Author Topic: UD2.7 dual Purpose Use  (Read 1487 times)
Offline FonziDaytona
Re: UD2.7 dual Purpose Use
« Reply #20 on: September 26, 2022, 07:55:31 PM »
I wonder if I can disable UVLO, at startup, and then re-enable? Or, use a switch instead of a jumper on the Interruptor output to toggle?
-Matt
« Reply #21 on: September 27, 2022, 03:12:49 AM »
Might help, but still leaves power-up state of OCD FF indeterminate.  Random chance FF will power up enabled.
Yes, that is what I was trying to suggest.  A normally-closed push-button switch would make starting easiest.  Just a push of the button rather than toggling a switch off and then back on.
« Reply #22 on: October 12, 2022, 05:11:46 PM »
Okay, so I’ve been running this for a little now and it seems to be doing the job, but I’ve found that my IGBT gate drive resistors (5.1ohm .5watt) are getting extremely hot, and I don’t understand why.
My math:
Cm300dy-12nf has 1200nC per the data sheet. Current needed should be:
1200nC*35khz = 42mA, right? I^2R heating should only be 9mW? I don’t see why my .5w resistors are getting so hot…
-Matt
« Last Edit: October 12, 2022, 05:15:33 PM by FonziDaytona »
« Reply #23 on: October 13, 2022, 05:07:57 AM »
My math:
First, induction heating etc. applications typically run much higher duty cycles than DRSSTC.  That is why DRSSTC's have less issue with gate resistor heating.
Analog simulation is one way to see details of gate resistor power dissipation.  For simple approximations, two changes from your math:
Gate charge of 1200nC is for 0-15Vge swing.  If UD2.7 is being fed 24V, then Vge is swing -24V to +24V (48Vpp rather than 15Vpp).  Gate charge will be roughly proportional to Vpp, so 1200nC * 48V / 15V =  3840nC.  3840nC * 35kHz = 134mA.  This presumes gate resistor is paralleled by a diode, so conducting current only during Vge rising edges.
134mA is average current.  RMS current is much higher.  Presume that UD2.7 output resistance and GDT wire resistance are negligible compared to gate resistor.  Presume no internal brick gate resistors.  (I don't see any listed in specification for Cm300dy-12nf.)  Also presume instant UD2.7 output switching.  With those assumptions, average voltage across gate resistor during current flow is 24V (48V down to 0V during each Vge rising edge).  So resistor power is 134mA * 24V = 3.2W (at 100% duty cycle).
The above assumptions end up being worst-case.  Some of that 3.2W per gate will be dissipated within UD2.7 output FETs.  (A higher percentage of the additional 3.2W/gate power from falling edges is dissipated within UD2.7 output FETs.)
I've concluded that bricks are overkill for most high-duty-cycle applications, since they require high gate drive power.  TO247 IGBTs are a better fit for such uses, or small bricks.  0-15Vge drive also works better for such, presuming layout is clean enough to make negative Vge unnecessary.  (And presuming no internal gate resistors, which then require negative Vge to turn off sufficiently fast.)
Good luck with modifications to fix gate resistor power issues!
« Reply #24 on: October 13, 2022, 04:47:02 PM »
Hi David,
I knew I was missing a few things :-)
That would explain the heating, then.
I ordered some 3W 5ohm resistors…I should be able to run at a little lower frequency (30khz) and be within their ratings. I may also incorporate my Interruptor to drop the on time down a bit. I had originally planned to do this for helping with current limit if my PSU winds up exceeding expectations.
Thanks!
Matt
post Re: IF D95T vs IF D95OC
RoamingD
Today at 06:56:51 AM
Solhi
Solhi
Solhi
AkashaStar
Solhi
post Re: Vacuum pump
Kirby4life
RickNitro
Solhi
LoOdaK
post Re: Trichel pulses
post Trichel pulses
mthome4
Solhi
post Re: Plasma Toroid
Solhi
AkashaStar
dru
Solhi
post Re: Non-laser pointer
post IF D95T vs IF D95OC
RoamingD
Solhi
post Non-laser pointer
post Buck converter question
dru
Solhi
Solhi
post Vacuum pump
post Re: QCW questions
