Author Topic: Feedback problems  (Read 332 times)
Offline flyingperson23
Feedback problems
« on: August 13, 2022, 06:17:43 PM »
I don't seem to be getting enough feedback to get my ud2.7 to oscillate. Im roughly following loneocean's drsstc3 and have the same feedback transformer setup (a Fair-Rite 5977006401 Type 77 and 5000-1 for 1024:1 ratio). My cm300s are switching but I'm only getting a few hundred millivolts of feedback and it's not oscillating properly. Any ideas? What should it look like when I scope the ct output? Should I be getting a few dozen volts? And how do I verify that my igbts are switching properly?
Re: Feedback problems
« Reply #1 on: August 13, 2022, 08:00:14 PM »
I don't seem to be getting enough feedback to get my ud2.7 to oscillate....And how do I verify that my igbts are switching properly?
Do you have a signal generator and oscilloscope?  Testing with a signal generator feeding UD2.7 feedback input is the best way to verify circuit operation.
These two threads discuss similar issues:
https://highvoltageforum.net/index.php?topic=722.msg4776#msg4776
https://highvoltageforum.net/index.php?topic=1373.msg10194#msg10194
« Reply #2 on: August 14, 2022, 12:09:56 AM »
I ran it with 15v vbus with a function generator giving a 73khz input, these are the scope outputs. For the primary current, 1v=21.3A
« Reply #3 on: August 14, 2022, 01:54:04 AM »
Scope traces all look fine.  15Vbus is likely too low for UD2.7 to start oscillation.  The first half-cycle needs to generate ~200mV or more to trigger the next half-cycle and start oscillation.  200mV on 50 ohms is 4mA, or 4A of primary current.  Looks like you are getting ~3A on first half-cycle at 15Vbus.  Of course, feedback current polarity needs to be correct too.
I'd recommend initial testing at much lower interrupter frequency, 1-10Hz, not 600Hz.  Less likely to fry anything.  Short enable times are also good initially for the same reason.  Then increase bus voltage to 30-50V or so.
« Reply #4 on: August 14, 2022, 02:18:56 AM »
How do I check feedback current polarity?
« Reply #5 on: August 14, 2022, 02:25:07 AM »
Generally people just try both and see which works.  That's why UD2.7 includes jumpers to reverse polarity.
Offline Mike
« Reply #6 on: August 14, 2022, 04:20:00 AM »
To add a little more to Dave's comment. If the feedback phase is incorrect it can still oscillate, but usually at a much higher frequency than expected. In my car it was about 1.1Mhz, but I'm sure it depends on a host of application specific parameters.
mthome4
Today at 10:28:54 PM
Today at 05:32:02 PM
post Re: Is this a pulse cap
55#sofcopper
Today at 04:39:00 PM
Today at 10:28:42 AM
Today at 04:49:55 AM
Today at 12:32:58 AM
dru
October 03, 2022, 11:29:26 PM
October 03, 2022, 10:43:21 PM
October 03, 2022, 10:22:59 PM
October 03, 2022, 08:18:40 PM
post Is this a pulse cap
55#sofcopper
October 03, 2022, 07:36:49 PM
October 03, 2022, 05:20:17 PM
October 03, 2022, 10:26:07 AM
dru
October 03, 2022, 03:31:12 AM
October 03, 2022, 01:57:50 AM
October 03, 2022, 01:45:48 AM
dru
October 03, 2022, 12:17:07 AM
dru
October 03, 2022, 12:14:34 AM
October 02, 2022, 08:10:51 PM
October 02, 2022, 05:47:51 PM
October 02, 2022, 05:31:05 PM
October 02, 2022, 05:27:23 PM
mthome4
October 02, 2022, 02:24:19 PM
October 02, 2022, 01:11:56 PM
October 02, 2022, 04:48:00 AM
mthome4
October 02, 2022, 12:46:19 AM
October 01, 2022, 10:13:29 PM
dru
post Re: MMC capacitor crash
JCF
JCF
post Re: DC charging solution
dru
dru
JCF
post DC charging solution
Conrad73
post Re: Ud failure
post Re: Ud failure
mthome4
post Re: Ud failure
post What am I missing?!?!?
Conrad73
dru
post Re: Ud failure
post Re: Ud failure
post Ud failure
mthome4
Peregrine
post Re: SSTC - PCB design
Przemekk00
RoamingD
post Re: TO247 mounting
mthome4
RoamingD
RoamingD
