Author Topic: Is this good GDT ?  (Read 307 times)
Offline LoOdaK
Is this good GDT ?
« on: June 11, 2022, 09:16:50 PM »
Hi guys I finally got ferrite cores and it was my first time that I wound GDT.
Could you please take a look at it and point at some mistakes and things I could improve.
GDT is made with cat5 cable, primary should be around 8 turns and secondaries around 12 turns
My concern is that wires are not twisted enough but I would like to hear opinions from more experienced people
Picture:
« Last Edit: June 13, 2022, 09:18:40 AM by LoOdaK »
Online davekni
Re: Is this good GDT ?
« Reply #1 on: June 12, 2022, 09:46:09 PM »
GDT ratios other than 1:1 are inherently difficult to make with low leakage inductance.  Yours is likely good enough.  I haven't personally used 2:3 ratio GDTs.  If you have a scope available, check resulting gate waveforms to make sure you have enough series resistance to damp excessive overshoot.
Since I've seen 2:3 ratio GDTs several times on this forum, decided to try to come up with a better winding technique (lower leakage inductance).  Came up with two options.  Both are tricky to construct, however.  Might eventually add one to my GDT tutorial thread if I can manage to make it reasonable.
Your lead wires are nicely twisted.  If you want to be a perfectionist and try to optimize the windings more:  What matters is pairing of primary and secondary wires.  Twisting of the two primary wires together within the winding is counter-productive.  As much as possible, pair primary wires with secondary wires.
Both of my thoughts for 2:3 designs use 3 paralleled primary wires instead of 2 or 1.  That way there is a primary turn for every secondary turn.  In your case, there would be a total of 24 primary wire turns (3 wires of 8 turns each).  That matches the 24 secondary wire turns (2 separate wires of 12 turns each).
My first thought is to wind the primary first.  (Wind all three primary wires together as a flat ribbon, not twisted for the part wrapping around the core, only lead sections twisted.  Then wind the two secondaries with each secondary turn between two primary turns.  I tried that with normal stranded cat5 wire.  Was difficult to hold primary in place while winding secondary.  May retry with solid wire.  That may be workable.
Other version is to pre-twist the three primary wires with two secondaries, then wind the twisted wires.  Hard to explain without pictures.  Also hard to keep track of which segment of twisted wire wraps which direction around the core.  I've messed that up twice already trying to document an example.
The key point is that your GDT is likely fine.  I'm just a perfectionist, so try to dream up more ideal options.
« Last Edit: June 12, 2022, 09:55:39 PM by davekni »
« Reply #2 on: June 12, 2022, 10:15:18 PM »
Could you please try to upload the picture to the forum? It seems like your image host is blocking other countries?
All I am seeing is this:
Online davekni
« Reply #3 on: June 13, 2022, 01:00:20 AM »
Interesting.  The picture worked fine yesterday and earlier today.  Now it isn't showing up for me either.  Yes, I agree that it would be best to put the picture directly in the post.  I hadn't even noticed that it wasn't initially.  The image that showed up initially in the post was plenty large that I don't click on any link.
Offline LoOdaK
« Reply #4 on: June 13, 2022, 09:14:09 AM »
Strange, I still see the photo  :o
Here is the link to the photo:
https://i.imgur.com/XyHqABx.jpg
EDIT: I also edited the image link in the post, it should show up now :)
« Last Edit: June 13, 2022, 09:19:34 AM by LoOdaK »
« Reply #5 on: June 13, 2022, 09:48:24 AM »
Your GDT winding is fine and will work just as good as a perfectly made one. There was once a website called the thedatastream that made GDT winding experiments. From very tight and perfect, to loosely coupled windings. There was a difference! But no difference that meant it would not work.
I think Dave tried to explain this winding method, where you parallel alle the "white" wires in the twisted pairs, for the primary and then use the color wire, one for each secondary. This way you have the primary twisted into the normal twisted pairs. Very tight coupling.
Picture from: https://kaizerpowerelectronics.dk/tesla-coils/kaizer-drsstc-i/
Offline LoOdaK
« Reply #6 on: June 23, 2022, 01:03:35 PM »
Sorry for the late reply,
thank you guys for the explanations and example, I hope my GDT will perform well.
I will post here results of my project for sure :)
post Re: Designing a regulated HV supply
Today at 06:48:18 AM
Hiemal
Today at 05:37:39 AM
Today at 05:00:02 AM
Today at 04:47:36 AM
post Re: DRSSTC trips GFCI outlet
boom198
Today at 04:03:53 AM
post Help with Class E plasma speaker Eastern Voltage Research
Today at 03:58:58 AM
Hiemal
Today at 03:36:19 AM
post Re: Mains Ramped SSTC - Power Supply Issue
Razerwire
June 30, 2022, 10:46:33 PM
post Re: IGBT Hookup guide
June 30, 2022, 10:13:37 PM
June 30, 2022, 09:00:08 PM
post IGBT Hookup guide
ThePickledNerd
June 30, 2022, 07:56:18 PM
Mike
June 30, 2022, 01:04:19 PM
June 30, 2022, 06:41:10 AM
June 30, 2022, 05:41:21 AM
post Ebay Bipolar Tesla Coil Rebuild
Razerwire
June 30, 2022, 05:19:18 AM
post Designing a regulated HV supply
Hiemal
June 30, 2022, 01:32:12 AM
post Re: Roskilde Festival 2022: Science Pavilion
[Contests and Events]
June 29, 2022, 05:14:33 PM
June 29, 2022, 03:14:25 PM
Mike
June 29, 2022, 12:46:43 PM
boom198
June 29, 2022, 02:17:25 AM
June 28, 2022, 07:38:02 PM
post Re: Using UCC37322 to drive cm300dy for Switching PSU
June 28, 2022, 05:19:24 PM
June 28, 2022, 04:34:46 PM
June 28, 2022, 01:49:07 PM
Razerwire
June 28, 2022, 09:42:52 AM
June 28, 2022, 08:47:31 AM
post Re: Auto tuning primary?
June 28, 2022, 08:45:41 AM
June 28, 2022, 05:35:15 AM
June 28, 2022, 05:30:25 AM
post Re: Why only one flip flop for ZCS-OCD triggering?
June 28, 2022, 05:09:25 AM
June 28, 2022, 05:05:27 AM
boom198
June 28, 2022, 04:51:22 AM
post Re: Odd Signal On VLF, Need Help Identifying Source
June 28, 2022, 01:19:41 AM
June 27, 2022, 10:25:55 PM
June 27, 2022, 09:15:26 PM
June 27, 2022, 09:10:43 PM
post Auto tuning primary?
Overlordcheese
June 27, 2022, 08:36:46 PM
post Why only one flip flop for ZCS-OCD triggering?
Overlordcheese
June 27, 2022, 08:31:45 PM
June 27, 2022, 06:14:48 PM
post Using UCC37322 to drive cm300dy for Switching PSU
June 27, 2022, 05:30:22 PM
June 27, 2022, 02:51:14 PM
June 27, 2022, 08:57:52 AM
June 27, 2022, 05:48:47 AM
post DRSSTC trips GFCI outlet
boom198
June 27, 2022, 03:47:49 AM
June 26, 2022, 05:59:04 PM
post Re: Van de Graaff generator voltage measurement
[Static Electricity]
June 26, 2022, 12:49:14 PM
June 25, 2022, 11:23:08 PM
June 25, 2022, 03:43:12 PM
June 25, 2022, 12:02:13 PM
post Roskilde Festival 2022: Science Pavilion
June 25, 2022, 07:37:22 AM
post Re: Bipolar CW
Vdekje
June 25, 2022, 05:05:20 AM
June 24, 2022, 08:32:54 PM
June 24, 2022, 06:28:10 PM
June 24, 2022, 05:52:55 PM
Mike
June 24, 2022, 12:56:41 PM
June 24, 2022, 04:32:42 AM
June 23, 2022, 11:51:16 PM
June 23, 2022, 10:12:26 PM
June 23, 2022, 10:11:07 PM
Manz
June 23, 2022, 06:10:14 PM
post Feedback on new freewheeling driver schematic
Mike
June 23, 2022, 01:36:42 PM
June 23, 2022, 01:30:29 PM
post Re: Is this good GDT ?
LoOdaK
post Re: First drsstc project, looking for recommendations
June 23, 2022, 03:49:07 AM
June 22, 2022, 06:30:42 PM
June 22, 2022, 02:16:02 PM
post Re: Problem with SSTC
June 22, 2022, 03:57:54 AM
June 21, 2022, 09:14:34 PM
post Dielectric breakdown of 6 oils -- sorta
June 21, 2022, 08:06:08 PM
Nunu00
June 21, 2022, 04:44:13 PM
Tetris
June 21, 2022, 04:39:23 AM
post Re: ocd input
June 21, 2022, 03:41:25 AM
post Re: Best magnet wire to avoid flashovers
June 20, 2022, 08:45:35 PM
June 20, 2022, 08:28:48 PM
post Re: DRSSTC using a ZVS Driver not working well - need help
June 20, 2022, 07:30:18 PM
June 20, 2022, 07:06:54 PM
June 20, 2022, 06:42:56 PM
BenTesla
June 20, 2022, 06:33:53 PM
June 19, 2022, 11:56:23 PM
Nunu00
June 19, 2022, 11:00:41 PM
June 19, 2022, 10:33:14 PM
June 19, 2022, 09:50:27 PM
June 19, 2022, 09:42:02 PM
June 19, 2022, 09:30:38 PM
post Best magnet wire to avoid flashovers
June 19, 2022, 09:01:09 PM
June 19, 2022, 08:58:16 PM
post Level of vacuum to purge transformer coils
June 19, 2022, 08:56:18 PM
Nunu00
June 19, 2022, 07:50:17 PM
June 19, 2022, 07:09:52 PM
June 19, 2022, 06:49:26 PM
BenTesla
June 19, 2022, 02:04:01 PM
Nunu00
June 19, 2022, 11:48:17 AM
June 19, 2022, 06:16:42 AM
post Re: ocd input
June 19, 2022, 03:50:22 AM
June 19, 2022, 03:42:14 AM
Nunu00
June 19, 2022, 01:56:08 AM
post Re: ocd input
June 19, 2022, 12:49:55 AM
June 18, 2022, 11:07:46 PM
Nunu00
June 18, 2022, 09:55:23 PM
June 18, 2022, 09:30:46 PM
