Author Topic: Problem with SSTC  (Read 1494 times)
Re: Problem with SSTC
« Reply #20 on: June 18, 2022, 04:27:13 AM »
The only acquisition modes available are Auto, Normal and Single.
Those are usually called "trigger modes".  Perhaps your scope does not have any selection for acquisition modes.
But in fact I did it as you can see from the first post. But since the igbt's continued to burn, I thought of carrying out this test.
Thank you for the reminder.  Yes, I see.  Would guess the JavaTC results to be more reliable than the meter's.
while on pin 2 and therefore also on 3 and 4 I see nothing, high frequency noise only.
Pin 2/3 and 4 should have square waves from 0 to 5V.  Is the high-frequency noise 0-5V?
Is your scope probe 1X or 10X?  1X probes have much higher capacitance and low bandwidth.  If 1X, probe capacitance is likely significantly higher than antenna etc. capacitance.  You may need a significantly larger resistor value.  The square wave on pin 2/3 and 4 will be somewhat noisy, as the antenna is still picking up random signals from adjacent electronics (light fixtures etc.).  Pick a resistor that gets average around operating frequency.  (If probe attenuation can be switched, use 10X for all your probing.  Be sure to adjust probe compensation using a ~1kHz square wave signal, usually provided by the scope for that purpose.)
Yes, unused inputs are connected together.
I presume they each input is connected to output of another inverter.  If an inverter input is connected to its own output, it will oscillate.
I tried to redo the tests by applying to the antenna a 200kHz square wave generated with an arduino.
Now on the gate of the first igbt I see this:
This looks like roughly +-25V gate drive.  Are you sure your GDT is 8:12 and not 8:16 or some other such 1:2 ratio?  Or, did you increase driver supply voltage above 12V?  Or perhaps you are using 10X scope probe that has not been adjusted to match scope input capacitance.
Also, do you know if your arduino output is square (50% duty cycle)?  Or, does it match the duty cycle of gate signals?  If the driver circuit is causing the duty cycle change shown, that indicates some problem.
Offline Nunu00
« Reply #21 on: June 18, 2022, 11:56:14 AM »
No, the noise has a lower voltage.
My probe can switch to 10X but if I do it on pin 1 of the HC14 I don't see anything anymore. In addition, as soon as the probe touches pin 1, the GDT stops emitting a kind of buzzing sound.
Another problem is that my oscilloscope does not have the 1kHz output to compensate the probe so the 10X measurements I don't think are very reliable.
No, as you can see from the photo only the unused inputs are connected together.
The GDT should be wound correctly, I think the problem is that the probe is not compensated correctly.
The output of the arduino is not perfectly at 50%, connecting it to the antenna, on pin 1 I see this
« Reply #22 on: June 18, 2022, 08:25:55 PM »
Lower voltage may be due to limited bandwidth of 1x probe.  Can you make your arduino output a 1kHz (approximately) square (approximately) wave for adjusting the probe in 10x mode?  Scoping will be much more helpful with a 10x probe.
What is your scope's vertical sensitivity range (min and max volts/division)?  Or, if you have a link to a data sheet or specifications for your scope, I'll take a look.  Perhaps volts/division doesn't go low enough to see pin1 signal with 10x probe.  Still, 10x will be MUCH better for almost all scoping:  much lower loading on circuit nodes and much higher bandwidth.
Are these four inputs also wired to ground or +5V on another layer?  If wired only to each other, they can still oscillate and cause issues.
That explains the duty cycle on gate voltage.  No issue there.  Gate voltage of +-25V is still above 1.5 x +-10V (or whatever the driver manages to generate on 12V supply, certainly not more than +-12V).  If you can get 10x working properly, I recommend probing GDT primary leads and then GDT output (Vge) with the same scope settings.  Then it will be clear if there is a GDT ratio issue or some other problem with scoping.
Offline Nunu00
« Reply #23 on: June 18, 2022, 09:55:23 PM »
The oscilloscope datasheet is this:
 [ You are not allowed to view attachments ] (I don't know why i get this error)
I tried to compensate the probe with a 1 kHz signal generated by the arduino but I can't do better than this:
However trying this way on pin 1 I see this:
While if I set the probe on 1X I see the wave that I had posted a few messages ago.
No, they are just connected to each other.
I tried again to carry out these measurements and on the GDT primary I see this:
While on the respective secondaries I see this:
« Last Edit: June 18, 2022, 10:04:37 PM by Nunu00 »
« Reply #24 on: June 18, 2022, 11:07:46 PM »
I've gotten the same error once or twice.  Thought perhaps it was an issue of file extension being JPG instead of jpg, but that doesn't appear to be the issue.  So, I don't know why either.
That is unfortunate!  Looks like the probe is designed for a scope with higher input capacitance than yours.  But, it also looks like arduino is putting out only 1.5V square wave, which seems too low.  Do you know what the arduino output voltage should be?  Perhaps the real issue is with the probe, internal 9meg resistor has failed to ~20-30meg.  That would explain both the inability to compensate and the low signal amplitude at low frequency.  Do you have a DMM?  I'd suggest measuring across scope probe input, in both 1x and 10x mode.  Should be 1meg in 1x mode and 10meg in 10x mode.  If 10meg is way off, can you find another 10x probe somewhere?  Even this cheap scope will be very valuable as long as it is functioning correctly.
If you know what voltage the arduino is outputting (typically same as supply voltage, either 3.3V or 5V), you could adjust the probe to give the correct amplitude at high frequency (100kHz and up).  Then 10x mode would be useful for measuring AC signals at TC operating frequency.
Yes, that makes sense.  Self-oscillating resistor value will need to be higher to get frequency reasonable without scope probe loading.  As I'd mentioned, it will be noisy due to antenna picking up random signals.
That should be fixed.  You could add a solder-bridge between pins 13 and 14.  Then all unused inputs are connected to +5V.
Ratio looks reasonably close to 1:1.5.  Given probe compensation failure, I'll ignore absolute amplitudes.
Offline Nunu00
« Reply #25 on: June 19, 2022, 01:56:08 AM »
I measured the resistance of the probe and in 1X mode I read 340 ohm while in 10X mode I read 9 Mega ohm, i get the same results also on another identical probe.
I also have the "probe" that comes with the oscilloscope which is simply a pair of alligator clips and the resistance of this one is zero ohm (but I can't switch it to 10X mode).
The input resistance of the oscilloscope is about 400k ohm even if 1 mega is written on the datasheet (this is also confirmed by a video I saw on youtube).
« Last Edit: June 19, 2022, 02:04:52 AM by Nunu00 »
« Reply #26 on: June 19, 2022, 03:42:14 AM »
Sorry, I wasn't clear.  I was referring to measuring probe tip to probe ground with probe connected to scope and scope turned on.  But I think your measurements are sufficient to understand the issue given comment quoted below.
Is this measured with the scope turned on?  If so, that explains why 10x probes do not work correctly.  Since the scope specifications both say "1 meg" and define input capability when using 10x probes, this would be blatantly dishonest advertising.
This is definitely limiting on scope usefulness :(  Probably best to stay with 1x and probe only low-impedance nodes (chip outputs in general).  For adjusting self-oscillation frequency, I'd probe HC14 pin 4.  That way scope load doesn't affect delay of pin1-2 inverter, as scope probe capacitance may affect even the output terminal somewhat.  Or, probe output of MCP14E5 to ground.  (Better not to probe across GDT input terminals.  Even with an isolated battery-powered scope, connecting scope "ground" lead to an active signal adds a large antenna to that node, which will couple to your SSTC feedback antenna and change circuit operation.)  Always ground scope probe to ECB ground, or to low-side IGBT emitter (or high-side emitter when half-bridge is not powered) when measuring gate voltages.
Back to possible general issues:  Besides connecting unused HC14 inputs to +5V or ground, the antenna lead wiring may need shielding.  Goal is to minimize unwanted feedback from half-bridge or other primary-side signals.  Some designs use coax cable or other shielded cable to bring the antenna connection from driver board to outside the box above primary coil.  Then the antenna is picking up mostly secondary voltage.  Shield is connected to driver board ground.  (Such coax or other shielded wiring will add capacitance.  Best to make that change before adjusting self-oscillation feedback resistor value.  Should reduce noise too.)
« Last Edit: June 19, 2022, 03:45:15 AM by davekni »
Offline Nunu00
« Reply #27 on: June 19, 2022, 11:48:17 AM »
I connected the unused inputs of the HC14 to +5V and then I did several tests (all with the probe in 1X) with different resistors but the only thing I get is the frequency variation on pin 1. On pin 4 and also on the MCP inputs I only see noise . The only way to get something is to touch the antenna with the hand, in this way the frequency obviously changes but increases the amplitude of the signal on pin 1 up to over 1 Vpp and on pin 4 i get a quite good square wave.
I could do this test but the only type of shielded cable at my disposal is the one used for the satellite TV signal. Could it work well?
« Reply #28 on: June 19, 2022, 06:49:26 PM »
Yes, that cable will be great electrically.  Hope it isn't physically too stiff to work with.
On pin 4 and also on the MCP inputs I only see noise.
Only possible explanation I can come up with is that antenna is coupling to GDT wires or other circuitry, causing oscillations that are too fast for your scope to measure cleanly.  I'd suggest scoping HC14 pin 4 one more time after changing to shielded cable for connection from antenna to circuit board.  If it is still noise, I'm at a loss for ideas.  Any very-nearby radio stations or other sources of strong RF signals being picked up by the antenna??  Not too likely.
Offline Nunu00
« Reply #29 on: June 19, 2022, 07:50:17 PM »
I replaced the antenna cable with the coaxial one but nothing has changed. On pin 1 I always see the same signal from about 600 mVpp but on pins 2/3 and 4 I see nothing. I might think the chip has some problem but applying an external signal it works fine so I don't know.
No, the only repeater near home is for mobile 4G but I don't think it can give me problems. Maybe it could be the switching power supply I'm using to power the circuit while doing the tests?
« Reply #30 on: June 19, 2022, 08:58:16 PM »
Do you mean "nothing" or is there noise centered around 2.5V (middle between 0V and logic supply of 5V)?  Perhaps it is worthwhile to check voltages with your DMM (presumably 10meg input impedance) on HC14 pin1, 2/3, and 4.  I wonder if one of the antenna input diodes or HC14 is partially damaged, pulling pin1 close to 5V, and only the scope's 400k to ground brings it into operating range.  Seems quite unlikely, but I'm running out of ideas.
4G should be much too high frequency to cause issues.  If it was the switching supply, shielded antenna cable should have helped at least some.  Cable shield is connected to circuit board ground, correct?
« Reply #31 on: June 19, 2022, 09:42:02 PM »
These cheap "DSO" oscilloscopes are grossly over advertised. It is downright lies and slander, its the "normal" Chinese exaggerated branding crap like tasers with 5MV output.
I would not trust any of these scopes at frequencies over 1/10th of their advertised band width. This is at least my own experience.
With dodgy input "impedance" given as 1M instead of a input resistance and capacitance, its worthless. It only makes sense to talk about impedance at a specific frequency.
Nunu00: Spend the money on a proper cheap DSO from Rigol, Hantek or similar. Even a old analog 20 MHz oscilloscope from a flea-market will be better. It might not show frequency and voltages, but at least you can trust its measurements :)
Offline Nunu00
« Reply #32 on: June 19, 2022, 11:00:41 PM »
I made the measurements with the DMM (according to the datasheet it has an input impedance of 10M and it shouldn't be crap like the oscilloscope) and on pins 1, 2/3 and 4 it detects about + 2.3V.
I also repeated the measurements with the oscilloscope in AC mode and on pin 1 I see this (I know the frequency is wrong but I was doing some tests with higher resistance values):
On pin 4 in AC mode I see this:
While in DC mode I see this:
The measurements seem to me consistent between the DMM and the oscilloscope.
Unfortunately I know, in fact I am planning to buy a Rigol DS1102Z.
« Last Edit: June 19, 2022, 11:57:49 PM by Mads Barnkob »
« Reply #33 on: June 20, 2022, 07:06:54 PM »
That may be about the correct resistance, as frequency will increase when probe is removed.  No way to know until probing pin 4 works correctly.
It is clear now that the HC14 is oscillating at 9 or 11MHz (aliasing with scope's 20Msps sample rate).  Amplitude is low because this is well beyond even the scope's specified 5MHz bandwidth.  This high-frequency oscillation is likely present only when loaded by the scope probe.  However, I think it may indicate a more general issue.  Looking back at images of the circuit board, ground appears to be routed in traces that don't form any sort of grid or other approximation of a ground plane.  In particular for this 9MHz oscillation, ground trace from HC14-7 to 0.1uF bypass capacitor is rather long.  I'd suggest hand-adding wires directly between ground points on the back of the board.  Or, even better, use copper foil to add ground connections.  A small capacitor directly between HC14 pins 7 and 14 would also help.  (Other chips would likely benefit from short-leaded bypass capacitors on the back too.  I haven't examined the overall layout in detail.)  Just adding the back-side HC14 bypass capacitor would likely be enough to stop the 9MHz oscillation.  A complete ground grid will prevent other issues.  This specific 9MHz oscillation may not be the exact problem causing IGBT frying.  It may be some other parasitic oscillation caused by ground (or supply) wiring inductance.
A good scope will definitely help with debug, especially allowing proper use of 10x probing.  In the mean time, you could probe at 1x with a ~1k resistor between probe tip and HC14-4 or whatever pin you are probing.  That will likely isolate probe capacitance from HC14-4 enough to prevent oscillation, but will further reduce measurement bandwidth.
Offline Nunu00
« Reply #34 on: June 21, 2022, 04:44:13 PM »
Ok, I think that until I will buy a decent oscilloscope I will stop testing because I feel like I'm wasting time and I'm wasting your time too.
Thanks, see you soon.
« Reply #35 on: June 22, 2022, 03:57:54 AM »
While you wait for a new scope, you could still be enhancing ground connections and bypass caps on your board.  That will clean up signal quality and make debugging even easier.  Might even fix the real problem.
Yes, a new scope will make debugging more efficient.  Still, it has been a somewhat fun challenge to decipher what is happening based on constrained measurements.  The 9-11MHz oscillation when probing HC14-4 is a key clue to ground interconnect and chip power bypassing being insufficient.
Good luck going forward!
post Re: Designing a regulated HV supply
Hiemal
Today at 05:37:39 AM
Today at 05:00:02 AM
Today at 04:47:36 AM
post Re: DRSSTC trips GFCI outlet
boom198
Today at 04:03:53 AM
post Help with Class E plasma speaker Eastern Voltage Research
Today at 03:58:58 AM
Hiemal
Today at 03:36:19 AM
post Re: Mains Ramped SSTC - Power Supply Issue
Razerwire
June 30, 2022, 10:46:33 PM
post Re: IGBT Hookup guide
June 30, 2022, 10:13:37 PM
June 30, 2022, 09:00:08 PM
post IGBT Hookup guide
ThePickledNerd
June 30, 2022, 07:56:18 PM
Mike
June 30, 2022, 01:04:19 PM
June 30, 2022, 06:41:10 AM
June 30, 2022, 05:41:21 AM
post Ebay Bipolar Tesla Coil Rebuild
Razerwire
June 30, 2022, 05:19:18 AM
post Designing a regulated HV supply
Hiemal
June 30, 2022, 01:32:12 AM
post Re: Roskilde Festival 2022: Science Pavilion
[Contests and Events]
June 29, 2022, 05:14:33 PM
June 29, 2022, 03:14:25 PM
Mike
June 29, 2022, 12:46:43 PM
boom198
June 29, 2022, 02:17:25 AM
June 28, 2022, 07:38:02 PM
post Re: Using UCC37322 to drive cm300dy for Switching PSU
June 28, 2022, 05:19:24 PM
June 28, 2022, 04:34:46 PM
June 28, 2022, 01:49:07 PM
Razerwire
June 28, 2022, 09:42:52 AM
June 28, 2022, 08:47:31 AM
post Re: Auto tuning primary?
June 28, 2022, 08:45:41 AM
June 28, 2022, 05:35:15 AM
June 28, 2022, 05:30:25 AM
post Re: Why only one flip flop for ZCS-OCD triggering?
June 28, 2022, 05:09:25 AM
June 28, 2022, 05:05:27 AM
boom198
June 28, 2022, 04:51:22 AM
post Re: Odd Signal On VLF, Need Help Identifying Source
June 28, 2022, 01:19:41 AM
June 27, 2022, 10:25:55 PM
June 27, 2022, 09:15:26 PM
June 27, 2022, 09:10:43 PM
post Auto tuning primary?
Overlordcheese
June 27, 2022, 08:36:46 PM
post Why only one flip flop for ZCS-OCD triggering?
Overlordcheese
June 27, 2022, 08:31:45 PM
June 27, 2022, 06:14:48 PM
post Using UCC37322 to drive cm300dy for Switching PSU
June 27, 2022, 05:30:22 PM
June 27, 2022, 02:51:14 PM
June 27, 2022, 08:57:52 AM
June 27, 2022, 05:48:47 AM
post DRSSTC trips GFCI outlet
boom198
June 27, 2022, 03:47:49 AM
June 26, 2022, 05:59:04 PM
post Re: Van de Graaff generator voltage measurement
[Static Electricity]
June 26, 2022, 12:49:14 PM
June 25, 2022, 11:23:08 PM
June 25, 2022, 03:43:12 PM
June 25, 2022, 12:02:13 PM
post Roskilde Festival 2022: Science Pavilion
June 25, 2022, 07:37:22 AM
post Re: Bipolar CW
Vdekje
June 25, 2022, 05:05:20 AM
June 24, 2022, 08:32:54 PM
June 24, 2022, 06:28:10 PM
June 24, 2022, 05:52:55 PM
Mike
June 24, 2022, 12:56:41 PM
June 24, 2022, 04:32:42 AM
June 23, 2022, 11:51:16 PM
June 23, 2022, 10:12:26 PM
June 23, 2022, 10:11:07 PM
Manz
June 23, 2022, 06:10:14 PM
post Feedback on new freewheeling driver schematic
Mike
June 23, 2022, 01:36:42 PM
June 23, 2022, 01:30:29 PM
post Re: Is this good GDT ?
LoOdaK
June 23, 2022, 01:03:35 PM
post Re: First drsstc project, looking for recommendations
June 23, 2022, 03:49:07 AM
June 22, 2022, 06:30:42 PM
June 22, 2022, 02:16:02 PM
post Re: Problem with SSTC
June 21, 2022, 09:14:34 PM
post Dielectric breakdown of 6 oils -- sorta
June 21, 2022, 08:06:08 PM
Nunu00
Tetris
June 21, 2022, 04:39:23 AM
post Re: ocd input
June 21, 2022, 03:41:25 AM
post Re: Best magnet wire to avoid flashovers
June 20, 2022, 08:45:35 PM
June 20, 2022, 08:28:48 PM
post Re: DRSSTC using a ZVS Driver not working well - need help
June 20, 2022, 07:30:18 PM
June 20, 2022, 06:42:56 PM
BenTesla
June 20, 2022, 06:33:53 PM
June 19, 2022, 11:56:23 PM
Nunu00
June 19, 2022, 10:33:14 PM
June 19, 2022, 09:50:27 PM
June 19, 2022, 09:30:38 PM
post Best magnet wire to avoid flashovers
June 19, 2022, 09:01:09 PM
post Level of vacuum to purge transformer coils
June 19, 2022, 08:56:18 PM
Nunu00
June 19, 2022, 07:09:52 PM
BenTesla
June 19, 2022, 02:04:01 PM
Nunu00
June 19, 2022, 06:16:42 AM
post Re: ocd input
June 19, 2022, 03:50:22 AM
Nunu00
post Re: ocd input
June 19, 2022, 12:49:55 AM
Nunu00
June 18, 2022, 09:30:46 PM
June 18, 2022, 08:34:32 PM
