Author Topic: Best magnet wire to avoid flashovers  (Read 257 times)
Offline abstruse1
« on: June 19, 2022, 09:01:09 PM »
Currently I'm winding my FB secondaries with 28 AWG wire in 1/4" wide partitions in HDPE forms.  Altho they do pretty well, they will flash over and die if I push them too hard.  My question is, is there a specific kind of wire/insulation for this task?
Abstruse1
Re: Best magnet wire to avoid flashovers
« Reply #1 on: June 19, 2022, 09:30:38 PM »
There is 3 grades of enameled / varnished copper wire or motor winding wire, the thickness of the varnish layer varies with the grade and the diameter of the copper wire. I have a full list of the grades and voltage ratings in the tesla coil secondary coil part of the DRSSTC design guide: https://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/secondary-coil/ you have to scroll down a bit or search :)
Offline abstruse1
« Reply #2 on: June 20, 2022, 06:42:56 PM »
Wonderful info, Mads!  Thanx.
From what you write re voltage differential/winding suggests my problem may not be too bad.  I have encountered several multi inch long areas on removed wire that have the insulation blown off (or otherwise missing).  I do make a serious effort to impregnate the coils in oil in a vacuum chamber ~28 in./Hg for several hours.  I have even heated the oil to ~200 deg. F while doing this.  Still, I can do better.
My bobbin is 2" in diameter, ~2-1/2" long, with five cuts, 1/4" wide, leaving ~1/4" wall thickness over the ferrite.  With 1,000 turns 28AWG, that leaves slightly over 1/4" of the bobbin standing above the windings.  I'm using UHMW polyethylene.
I've thought about coating the windings with Glyptol as I'm winding, but that may enclose the Glyptol so that it never dries,  which it does via solvent evaporation (heating might force drying).  I don't know how much its dielectric properties would be compromised if it isn't dry.  Any thoughts on this method?
Or I could use a low viscosity two-part epoxy, which would assure setting.
I could cycle the vacuum in the chamber after winding to coax whatever liquid I use to work its way thru the windings.
BTW, I've tested several liquid dielectrics and it's looking like soybean oil may be the best.
As we say in this country, "You da man!"
Abstruse1
« Reply #3 on: June 20, 2022, 08:28:48 PM »
Soybean oil will eventually turn rancid. Its best to stick with mineral oil.
Offline abstruse1
« Reply #4 on: June 20, 2022, 08:45:35 PM »
I can tell when the soya oil turns rancid.  Makes my popcorn taste bad.
Abstruse1
Today at 06:48:18 AM
Hiemal
Today at 05:37:39 AM
Today at 05:00:02 AM
Today at 04:47:36 AM
boom198
Today at 04:03:53 AM
Today at 03:58:58 AM
Hiemal
Today at 03:36:19 AM
Razerwire
June 30, 2022, 10:46:33 PM
post Re: IGBT Hookup guide
June 30, 2022, 10:13:37 PM
June 30, 2022, 09:00:08 PM
post IGBT Hookup guide
ThePickledNerd
June 30, 2022, 07:56:18 PM
Mike
June 30, 2022, 01:04:19 PM
June 30, 2022, 06:41:10 AM
June 30, 2022, 05:41:21 AM
Razerwire
June 30, 2022, 05:19:18 AM
Hiemal
June 30, 2022, 01:32:12 AM
[Contests and Events]
June 29, 2022, 05:14:33 PM
June 29, 2022, 03:14:25 PM
Mike
June 29, 2022, 12:46:43 PM
boom198
June 29, 2022, 02:17:25 AM
June 28, 2022, 07:38:02 PM
June 28, 2022, 05:19:24 PM
June 28, 2022, 04:34:46 PM
June 28, 2022, 01:49:07 PM
Razerwire
June 28, 2022, 09:42:52 AM
June 28, 2022, 08:47:31 AM
post Re: Auto tuning primary?
June 28, 2022, 08:45:41 AM
June 28, 2022, 05:35:15 AM
June 28, 2022, 05:30:25 AM
June 28, 2022, 05:09:25 AM
June 28, 2022, 05:05:27 AM
boom198
June 28, 2022, 04:51:22 AM
June 28, 2022, 01:19:41 AM
June 27, 2022, 10:25:55 PM
June 27, 2022, 09:15:26 PM
June 27, 2022, 09:10:43 PM
post Auto tuning primary?
Overlordcheese
June 27, 2022, 08:36:46 PM
Overlordcheese
June 27, 2022, 08:31:45 PM
June 27, 2022, 06:14:48 PM
June 27, 2022, 05:30:22 PM
June 27, 2022, 02:51:14 PM
June 27, 2022, 08:57:52 AM
June 27, 2022, 05:48:47 AM
post DRSSTC trips GFCI outlet
boom198
June 27, 2022, 03:47:49 AM
June 26, 2022, 05:59:04 PM
[Static Electricity]
June 26, 2022, 12:49:14 PM
June 25, 2022, 11:23:08 PM
June 25, 2022, 03:43:12 PM
June 25, 2022, 12:02:13 PM
June 25, 2022, 07:37:22 AM
post Re: Bipolar CW
Vdekje
June 25, 2022, 05:05:20 AM
June 24, 2022, 08:32:54 PM
June 24, 2022, 06:28:10 PM
June 24, 2022, 05:52:55 PM
Mike
June 24, 2022, 12:56:41 PM
June 24, 2022, 04:32:42 AM
June 23, 2022, 11:51:16 PM
June 23, 2022, 10:12:26 PM
June 23, 2022, 10:11:07 PM
Manz
June 23, 2022, 06:10:14 PM
Mike
June 23, 2022, 01:36:42 PM
June 23, 2022, 01:30:29 PM
post Re: Is this good GDT ?
LoOdaK
June 23, 2022, 01:03:35 PM
June 23, 2022, 03:49:07 AM
June 22, 2022, 06:30:42 PM
June 22, 2022, 02:16:02 PM
post Re: Problem with SSTC
June 22, 2022, 03:57:54 AM
June 21, 2022, 09:14:34 PM
June 21, 2022, 08:06:08 PM
Nunu00
June 21, 2022, 04:44:13 PM
Tetris
June 21, 2022, 04:39:23 AM
post Re: ocd input
June 21, 2022, 03:41:25 AM
June 20, 2022, 07:30:18 PM
June 20, 2022, 07:06:54 PM
BenTesla
June 20, 2022, 06:33:53 PM
June 19, 2022, 11:56:23 PM
Nunu00
June 19, 2022, 11:00:41 PM
June 19, 2022, 10:33:14 PM
June 19, 2022, 09:50:27 PM
June 19, 2022, 09:42:02 PM
June 19, 2022, 08:58:16 PM
June 19, 2022, 08:56:18 PM
Nunu00
June 19, 2022, 07:50:17 PM
June 19, 2022, 07:09:52 PM
June 19, 2022, 06:49:26 PM
BenTesla
June 19, 2022, 02:04:01 PM
Nunu00
June 19, 2022, 11:48:17 AM
June 19, 2022, 06:16:42 AM
post Re: ocd input
June 19, 2022, 03:50:22 AM
June 19, 2022, 03:42:14 AM
Nunu00
June 19, 2022, 01:56:08 AM
post Re: ocd input
June 19, 2022, 12:49:55 AM
June 18, 2022, 11:07:46 PM
Nunu00
June 18, 2022, 09:55:23 PM
June 18, 2022, 09:30:46 PM
