Author Topic: Resistance to protect flybacks, etc.  (Read 113 times)
Offline abstruse1
« on: September 15, 2021, 04:42:06 PM »
I see recommendations to use a resistor with HV outputs of flybacks and other transformers.  Apparently. this can be done two ways, in series or in parallel with the HV output.  Is this right?
In parallel, it seems that this makes sure the output is never completely open.  But the resistor is always in place, thereby reducing a bit of the transformer output.  Too low resistance would kill the output, while too high might not be adequate.  What is a good range of resistance for this purpose?
I'm not sure what function the resistor affords in series. Perhaps just giving a microsecond or two before the full transformer output is called upon.  Or what?  In any case, what's a good resistance range for this function?
Thanx, guys.
Abstruse1
   Been working with electicity for 60 years and still getting
      shocked!
Offline johnnyzoo
Re: Resistance to protect flybacks, etc.
« Reply #1 on: September 15, 2021, 08:20:53 PM »
A parallel resistor will provide a base load for the transformer. This may be beneficial or necessary with flyback/boost-type converters and certain resonant converters which may be damaged by overvoltage if operated without load.
A series resistor can be used to limit the output current. Whether this is necessary or useful depends entirely on the transformer/converter and the application.
Good resistance value also depends entirely on the transformer and the converter driving it. As for TV/CRT transformers, I can't immediately recommend any specific value, but a suitable parallel load resistor would probably be in the mega-ohm range or higher.
edit: I just noticed the subforum - are you asking about HV transformers in general, or cascade multipliers specifically?
« Last Edit: September 15, 2021, 08:27:14 PM by johnnyzoo »
Offline abstruse1
« Reply #2 on: September 16, 2021, 01:35:02 AM »
Thanx, Johnny. I was asking about xfmrs, but the reason I’m working with them is to drive CW multipliers. Your explanations are helpful.
Abstruse1
      shocked!
post Re: Idea for QCW DRSSTC
Today at 07:26:30 AM
post Tesla plate
Today at 01:54:49 AM
post Re: Large Rectifier Tube
Chrisader
post Idea for QCW DRSSTC
