Author Topic: Air cored inductors proximity to conductive objects  (Read 415 times)
Offline John123
  • All the gear, no idea. UK
« on: November 23, 2022, 01:10:17 AM »
Can air cored inductors be influenced by proximity to other conductive things such as heatsinks even if nothing actually enters the inside of the windings? I'm talking about simple ones such as this:
Re: Air cored inductors proximity to conductive objects
« Reply #1 on: November 23, 2022, 04:44:20 AM »
Yes, but much less so than similar ferrite-core inductors.  With air-core, most of the magnetic reluctance is where field is concentrated through core center.  With lots of area for field to return outside of the coil, blocking some of that return path has only a tiny effect.  Unless you block much of it, such as if you milled a slot in a heatsink and placed it over the coil blocking most field return paths.
Online Twospoons
« Reply #2 on: November 23, 2022, 09:29:01 AM »
It would be very dependent on the aspect ratio of the coil - long skinny vs wide flat.  This is how basic metal detectors work, after all, by using a wide flat coil.
Offline John123
« Reply #3 on: November 23, 2022, 11:27:18 PM »
Thanks Dave, here's some photos of it. Excuse the messy amateur DIY construction.
It's a single layer coil measuring 32.5mm x 15mm and about 26 turns of litz wire (was aiming for a couple uH). It's 12mm at its closest point from the grounded heatsink. Flying blue wire is circuit ground.
« Last Edit: November 23, 2022, 11:30:29 PM by John123 »
« Reply #4 on: November 24, 2022, 03:02:11 AM »
Looks fine.  Heat sink should have negligible effect on inductance of coil with that geometry.
post Re: Teardown of General Electrics 3 Million Volt Lightning Laboratory
Avenger
February 07, 2023, 11:56:13 PM
February 07, 2023, 09:14:32 PM
February 07, 2023, 05:15:53 PM
TizianoBll
February 07, 2023, 04:50:10 PM
Avenger
February 07, 2023, 02:33:52 PM
post Re: Voltage reading on the OCD resistor
Alex_1996
February 07, 2023, 11:01:32 AM
post Re: Has anyone used PCB123 ?
February 07, 2023, 08:29:21 AM
post Re: Level of vacuum to purge transformer coils
February 07, 2023, 05:25:00 AM
February 07, 2023, 05:15:22 AM
February 07, 2023, 04:55:19 AM
post Has anyone used PCB123 ?
February 07, 2023, 04:21:26 AM
February 07, 2023, 03:43:21 AM
February 06, 2023, 09:57:44 PM
February 06, 2023, 09:29:13 PM
February 06, 2023, 09:27:37 PM
February 06, 2023, 09:17:02 PM
February 06, 2023, 09:13:43 PM
February 06, 2023, 09:11:25 PM
February 06, 2023, 09:07:56 PM
February 06, 2023, 09:06:04 PM
February 06, 2023, 08:56:53 PM
February 06, 2023, 08:52:03 PM
February 06, 2023, 08:48:18 PM
February 06, 2023, 08:46:52 PM
post Teardown of General Electrics 3 Million Volt Lightning Laboratory
February 06, 2023, 08:41:13 PM
post Saving GE's 3 Million Volt Lightning Laboratory
[Crowdfunding]
February 06, 2023, 07:33:09 PM
post Re: Inverter question
RoamingD
February 06, 2023, 05:18:47 PM
February 06, 2023, 03:17:53 PM
RoamingD
February 06, 2023, 02:40:42 PM
Alex_1996
February 06, 2023, 01:04:33 PM
post Re: Chunky Windings From Distribution Transformer
February 06, 2023, 11:15:11 AM
post Re: 160mm DRSSTC project
Mathieu thm
February 05, 2023, 10:25:52 PM
February 05, 2023, 10:23:12 PM
February 05, 2023, 09:21:30 PM
post Inverter question
RoamingD
February 05, 2023, 05:42:44 PM
post Re: Another Huawei RRU3928 teardown but the 900MHz model this time
February 05, 2023, 04:17:25 PM
post Voltage reading on the OCD resistor
Alex_1996
February 04, 2023, 02:06:43 PM
Alex_1996
February 04, 2023, 01:45:58 PM
post Re: QCW questions
February 04, 2023, 05:14:57 AM
February 03, 2023, 07:39:37 AM
post Chunky Windings From Distribution Transformer
February 02, 2023, 08:48:05 PM
post Re: ud 2.7c poped caps
February 01, 2023, 04:25:30 AM
January 31, 2023, 05:20:38 PM
January 31, 2023, 04:49:32 AM
nzoomed
January 31, 2023, 02:25:40 AM
post Re: Welding a MOT
January 30, 2023, 10:36:01 PM
January 30, 2023, 10:16:14 PM
Avenger
January 30, 2023, 09:34:51 PM
January 30, 2023, 06:33:10 AM
post Re: improving zvs driver
January 30, 2023, 03:42:13 AM
January 30, 2023, 01:01:56 AM
x-rayLamp
January 30, 2023, 12:04:20 AM
January 29, 2023, 07:15:43 PM
January 29, 2023, 06:13:45 PM
Mike
January 29, 2023, 05:53:11 PM
post Please, help me (financially) build a DRSSTC
[Crowdfunding]
Pavol
January 29, 2023, 03:02:55 PM
post ud 2.7c poped caps
January 29, 2023, 02:04:59 PM
post Showa SP-103 Standalone Xray Head Teardown
January 29, 2023, 01:04:56 PM
January 29, 2023, 04:24:43 AM
January 29, 2023, 12:54:13 AM
January 28, 2023, 11:47:22 PM
January 28, 2023, 11:34:58 PM
January 28, 2023, 10:14:54 PM
January 28, 2023, 04:53:39 PM
January 28, 2023, 04:59:05 AM
post Re: First test of the SSTC
January 28, 2023, 04:44:51 AM
January 28, 2023, 04:35:22 AM
LoOdaK
January 28, 2023, 03:29:09 AM
January 27, 2023, 11:15:03 PM
January 27, 2023, 08:43:51 PM
January 27, 2023, 08:17:06 PM
January 27, 2023, 08:07:12 PM
January 27, 2023, 01:30:02 PM
x-rayLamp
January 27, 2023, 01:01:01 PM
post Re: Phase lead problems on ud2.7c
vince1
January 27, 2023, 12:49:46 PM
January 27, 2023, 06:07:49 AM
January 27, 2023, 05:22:46 AM
January 27, 2023, 05:10:14 AM
January 27, 2023, 05:05:40 AM
January 27, 2023, 04:44:24 AM
post Phase lead problems on ud2.7c
vince1
January 27, 2023, 01:26:20 AM
x-rayLamp
January 26, 2023, 08:13:24 PM
LoOdaK
January 26, 2023, 12:02:14 PM
January 26, 2023, 12:01:48 PM
post Re: Ramped SSTC - Power Supply Issues
January 26, 2023, 05:35:32 AM
January 26, 2023, 04:55:24 AM
January 26, 2023, 04:14:49 AM
January 26, 2023, 03:57:19 AM
January 26, 2023, 03:42:01 AM
January 25, 2023, 10:21:43 PM
post Welding a MOT
January 25, 2023, 09:37:27 PM
January 25, 2023, 09:36:22 PM
January 25, 2023, 08:35:49 PM
post improving zvs driver
x-rayLamp
January 25, 2023, 04:32:37 PM
nzoomed
January 25, 2023, 08:27:01 AM
January 25, 2023, 04:08:42 AM
January 24, 2023, 06:37:39 PM
January 24, 2023, 05:21:49 AM
post Re: 8 kW Induction Cooktop Teardown and Reverse engineering
January 24, 2023, 04:41:01 AM
post Ramped SSTC - Power Supply Question + General Improvements
January 23, 2023, 10:48:17 PM
