Author Topic: Kaizer DRSSTC 3  (Read 646 times)
Kaizer DRSSTC 3
« on: May 11, 2022, 09:40:00 PM »
I started construction on my large DRSSTC on the 24th of December 2011. What followed was a long journey of building, sourcing materials, becoming a father and at some point reach first full power light on the 31st of March 2016. A 4++ year long journey!
Bridge2x CM600DU-24FA IGBTs in a full bridge configuration
Bridge supply4x 6000uF 350V filtering capacitors, two in series, two string in parallel for 6000uF at 700V.
Primary coilFlat primary. Inner diameter 375 mm, Outer diameter 855 mm. 8 turns 10 mm copper tubing, turn spacing 20 mm
tapped at 6.75 turns.
MMC0.8uF at 15kV. Made from GTO snubber capacitors. 5 in series.
Secondary coil315 mm diameter, 1500 mm long, 1800 windings, 0,75 mm enamelled copper wire.
Resonant frequencyAround 38 kHz.
Topload7 rings of 25 mm aluminium tubing forming a 150cm diameter toroid.
Input power3x400VAC 16A / 11kW
Spark length3.6 meters
First full power light (31st of March 2016)
Kaizer DRSSTC 3 - Test After 5 Years In Storage (6th of May 2022)
Re: Kaizer DRSSTC 3
« Reply #1 on: May 11, 2022, 09:53:15 PM »
Camera as time machine!   Nice work.
We share enthusiasm for transporting large things by bicycle.  In about 1994 I stopped at a garage sale an hour away from home. Found and bought more than 50 pounds of lead metal, and got it all home in panniers and taped onto the rear rack.
Re: Kaizer DRSSTC 3
« Reply #2 on: May 13, 2022, 09:24:22 PM »
We had a good session with trying out some different interrupters, targets and lighting around the coil, for filming. Darkness did however surprise us a bit and it was hard to adjust lighting and run the coil at once, so a bit noise filled videos.
It was most of the time pulling around 5-10 kW, peaked out at 19kW with a quite insane BPS that I quickly turned down again as the 3 meter sparks was turning into a flame, it had that flicking change in sound as when sparks goes into full plasma flame. The measurements in the video is from a Merlin Gerin PM700 power meter.
The coil was, the whole time, fed through the 3 Phase 400 VAC 6 A Variac Stack With Voltage/Current Meters ( https://highvoltageforum.net/index.php?topic=2015.0 ) which did not even get warm to the touch.
The future holds a collaboration with ChaosEngine https://www.chaosengine.dk/ and https://www.instagram.com/chaos.engine/ where we will combine art and electricity in some way
Re: Kaizer DRSSTC 3
« Reply #3 on: May 15, 2022, 03:53:35 AM »
Variac wipers are often hot spots, causing the winding to fail at the wiper setpoint.  Not sure if checking overall Variac temperature is a good way to judge margin for short-term overload.
Impressive video and demonstration!  I'm wondering if you could achieve even longer arcs (at least a little bit) with further detuning and/or a shorter breakout point.  It doesn't seem to be struggling to break out initially as would be the case if detuned was close to the limit.  Of course, perhaps it is at the limit.  Hard to tell by viewing a video only.  In my case, an interruption sequence of ramped pulse widths also helped.  The ramp from short to long helped an arc form with slightly more detuning than otherwise worked.  Final enable pulse at the end of the ramp jumped to 2x longer, trying to get a tiny bit more length from an arc that had already reduced secondary frequency below primary.
Re: Kaizer DRSSTC 3
« Reply #4 on: May 15, 2022, 04:13:02 PM »
I spy a lot of tinfoil on the power cable, which looks like a pain in the ass to deal with - have you looked at using industrial control cable with shielding? That's what I moved to using (with the shield grounded) once I thought through the likely consequences of a hit on an unshielded mains cable.
Also, what controller is this currently running?
Re: Kaizer DRSSTC 3
« Reply #5 on: May 15, 2022, 08:22:11 PM »
That is good point about the variac, since its even a enclosed unit IP44 I think, its impossible to inspect the wiper, unless the entire thing is split in atoms. With the soft start box which pre-charges DC bus through power resistors, the variac is really not needed. I just brought it on this first try after storage to be sure to nurse it a bit and give the DCbus capacitors a soft low voltage start.
You are properly right about the tuning. Since its over 4 years from last tuning, I forgot why and where, but there is only one hole made in the base plate. I think its tuned exactly where JavaTC predicted it to be tuned. But considering that I, at that time, knew about detuning, it most be tuned lower. that just resonance.
To avoid buying new cable, I am putting it all through some copper braided shielding harness that I already have. Got enough to cover enough of what is in the danger zone. Then I will add some kind of protective cloth sleeve outside of that. The tin foil is just a 2 minute job, but ends up costing a roll every time as it gets a little bump or kink and there is no more unwinding it in one piece :)
Its running with my own single side version of UD2.1b, double GDTs.
Re: Kaizer DRSSTC 3
post Re: Aluminium Nitride Thermal Pads
Today at 08:33:16 AM
post Re: Feedback problems
Mike
Today at 04:20:00 AM
Today at 02:25:07 AM
Today at 02:18:56 AM
post Re: Problem with VTTC Staccato interrupter PLZ HELP
Today at 01:57:37 AM
Today at 01:54:04 AM
Today at 12:09:56 AM
post Re: Half-bridge for my first sstc
August 13, 2022, 10:14:40 PM
post Problem with VTTC Staccato interrupter PLZ HELP
NerdlabsMadScience
August 13, 2022, 09:32:08 PM
LoOdaK
August 13, 2022, 09:11:03 PM
August 13, 2022, 08:45:41 PM
LoOdaK
August 13, 2022, 08:20:01 PM
August 13, 2022, 08:00:14 PM
August 13, 2022, 07:41:45 PM
post A little idea I had for my dual full bridge design
Overlordcheese
August 13, 2022, 06:42:34 PM
post Feedback problems
August 13, 2022, 06:17:43 PM
LoOdaK
August 13, 2022, 03:18:05 PM
August 12, 2022, 11:03:52 PM
LoOdaK
August 12, 2022, 10:53:44 PM
August 12, 2022, 10:13:02 PM
LoOdaK
August 12, 2022, 09:35:29 PM
August 12, 2022, 08:28:28 PM
August 12, 2022, 07:26:41 PM
August 12, 2022, 06:52:58 PM
August 12, 2022, 06:39:27 PM
August 12, 2022, 06:38:44 PM
August 12, 2022, 05:57:00 PM
August 12, 2022, 12:44:20 PM
LoOdaK
August 12, 2022, 08:36:23 AM
post Aluminium Nitride Thermal Pads
August 12, 2022, 04:31:17 AM
post Re: Helpy Trying to Replicate This Strange Slittle DRSSTC? PLS
ItsChloeUwU
August 12, 2022, 02:55:27 AM
post Re: Small DRSSTC Questions
Mike
August 12, 2022, 01:27:14 AM
August 11, 2022, 11:51:42 PM
August 11, 2022, 11:35:43 PM
post Say what -- arcing TO polycarbonate!
August 11, 2022, 10:56:28 PM
August 11, 2022, 07:40:03 PM
post Re: Huge Mistake Designing My Coil
MarcusFunt
August 11, 2022, 06:54:14 PM
August 11, 2022, 05:07:28 PM
post Half-bridge for my first sstc
LoOdaK
August 11, 2022, 11:13:20 AM
post Huge Mistake Designing My Coil
MarcusFunt
August 11, 2022, 10:03:54 AM
Mike
August 11, 2022, 06:12:48 AM
post Re: Painfully Amazing Stuff
August 11, 2022, 03:14:55 AM
55#sofcopper
August 11, 2022, 02:55:16 AM
post Painfully Amazing Stuff
August 10, 2022, 10:47:09 PM
post Re: HV AC Current Measurement
August 10, 2022, 07:51:16 PM
August 10, 2022, 06:36:23 PM
August 10, 2022, 01:34:40 AM
post Re: High Voltage pcb
FonziDaytona
August 09, 2022, 10:17:24 PM
August 09, 2022, 10:16:33 PM
post Re: How To Varnish A Tesla Coil Secondary Coil
August 09, 2022, 09:22:37 PM
August 09, 2022, 09:19:26 PM
FonziDaytona
August 09, 2022, 08:32:08 PM
August 09, 2022, 08:26:32 PM
post Re: Coherent VersaPulse VPW - what should I do with it?
August 09, 2022, 08:15:54 PM
post High Voltage pcb
FonziDaytona
August 09, 2022, 08:15:10 PM
post Top load material selection
55#sofcopper
August 09, 2022, 04:44:43 PM
August 09, 2022, 04:20:01 PM
post Loneoceans UD 2.7 rev c issue
mthome4
August 09, 2022, 03:11:56 PM
post Re: A big-ish diy xformer
August 09, 2022, 07:30:29 AM
August 09, 2022, 07:06:52 AM
August 09, 2022, 07:06:34 AM
August 09, 2022, 06:28:49 AM
August 09, 2022, 06:18:56 AM
August 09, 2022, 06:08:53 AM
August 09, 2022, 04:29:49 AM
post HV AC Current Measurement
August 09, 2022, 02:18:35 AM
August 09, 2022, 12:42:21 AM
August 09, 2022, 12:31:47 AM
August 09, 2022, 12:22:26 AM
August 09, 2022, 12:00:39 AM
post Coherent VersaPulse VPW - what should I do with it?
August 08, 2022, 11:24:45 PM
post Re: Optic fiber interrupter in EU
August 08, 2022, 10:07:08 PM
August 08, 2022, 10:01:56 PM
August 08, 2022, 10:00:22 PM
August 08, 2022, 09:52:09 PM
August 08, 2022, 09:51:09 PM
post Re: Where To Get "Free" TO-247 IGBTs and MOSFETs
August 08, 2022, 09:50:49 PM
post How To Varnish A Tesla Coil Secondary Coil
August 08, 2022, 09:47:24 PM
August 08, 2022, 09:44:04 PM
August 08, 2022, 09:43:38 PM
August 08, 2022, 09:42:37 PM
August 08, 2022, 09:27:10 PM
post Optic fiber interrupter in EU
ItsChloeUwU
August 08, 2022, 08:09:38 PM
post Helpy Trying to Replicate This Strange Slittle DRSSTC? PLS
ItsChloeUwU
August 08, 2022, 04:10:00 PM
August 08, 2022, 07:54:27 AM
post Re: SCR precharge
August 07, 2022, 07:28:51 PM
post Re: Bipolar CW -- update
August 07, 2022, 07:15:11 PM
August 07, 2022, 06:46:44 PM
alexhanyuan
August 07, 2022, 06:11:59 PM
August 07, 2022, 08:25:56 AM
August 07, 2022, 03:46:50 AM
post SCR precharge
alexhanyuan
August 06, 2022, 10:23:27 PM
August 06, 2022, 09:34:35 PM
post Re: Can someone help, am not getting any plasma :-) much appreciated
ItsChloeUwU
August 06, 2022, 07:49:05 PM
post Re: Primary Wire Getting Hot, Secondary flashovers, RSG Not Alway Fireing? Help pls.
ItsChloeUwU
August 06, 2022, 07:42:00 PM
August 06, 2022, 07:05:35 PM
August 06, 2022, 04:06:48 PM
post Re: CORE FOR GDT AND CT
Didik
August 05, 2022, 11:59:58 AM
August 05, 2022, 09:56:26 AM
August 05, 2022, 06:25:39 AM
