Author Topic: Journey to a small stand alone CW signal synthesizer  (Read 1930 times)
Offline Da_Stier
« on: April 06, 2020, 09:56:07 AM »
Since I do a lot of experiments, where I need many different frequencies, I was in need of a small standalone source to generate these signals.
I do own two nice RF signal generators, however they are huge, very expensive and quite overkill if I just need a single tone.
So I came across a cheap eval board for the ADF4351 synthesizer IC from Analog Devices on ebay.
At the time they cost around 40€ shipped which was an ok deal at the time.
They can generate anywhere between 35MHz and 4.4GHz. The amplitude is mainly fixed and at around -6dBm.
After playing a bit with the module, I had a list of pros and cons for it:
+ relatively cheap
+ nice frequency range
+ small
- the onboard reference is quite bad
- you have to change a solder jumper to use the external clock input
- not standalone since it has no controller
- no shielding
So I decided I will just run my own PCB for the IC and tackle all the prementioned points.
This was the first board I came up with.
While it did work, I still was not really satisfied with its performance.
Since the PCB is just normal FR4, the amplitude responce at higher frequencies was terrible (attenuating up to 14dB).
The RF switch that I used for switching over the clock reference only had about 30dB of isolation in the offstate which wasn't enough if you connected an external source but wanted to use the internal one.
And the biggest point... it was expensive.... one fully populated board had a BOM cost of around 65€ which I found pretty high.
After looking on ebay again, I saw, that the original eval boards came down in price quite significantly, selling for only 15€ now.
So I decided I would try something a bit different for the second version of the board.
I decided to use the eval board as an drop in module like I use the arduino boards.
This works really well and basically solves all the problems of V1.
The last step was some mechanical design.
I milled some aluminium shielding cans and printed some plastic lids for the bottom.
So this is the final module. It costs me around 25€ to build and can output between 35MHz and 4.4GHz.
It is controlled either via USB or UART, both connected over the DB9 connector on the front.
By using the external clock, I can lock them together on the same reference, which comes in quite handy sometimes.
I hope some of you find this small journey of interest.
Greetings,
Michael
post Re: Re-chargeable 1.5 volt lithium ion AAA batteries
Today at 04:47:35 AM
Today at 03:59:27 AM
post Re: Kaizer VTTC 1
March 28, 2024, 09:15:11 PM
post Re: capacitor and diodes. Voltage values for a CW
Alberto
March 28, 2024, 01:01:12 PM
post Re: Big Coil Build Log
March 28, 2024, 05:47:34 AM
March 28, 2024, 04:45:07 AM
March 28, 2024, 04:18:27 AM
post Push Pull VTTC
janno288
March 28, 2024, 01:10:08 AM
Alberto
March 27, 2024, 10:54:52 PM
markus
March 27, 2024, 11:53:42 AM
post Re: OCD Triggering Early + Low Output
March 27, 2024, 05:14:36 AM
post Re: Is the UD2.7C under voltage lock out basically worthless?
March 27, 2024, 04:47:48 AM
post Re: DRSSTC Questions
March 27, 2024, 04:41:59 AM
March 27, 2024, 12:04:34 AM
post Re: Super flat QCW simulation (does this look reasonable?)
toooldforthis
March 26, 2024, 11:08:14 PM
March 26, 2024, 11:07:20 PM
March 26, 2024, 10:46:29 PM
post OCD Triggering Early + Low Output
March 26, 2024, 09:03:43 PM
March 26, 2024, 08:46:59 PM
March 26, 2024, 05:02:18 PM
March 26, 2024, 03:16:03 PM
March 26, 2024, 01:41:49 PM
March 26, 2024, 04:48:22 AM
March 26, 2024, 04:16:37 AM
March 26, 2024, 04:16:24 AM
post Re: Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 26, 2024, 04:13:02 AM
March 26, 2024, 04:00:43 AM
March 26, 2024, 03:19:18 AM
March 26, 2024, 01:50:42 AM
March 25, 2024, 08:05:02 PM
March 25, 2024, 07:41:29 PM
March 25, 2024, 06:45:46 PM
March 25, 2024, 05:44:25 PM
March 25, 2024, 04:47:17 PM
March 25, 2024, 04:27:22 PM
post Re-chargeable 1.5 volt lithium ion AAA batteries
March 25, 2024, 03:57:34 PM
markus
March 25, 2024, 02:06:41 PM
March 25, 2024, 04:43:25 AM
March 25, 2024, 02:39:40 AM
March 25, 2024, 12:47:09 AM
Alberto
March 24, 2024, 07:36:32 PM
Alberto
March 24, 2024, 07:27:24 PM
March 24, 2024, 04:25:23 AM
Alberto
March 23, 2024, 10:47:35 PM
March 23, 2024, 09:30:21 PM
Alberto
March 23, 2024, 04:34:31 PM
March 23, 2024, 03:04:25 PM
Alberto
March 23, 2024, 01:38:34 PM
March 23, 2024, 04:20:03 AM
March 23, 2024, 12:54:30 AM
March 23, 2024, 12:05:57 AM
post capacitor and diodes. Voltage values for a CW
Alberto
March 22, 2024, 11:45:03 PM
OmGigaTron
March 22, 2024, 11:30:09 PM
post Smoke Screen Machine Protect 950 XP - Teardown of a Smoke Cannon!
March 22, 2024, 10:20:35 PM
post Re: Where's all this voltage coming from?
March 22, 2024, 09:21:13 PM
March 22, 2024, 03:37:11 PM
post What actually kills MOSFETs?
March 22, 2024, 05:09:20 AM
March 22, 2024, 03:57:54 AM
March 22, 2024, 02:59:25 AM
March 21, 2024, 06:31:42 PM
post Re: 2x Panasonic Inverter Microwaves - what to salvage, dangers?
March 21, 2024, 03:08:01 PM
post Re: [WTS] IGBT, Ferrite, Capacitors, Tools, PSU, Industrial components and parts
March 21, 2024, 01:37:32 PM
Alberto
March 21, 2024, 11:42:07 AM
post Re: Phase Lead Questions
March 21, 2024, 04:09:14 AM
March 21, 2024, 02:15:31 AM
post My Homemade Structural Analysis X-Ray Machine
March 21, 2024, 01:35:40 AM
March 20, 2024, 10:40:00 PM
March 20, 2024, 08:03:41 PM
March 20, 2024, 07:51:57 PM
March 20, 2024, 10:39:47 AM
March 20, 2024, 04:09:59 AM
March 20, 2024, 01:13:23 AM
March 20, 2024, 12:45:16 AM
March 20, 2024, 12:30:30 AM
March 19, 2024, 11:12:24 PM
Late
March 19, 2024, 09:47:49 PM
Late
March 19, 2024, 09:44:19 PM
post Phase Lead Questions
March 19, 2024, 06:52:09 PM
March 19, 2024, 05:02:44 PM
March 19, 2024, 05:01:41 PM
March 19, 2024, 04:31:02 PM
March 19, 2024, 03:59:54 PM
March 19, 2024, 06:41:39 AM
March 19, 2024, 04:05:49 AM
OmGigaTron
March 18, 2024, 09:08:35 PM
post Re: Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 09:07:35 PM
March 18, 2024, 08:57:06 PM
March 18, 2024, 03:51:33 PM
Late
March 18, 2024, 02:59:46 PM
Late
March 18, 2024, 02:33:25 PM
post Can I Trust This Super Cheap Site?
2020-Man
March 18, 2024, 11:02:12 AM
March 18, 2024, 02:36:11 AM
post Re: Best forum for vacuum tube amplifiers?
March 17, 2024, 07:42:55 PM
Michelle_
March 17, 2024, 04:15:14 PM
Michelle_
March 17, 2024, 05:05:04 AM
March 17, 2024, 04:50:51 AM
March 17, 2024, 04:45:17 AM
post 2x Panasonic Inverter Microwaves - what to salvage, dangers?
Michelle_
March 17, 2024, 04:17:51 AM
post Where's all this voltage coming from?
March 17, 2024, 01:29:32 AM
March 17, 2024, 12:33:06 AM
