Author Topic: increasing primary current without increasing IGBT losses  (Read 332 times)
« on: June 14, 2022, 11:50:29 PM »
Has anybody else ever tried to use a transformer between the bridge and the primary resonant circuit to step up the current? I've been thinking about that for a while and actually given it a go and it really seems to work very well in deed. The two main benefits I can see are a slower rise in primary current (only good if you want it to slow down of course :P) and a lower current in the power semiconductors. Second of which of course means you can either use smaller IGBTs or drive more current through the coil with your existing ones.
I tested two setups by modifying the primary circuit of my big coil (2m coil with 3m sparks). Design specs are 50kHz F_res, 800A primary current and 20kW peak power draw. Using skm400 IGBTs
First test setup was the transformer for the welding machine I'm building. 18 Primary turns and 2x3 secondary in series giving me a 6:1 ratio. That however didn't work, and ran into very significant current limitations as well as non linearities because of high stray inductance. Presumabley on the primary coil, meaning the core saw all of the current without any load applied and saturated, resulting in big losses. Scoping the secondary voltage of the transformer showed a hughe sinusoidal swing as opposed to the nice square wave I was expecting.
Second setup was the two secondaries arranges as an autotransformer, with a 2:1 ratio. Here the stray inductance is a lot lower, which results in the output voltage being pretty much exactly 0.5xV_bridge even with a high primary current.
Using the second setup I did some static load testes with a sledge hammer as the load ,250V on the bus and 400us pulses at 200Hz. For reference my coil would reach around 35°C heatsink temperature at 800A current limit without the Transformer in place. After installing the trafo I went up to 1000A limit and it only got to around 27°C. Testing with 1200A got me to the point where everything in the coil started overheating... except for the IGBTs. I'd need to re-design my coil to be able to keep up with the new capabilities :P
Something that I'd now want to do is to acutally do some engineering calculations on that transformer (calculate flux density swing etc) so I can optimize the transformer a little bit more. Even though I suspect that won't be easy beacuse the primary has a voltage imposed on it while the secondary a current. Netzpfuscher also suggested using the primary coil as the autotransformer, feeding the outer most winding from the bridge, which might be interesing to try out. Though I suspect the stray inductance of that setup could be a little too much. And of course finally I need to do a test run with a real secondary as the load... who knows maybe I'll crack 4m :P
I really do think that for low resonant circuit impedance coils or those that operate with a high bus voltage a transformer might be a very viable way of pushing beyond what your IGBTs could do on their own. Maybe somebody else would like to give it a try :)
Re: increasing primary current without increasing IGBT losses
« Reply #1 on: June 15, 2022, 05:26:39 AM »
A transformer could be useful for altering characteristics of an existing coil that is difficult to modify.  For anyone designing a new coil, it is probably easier and cheaper and smaller to build a higher-impedance primary.  A perfect 2:1 transformer (no parasitics of any sort) is exactly the same as 4x primary inductance (2x turn count occupying the same space) and 1/4x primary capacitance (at 2x peak primary capacitor voltage).  Requires the same number/size of MMC capacitors arranged with twice the number in series and half the number in parallel.  Of course, if this higher-impedance primary allows increasing coil peak power, then MMC voltage/current capability needs to be increased proportionately.  Same holds true for a transformer-driven version.
Your transformer (ie. higher-impedance primary) experiment should provide valuable information on arc length.  I can imagine two competing effects.  Higher primary current should allow arcs to start with more detuning.  Lower primary H-bridge drive voltage might reduce how low a secondary frequency that primary drive can feed.  Not certain these are valid ways to view arc length effects, nor which one is more significant if they are valid.  Anyone else have thoughts about what to expect for arc length change?
BTW, my first coil (SSTC) is transformer-coupled.  Two H-bridges (for two separate 120V line circuits) drive transformers (series-connected secondaries) feeding the bottom of the SSTC "secondary".  There is no SSTC primary coil.
« Last Edit: June 15, 2022, 06:22:19 AM by davekni »
« Reply #2 on: June 15, 2022, 06:37:08 PM »
Applause for Dave's point about, where possible,
rewinding the TC primary to better match the driver.
The principle works for pretty much anything that has coils: Motors, electromagnets, various "launchers", wireless device chargers, and of course transformers.
Same coil volume and copper mass is partitioned into more or fewer turns, for more or less inductance and resistance.
With no change in operating frequency, current density, efficiency, etc.
« Reply #3 on: June 15, 2022, 08:08:10 PM »
davekni wrote:
I don't understand this. Can you please explain?
I've written here a bit about high impedance primaries. https://highvoltageforum.net/index.php?topic=1928.msg14441#msg14441
As has been pointed out, a higher impedance primary tank is basically what you get if you drive it with a step down transformer.
« Reply #4 on: June 16, 2022, 01:25:12 AM »
Well the impedance of the primary increasing is only a side point really. The main benefit is that you can simply drive twice as much primary current with the same IGBTs.
« Reply #5 on: June 16, 2022, 03:25:02 AM »
That wasn't a complete thought.  I agree, it doesn't make sense.  I think the down-side of too-high primary impedance is as you mention in your other referenced post:  As secondary frequency drops to primary frequency, primary Q may drop too low to draw enough power from H-bridge.  So, the issue is at matched frequency, not after secondary frequency drops below primary frequency.
Your other referenced post also brings up a possible bright side.  If enough primary energy can be stored up before secondary frequency drops to match, that energy might be enough to extend the arc to the point where primary frequency is below secondary, skipping past the problematic low-Q primary point.
Don't understand this comment.  2x primary current behaves exactly the same as 1x primary current through 2x primary turns (4x primary impedance).  Same advantages without the need for a transformer.  Whatever you hope to gain by 2:1 transformer can be gained with higher-impedance primary instead.  Choice depends on which is easier to build given your existing coil.
« Reply #6 on: June 16, 2022, 12:39:00 PM »
@davekni: Thank you for the explanation. I see now, what you were getting at.
@TMaxElectronics: The IGBT current limit is not the only issue limiting primary current. Once the arc breaks out, the energy dissipated there will manifest itself as a lossy primary tank. This implies, that you will need a certain input voltage to the primary in order to establish a certain input current. The higher the input voltage is, the larger is also the achievable current.
A step down transformer will lower the input voltage to the tank, so in the end input current and with it input power might suffer too much.
This is not to say, that there might be no advantage to a transformer. That depends on your present tank impedance and whether it matches the bridges voltage and current capabilities.
post Re: Designing a regulated HV supply
Today at 06:48:18 AM
Hiemal
Today at 05:37:39 AM
Today at 05:00:02 AM
Today at 04:47:36 AM
post Re: DRSSTC trips GFCI outlet
boom198
Today at 04:03:53 AM
post Help with Class E plasma speaker Eastern Voltage Research
Today at 03:58:58 AM
Hiemal
Today at 03:36:19 AM
post Re: Mains Ramped SSTC - Power Supply Issue
Razerwire
June 30, 2022, 10:46:33 PM
post Re: IGBT Hookup guide
June 30, 2022, 10:13:37 PM
June 30, 2022, 09:00:08 PM
post IGBT Hookup guide
ThePickledNerd
June 30, 2022, 07:56:18 PM
Mike
June 30, 2022, 01:04:19 PM
June 30, 2022, 06:41:10 AM
June 30, 2022, 05:41:21 AM
post Ebay Bipolar Tesla Coil Rebuild
Razerwire
June 30, 2022, 05:19:18 AM
post Designing a regulated HV supply
Hiemal
June 30, 2022, 01:32:12 AM
post Re: Roskilde Festival 2022: Science Pavilion
[Contests and Events]
June 29, 2022, 05:14:33 PM
June 29, 2022, 03:14:25 PM
Mike
June 29, 2022, 12:46:43 PM
boom198
June 29, 2022, 02:17:25 AM
June 28, 2022, 07:38:02 PM
post Re: Using UCC37322 to drive cm300dy for Switching PSU
June 28, 2022, 05:19:24 PM
June 28, 2022, 04:34:46 PM
June 28, 2022, 01:49:07 PM
Razerwire
June 28, 2022, 09:42:52 AM
June 28, 2022, 08:47:31 AM
post Re: Auto tuning primary?
June 28, 2022, 08:45:41 AM
June 28, 2022, 05:35:15 AM
June 28, 2022, 05:30:25 AM
post Re: Why only one flip flop for ZCS-OCD triggering?
June 28, 2022, 05:09:25 AM
June 28, 2022, 05:05:27 AM
boom198
June 28, 2022, 04:51:22 AM
post Re: Odd Signal On VLF, Need Help Identifying Source
June 28, 2022, 01:19:41 AM
June 27, 2022, 10:25:55 PM
June 27, 2022, 09:15:26 PM
June 27, 2022, 09:10:43 PM
post Auto tuning primary?
Overlordcheese
June 27, 2022, 08:36:46 PM
post Why only one flip flop for ZCS-OCD triggering?
Overlordcheese
June 27, 2022, 08:31:45 PM
June 27, 2022, 06:14:48 PM
post Using UCC37322 to drive cm300dy for Switching PSU
June 27, 2022, 05:30:22 PM
June 27, 2022, 02:51:14 PM
June 27, 2022, 08:57:52 AM
June 27, 2022, 05:48:47 AM
post DRSSTC trips GFCI outlet
boom198
June 27, 2022, 03:47:49 AM
June 26, 2022, 05:59:04 PM
post Re: Van de Graaff generator voltage measurement
[Static Electricity]
June 26, 2022, 12:49:14 PM
June 25, 2022, 11:23:08 PM
June 25, 2022, 03:43:12 PM
June 25, 2022, 12:02:13 PM
post Roskilde Festival 2022: Science Pavilion
June 25, 2022, 07:37:22 AM
post Re: Bipolar CW
Vdekje
June 25, 2022, 05:05:20 AM
June 24, 2022, 08:32:54 PM
June 24, 2022, 06:28:10 PM
June 24, 2022, 05:52:55 PM
Mike
June 24, 2022, 12:56:41 PM
June 24, 2022, 04:32:42 AM
June 23, 2022, 11:51:16 PM
June 23, 2022, 10:12:26 PM
June 23, 2022, 10:11:07 PM
Manz
June 23, 2022, 06:10:14 PM
post Feedback on new freewheeling driver schematic
Mike
June 23, 2022, 01:36:42 PM
June 23, 2022, 01:30:29 PM
post Re: Is this good GDT ?
LoOdaK
June 23, 2022, 01:03:35 PM
post Re: First drsstc project, looking for recommendations
June 23, 2022, 03:49:07 AM
June 22, 2022, 06:30:42 PM
June 22, 2022, 02:16:02 PM
post Re: Problem with SSTC
June 22, 2022, 03:57:54 AM
June 21, 2022, 09:14:34 PM
post Dielectric breakdown of 6 oils -- sorta
June 21, 2022, 08:06:08 PM
Nunu00
June 21, 2022, 04:44:13 PM
Tetris
June 21, 2022, 04:39:23 AM
post Re: ocd input
June 21, 2022, 03:41:25 AM
post Re: Best magnet wire to avoid flashovers
June 20, 2022, 08:45:35 PM
June 20, 2022, 08:28:48 PM
post Re: DRSSTC using a ZVS Driver not working well - need help
June 20, 2022, 07:30:18 PM
June 20, 2022, 07:06:54 PM
June 20, 2022, 06:42:56 PM
BenTesla
June 20, 2022, 06:33:53 PM
June 19, 2022, 11:56:23 PM
Nunu00
June 19, 2022, 11:00:41 PM
June 19, 2022, 10:33:14 PM
June 19, 2022, 09:50:27 PM
June 19, 2022, 09:42:02 PM
June 19, 2022, 09:30:38 PM
post Best magnet wire to avoid flashovers
June 19, 2022, 09:01:09 PM
June 19, 2022, 08:58:16 PM
post Level of vacuum to purge transformer coils
June 19, 2022, 08:56:18 PM
Nunu00
June 19, 2022, 07:50:17 PM
June 19, 2022, 07:09:52 PM
June 19, 2022, 06:49:26 PM
BenTesla
June 19, 2022, 02:04:01 PM
Nunu00
June 19, 2022, 11:48:17 AM
June 19, 2022, 06:16:42 AM
post Re: ocd input
June 19, 2022, 03:50:22 AM
June 19, 2022, 03:42:14 AM
Nunu00
June 19, 2022, 01:56:08 AM
post Re: ocd input
June 19, 2022, 12:49:55 AM
June 18, 2022, 11:07:46 PM
Nunu00
June 18, 2022, 09:55:23 PM
June 18, 2022, 09:30:46 PM
