 VAC it is about 20-30 cm to a grounded rod, no corona discharges (at least I haven't seen any during the day).
Is it the energy coming back from secondary causing the tail shape?
Also, do you think that connecting the coil's own grounding to socket's ground is a good idea?
« Last Edit: October 16, 2021, 10:13:16 PM by kubajed »
Re: DRSSTC tuning
« Reply #3 on: October 16, 2021, 10:24:27 PM »
It's fine to use them to suppress voltage transients between G-E of your IGBTs because in case the voltage spike causes them to conduct, your GDT cannot provide much current to overheat them. But the current flowing in the bridge is in orders of 1000Amps! If the TVS starts to conduct, it will overheat quickly and fail short circuit which can and will destroy your IGBTs. Those transistors can take much more avalanche energy than the TVS diode. You would need many of them in parallel. (It also adds unnecessary capacitances and inductances to the bridge).
Not all the energy from the primary gets transferred to the secondary, the tail is caused by the leftover energy in the primary getting back to DC bus capacitors.
Well it's better than nothing. I always ground the secondary to the mains socket but every time I run my coils, I connect some earth connection in parallel (Any nearby grounded object, usually central heating pipes or threaded rod stuck into ground)
Marek Novotny
www.uhvlab.org
Offline kubajed
Re: DRSSTC tuning
« Reply #4 on: October 16, 2021, 10:32:35 PM »
Than you for explanation. If that is the energy from the primary circuit, why the tail differs that much in shape with and without the secondary?
Do you have any idea what could be a cause of small arcing? I think my ground path is quite good, I put about 0.7 m of a rod into the soil nearby the coil.
Re: DRSSTC tuning
« Reply #5 on: October 17, 2021, 12:08:46 AM »
I'm not sure, but that might be because with secondary in place, some energy still gets transferred to the secondary, which might change the shape? Not sure about this one.
That is probably the best way to ground the secondary coil. But again, I'm not sure what explains the small arcs.
Maybe you just run too short on-times (unlikely). Maybe your coil still needs some tuning (more likely).
Marek Novotny
www.uhvlab.org
Offline kubajed
Re: DRSSTC tuning
« Reply #6 on: October 17, 2021, 10:24:09 AM »
The on-time was in the range of 100-200 us and about 30 BPS.
Ok, I managed to get 1 m long sparks at 100 VAC input, however they only occur when I put a grounded object as a target, no corona discharge. When I was trying to achieve longer sparks and moved the target a bit, some streamers hit the secondary (from toroid to secondary) slightly above the strike rail.
« Last Edit: October 17, 2021, 04:08:21 PM by kubajed »
Re: DRSSTC tuning
« Reply #7 on: October 17, 2021, 04:38:16 PM »
Are you using some breakout rod from the toroid?
Also, if your secondary got hit, it's an indication that you need bigger toroid to shape the electric field better for protection.
Marek Novotny
www.uhvlab.org
Offline kubajed
Re: DRSSTC tuning
« Reply #8 on: October 17, 2021, 05:23:28 PM »
Yes, I’m using a sharp rod on the top of the toroid.
Even visually the toroid is a bit small, so it’s size actually could be a problem.
Re: DRSSTC tuning
« Reply #9 on: October 17, 2021, 05:49:08 PM »
Well I don't know what's wrong with the arc size but the toroid definitely needs an upgrade. The toroid must distribute the electric field well enough to protect from any primary/secondary strikes.
I recommend you to stop with your experiments until you upgrade the topload to prevent any secondary or primary strikes which can be potentially destructive.
My rule of thumb is that the topload major diameter should be just slightly smaller than the secondary height and it's minor diameter should be just slightly smaller than the width of your secondary.
In your case I suggest R = 1000mm and r = 200mm toroid.
Marek Novotny
www.uhvlab.org
Offline Duane B
    • Roaring 20s Superhets
Re: DRSSTC tuning
« Reply #10 on: October 17, 2021, 07:34:43 PM »
Looking at the gate waveform, is the gate voltage the yellow waveform and the primary current the blue waveform? If the primary current is the blue waveform then I see a beat pattern of approximately 13 kHz (the time between the two humps). This indicates to me that the primary and secondary may be off-tune by 13 kHz.
If corona sparks are not coming off the secondary then all the stored energy has to ring down through the secondary and the primary after gate drives stop. The primary and secondary are a coupled circuit and they will ring down their energy together. I would say that most of the stored energy will be in the secondary on the ring down.
Duane Bylund
Re: DRSSTC tuning
« Reply #11 on: October 17, 2021, 09:07:55 PM »
Great details and scope plots to start this thread.  Thank you.
BTW, is that first primary-only scope plot really at 5V/div for current?  That would correspond to +-13V, or +-5200A.  Or, is your CT burden resistor 2 ohms for this scope trace (for 100A/V with 200:1 CT)?
Yes, probably a spike coupled from a secondary arc through parasitic capacitances and inductances.  Not necessary to fix.
Yes, I think that is accurate.  With primary only, the high-frequency voltage ring-down tail is the LC resonance of primary inductance with IGBT capacitance.  Secondary ring-down adds to that high-frequency ring-down, with clipping due to IGBT diodes.
Concerning grounding, I use both line ground and large counterpoise (conductive sheet under entire DRSSTC assembly against concrete or whatever surface your DRSSTC is standing on).  Can be aluminum foil or screen or whatever.  A counterpoise can be more effective (lower impedance) than a rod at DRSSTC frequencies.
Yes, I agree here.
One final suggestion:  If at all possible, I'd test after dark.  Corona is almost impossible to see in daylight.  When dark, you can spot corona and the beginning of arcs to problematic places (such as secondary coil) before they cause too much damage.
« Last Edit: October 17, 2021, 09:43:20 PM by davekni »
Offline kubajed
Re: DRSSTC tuning
« Reply #12 on: October 23, 2021, 12:01:14 AM »
Ok, thank you, I was thinking about increasing the size of the toroid, but now I see it is inevitable. Did you mean diameters instead of radiuses, so that R = 500 mm and r = 100 mm?
Yes.
This CT has a ratio of 1:85 and the resistor was 1R.
Thank you for all your suggestions. What do you think about the primary though? Does its construction result in too high coupling? Should I modify it?
« Last Edit: October 23, 2021, 12:03:43 AM by kubajed »
Re: DRSSTC tuning
« Reply #13 on: October 23, 2021, 01:05:04 AM »
Can't tell just by looking.  Enter your design information into JavaTC.  It will give great estimates of parameter values including coupling.  (Pay attention to diameter and radius entries.  JavaTC is a mix, so easy to make mistakes.)
Offline kubajed
Re: DRSSTC tuning
« Reply #14 on: October 31, 2021, 07:01:20 PM »
I used JavaTC to calculate the coupling factor, and with this primary it is 0.235. If I lower the primary by 10 cm it will be 0.145.
Re: DRSSTC tuning
« Reply #15 on: November 01, 2021, 04:34:05 AM »
Yes, 0.145 is more typical for DRSSTC.  Usual issue with high coupling is "racing sparks", small arcs up the lower part of the secondary and sometimes to the primary too.  It is possible that you sere experiencing racing sparks.  I doubt they would be visible in daylight.  Even the normal intended arcs from the break-out point can be difficult to see in daylight.
Offline kubajed
Re: DRSSTC tuning
« Reply #16 on: November 06, 2021, 04:45:07 PM »
I think I'll go for this type of a topload. What do you think?
Re: DRSSTC tuning
« Reply #17 on: November 06, 2021, 05:08:37 PM »
It will work just as fine as rings or full blown toroid. BUT. There is one but :) You need to ensure that the distance between spiral turns is no bigger than what you see in the picture, else it will start having "sharp corners", where you will get random break outs from.
Re: DRSSTC tuning
Evaykv
Today at 01:49:46 PM
Today at 07:59:37 AM
Today at 07:54:38 AM
Today at 07:52:59 AM
Today at 07:51:01 AM
Today at 07:47:23 AM
Today at 07:37:57 AM
post Re: Someone built Big TC
Today at 07:21:43 AM
patracy
Today at 06:06:59 AM
Today at 05:27:27 AM
Today at 03:19:55 AM
Today at 02:31:46 AM
Today at 02:22:20 AM
post Driverless SSTC
bismallah
post Re: "Exploding" water
Kamui
post "Exploding" water
Igorjel
post Re: First DRSSTC
balazs
post Re: Safety concern
turtle
balazs
Kizmo
Kizmo
post First DRSSTC
balazs
post Re: sstc bad gdt signal
balazs
huntergroundmind
post GDT minimum frequency
PowerTech
post Re: Is this IGBT enough?
PEDRO HENRIQUE
euthon
post sstc bad gdt signal
balazs
turtle
PowerTech
euthon
euthon
turtle
