Author Topic: RF mosfets and laser generation  (Read 612 times)
Offline dru
« on: October 03, 2022, 03:31:12 AM »
I was reading the data sheet for an RF MOSFET today and was very surprised to see laser generation as the first listed application. To my knowledge the longest wavelength semiconductor laser is 450um currently, so how could a MOSFET that switches at a max of 250mhz be useful in laser generation? A quick calculation puts the shortest producible wavelength from this fet at about 1.2m. https://www.nxp.com/docs/en/data-sheet/MRF300AN.pdf
Offline Da_Stier
Re: RF mosfets and laser generation
« Reply #1 on: October 03, 2022, 10:26:07 AM »
Hi dru,
you wouldn't use them to directly generate laser light. You would build an RF source with high CW power output (normally in the 27MHz ISM band).
This generator is then used to ionize some gas to generate a laser beam.
I think it is called something along the lines of "RF doped laser" or "RF doped plasma".
I'm not really an expert in any way in this field, I only reused some of the RF equipment from it.
Greetings,
Michael
Offline dru
« Reply #2 on: October 03, 2022, 11:29:26 PM »
Hi dru,
Greetings,
Michael
Hi Michael, thanks for the response! That makes sense, I had a feeling it had something to do with gas discharge lasers. I remember when I was researching helium-neon lasers that the power supply was usually switching at much lower frequencies, around 15khz, so that's why I was confused. I did some digging and I found in some he-ne lasers used for research they excite the gas with rf generators, so I'm guessing that's the type of application of this mosfet.
Today at 04:02:35 PM
ae7b
Today at 06:53:52 AM
Keybored
Today at 12:25:37 AM
Lucasww
bobfrancis1980
Lucasww
bobfrancis1980
post GDT magnetizing current
Keybored
Lucasww
bobfrancis1980
bobfrancis1980
Keybored
bobfrancis1980
post Re: 2 Layer primary coil
post 2 Layer primary coil
tazea
Hysteresis
nzoomed
post Segmented Primary Coil
tbbrune
post Chain reactions
post P5104 40kV 20MHz probes
Benjamin_collier
tazea
post Small Coil Build
post Re: GU-81 vs. GU-81M
thehay95
nzoomed
post Re: Benjamin's DRSSTC3
post Benjamin's DRSSTC3
bobfrancis1980
coilerer
coilerer
bobfrancis1980
