Author Topic: Measuring TC secondary parameters  (Read 182 times)
Offline Duane B
    • Roaring 20s Superhets
« on: September 22, 2021, 05:01:22 AM »
I was just wondering how most people measure the secondary coil parameters, like effective L, C, and R at the resonant frequency? Coil Q etc.? I have seen a lot of references to JAVATC. Do most people just input data into a computer program and get the answers that way, without actually measuring things? Thanks for any input!
Duane Bylund
Re: Measuring TC secondary parameters
« Reply #1 on: September 22, 2021, 05:14:30 AM »
Most coilers start with JAVATC to get a design. Its fairly accurate if you supply all parameters. I then use a scope and a signal generator to get a more precise value of the resonant frequency of the secondary circuit and primary circuit. The initial tap point on the primary coil is supplied by JAVATC. The tap point is then refined during operation.
Offline Duane B
« Reply #2 on: September 25, 2021, 09:16:36 PM »
Most coilers probably don’t measure their secondary coil parameters. However, I’ve been doing a lot of experimenting with different types of counterpoises, top loads, and distances of the top load from the top of the coil, etc. I make secondary coil measurements quite often to see the effect different things have on R, L, and C. Since the top of the secondary is at a very high impedance and low capacitance it is difficult to make any kind of measurements there. I measure everything at the base of the coil with methods that have no appreciable effect on the circuit.
Now, I know the secondary coil has distributed capacitance, and distributed inductance for that matter, but for simplicity purposes I treat the secondary coil as a series RLC circuit with lumped components. As a matter of fact, I believe the ideal secondary coil would be a simple series circuit with lumped components. The current and resonant voltage rise along the length of the entire coil would be linear and maximum.
Here is my technique (all measurements made at the ¼ wave resonant frequency):
1. Measure resonant frequency, Fr (Fr needs to be measured accurately with a frequency counter)
2. Measure input impedance, Zin = R = Vin/In (measured with oscilloscope voltage probe and current transformer)
3. Measure half-power bandwidth, BW (bandwidth is the frequency range between the two half-power points, Fu – Fl. The half-power points are the frequencies where the input current is .7071 times the maximum current at resonance. This is a tricky measurement because the load will change on the generator and the frequency and output voltage will have to be adjusted at the same time to get the current you want and to keep the output voltage constant. Also, it is difficult to make accurate measurements with an oscilloscope).
4. Calculate Q:    Q = Fr/BW
5. Calculate X:   X = Q*Zin
6. Calculate L:    L = X/2*pi*Fr
7. Calculate C:   C = 1/2*pi*Fr*X
That’s about it. All measurements were made at the base of the coil where the impedance is low and with methods that do not appreciably effect the circuit. This “equivalent” circuit should act the same as the secondary coil from small-signal up to 10’s of kilowatts and higher (until sparks break out).
Duane Bylund
« Reply #3 on: September 25, 2021, 09:51:49 PM »
Interesting way to measure impedance.  I wonder if Q measurement would be easier or more accurate looking for the +-45 degree phase between current and voltage rather than sqrt(2) impedance.
I've always measured secondary coil inductance at low frequency, then presumed it doesn't change too much with frequency.  Of course, both winding wire skin/proximity effect and capacitance from the coil reduce inductance some.
Today at 01:58:47 AM
October 24, 2021, 10:42:48 PM
October 24, 2021, 08:21:45 PM
October 24, 2021, 08:04:02 PM
October 24, 2021, 07:56:31 PM
post My Switches Don’t Switch
October 24, 2021, 06:50:05 PM
October 24, 2021, 11:18:22 AM
post Mains Staccato / SGTC
October 24, 2021, 09:44:10 AM
October 24, 2021, 06:21:17 AM
October 24, 2021, 05:55:33 AM
October 24, 2021, 05:47:46 AM
October 24, 2021, 05:03:08 AM
October 24, 2021, 02:21:37 AM
October 23, 2021, 09:14:00 PM
October 23, 2021, 08:48:22 PM
October 23, 2021, 08:33:22 PM
October 23, 2021, 03:40:46 PM
October 23, 2021, 10:29:37 AM
October 23, 2021, 01:07:13 AM
post Re: DRSSTC tuning
October 23, 2021, 01:05:04 AM
October 23, 2021, 12:48:40 AM
kubajed
October 23, 2021, 12:01:14 AM
October 22, 2021, 11:52:23 PM
Franksmather
October 22, 2021, 08:56:59 PM
October 22, 2021, 11:58:51 AM
October 22, 2021, 07:03:26 AM
October 22, 2021, 05:04:51 AM
October 22, 2021, 04:43:23 AM
October 22, 2021, 04:27:13 AM
HVuser
October 21, 2021, 11:15:28 PM
post Re: Tesla Coil Music
October 21, 2021, 09:45:55 PM
post Re: Coin shrinking video
October 21, 2021, 08:32:37 PM
October 21, 2021, 06:10:06 PM
post Re: 3kJ coin shrinking
October 21, 2021, 06:09:19 PM
October 21, 2021, 06:07:54 PM
October 21, 2021, 01:27:29 PM
October 21, 2021, 12:37:00 PM
October 21, 2021, 06:34:26 AM
October 21, 2021, 06:06:50 AM
post 3kJ coin shrinking
October 21, 2021, 05:48:49 AM
Kevindk9
October 21, 2021, 01:11:41 AM
Kevindk9
October 21, 2021, 12:54:21 AM
October 20, 2021, 09:31:01 PM
October 20, 2021, 08:04:27 PM
AeraCura_
October 20, 2021, 05:23:00 PM
October 20, 2021, 01:22:22 PM
October 20, 2021, 01:14:06 PM
Vtroxi
October 20, 2021, 09:18:37 AM
October 20, 2021, 06:48:43 AM
post Coin shrinking video
October 20, 2021, 06:01:40 AM
