Author Topic: Vacuum pump  (Read 2267 times)
Re: Vacuum pump
« Reply #20 on: November 22, 2022, 06:40:32 AM »
One could probably  employ the same technique as used in wet-bulb humidity sensors, and soak the liquid into some kind of wick. That would give very high surface area, remove the hydrostatic pressure issue, and probably break bubbles too.
Online davekni
Re: Vacuum pump
« Reply #21 on: November 22, 2022, 06:42:31 AM »
At micron pressure levels, I don't think any bubble boiling is feasible.  I think it will be all surface evaporation/sublimation.  Mercury vapor pressure a bit above room temperature could be used, though with the hazard of mercury.  Ice at -50C or so would be reasonable, but not easy to make or know temperature accurately.
Offline Alberto
Re: Vacuum pump
« Reply #22 on: November 23, 2022, 08:45:37 AM »
Thanks for your answers
Offline Alberto
Re: Vacuum pump
« Reply #23 on: December 31, 2022, 05:58:46 PM »
Hello and happy new year! (sorry my english)
One final question. I have found a good one (15 microns advertised, probably 25 at real), but it is only 1,8 CFM (51 liters per minute). I usually see in the youtube experiment videos 4 or 5 CFM, so I don´t know if 1,8 CFM it is not enought. I mean, for small experiments with plasma and small volumes.
If i understand well at atmosferic presure that means that move 1,8 CFM, but at the moment that it starts making vacuum the rate goes down and less CFM means I´ll need more toime to get the final vacuum right?
so 1,8 CFM is OK?
thank you for all your help and advice
Online davekni
Re: Vacuum pump
« Reply #24 on: January 01, 2023, 07:50:18 PM »
I'd guess 1,8 CFM would be fine for your experiments.  I think my pump is 2,5 CFM.  Might take a bit longer to wait for outgassing of experiment containers to drop low enough.
Yes, AFAIK that is correct.  Gasses (ie tanks of compressed gas) are usually measured in the volume they would expand to at atmospheric pressure.  Same for vacuum pumps, I think.   At 1/2 atmospheric pressure, I think the pump will remove roughly 1,8 CFM of that pressure, which is 0,9 CFM at atmospheric pressure.  In other words, a 1,8 CFM vacuum pump connected to a 1,8 CF vacuum container would reduce pressure exponentially, to a factor of 1/e every minute.  Of course, this ignores outgassing or any other source of gas being added to the container.  And also of course, as pressure gets lower, approaching ultimate pump capability (ie. 25 microns), gas removal rate will decrease.
Offline Alberto
Re: Vacuum pump
« Reply #25 on: January 01, 2023, 11:24:48 PM »
Thank you!
For example, how much it last for your pump get the final vacuum? For example 0,25 liters
Re: Vacuum pump
« Reply #26 on: January 02, 2023, 12:49:25 AM »
Don't overlook the vacuum conductance of hose between chamber and pump.
It's measured in same units as pump speed (CFM, l/s, l/minute, etc.).
A 1.8 CFM (0.85 l/s) hose going to perfect vacuum would reduce chamber pressure just as fast as 1.8 CFM pump with no hose.
With hose and pump in series, you have a 0.9 CFM system.
Hose conductance varies with pressure, but is constant at the low end of our range of interest here.
I think 1.8 CFM is about 1 meter of 3/4 inch hose, and less than 2 inches of 1/4 inch hose.
There are simple formulas online.  Here's a picture from one reference
 https://www.vacuumscienceworld.com/blog/conductance-influence-in-vacuum-systems
« Last Edit: January 02, 2023, 12:55:05 AM by klugesmith »
Online davekni
Re: Vacuum pump
« Reply #27 on: January 02, 2023, 08:33:47 PM »
Great point about tubing, and good reference too!  I tend to underestimate effect of tubing when doing vacuum experiments.
Unfortunately, there is a simple calculation, and then there is reality.  Simple exponential calculation may be good to 1 mbar or so (760 microns).
A 1.8 CFM pump is 0.85 liters/second.  To make math simple, presume that tubing reduces this to 0.25 liters/second.  Then pressure would reduce by 1/e every second.  Pressure = initial_pressure * exp(-time_in_seconds).  After 7 seconds, pressure would drop by exp(-7), from 1 bar to 1 mbar.  If pump and system were ideal, pressure would reduce by another factor of 1000 over the next 7 seconds to 1 ubar (0.76 microns).
In reality, as you drop below 1 mbar, outgassing (from vacuum chamber walls, tubing, even pump internals) can add gas almost as fast as pump is removing gas.  Speed becomes dependent on rate of outgassing.  There may be ways to estimate that too, but depends strongly on material properties.  (I've also found out the hard way that many types of tubing are not good for vacuum use.  Especially typical silicone rubber tubes.  Air diffuses rapidly through tube walls.)  Getting from 1 bar to 1 mbar is much faster than getting from 1 mbar to 32 ubar (25 microns).
Offline jpsmith123
Re: Vacuum pump
« Reply #28 on: January 02, 2023, 09:42:28 PM »
Before I bought my Adixen/Pfeiffer vacuum pump (2005SD), I experimented with three or four different varieties of cheap air conditioner service type two stage rotary vane pumps, including the 3 cfm model from Harbor Freight.
I ended up returning or selling them all and saving up some more money until a good deal eventually came along on a high end pump on ebay.
Nowadays I see people selling some cheap pumps on ebay with an advertised ultimate vacuum spec. of 0.3 Pa (which would be about 2.25 millitorr) such as the following linked one.
https://www.ebay.com/itm/293778324267
I don't know if this particular pump will actually achieve the advertised ultimate vacuum, but one of the cheap pumps I bought many years ago actually buried my Varian TC gauge just like the Adixen/Pfeiffer pump does (whereas the Harbor Freight pump bottomed out at around 25 millitorr IIRC). The particular pump I had which did that was made in Argentina and it seemed well made except for the horrible mechanical design of the inlet and exhaust ports, which is why I sold it.
What I would look for today in a cheap pump would be: (1) a good ultimate vacuum spec. (I would consider 0.3 Pa to be good if it's real); (2) a pumping speed of at least a few CFM; (3) inlet and exhaust ports which have enough open area around them so that they could be adapted to connect to standard vacuum hardware e.g. KF25 flanged stuff; and (4) (if possible) gas ballast.
(In my experience, one good thing about ebay is that if you buy that vacuum pump and you find the ultimate vacuum isn't anywhere near the advertised spec. of 0.3 Pa you can return it, usually free of charge).
BTW there are a few places selling relatively inexpensive Chinese made vacuum hardware such as stainless steel tees, crosses, hoses, nipples, valves, foreline traps, etc., with KF flanges, so if you can find a pump whose inlet port is 1/4" NPT for example (and there is enough room around it), you can get an adapter like the following linked one and this will generally make it easier to use the pump.
https://www.ebay.com/itm/224801525604
Offline Alberto
Re: Vacuum pump
« Reply #29 on: January 03, 2023, 11:58:35 PM »
Thanks for all your help!!!
So, 0,3 pascals are achievable with a 2 stage pump?
Thank you
Offline jpsmith123
Re: Vacuum pump
« Reply #30 on: January 05, 2023, 03:59:06 AM »
With high end pumps that are in good shape, no doubt. And some of the cheap AC service pumps seem to be capable of it as well. In my experience I had one cheap pump that was able to get down to 1 millitorr or better (measured right at the pump's inlet port with nothing else attached) and one that didn't meet the advertised spec. which I returned.
I have a Varian #801 thermocouple gauge controller with a #531 thermocouple tube.
The #801 looks like this:
https://www.recycledgoods.com/varian-801-thermocouple-vacuum-pressure-gauge-tube-control/
You can often find them for sale (used) on ebay and elsewhere fairly inexpensively. The type 531 TC tubes can also often be found on ebay, new and used, often at a good price. Here is a spec. sheet on the tube:
https://www.agilent.com/cs/library/datasheets/public/Copy%20of%20531%20and%20536%20Thermocouple%20Gauge%20Tubes%20Data%20Sheet.pdf
And here's a publication you may find useful: "Vacuum and Leak Detection Reference Formulas, Properties, and Glossary Training Guide":
https://www.agilent.com/cs/library/brochures/brochure-vacuum-leak-detection-reference-formulas-properties-glossary-5994-5366en-agilent.pdf
Once I got the Varian #801, I wanted to put it in some kind of enclosure. I ended up buying one from Duniway:
https://www.duniway.com/part/tcg-box
If you acquire/build a TC gauge (or some other type of vacuum measurement device) first, then you can use it to test the performance (ultimate vacuum) of any pump you buy and then return the pump if it's not at least somewhere close to the advertised spec.
BTW there might be some info here that may be useful:
http://www.belljar.net/articles.html
Offline Alberto
Re: Vacuum pump
« Reply #31 on: January 05, 2023, 09:26:19 PM »
Thank you!
Re: Vacuum pump
post Re: Teardown of General Electrics 3 Million Volt Lightning Laboratory
Avenger
February 07, 2023, 11:56:13 PM
February 07, 2023, 09:14:32 PM
February 07, 2023, 05:15:53 PM
TizianoBll
February 07, 2023, 04:50:10 PM
Avenger
February 07, 2023, 02:33:52 PM
post Re: Voltage reading on the OCD resistor
Alex_1996
February 07, 2023, 11:01:32 AM
post Re: Has anyone used PCB123 ?
February 07, 2023, 08:29:21 AM
post Re: Level of vacuum to purge transformer coils
February 07, 2023, 05:25:00 AM
February 07, 2023, 05:15:22 AM
February 07, 2023, 04:55:19 AM
post Has anyone used PCB123 ?
February 07, 2023, 04:21:26 AM
February 07, 2023, 03:43:21 AM
February 06, 2023, 09:57:44 PM
February 06, 2023, 09:29:13 PM
February 06, 2023, 09:27:37 PM
February 06, 2023, 09:17:02 PM
February 06, 2023, 09:13:43 PM
February 06, 2023, 09:11:25 PM
February 06, 2023, 09:07:56 PM
February 06, 2023, 09:06:04 PM
February 06, 2023, 08:56:53 PM
February 06, 2023, 08:52:03 PM
February 06, 2023, 08:48:18 PM
February 06, 2023, 08:46:52 PM
post Teardown of General Electrics 3 Million Volt Lightning Laboratory
February 06, 2023, 08:41:13 PM
post Saving GE's 3 Million Volt Lightning Laboratory
[Crowdfunding]
February 06, 2023, 07:33:09 PM
post Re: Inverter question
RoamingD
February 06, 2023, 05:18:47 PM
February 06, 2023, 03:17:53 PM
RoamingD
February 06, 2023, 02:40:42 PM
Alex_1996
February 06, 2023, 01:04:33 PM
post Re: Chunky Windings From Distribution Transformer
February 06, 2023, 11:15:11 AM
post Re: 160mm DRSSTC project
Mathieu thm
February 05, 2023, 10:25:52 PM
February 05, 2023, 10:23:12 PM
February 05, 2023, 09:21:30 PM
post Inverter question
RoamingD
February 05, 2023, 05:42:44 PM
post Re: Another Huawei RRU3928 teardown but the 900MHz model this time
February 05, 2023, 04:17:25 PM
post Voltage reading on the OCD resistor
Alex_1996
February 04, 2023, 02:06:43 PM
Alex_1996
February 04, 2023, 01:45:58 PM
post Re: QCW questions
February 04, 2023, 05:14:57 AM
February 03, 2023, 07:39:37 AM
post Chunky Windings From Distribution Transformer
February 02, 2023, 08:48:05 PM
post Re: ud 2.7c poped caps
February 01, 2023, 04:25:30 AM
January 31, 2023, 05:20:38 PM
January 31, 2023, 04:49:32 AM
nzoomed
January 31, 2023, 02:25:40 AM
post Re: Welding a MOT
January 30, 2023, 10:36:01 PM
January 30, 2023, 10:16:14 PM
Avenger
January 30, 2023, 09:34:51 PM
January 30, 2023, 06:33:10 AM
post Re: improving zvs driver
January 30, 2023, 03:42:13 AM
January 30, 2023, 01:01:56 AM
x-rayLamp
January 30, 2023, 12:04:20 AM
January 29, 2023, 07:15:43 PM
January 29, 2023, 06:13:45 PM
Mike
January 29, 2023, 05:53:11 PM
post Please, help me (financially) build a DRSSTC
[Crowdfunding]
Pavol
January 29, 2023, 03:02:55 PM
post ud 2.7c poped caps
January 29, 2023, 02:04:59 PM
post Showa SP-103 Standalone Xray Head Teardown
January 29, 2023, 01:04:56 PM
January 29, 2023, 04:24:43 AM
January 29, 2023, 12:54:13 AM
January 28, 2023, 11:47:22 PM
January 28, 2023, 11:34:58 PM
January 28, 2023, 10:14:54 PM
January 28, 2023, 04:53:39 PM
January 28, 2023, 04:59:05 AM
post Re: First test of the SSTC
January 28, 2023, 04:44:51 AM
January 28, 2023, 04:35:22 AM
LoOdaK
January 28, 2023, 03:29:09 AM
January 27, 2023, 11:15:03 PM
January 27, 2023, 08:43:51 PM
January 27, 2023, 08:17:06 PM
January 27, 2023, 08:07:12 PM
January 27, 2023, 01:30:02 PM
x-rayLamp
January 27, 2023, 01:01:01 PM
post Re: Phase lead problems on ud2.7c
vince1
January 27, 2023, 12:49:46 PM
January 27, 2023, 06:07:49 AM
January 27, 2023, 05:22:46 AM
January 27, 2023, 05:10:14 AM
January 27, 2023, 05:05:40 AM
January 27, 2023, 04:44:24 AM
post Phase lead problems on ud2.7c
vince1
January 27, 2023, 01:26:20 AM
x-rayLamp
January 26, 2023, 08:13:24 PM
LoOdaK
January 26, 2023, 12:02:14 PM
January 26, 2023, 12:01:48 PM
post Re: Ramped SSTC - Power Supply Issues
January 26, 2023, 05:35:32 AM
January 26, 2023, 04:55:24 AM
January 26, 2023, 04:14:49 AM
January 26, 2023, 03:57:19 AM
January 26, 2023, 03:42:01 AM
January 25, 2023, 10:21:43 PM
post Welding a MOT
January 25, 2023, 09:37:27 PM
January 25, 2023, 09:36:22 PM
January 25, 2023, 08:35:49 PM
post improving zvs driver
x-rayLamp
January 25, 2023, 04:32:37 PM
nzoomed
January 25, 2023, 08:27:01 AM
January 25, 2023, 04:08:42 AM
January 24, 2023, 06:37:39 PM
January 24, 2023, 05:21:49 AM
post Re: 8 kW Induction Cooktop Teardown and Reverse engineering
January 24, 2023, 04:41:01 AM
post Ramped SSTC - Power Supply Question + General Improvements
January 23, 2023, 10:48:17 PM
