Author Topic: Cheaper Tesla coil capacitors  (Read 361 times)
Offline MarcusFunt
« on: June 09, 2022, 08:44:49 PM »
I am thinking of making a dual mot sgtc, and therefore i need capacitors.
My coil will be running at around 320khz.
I ran some calculations on the max voltage of the mots and doubled the value to 12000V.
I am aiming for slower arcs of around 150 bms. So my max capacitance becomes 95nf.
All decent tesla coil capacitors i found are REALLY expensive, so my idea was:
https://www.amazon.de/-/en/gp/product/B08NVLCGBS/ref=ox_sc_act_title_2?smid=A3TAA9JQ6SVWB5&psc=1 (induction cooker capacitors) induction cookers KILL capacitors, and so do tesla coils. (i would get a capacitor rated 12kv 33nf)
The safe route: https://dk.rs-online.com/web/p/products/7441461/ (Fancy CDE cap)(12kv but only 12nf)
Experimental: https://dk.rs-online.com/web/p/filmkondensatorer/1051060 (REALLY CHEAP) i could build a large mmc that is WAY in excess of the others
Also: https://dk.rs-online.com/web/p/filmkondensatorer/7123905(12kv 15nf)
Let me know if you know any decent capacitor that fit in my budget of around 20£(Has to be from within the eu because of import taxes)
I heard somewhere that you look at the dc voltage of the tesla coil. is that true?
Re: Cheaper Tesla coil capacitors
« Reply #1 on: June 10, 2022, 05:16:48 AM »
MOTs are particularly dangerous:  Enough voltage to arc through clothing with current capability several times lethal threshold.  NSTs are much safer, generally limited to 60mA or less, so much less likely to be lethal if you make a single mistake.  I have a dual-MOT SRSGTC, but rarely set it up because I'm too afraid of making a mistake.
That is rather low power for two MOTs.  6kV on 95nF is 1.71J, or 257 watts at 150 BPS.  Two MOTs are capable of 2kW (or more for intermittent use).  My coil runs at 120 BPS with ~700nF and resonant charging to 9kV.  Of course, if you have two MOTs in hand, that's cheaper than purchasing anything safer for 257 watts.
Your first link to 0.33uF 1200Vdc induction cooker capacitors looks like roughly the same parts I use in my DRSSTC and have ran some destructive testing to 2100Vpk (4200Vpp) at 80kHz 1% duty cycle.  Your third link labeled "VERY CHEAP" would require 4 times as many parts for the same final Vdc rating and capacitance, since they are only 630Vdc rated.  Would likely work fine, though I have no experience with these.
Have fun, and experiment safely!
« Last Edit: June 10, 2022, 05:18:27 AM by davekni »
Offline MarcusFunt
« Reply #2 on: June 10, 2022, 09:41:02 AM »
I only felt safe enough to build it because a am doing it with two friends.
I think of using the cheap caps because I can distribute the load across 80( or so) caps.
« Reply #3 on: July 05, 2022, 08:23:07 PM »
20£ is a small budget for a MMC and you will properly have to find a good bargain on ebay to make it for that small amount. Another route is to make it smaller than needed, going low on voltage and current rating will however shorten the life time of the MMC considerably.
Using DC voltage ratings instead of AC voltage ratings is a "trade off". You can design it cheaper and the short pulse operation of a Tesla coil can to some degree justify this, as the heat losses have more time to dissipate. But there is no doubt, that designing with DC voltage ratings, you again shorten the life time of the MMC.
The capacitors you look at are maybe designed for 5-10 years full spec operation, so if you can get 100 hours of full abuse on them, well 100 hours run time of a Tesla coil is a really long time and most amateur built coils will rarely see 100 hours in their life time :)
post Re: Aluminium Nitride Thermal Pads
Today at 08:33:16 AM
post Re: Feedback problems
Mike
Today at 04:20:00 AM
Today at 02:25:07 AM
Today at 02:18:56 AM
post Re: Problem with VTTC Staccato interrupter PLZ HELP
Today at 01:57:37 AM
Today at 01:54:04 AM
Today at 12:09:56 AM
post Re: Half-bridge for my first sstc
August 13, 2022, 10:14:40 PM
post Problem with VTTC Staccato interrupter PLZ HELP
NerdlabsMadScience
August 13, 2022, 09:32:08 PM
LoOdaK
August 13, 2022, 09:11:03 PM
August 13, 2022, 08:45:41 PM
LoOdaK
August 13, 2022, 08:20:01 PM
August 13, 2022, 08:00:14 PM
August 13, 2022, 07:41:45 PM
post A little idea I had for my dual full bridge design
Overlordcheese
August 13, 2022, 06:42:34 PM
post Feedback problems
August 13, 2022, 06:17:43 PM
LoOdaK
August 13, 2022, 03:18:05 PM
August 12, 2022, 11:03:52 PM
LoOdaK
August 12, 2022, 10:53:44 PM
August 12, 2022, 10:13:02 PM
LoOdaK
August 12, 2022, 09:35:29 PM
August 12, 2022, 08:28:28 PM
August 12, 2022, 07:26:41 PM
August 12, 2022, 06:52:58 PM
August 12, 2022, 06:39:27 PM
August 12, 2022, 06:38:44 PM
August 12, 2022, 05:57:00 PM
August 12, 2022, 12:44:20 PM
LoOdaK
August 12, 2022, 08:36:23 AM
post Aluminium Nitride Thermal Pads
August 12, 2022, 04:31:17 AM
post Re: Helpy Trying to Replicate This Strange Slittle DRSSTC? PLS
ItsChloeUwU
August 12, 2022, 02:55:27 AM
post Re: Small DRSSTC Questions
Mike
August 12, 2022, 01:27:14 AM
August 11, 2022, 11:51:42 PM
August 11, 2022, 11:35:43 PM
post Say what -- arcing TO polycarbonate!
August 11, 2022, 10:56:28 PM
August 11, 2022, 07:40:03 PM
post Re: Huge Mistake Designing My Coil
MarcusFunt
August 11, 2022, 06:54:14 PM
August 11, 2022, 05:07:28 PM
post Half-bridge for my first sstc
LoOdaK
August 11, 2022, 11:13:20 AM
post Huge Mistake Designing My Coil
MarcusFunt
August 11, 2022, 10:03:54 AM
Mike
August 11, 2022, 06:12:48 AM
post Re: Painfully Amazing Stuff
August 11, 2022, 03:14:55 AM
55#sofcopper
August 11, 2022, 02:55:16 AM
post Painfully Amazing Stuff
August 10, 2022, 10:47:09 PM
post Re: HV AC Current Measurement
August 10, 2022, 07:51:16 PM
August 10, 2022, 06:36:23 PM
August 10, 2022, 01:34:40 AM
post Re: High Voltage pcb
August 09, 2022, 10:17:24 PM
August 09, 2022, 10:16:33 PM
post Re: How To Varnish A Tesla Coil Secondary Coil
August 09, 2022, 09:22:37 PM
August 09, 2022, 09:19:26 PM
August 09, 2022, 08:32:08 PM
August 09, 2022, 08:26:32 PM
post Re: Coherent VersaPulse VPW - what should I do with it?
August 09, 2022, 08:15:54 PM
post High Voltage pcb
August 09, 2022, 08:15:10 PM
post Top load material selection
55#sofcopper
August 09, 2022, 04:44:43 PM
August 09, 2022, 04:20:01 PM
post Loneoceans UD 2.7 rev c issue
mthome4
August 09, 2022, 03:11:56 PM
August 09, 2022, 07:30:29 AM
August 09, 2022, 07:06:52 AM
August 09, 2022, 07:06:34 AM
August 09, 2022, 06:28:49 AM
August 09, 2022, 06:18:56 AM
August 09, 2022, 06:08:53 AM
August 09, 2022, 04:29:49 AM
post HV AC Current Measurement
August 09, 2022, 02:18:35 AM
August 09, 2022, 12:42:21 AM
August 09, 2022, 12:31:47 AM
August 09, 2022, 12:22:26 AM
August 09, 2022, 12:00:39 AM
post Coherent VersaPulse VPW - what should I do with it?
August 08, 2022, 11:24:45 PM
post Re: Optic fiber interrupter in EU
August 08, 2022, 10:07:08 PM
August 08, 2022, 10:01:56 PM
Maju
August 08, 2022, 10:00:22 PM
August 08, 2022, 09:52:09 PM
August 08, 2022, 09:51:09 PM
August 08, 2022, 09:50:49 PM
post How To Varnish A Tesla Coil Secondary Coil
August 08, 2022, 09:47:24 PM
August 08, 2022, 09:44:04 PM
August 08, 2022, 09:43:38 PM
August 08, 2022, 09:42:37 PM
August 08, 2022, 09:27:10 PM
post Optic fiber interrupter in EU
ItsChloeUwU
August 08, 2022, 08:09:38 PM
post Helpy Trying to Replicate This Strange Slittle DRSSTC? PLS
ItsChloeUwU
August 08, 2022, 04:10:00 PM
August 08, 2022, 07:54:27 AM
post Re: SCR precharge
August 07, 2022, 07:28:51 PM
post Re: Bipolar CW -- update
August 07, 2022, 07:15:11 PM
August 07, 2022, 06:46:44 PM
August 07, 2022, 06:11:59 PM
August 07, 2022, 08:25:56 AM
August 07, 2022, 03:46:50 AM
post SCR precharge
August 06, 2022, 10:23:27 PM
August 06, 2022, 09:34:35 PM
ItsChloeUwU
August 06, 2022, 07:49:05 PM
ItsChloeUwU
August 06, 2022, 07:42:00 PM
August 06, 2022, 07:05:35 PM
August 06, 2022, 04:06:48 PM
post Re: CORE FOR GDT AND CT
Didik
August 05, 2022, 11:59:58 AM
August 05, 2022, 09:56:26 AM
August 05, 2022, 06:25:39 AM
