Author Topic: TO247 mounting  (Read 304 times)
Offline mthome4
TO247 mounting
« on: September 18, 2022, 06:32:10 PM »
Hello, I will show you a tip to mount IGBTs in TO247 package to perform better heat dissipation.
If the IGBT mounting screw is used with an insulating pad, the IGBT may crush the pad at the screw and lift the other side of the IGBT (where there is the die), and the heat transfer is not good.
The main idea is to apply pressure just above the IGBT die for better heat dissipation.
I made metal tabs from this piece of metal, the next pictures are enough to understand without comment :
« Last Edit: September 18, 2022, 06:38:22 PM by mthome4 »
Mathieu Thomé
Offline Weston
Re: TO247 mounting
« Reply #1 on: September 19, 2022, 09:58:56 PM »
Looks like a cool idea! I have seen some similar clips in commercial products.
One thing I would be worried about is the compliance of the strap you are using, if its not springy it might just deform under load and not have much clamping force, especially after a few thermal cycles. A spring washer might help.
Luckily it does not require too much clamping force, it just has to be in the right place. A M3 screw tightened to the suggested torque provides ~200+ PSI of force on the area of the thermal pad and can warp the package, as you mentioned. But you really only need 25 - 50PSI on most thermal pads to get the minimum thermal resistance.
Re: TO247 mounting
« Reply #2 on: September 20, 2022, 05:15:35 AM »
Yes, nice implementation.  Much better than just a screw for mounting even without much springiness.  A spring washer under the screw head is a great addition.
Re: TO247 mounting
post Re: IF D95T vs IF D95OC
RoamingD
Today at 06:56:51 AM
Solhi
Solhi
Solhi
AkashaStar
Solhi
post Re: Vacuum pump
Kirby4life
RickNitro
Solhi
LoOdaK
post Re: Trichel pulses
post Trichel pulses
mthome4
Solhi
post Re: Plasma Toroid
prabhatkumar
Solhi
AkashaStar
dru
Solhi
prabhatkumar
post Re: Non-laser pointer
post IF D95T vs IF D95OC
RoamingD
Solhi
post Non-laser pointer
post Buck converter question
dru
Solhi
November 17, 2022, 03:26:32 AM
November 16, 2022, 11:23:37 PM
November 16, 2022, 08:00:54 PM
November 16, 2022, 05:09:00 PM
November 16, 2022, 04:57:27 PM
post TV flyback number of primary turns rule of thumb
November 16, 2022, 03:27:06 PM
November 16, 2022, 03:16:13 PM
post Bluetooth to aux for plasma speaker circuits
November 16, 2022, 03:00:54 PM
Solhi
November 16, 2022, 11:43:49 AM
post Re: Electrical resistance cooking
November 16, 2022, 09:00:46 AM
November 16, 2022, 08:53:42 AM
November 16, 2022, 05:45:24 AM
November 15, 2022, 08:17:46 PM
November 15, 2022, 07:25:04 PM
post Re: Yet another UD2.x pulse skipper
November 14, 2022, 12:26:19 PM
November 14, 2022, 04:57:41 AM
November 14, 2022, 12:32:54 AM
post Vacuum pump
November 13, 2022, 11:06:55 PM
November 13, 2022, 06:32:11 PM
November 13, 2022, 04:41:20 PM
post Re: QCW questions
November 13, 2022, 02:38:41 PM
November 13, 2022, 05:23:09 AM
November 12, 2022, 10:39:21 PM
November 12, 2022, 12:45:16 PM
November 12, 2022, 05:44:35 AM
November 12, 2022, 05:30:10 AM
November 12, 2022, 01:11:31 AM
November 12, 2022, 12:42:54 AM
