Author Topic: mains slayer exciter HELP!!!  (Read 2959 times)
Offline Jun
« on: December 29, 2020, 04:02:33 PM »
Hi everyone.
I constructed the mains powered slayer exciter from sketchy Russian schematic, but there is problem with oscillating.
I am using 7 turns primary, 600 turns secondary, ballast which passes 2A at 230V, IRFP460 and two 12V zener diodes to clamp the gate voltage below 12V. I am also using potentiometer instead of R1 to adjust for different input voltages.
However, when I probe the gate-source voltage of the mosfet, the gate voltage is clamped below 5V which is just enough to turn on mosfet and heats up, but cannot start the oscillation.
I would like to know why the gate voltage is below 5V, and why it cannot start up the oscillation.
I would also like to know the purpose of the 1uF capacitor. Is it a resonant cap or does it help to start the oscillation.
Thank you in advance and any help is appreciated.
Offline Da_Stier
Re: mains slayer exciter HELP!!!
« Reply #1 on: December 29, 2020, 04:54:22 PM »
interesting circuit, amazingly simple for sure.
Can you show your exact circuit with the parts you used?
I guess you have a zener diode in each direction to GND?
This would explain why the gate voltage can't go up, since a Zener diode is just a normal diode in reverse.
Greetings,
Michael
« Reply #2 on: December 29, 2020, 08:47:43 PM »
Have you measured your zener diodes to verify they are 12V and not 5V?  (If you do get it to work, the original part is a 12V bidirectional TVS diode capable of 5W dissipation.  Typical small zener diodes may fry in this use.)
The only other possibility that comes to mind is a scoping artifact.  If that scope has a mode similar to Tek's "Hi-Res" mode, it may be filtering out all the oscillation at 5ms/div.  (That mode averages all the 1GHz samples within each longer sample interval for slower sweeps.  Very useful for precise low-frequency measurements, as it hides high-frequency signals and noise.)
Offline Jun
« Reply #3 on: December 30, 2020, 01:58:08 AM »
The spec is:
50 ohm 230mH inductor as ballast
10A fuse
MUR460 diode
1uF 275V santan polypropylene cap
10k resistor
12V zener
1k potentiometer
IRFP460
7 turn primary (wire from inverter microwave transformer)
600 turn secondary 26awg on 3 inch PVC
aluminium ducted topload
Powered by variac
I originally had tested 16V zener diodes but they also experienced the exact same problem.
It is not resonating at all as I would be able to the output in the secondary if it did. The mosfet is just conducting 50hz current and heats up little bit.
« Last Edit: December 30, 2020, 01:59:44 AM by Jun »
« Reply #4 on: December 30, 2020, 02:11:11 AM »
I suggest disconnecting L1 so that no power is drawn.  Then scope the gate waveform with the 1k POT at maximum (1k).  Presuming you still get 5V max, next disconnect the IRFP460 gate.  If the voltage rises, then the IRFP460 gate has been damaged, likely due to ESD before assembly or some other reason for excess voltage.  If voltage is still 5V with gate disconnected, next disconnect zener diodes.  At this point it is only a resistor divider, 10k to 1k, so must go to 1/11th of line voltage.  If not, then there is an issue with your scope or ...  If voltage does rise, then the zener diodes are bad.
Offline Jun
« Reply #5 on: December 30, 2020, 10:04:55 AM »
I think I figured out the problem. After I dismantle everything and measured the fres using normal slayer exciter, the resonant frequency was around 2MHz which might be too high for stable oscillation. I can try to reduce fres or make HFSSTC instead.
« Reply #6 on: December 30, 2020, 06:26:24 PM »
2MHz is on the high side, but might be possible with that circuit.  That still doesn't explain why the gate voltage limited at 5V, unless there was some 2MHz oscillation that didn't show up on the scope.
Offline Magneticitist
« Reply #7 on: January 08, 2021, 05:23:16 PM »
I read some comments the other day on Teslista555's new videos that brought to mind something I hadn't actually thought of before. One person was saying their gates seemed always clamped to 5v because of the zener (12v zeners) capacitance at around 1mhz. This was a shared sentiment by Teslista555 as to why he went without them and chose to protect the gate with a small filter.
Today at 04:57:47 AM
ethanwu0131
Today at 03:40:53 AM
post Re: First DRSSTC SKM100
Today at 01:31:17 AM
Michelle_
April 15, 2024, 11:19:52 PM
Michelle_
April 15, 2024, 11:10:19 PM
April 15, 2024, 11:04:19 PM
April 15, 2024, 11:02:05 PM
Michelle_
April 15, 2024, 10:57:59 PM
Michelle_
April 15, 2024, 10:55:46 PM
April 15, 2024, 10:37:32 PM
April 15, 2024, 10:05:00 PM
April 15, 2024, 09:28:50 PM
April 15, 2024, 09:06:42 PM
April 15, 2024, 08:46:32 PM
April 15, 2024, 08:38:39 PM
sky-guided
April 15, 2024, 08:23:40 PM
Bobakman
April 15, 2024, 06:43:23 PM
April 15, 2024, 06:29:10 AM
Michelle_
April 15, 2024, 05:21:53 AM
Michelle_
April 15, 2024, 05:15:33 AM
April 15, 2024, 04:07:54 AM
April 15, 2024, 03:49:03 AM
April 14, 2024, 09:46:30 PM
Michelle_
April 14, 2024, 07:31:00 PM
April 14, 2024, 02:26:19 PM
post Re: mg75q2ys40 IGBT
April 14, 2024, 07:20:54 AM
April 14, 2024, 07:18:20 AM
Michelle_
April 13, 2024, 06:46:40 AM
Michelle_
April 13, 2024, 04:18:42 AM
April 13, 2024, 03:24:20 AM
April 13, 2024, 03:20:46 AM
Michelle_
April 13, 2024, 03:13:22 AM
post Re: Capacitor Blowout
lbattraw
April 12, 2024, 09:14:58 PM
post mg75q2ys40 IGBT
thedark
April 12, 2024, 08:40:18 PM
April 12, 2024, 07:20:30 PM
April 12, 2024, 07:12:43 PM
ethanwu0131
April 12, 2024, 04:47:33 PM
April 12, 2024, 11:43:36 AM
April 12, 2024, 12:49:02 AM
April 12, 2024, 12:41:16 AM
April 12, 2024, 12:22:41 AM
Michelle_
April 11, 2024, 10:45:53 PM
April 11, 2024, 07:39:30 PM
April 11, 2024, 07:24:52 PM
sky-guided
April 11, 2024, 06:09:30 PM
April 11, 2024, 12:55:16 PM
April 11, 2024, 03:40:00 AM
sky-guided
April 11, 2024, 03:05:07 AM
Michelle_
April 11, 2024, 02:57:33 AM
April 11, 2024, 01:44:32 AM
Michelle_
April 11, 2024, 01:31:40 AM
OmGigaTron
April 11, 2024, 01:11:00 AM
April 11, 2024, 12:58:52 AM
Michelle_
April 11, 2024, 12:31:37 AM
April 11, 2024, 12:30:21 AM
April 10, 2024, 11:41:46 PM
April 10, 2024, 11:33:32 PM
Michelle_
April 10, 2024, 10:41:33 PM
April 10, 2024, 10:31:31 PM
Michelle_
April 10, 2024, 09:56:35 PM
unrealcrafter2
April 10, 2024, 08:59:26 PM
markus
April 10, 2024, 06:35:30 PM
April 10, 2024, 05:35:14 PM
post Drsstc voltage spike question
unrealcrafter2
April 10, 2024, 03:07:02 PM
Michelle_
April 10, 2024, 03:42:12 AM
Michelle_
April 10, 2024, 03:41:04 AM
sky-guided
April 10, 2024, 02:50:23 AM
Unrealeous
April 10, 2024, 01:32:17 AM
OmGigaTron
April 10, 2024, 01:26:29 AM
OmGigaTron
April 10, 2024, 01:18:35 AM
post Re: Big Coil Big Sparks
April 09, 2024, 07:34:19 PM
April 09, 2024, 06:14:27 PM
markus
April 09, 2024, 06:08:53 PM
markus
April 09, 2024, 05:15:19 PM
Michelle_
April 09, 2024, 05:11:04 PM
April 09, 2024, 06:32:16 AM
post DRSSTC V1 using BSM150
Unrealeous
April 09, 2024, 04:04:47 AM
April 09, 2024, 03:27:11 AM
April 09, 2024, 03:25:47 AM
OmGigaTron
April 09, 2024, 03:01:40 AM
sky-guided
April 09, 2024, 02:46:46 AM
OmGigaTron
April 08, 2024, 09:32:57 PM
OmGigaTron
April 08, 2024, 09:25:11 PM
April 08, 2024, 08:45:15 PM
OmGigaTron
April 08, 2024, 08:24:13 PM
post Big Coil Big Sparks
April 08, 2024, 04:02:48 PM
April 08, 2024, 03:45:30 AM
thedark
April 08, 2024, 03:35:32 AM
April 08, 2024, 03:12:45 AM
April 08, 2024, 03:03:26 AM
April 08, 2024, 02:24:41 AM
thedark
April 08, 2024, 01:29:53 AM
April 08, 2024, 12:55:50 AM
April 08, 2024, 12:38:52 AM
April 07, 2024, 11:56:02 PM
April 07, 2024, 07:49:29 PM
thedark
April 07, 2024, 06:28:12 PM
post First DRSSTC SKM100
April 07, 2024, 06:13:59 PM
April 07, 2024, 05:44:55 AM
April 07, 2024, 12:45:52 AM
