Author Topic: Auto tuning primary?  (Read 280 times)
Offline Overlordcheese
« on: June 27, 2022, 08:36:46 PM »
I’ve had this idea for a while: what if, in addition to the primary tank capacitor, we had a system of… MMMCs I guess (triple m intended). However, they aren’t directly connected in parallel to the tank capacitor, instead a switch in the form of two mosfets or igbts connected so that it acts like a bipolar switch. At the beginning of every pulse, a microcontroller would cycle through all the possible capacitor combinations, and using secondary feedback, would measure which one produces the highest output voltage. This way, when the environment changes, the coil still performs
But people laughed at me on discord so I’m assuming there’s a stupid part to it
Re: Auto tuning primary?
« Reply #1 on: June 27, 2022, 09:15:26 PM »
There are some fundamental issues with changing the capacitance, rather than changing the inductance.
- The sweet spot of tuning a primary LC circuit is within centimeters on the primary coil. And it all depends on the spark load, this is also the issue you want to adress.
- The speed at which you have to do these calculations and switching, how much time do you have to get a good enough sampling rate, do calculations and then do switching?
- Switching on the MMC, you would properly need a lot of switches and end up with a very complex matrix that requires expensive control (fast)
I wont laugh at it, but simply say its a very over complicated solution to a not-very-problematic problem.
« Reply #2 on: June 27, 2022, 10:25:55 PM »
Start by figuring the electrical requirements of your capacitor tuning switches.
Maximum RF current (bidirectional) and resistance or Vf in a switch that is ON.
Maximum RF voltage (bipolar) across a switch that is OFF.
I'm not seeing any obvious semiconductors that are a good fit.
Perhaps vacuum relays. https://www.ebay.com/itm/254791558120 or
https://www.rossengineeringcorp.com/products/control/single-pole-hv-vacuum-contactors
Or home-made mechanical contactors, like moving a tap on primary coil to adjust inductance.
But with MMC the steps are discrete and coarse.
« Last Edit: June 27, 2022, 10:28:16 PM by klugesmith »
« Reply #3 on: June 28, 2022, 05:35:15 AM »
Both my SRSGTC and DRSSTC use MMC changes for tuning.  Primary coils are litz wire and not adjustable.  However, adjustments are all manual, connecting or removing capacitor sets.  All have connectors, so no soldering involved.  My SRSGTC has coupling factor (primary to secondary) lower than optimum and required relatively fine adjustment as Mads mentioned.  My DRSSTC is much less sensitive to tuning.  7% steps are fine.  I change from 500nF for music to 700nF for maximum spark length.  Might be related to my relatively-low impedances and high-current H-bridge.
Yes, this is the key.  Definitely not worth the work for normal tuning.
However, I am slowly building a crazy experiment to do something like you suggest.  Not for initial tuning.  Instead to adjust tuning within the duration of each enable pulse.  The idea is to add primary capacitance as the arc adds secondary capacitance.  That way primary remains in tune with secondary for longer, hopefully allowing arcs to grow longer than is possible with fixed tuning.
My design uses 448 BTB16 TRIACS as 6 banks of 4S18P.  These will short out parts of the MMC in 6 steps.  Remaining series parts of MMC will have higher capacitance when not in series with the shorted sections.  Thus the 4S18P sections never see full MMC voltage.  Trick will be precise timing of TRIAC gate drive.  Any mistake that turns on TRIACs when voltage is not close to zero will dump MMC energy into TRIACs and make a bunch of melted silicon  :(  So, this is an experiment that may be interesting and may fail catastrophically.
« Reply #4 on: June 28, 2022, 08:45:41 AM »
Finn Hammer built a "auto-tuning" or "tune-on-the-fly" primary coil DRSSTC called Thumper. Pictures can no longer be opened on 4hv, but you can get the idea here: https://4hv.org/e107_plugins/forum/forum_viewtopic.php?p=12&id=68820#post-87712
He never got it to work like he imagined, the small changes on the primary was, as Dave also states, not really needed (judging by spark output) and it was too slow to do any real time optimization. I seem to recall a chat with him some years ago where he mentioned he did not really use it after the experiments, but it was an easy way to tune, just not worth the huge engineering effort :)
Today at 08:33:16 AM
post Re: Feedback problems
Mike
Today at 04:20:00 AM
Today at 02:25:07 AM
Today at 02:18:56 AM
Today at 01:57:37 AM
Today at 01:54:04 AM
Today at 12:09:56 AM
August 13, 2022, 10:14:40 PM
NerdlabsMadScience
August 13, 2022, 09:32:08 PM
LoOdaK
August 13, 2022, 09:11:03 PM
August 13, 2022, 08:45:41 PM
LoOdaK
August 13, 2022, 08:20:01 PM
August 13, 2022, 08:00:14 PM
August 13, 2022, 07:41:45 PM
Overlordcheese
August 13, 2022, 06:42:34 PM
post Feedback problems
August 13, 2022, 06:17:43 PM
LoOdaK
August 13, 2022, 03:18:05 PM
August 12, 2022, 11:03:52 PM
LoOdaK
August 12, 2022, 10:53:44 PM
August 12, 2022, 10:13:02 PM
LoOdaK
August 12, 2022, 09:35:29 PM
August 12, 2022, 08:28:28 PM
August 12, 2022, 07:26:41 PM
August 12, 2022, 06:52:58 PM
August 12, 2022, 06:39:27 PM
August 12, 2022, 06:38:44 PM
August 12, 2022, 05:57:00 PM
August 12, 2022, 12:44:20 PM
LoOdaK
August 12, 2022, 08:36:23 AM
August 12, 2022, 04:31:17 AM
August 12, 2022, 02:55:27 AM
Mike
August 12, 2022, 01:27:14 AM
August 11, 2022, 11:51:42 PM
August 11, 2022, 11:35:43 PM
August 11, 2022, 10:56:28 PM
August 11, 2022, 07:40:03 PM
MarcusFunt
August 11, 2022, 06:54:14 PM
August 11, 2022, 05:07:28 PM
LoOdaK
August 11, 2022, 11:13:20 AM
MarcusFunt
August 11, 2022, 10:03:54 AM
Mike
August 11, 2022, 06:12:48 AM
August 11, 2022, 03:14:55 AM
55#sofcopper
August 11, 2022, 02:55:16 AM
post Painfully Amazing Stuff
August 10, 2022, 10:47:09 PM
August 10, 2022, 07:51:16 PM
August 10, 2022, 06:36:23 PM
August 10, 2022, 01:34:40 AM
post Re: High Voltage pcb
August 09, 2022, 10:17:24 PM
August 09, 2022, 10:16:33 PM
August 09, 2022, 09:22:37 PM
August 09, 2022, 09:19:26 PM
August 09, 2022, 08:32:08 PM
August 09, 2022, 08:26:32 PM
August 09, 2022, 08:15:54 PM
post High Voltage pcb
August 09, 2022, 08:15:10 PM
55#sofcopper
August 09, 2022, 04:44:43 PM
August 09, 2022, 04:20:01 PM
mthome4
August 09, 2022, 03:11:56 PM
August 09, 2022, 07:30:29 AM
August 09, 2022, 07:06:52 AM
August 09, 2022, 07:06:34 AM
August 09, 2022, 06:28:49 AM
August 09, 2022, 06:18:56 AM
August 09, 2022, 06:08:53 AM
August 09, 2022, 04:29:49 AM
August 09, 2022, 02:18:35 AM
August 09, 2022, 12:42:21 AM
August 09, 2022, 12:31:47 AM
August 09, 2022, 12:22:26 AM
August 09, 2022, 12:00:39 AM
August 08, 2022, 11:24:45 PM
August 08, 2022, 10:07:08 PM
August 08, 2022, 10:01:56 PM
Maju
August 08, 2022, 10:00:22 PM
August 08, 2022, 09:52:09 PM
August 08, 2022, 09:51:09 PM
August 08, 2022, 09:50:49 PM
August 08, 2022, 09:47:24 PM
August 08, 2022, 09:44:04 PM
August 08, 2022, 09:43:38 PM
August 08, 2022, 09:42:37 PM
August 08, 2022, 09:27:10 PM
August 08, 2022, 08:09:38 PM
August 08, 2022, 04:10:00 PM
August 08, 2022, 07:54:27 AM
post Re: SCR precharge
August 07, 2022, 07:28:51 PM
post Re: Bipolar CW -- update
August 07, 2022, 07:15:11 PM
August 07, 2022, 06:46:44 PM
August 07, 2022, 06:11:59 PM
August 07, 2022, 08:25:56 AM
August 07, 2022, 03:46:50 AM
post SCR precharge
August 06, 2022, 10:23:27 PM
August 06, 2022, 09:34:35 PM
August 06, 2022, 07:49:05 PM
August 06, 2022, 07:42:00 PM
August 06, 2022, 07:05:35 PM
August 06, 2022, 04:06:48 PM
post Re: CORE FOR GDT AND CT
Didik
August 05, 2022, 11:59:58 AM
August 05, 2022, 09:56:26 AM
August 05, 2022, 06:25:39 AM
