Author Topic: Where To Get "Free" TO-247 IGBTs and MOSFETs  (Read 1852 times)
« on: July 31, 2022, 08:57:46 PM »
A look at a box of IGBTs and MOSFETs that I have salvaged from household electronics like microwave ovens, induction stoves, solar inverters, welding machines, car and battery charges and other common high power electronics with switching inverters.
Do you have any sources for salvaging IGBTs / MOSFETs that is widely available from "household" items?
Online ZakW
Re: Where To Get "Free" TO-247 IGBTs and MOSFETs
« Reply #1 on: July 31, 2022, 10:27:33 PM »
Hey Mads,
I don't have a household source but I am fortunate to work for an ISP in my area. I am friends with the warehouse who handles recycling old equipment so every now and again i go take a look at what they have. There is usually a huge crate (5ft cubed) full of all kinds of PCBs. I have built up a nice stock of heasinks, MOSFETs, and misc diodes.
Offline Max
    • My Youtube Channel
« Reply #2 on: August 02, 2022, 07:36:07 PM »
As I commented on youtube, SMA solar inverters are popular here around. The models that are now slowly being retired/failing (a.k.a. the stuff that shows up for cheap or free) are just full of salvageable parts. Unfortunately, more recent models seem to be less salvage-friendly; f.ex. one we got installed in our house has the heatsink integrated into the casing. They're also noticeably smaller now.
Anyways, those older ones only contain the good, expensive name brand stuff. TI opamps, Avago opto-isolated gate drivers, big made-in-germany inductors, huge heatsinks, silicone cables, WAGO connectors, ... Even the unisolated faston crimp contacts all the wires give you immediately a feel of quality (it's the type with latch like these).
Also, all SMD parts on all PCBs were conformally coated.
Below the picture I included a list of everything I salvaged out of a 4 or 5kW unit whose bus capacitors blew up (MOSFETs and IGBTs seem fine). I didn't do any sort of reverse engineering but it is interesting to note that the main inverter apparently uses 1200V MOSFETs, not IGBTs.
  • Passives
    • Bunch of good quality WIMA and EPCOS foil capacitors (top right)
    • 4x EPCOS 680uF 450V (possibly bad condition, since some of them blew up (cf PCB))
    • 3x 2x2.8mH 10A 250V EPCOS Common Mode Choke Product Link
    • 3x "small", 2x large inductors - all made in germany by SMP. The small ones are likely associated to each of the three solar DC inputs, the larger ones likely related to the single phase AC output. Based on another, similar inductor from another SMA unit, the big inductors are in the ballpark of 2mH 25A.
  • Sensors
  • ICs
    • Bunch of logic ICs (74HC/AHC)
    • 7x LM258 OpAmp Dual 700kHz GBW
    • 3x TI TL084 Quad OpAmp JFET 3MHz GBW Product Link
    • 8x LM293 Comparator Dual
    • 3x TL2843 Current Mode PWM Controller Product Link
    • 3x HEF4066BT Quad SPST Analog Switch Product Link
    • 4x SFH6156-3 Opto-Coupler Product Link
    • 4x Avago HCPL-J312 2A Optio-Isolated Gate Drivers Product Link
    • 3x IR4427 Dual Low-Side Driver Product Link
  • Power
  • Misc
    • Clips for mounting the TOxxx power semiconductors to the heatsink standoffs. These weren't cheap either I'm sure.
    • 2x Massive heatsinks - about 20cm x 50cm
    • 6x EPCOS Varistor (625Vrms 6.5kApk) + Thermal fuse (3A 250V 102°C)
    • Bunch of massive WAGO PCB Connectors
    • Bunch of nice silicone cables with "solar" connectors
    • Some wires with high quality crimp contacts (these faston crimps were probably 20-30 cent each in bulk).
    • 4x Panasonic Relay SPST-NO 250V 20A (9V coil)
    • 1x 16x2 character LCD module (no backlight).
« Last Edit: August 02, 2022, 08:58:15 PM by Max »
« Reply #3 on: August 04, 2022, 08:50:24 PM »
That is an impressive amount of good stuff in one unit.
I agree on the whole-cast being shite thing. I dug through a pile of maybe 20 solar inverters and only 5 of them even had TO-247 IGBTs, rest were multi phase bricks or press-fit skiip modules. Heat sinks are cast as part of the chassis, with DC bus capacitors and inductors imbedded into it with epoxy. Its complete trash to the metal scrappers as its now a whole unit of electronics waste and they cant get the heat sink or inductors "out".
Legislation is properly so badly made that when manufacturers have to assure it will be recycled, its not necessarily recycled in a smart, re-useable or low energy cost way. It is just possible.
« Reply #4 on: August 08, 2022, 09:50:49 PM »
I found it very helpful to just search ebay for the big IGBT manufacturer names from time to time. I found everything from skm200 bricks for 5€ to an entire 400A VFD output stage which included a 20kg heatsink, 12 electrolytic caps and 6 SKM300 halfbridges for 5€ :)
Same thing goes for electrolytic capacitors, even the big ones can sometimes be found for als little as 2,50€.
Oh and regarding salvaged IGBTs from induction cookers: you can just use an induction cooker powerstage directly for a tesla coil. Thats how I got started building coils ;D
Offline dru
« Reply #5 on: November 10, 2022, 08:25:30 PM »
I pretty much only use salvaged components for my circuits, partly due to high cost of appropriately rated transistors but also because I think a lot about how many good components are being put into landfills and stuff. The best sources I've found are similar to what you listed, in general I look for devices that were designed to last a long time: Inverter microwaves, telecom power supplies, various induction heating devices (cooktops, furnaces/foundries), industrial SMPSs, arc inverter welders, high power audio amps, a treadmill, air conditioners. Anything that was designed for 24/7 operation, medical equipment, or power supplies for use in server farms etc. though those are hard to find. Any equipment used in environments where human safety was conditional on operation will have very robust components.
« Reply #6 on: August 06, 2023, 10:13:11 PM »
A look at a bag of IGBTs and MOSFETs that I quickly salvaged from industrial electronics like induction cookers, solar inverters, welding machines, car and battery charges and other common high power electronics with switching inverters.
post Re: Rotary Spark Gap Arcing Not Sustained
tbbrune
Today at 01:48:32 AM
post Re: How do you measure HV current?
October 03, 2023, 10:32:16 PM
post How do you measure HV current?
nsled
October 03, 2023, 10:09:13 PM
October 03, 2023, 07:36:37 PM
post NTC question
October 03, 2023, 07:24:34 PM
post Re: First drsstc issues
Hari33
October 03, 2023, 06:40:29 PM
post Re: First SSTC
Egg
October 03, 2023, 11:15:40 AM
post Re: Pole pigs in Australia (Europe?) vs North America
Download
October 03, 2023, 10:45:59 AM
Hari33
October 03, 2023, 09:40:15 AM
post Re: Driverless DRSSTC Interruption
Lucasww
October 03, 2023, 08:28:01 AM
Lucasww
October 03, 2023, 08:21:23 AM
post Re: First SSTC
October 03, 2023, 06:23:45 AM
post Re: First SSTC
Egg
October 03, 2023, 06:16:23 AM
post Re: cw sstc build advise (parameters)
October 03, 2023, 05:17:47 AM
October 03, 2023, 05:14:06 AM
Hari33
October 03, 2023, 05:13:00 AM
October 03, 2023, 04:30:32 AM
October 03, 2023, 03:07:31 AM
October 03, 2023, 02:53:26 AM
post First SSTC
blahaj
October 03, 2023, 02:24:27 AM
October 02, 2023, 09:56:41 PM
October 02, 2023, 06:00:47 PM
Hari33
October 02, 2023, 03:59:17 PM
October 02, 2023, 06:09:09 AM
post Pole pigs in Australia (Europe?) vs North America
Download
October 02, 2023, 05:32:52 AM
Hysteresis
October 02, 2023, 05:30:43 AM
tbbrune
October 02, 2023, 05:16:37 AM
Hysteresis
October 02, 2023, 05:11:57 AM
October 02, 2023, 04:53:08 AM
tbbrune
October 02, 2023, 04:39:17 AM
Hysteresis
October 02, 2023, 03:01:58 AM
tbbrune
October 02, 2023, 01:15:24 AM
post RDRSSTC - Project Build
October 01, 2023, 11:01:03 PM
post Re: 3kJ coin shrinking
October 01, 2023, 07:32:22 PM
October 01, 2023, 07:23:35 PM
October 01, 2023, 07:14:40 PM
Hysteresis
October 01, 2023, 04:54:44 PM
October 01, 2023, 04:52:09 PM
October 01, 2023, 04:35:41 PM
post Re: can't get enough power out of high voltage generator
Luca c.
October 01, 2023, 01:54:43 PM
October 01, 2023, 06:51:33 AM
October 01, 2023, 06:44:40 AM
October 01, 2023, 05:33:53 AM
post Driverless DRSSTC Interruption
ARCreator
October 01, 2023, 04:58:52 AM
post 40kW X-ray Machine (Huge XRT Arcs, Tube Autopsy, Mods, etc.) Part 2 video
breezetix
October 01, 2023, 01:55:15 AM
tbbrune
October 01, 2023, 12:12:39 AM
September 30, 2023, 11:18:29 PM
Hari33
September 30, 2023, 10:01:31 PM
Hari33
September 30, 2023, 09:48:42 PM
September 30, 2023, 09:31:43 PM
September 30, 2023, 09:23:25 PM
September 30, 2023, 09:13:37 PM
post Re: Question about center tap autotransformer
Egg
September 30, 2023, 07:20:35 PM
September 30, 2023, 06:59:36 PM
tbbrune
September 30, 2023, 04:45:23 PM
post Re: A DIY Flame gun
September 30, 2023, 03:24:23 PM
post Re: Interesting IGBT failure
September 30, 2023, 11:58:45 AM
Lucasww
September 30, 2023, 08:26:40 AM
September 30, 2023, 07:32:22 AM
September 30, 2023, 06:23:14 AM
post Question about center tap autotransformer
christianrodher
September 30, 2023, 05:11:00 AM
post cw sstc build advise (parameters)
September 30, 2023, 04:46:02 AM
September 30, 2023, 04:20:20 AM
September 30, 2023, 03:12:12 AM
post Re: GDT (Gate Drive Transformer) tutorial
September 30, 2023, 02:42:02 AM
September 30, 2023, 01:43:06 AM
post Re: Heatsink grounding
September 30, 2023, 01:20:27 AM
September 30, 2023, 12:32:30 AM
September 30, 2023, 12:06:24 AM
September 29, 2023, 09:35:21 PM
September 29, 2023, 09:00:54 PM
September 29, 2023, 07:15:19 PM
post Heatsink grounding
September 29, 2023, 04:33:32 PM
September 29, 2023, 04:20:52 PM
post Aliexpress Mystery Driver
September 29, 2023, 04:15:30 PM
September 29, 2023, 01:43:46 PM
post Interesting IGBT failure
September 29, 2023, 10:56:54 AM
IonWind
September 29, 2023, 09:55:11 AM
September 29, 2023, 05:49:38 AM
September 29, 2023, 12:30:30 AM
September 28, 2023, 11:01:20 PM
September 28, 2023, 10:33:46 PM
September 28, 2023, 09:40:55 PM
post A DIY Flame gun
September 28, 2023, 08:57:30 PM
post Re: Ramped SSTC build, some questions
September 28, 2023, 06:21:53 PM
Luca c.
September 28, 2023, 04:29:08 PM
September 28, 2023, 05:16:32 AM
September 28, 2023, 04:51:48 AM
September 28, 2023, 04:44:12 AM
Egg
September 27, 2023, 10:22:40 PM
Luca c.
September 27, 2023, 07:37:00 PM
September 27, 2023, 07:21:16 PM
Luca c.
September 27, 2023, 06:57:27 PM
Egg
September 27, 2023, 05:05:09 PM
September 27, 2023, 04:58:12 PM
post can't get enough power out of high voltage generator
Luca c.
September 27, 2023, 04:42:28 PM
Manz
September 27, 2023, 03:54:47 PM
September 27, 2023, 12:18:44 PM
post Re: Brass vs Copper for spark gap?
September 27, 2023, 10:30:04 AM
September 27, 2023, 05:56:15 AM
